System Sensor 200 series
(Redirected from Fire-Lite 350 series)
200 series
1993 {"label": "Introduced", "field": "1993"}
System Sensor 500 series
System Sensor LZR-1 {"label": "Preceded by", "field": "System Sensor 500 series
System Sensor LZR-1"}
System Sensor FAAST series
System Sensor InnovairFlex series
System Sensor Select series {"label": "Succeeded by", "field": "System Sensor FAAST series
System Sensor Select series"}
The System Sensor 200 series is a series of addressable detectors.
The 200 series was released in 1993 as a low-profile version of the 500 series with common housing for ionization and photoelectric smoke detectors.[1]
In 1995, System Sensor introduced the 3251 OMNI Sensor with ionization, photoelectric, and heat sensors.[2] The OMNI Sensor featured thermistors similar to the 2300 series, but the thermistor cells were reduced in size to match the 1251 and 2251.
Around 2000, the 1251 and 2251 were updated to place the digits on the address switches closer together, providing space for options 10-15 on advanced protocol models. The 5251P and 5251RP heat detectors were also introduced as successors to the 5551B and 5551R with this change, and the 2251T was introduced with a similar thermistor design to the 3251 to replace the 2551THR.
In late 2000, System Sensor introduced the 2251TM Acclimate detector.[3][4] The OMNI Sensor was later discontinued and replaced with the Acclimate detector.[5]
In 2002, System Sensor introduced the Pinnacle laser smoke detector as a replacement for the LZR-1.[6]
In 2003, all detectors besides the Pinnacle detector were redesigned to have a shape more closely resembling the i3 series.[7] The new models could be identified with the "B" suffix, and the standard temperature heat detectors were marked with a gray circle outline. The 5251H was also introduced at this time, featuring the new design and a black circle marking.
Between 2003 and 2004, the duct detectors were updated to support a wider air velocity range. The new models had an L suffix at the end.
In 2004, beam detectors were introduced.[8] These were similar to the conventional beam detectors in the BEAM series.
In 2007, System Sensor introduced the 2251-COPTIR, which included 4 sensors.[9][10] System Sensor also introduced the 7251DH laser duct detector around this time.[11]
Around 2008, the B224RB relay base and B224BI isolator base were redesigned to resemble the B200S sounder base, which was released in 2009 together with the B200SR.[12][13] The B200SR functioned as a replacement for the B501 sounder bases, while the B200S was controlled by the FACP. Both models used the same tone as the SpectrAlert Advance horn.
Between 2009 and 2010, System Sensor discontinued the Innovair detectors due to the release of the InnovairFlex series.[14] The 2251BR was released as a remote test capable detector that could be placed in an InnovairFlex base.
In 2015, System Sensor introduced the B200S-LF and B200SR-LF as low frequency versions of the B200S and B200SR respectively.[15]
In July 2015, System Sensor discontinued the ionization smoke detectors due to the increased manufacturing and recycling costs.[16] Depending on the application, consumers were instructed to use photoelectric, multi-criteria, aspirating, or laser detectors.
Model Protocol Replaced Replaced by
1251[17] CLIP 1551B 1251B
1251B[18] 1251 2251B
2251TMB
2251-COPTIR
7251
8251F
Model Protocol Heat sensor? Intrinsically safe? Remote test capable? Replaced Replaced by
2251 CLIP No No No 2551HR 2251B
2251T CLIP Yes No No 2551THR 2251TB
2251EIS[19] CLIP No Yes No
2251B No No No 1251B
2251
2351B-IV
2251TB Yes No No 2251T 2351TB-IV
2251BR No No Yes DH200PL (with DNR)
DH200RPL (with DNR)
2351BR-IV
Multi-criteria detectors
Model Protocol Ionization sensor? Photoelectric sensor? Heat sensor? Infrared sensor? CO sensor? Replaced Replaced by
2251TM CLIP No Yes Yes No No 3251 2251TMB
2251TMB No Yes Yes No No 1251B
2251TM
2351TIR-IV
2251-COPTIR No Yes Yes Yes Yes 1251B FC351
3251[20] CLIP Yes Yes Yes No No 2251TM
Model Protocol Type Replaced Replaced by
5251P[21] CLIP Fixed temperature 5551B 5251B
5251RP CLIP Rate-of-rise 5551R 5251RB
5251B Fixed temperature 5251P 5351B-IV
5251RB Rate-of-rise 5251RP 5351RB-IV
5251H High temperature None 5351H-IV
Laser smoke detectors
7251[22] Spot 1251B
LZR-1
7351
7251DH Duct None DNRHS
Beam detectors
Model Integral sensitivity test? Replaced Replaced by
BEAM200[23] No
BEAM200S Yes
Innovair duct detectors
Model Relay? Replaced Replaced by
DH200P[24] No DH500 DH200PL
DH200RP Yes DH500ACDC DH200RPL
DH200PL[25] No DH200P DNR + 2251BR
DH200RPL Yes DH200RP DNR + 2251BR
Bases
Model Auxiliary function Replaced Replaced by
B210LP[26] None
B224RB Relay
B224BI Isolator
B200S Intelligent horn None
B200SR Horn B501BH
B501BHT
B501BH-2
B501BHT-2
B200S-LF Intelligent low frequency sounder None
B200SR-LF Low frequency sounder None
Faraday rebranded 200 series products as part of the 8400 series, 9100 series, and 9200 series until 2004.[27][28][29]
Fire-Lite Alarms
350 series
Fire-Lite Alarms started rebranding the original 200 series in 2001 as the 350 series, replacing the 300 series.[30] The 350 series supported extended addressing for the MS-9600, but it did not support LiteSpeed.
Fire-Lite model System Sensor model Replaced Replaced by
SD350[31] 2251 SD300 SD355
SD350A SD300A SD355A
SD350T 2251T SD300T SD355T
SD350TA SD300TA SD355TA
CP350[32] 1251 CP300 CP355
CP350A CP300A CP355A
H350[33] 5251P None H355
H350R 5251RP None H355R
D350P[34] DH200P None D350PL
D350RP DH200RP None D350RPL
D350PL[35] DH200PL D350P D355PL
D350RPL DH200RPL D350RP D355PL
355 series
The 355 series replaced the 350 series in 2006.[36] The 355 series supported LiteSpeed, which was introduced in 2007 on the MS-9600LS.
SD355[37] 2251B CP355
HFS-P
SD350
SD365-IV
SD355A SD350A SD365A-IV
SD355T 2251TB HFS-PT
SD350T
SD365T-IV
SD355TA SD350TA SD365TA-IV
SD355R[38] 2251BR HFS-DPR SD365R-IV
CP355[39] 1251B CP350 8100 + MMF-301
AD355
SD355
CP355A CP350A
H355[40] 5251B H350
HFS-T
H365-IV
H355A None H365A-IV
H355R 5251RB H350R H365R-IV
H355RA None H365RA-IV
H355HT 5251H None H365HT-IV
H355HTA None H365HTA-IV
AD355[41] 2251TMB CP355 AD365-IV
AD355A None AD365A-IV
BEAM355[42] BEAM200 None
BEAM355S BEAM200S None
D355PL[43] DNR + 2251BR D350PL
D350RPL
HFS-D
D365PL
FCI CLIP detectors
Gamewell-FCI model System Sensor model Replaced Replaced by
ASD-IL[44] 1251 ASD-I ASD-IL2
ASD-PL 2251 ASD-P ASD-PL2
ATD-L 5251P ATD ATD-L2
ATD-RL 5251RP ATD-R ATD-RL2
MCS-ACCLIMATE 2251TM None MCS-ACCLIMATE2
ASD-IL2[45] 1251B ASD-IL ASD-IL2F
ASD-PL2[46] 2251B ASD-PL ASD-PL2F
ASD-PTL2 2251TB ASD-PTL2F
ATD-L2[47] 5251B ATD-L ATD-L2F
ATD-RL2 5251RB ATD-RL ATD-RL2F
ATD-HL2 5251H None ATD-HL2F
MCS-ACCLIMATE2[48] 2251TMB MCS-ACCLIMATE MCS-ACCLIMATE2F
ADP[49] DH200PL ADPF
ADP-R DH200RPL ADPRF
SmartScan series
SS-P[50] 2251B ASD-PL2F
SS-M 2251TB ASD-PTL2F
SS-APT[51] 2251TMB MCS-ACCLIMATE2F
SS-I[52] 1251B ASD-IL2F
SS-T[53] 5251B ATD-L2F
SS-TR 5251RB ATD-RL2F
SS-TH 5251H ATD-HL2F
SS-L[54] 7251 ASD-LS
SS-PD[55] DH200PL
SS-PDR DH200RPL
BD-SS[56] BEAM200 ABD-2F
BDT-SS BEAM200S ABD-RT2F
Velociti series
ADPF[57] DH200PL ADP DNR + ASD-PL2FR
ADPRF DH200RPL ADP-R DNR + ASD-PL2FR + AOM-2RF
ASD-IL2F[58] 1251B ASD-IL2
SS-I
AAD-8100
ASD-PL2F
ASD-LS
MCS-4-WARN
MCS-ACCLIMATE2F
ASD-LS[59] 7251 ASD-IL2F
SS-L
ASD-LS3
ASD-PL2F[60] 2251B ASD-IL2F
ASD-PL2
HFS-P
SS-P
ASD-PL3-IV
ASD-PTL2F 2251TB ASD-PTL2
HFS-PT
SS-M
ASD-PTL3-IV
ASD-PL2FR[61] 2251BR ADPF (with DNR)
ADPRF (with DNR + AOM-2RF)
HFS-D (with DNR)
HFS-DPR
ASD-PL3R-IV
ATD-L2F[62] 5251B ATD-L2
HFS-T
SS-T
ATD-L3-IV
ATD-RL2F 5251RB ATD-RL2
SS-TR
ATD-L3R-IV
ATD-HL2F 5251H ATD-HL2
SS-TH
ATD-L3H-IV
ABD-2F[63] BEAM200 BD-SS
ABD-RT2F BEAM200S BDT-SS
MCS-ACCLIMATE2F[64] 2251TMB ASD-IL2F
MCS-ACCLIMATE2
SS-APT
MCS-PTIR-IV
MCS-4-WARN[65] 2251-COPTIR ASD-IL2F MCS-COF3
Farenhyt series
Silent Knight introduced the Intelligent Device Protocol for Farenhyt systems in March 2006.[66]
Honeywell model System Sensor model Replaced Replaced by
IDP-ION[67] 1251B None 8100 + IDP-MINIMON
IDP-ACCLIMATE
IDP-FIRE-CO
IDP-PHOTO
IDP-PHOTO[68] 2251B HFS-P
IDP-ION
IDP-PHOTO-IV
IDP-PHOTO-T 2251TB HFS-PT IDP-PHOTO-T-IV
IDP-PHOTOR 2251BR IDP-PDUCT (with DNR)
IDP-PDUCT-R (with DNR + IDP-RELAY)
HFS-D (with DNR)
HFS-DPR
IDP-PHOTO-R-IV
IDP-ACCLIMATE 2251TMB IDP-ION IDP-PTIR-IV
IDP-BEAM BEAM200 None
IDP-BEAM-T BEAM200S None
IDP-HEAT 5251B HFS-T IDP-HEAT-IV
IDP-HEAT-HT 5251H None IDP-HEAT-HT-IV
IDP-HEAT-ROR 5251RB None IDP-HEAT-ROR-IV
IDP-PDUCT[69] DH200PL None DNR + IDP-PHOTOR
IDP-PDUCT-R DH200RPL None DNR + IDP-PHOTOR + IDP-RELAY
HFS series
Honeywell sold the 2251BR detector in DNR housing as the HFS-D, for use with the HFS series panels. The 2251BR was also sold on its own as the HFS-DPR.
XLS series
TC806B1001[70] 2251 TC806B1076
TC806B1076[71] 2251B TC806B1001
TC807B1059
TC806B3010-IV
TC806B1084 2251TB TC806B3104-IV
TC806DNR 2251BR TC806DNR3000-IV
TC807B1000[72] 1251 TC807B1059
TC807B1059 1251B TC807B1000 TC808B1076
TC840C1000
TC840M1021
TC846F1002
TC808B1002
TC808B1041 5251B TC808B3011-IV
TC808B1041CDN 5251BA TC808B3011CDN-IV
TC808B1058 5251RB TC808B3012-IV
TC808B1058CDN 5251RBA TC808B3012CDN-IV
TC808B1066 5251H
TC808B1066CDN 5251HA
TC840C1000 2251-COPTIR TC807B1059 TC840C3206-IV
TC840M1021 2251TMB TC807B1059 TC840M3021-IV
TC846A1005
TC846A1013
Johnson Controls
300 series
Johnson Controls model System Sensor model Replaced Replaced by
1351J[73] 1251 1951J
1351JA 1951JA
2351J 2251 2951J
2351JA 2951JA
2351TJ 2251T 2951TJ
2351TJA 2951TJA
5351J 5251P 5951J
5351JA 5951JA
5351RJ 5251RP 5951RJ
5351RJA 5951RJA
7351J 7251 1951J J7351
7351JA
DH300PL DH200PL DNR + 2951JR
DH300PLA DNR + 2951JRA
DH300RPL DH200RPL
DH300RPLA
900 series
1951J 1251B 1351J 2951J
2951TMJ
2951J-COPTIR
7351J
8251FJ
1951JA 1351JA
2951J 2251B 1951J
2351J
J2351-IV
2951JA 2351JA
2951JR 2251BR DH300PL (with DNR)
DH300RPL (with DNR)
J2351R-IV
2951JRA DH300PLA (with DNR)
DH300RPLA (with DNR)
2951TJ 2251TB 2351TJ J2351T-IV
2951TJA 2351TJA
2951TMJ 2251TMB 1951J
2951TMJA
2951J-COPTIR 2251-COPTIR 1951J
2951J-COPTIRA
5951J 5251B 5351J J5351-IV
5951JA 5351JA
5951RJ 5251RB 5351RJ J5351R-IV
5951RJA 5351RJA
5951HJ 5251H None J5351H-IV
5951HJA None
700 series
The original Notifier rebrands of the 200 series were given the -751 suffix, and they did only supported CLIP. FlashScan detectors were introduced in 2000 together with the AFC-600 and could be identified with a "F" prefix.[74]
Notifier model System Sensor model FlashScan capable? Replaced Replaced by
CPX-751[75] 1251 No CPX-551 FSI-751
SDX-751 2251 No SDX-551 FSP-751
IPX-751[76] 3251 No FAPT-751
LPX-751 LZR-1 No None FSL-751
LPX-751L 7251 No None FSL-751
FSI-751[77] 1251 Yes CPX-751 FSI-851
FSP-751 2251 Yes SDX-751 FSP-851
FSP-751T 2251T Yes SDX-551TH FSP-851T
FAPT-751[78] 2251TM Yes IPX-751 FAPT-851
FST-751[79] 5251P Yes FDX-551 FST-851
FST-751R 5251RP Yes FDX-551R FST-851R
FSL-751 7251 Yes FSI-851
LPX-751
LPX-751L
FSV-951R-IV
FSD-751P[80] DH200P Yes FSD-751PL
FSD-751RP DH200RP Yes FSD-751RPL
FSD-751PL[81] DH200PL Yes FSD-751P DNR + FSP-851R
FSD-751RPL DH200RPL Yes FSD-751RP DNR + FSP-851R + FRM-1
800 series
The 800 series detectors supported both CLIP and FlashScan. These were released in 2003.[82]
Notifier model System Sensor model Replaced Replaced by
FAPT-851 2251TMB FAPT-751
FSI-851
FPTI-951-IV
FSI-851 1251B FSI-751 FAPT-851
FSA-8000
FSC-851
FSL-751
FSP-851
FSP-851 2251B FSI-851
FSP-751
FSP-951-IV
FSP-851T 2251TB FSP-751T FSP-951T-IV
FSP-851R[83] 2251BR FSD-751PL (with DNR)
FSD-751RPL (with DNR)
FSP-951R-IV
FST-851 5251B FST-751 FSP-951-IV
FST-851R[84] 5251RB FST-751R FSP-951R-IV
FST-851H 5251H None FSP-951H-IV
FSC-851[85] 2251-COPTIR FSI-851 FCO-951-IV
FireWarden detectors
Notifier produced a separate series of detectors for use with FireWarden panels.
ND-100R[86] DH200RPL DNR + NP-100R
NH-100[87] 5251B HFS-T
NH-100A
NH-100R 5251RB
NH-100RA
NI-100[88] 1251B NP-100
NI-100A
NP-100[89] 2251B HFS-P
NI-100
NP-100A
NP-100T 2251TB HFS-PT
NP-100TA
NP-100R[90] 2251BR HFS-D (with DNR)
HFS-DPR
ND-100R (with DNR)
Silent Knight started rebranding 200 series devices in 2009.[91]
Silent Knight model System Sensor model Replaced Replaced by
SK-PHOTO 2251B HFS-P
SK-ION
SK-PHOTO-W
SK-PHOTO-T 2251TB HFS-PT SK-PHOTO-T-W
SK-PHOTOR[92] 2251BR HFS-DPR SK-PHOTO-R-W
SK-ION 1251B None 8100 + SK-MINIMON
SK-ACCLIMATE
SK-FIRE-CO
SK-PHOTO
SK-HEAT 5251B HFS-T SK-HEAT-W
SK-HEAT-HT 5251H None SK-HEAT-HT-W
SK-HEAT-ROR 5251RB None SK-HEAT-ROR-W
SK-ACCLIMATE 2251TMB SK-ION SK-PTIR-W
SK-DUCT DNR + 2251BR HFS-D SK-DUCT-W
SK-BEAM BEAM200 None
SK-BEAM-T BEAM200S None
  1. https://nfpa.access.preservica.com/uncategorized/IO_e739b0ac-5683-41d8-8725-3d1426de8e70/
  2. https://nfpa.access.preservica.com/uncategorized/IO_07a0ad96-a2e8-4dfb-9596-317511ba151b/
  3. "sitemap page" System Sensor. Archive 2000-07-07 vs. 2000-10-17
  4. https://web.archive.org/web/20001209133400/http://www.systemsensor.com/Intelligent/acclimat.htm
  5. https://web.archive.org/web/20040306064955/http://systemsensor.com:80/html/id.html?search=Intelligent%20Smoke%20Detector
  6. "Pinnacle - Ultra High Sensitivity Laser Smoke Detector" (A05-0347-000). System Sensor (2002).
  7. "Intelligent Detection" System Sensor. Archive 2003-06-22 vs. 2003-10-19
  8. "Intelligent Detection" System Sensor. Archive 2003-12-24 vs. 2004-04-05
  9. https://web.archive.org/web/20080110051642/http://www.systemsensor.com/html/id.html?search=Intelligent%20Smoke%20Detector
  10. https://web.archive.org/web/20110110232350/http://www.systemsensor.com/html/id.html?search=Intelligent%20Smoke%20Detector
  11. "Intelligent Detection" System Sensor. Archive 2007-11-10 vs. 2008-01-10
  12. https://web.archive.org/web/20090729061302/http://www.systemsensor.com:80/html/id.html?search=base
  13. "B200S Intelligent Sounder Base" (A05-0455-000). System Sensor (April 2009).
  14. "Intelligent Detection" System Sensor. Archive 2009-07-29 vs. 2010-08-23
  15. "Documentation" Silent Knight. Archive 2015-01-12 vs. 2015-02-06
  16. "Ionization Smoke Detector: Remove, Recycle, Replace." (SPFL78501). System Sensor (2015).
  17. https://web.archive.org/web/20000620173647/http://www.systemsensor.com/Intelligent/plug.htm
  18. https://web.archive.org/web/20031224232554/http://www.systemsensor.com/html/id.html?search=Intelligent%20Smoke%20Detector
  19. https://web.archive.org/web/20000821185848/http://www.systemsensor.com/Intelligent/intrinsi.htm
  20. https://web.archive.org/web/20000821185948/http://www.systemsensor.com/Intelligent/multi.htm#
  21. https://web.archive.org/web/20000821190341/http://www.systemsensor.com/Intelligent/thermal.htm
  22. "Pinnacle Low-Profile Plug-in Intelligent Laser Smoke Detector" (A05-0314-001). System Sensor (October 2001).
  23. "Model BEAM200(S) Single-ended Reflected Type Beam Smoke Detector" (A05-0364-000). System Sensor (January 2004).
  24. "Innovair™ 200 Series Intelligent Duct Smoke Detectors" (A05-0280-001). System Sensor (January 2000).
  25. "Innovair Intelligent Low-Flow Duct Smoke Detectors" (A05-0353-000). System Sensor (July 2003).
  26. https://web.archive.org/web/20001020100231/http://systemsensor.com/Intelligent/bases.htm
  27. https://tecumsehtech.com/Detectors-and-Modules
  28. https://web.archive.org/web/20040219083128/http://www.faradayllc.com/products_addressable.html
  29. https://web.archive.org/web/20040401233430/http://faradayfirealarms.com/products_initiating.html
  30. "Addressable Devices" Fire-Lite Alarms. Archive 2001-03-08 vs. 2001-04-29
  31. "SD350(A)/SD350T(A) Addressable Photoelectric Detectors" (DF-52149). Fire-Lite Alarms (May 3, 2001).
  32. "CP350 Intelligent Addressable Ionization Detector" (DF-52158). Fire-Lite Alarms (May 3, 2001).
  33. "H350/H350R Intelligent Addressable Thermal (Heat) Detectors for use with MS-9600" (DF-52167). Fire-Lite Alarms (June 25, 2001).
  34. "D350P/D350RP Intelligent Addressable Photoelectronic Duct Smoke Detector" (DF-52176). Fire-Lite Alarms (May 2, 2001).
  35. "D350PL(A) and D350RPL(A) Intelligent Low-Flow Photoelectric Duct Smoke Detectors" (DF-52398). Fire-Lite Alarms (January 11, 2005).
  36. "FireLite Systems - Products" Fire-Lite Alarms. Archive 2006-04-20 vs. 2006-09-04
  37. "SD355(A)/SD355T(A) Addressable Photoelectric Smoke Detectors" (DF-52384). Fire-Lite Alarms (July 14, 2004).
  38. "DNR-InnovairFlex Intelligent Non-Relay Photoelectric Duct Smoke Detector" (df-60430). Fire-Lite Alarms (July 13, 2011).
  39. "CP355(A) Intelligent Addressable Ionization Smoke Detectors" (DF-52383). Fire-Lite Alarms (July 14, 2004).
  40. "H355 (A) Series Intelligent Addressable Thermal (Heat) Detectors for MS-9600, MS-9200UD" (DF-52385). Fire-Lite Alarms (July 14, 2004).
  41. "AD355 (A) "Adapt" Multi-Sensor Low-Profile Intelligent Detectors" (DF-52386). Fire-Lite Alarms (July 14, 2004).
  42. "BEAM355 and BEAM355S Single-Ended, Reflected-Type Addressable Beam Smoke Detectors" (DF-52408). Fire-Lite Alarms (January 6, 2005).
  43. https://web.archive.org/web/20120109170353/http://firelite.com/products/innovair.htm
  44. "Analog Addressable Sensors" (9020-0471). Fire Control Instruments (2000).
  45. "ASD-IL2" (9020-0558). Fire Control Instruments (2003).
  46. "ASD-PL2" (9020-0559). Fire Control Instruments (2003).
  47. "ATD-L2" (9020-0560). Fire Control Instruments (2003).
  48. "MCS-ACCLIMATE2" (9020-0561). Fire Control Instruments (2003).
  49. "ADP Series" (9020-0567). Fire Control Instruments (2003).
  50. "SS-P and SS-M Intelligent Addressable Plug-In Photoelectric Smoke Detectors with SmartScan®" (CS-2458). Gamewell (May 13, 2005).
  51. "SS-APT Acclimate™ Multi-Sensor Smoke Detector Low-Profile, Intelligent, Addressable" (CS-2462). Gamewell (October 21, 2004).
  52. "SS-I Intelligent Addressable Plug-In Ionization Smoke Detector" (CS-2459). Gamewell (October 21, 2004).
  53. "SS-T Series Intelligent Addressable Plug-In Thermal (Heat) Detectors" (CS-2460). Gamewell (October 21, 2004).
  54. "SS-L Laser Smoke Detector" (CS-2461). Gamewell (October 21, 2004).
  55. "SS-PD and SS-PDR Intelligent Low-Flow Photoelectric Duct Smoke Detectors" (CS-2463). Gamewell (October 21, 2004).
  56. "BD-SS and BDT-SS Single-Ended, Reflected-Type, Addressable Beam Smoke Detector with SmartScanTM" (CS-2516). Gamewell (April 14, 2005).
  57. "ADPF and ADPRF" (9020-0622). Fire Control Instruments (2005).
  58. "ASD-IL2F" (9020-0619). Fire Control Instruments (2005).
  59. "ASD-LS" (9020-0525). Fire Control Instruments (2002).
  60. "ASD-PL2F and ASD-PTL2F" (9020-0617). Fire Control Instruments (2005).
  61. "Velociti® Series ASD-PL2F, ASD-PTL2F and ASD-PL2FR" (9020-0617). Gamewell-FCI (2010).
  62. "ATD-L2F, ATD-RL2F, and ATD-HL2F" (9020-0620). Fire Control Instruments (2005).
  63. "Velociti® Series ABD-2F and ABD-RT2F" (9020-0623). Gamewell-FCI (2008).
  64. "MCS-ACCLIMATE2F" (9020-0618). Fire Control Instruments (2005).
  65. "Velociti® Series MCS-4-Warn" (9021-60672). Honeywell Gamewell FCI (November 2017).
  66. https://web.archive.org/web/20070520191545/http://www.farenhyt.com/htmfiles/pressrelease.htm#March2006
  67. "Addressable Devices with Intelligent Device Protocol (IDP)" (350361). Silent Knight (2015).
  68. "Supplement to Farenhyt Manuals" (LS10213-152FH-E:J). Honeywell (February 17, 2022).
  69. "IDP-Pduct/IDP-Pduct-R" (350284). Silent Knight (2008).
  70. https://i.ebayimg.com/images/g/dK8AAOSwZrJgLVRo/s-l1600.jpg
  71. "Detector/Base Compatibility Chart". System Sensor (October 30, 2014).
  72. https://i.ebayimg.com/images/g/UNYAAOSwGo1j39Dv/s-l1600.jpg
  73. "Johnson Controls IFC/NOTIFIER Compatibility Document" (LS10200-000NF-E:B). Notifier (January 11, 2022).
  74. "CSFM  Listing Sheets" Notifier Fire Systems. Archive 2000-06-15 vs. 2000-08-21
  75. "CPX-751 and SDX-751 Low-Profile Intelligent Plug-in Smoke Detectors" (DN-7086). Notifier (December 16, 2005).
  76. https://web.archive.org/web/20000523135951/http://www.notifier.com/advanced_detection.htm
  77. "FSI-751 and FSP-751/751T Low-Profile Intelligent Plug-in Smoke Detectors with FlashScan®" (DN-6714). Notifier (November 13, 2002).
  78. "FAPT-751 Acclimate Plus™ Multi-Sensor Low-Profile Intelligent Detector" (DN-6833). Notifier (April 1, 2003).
  79. "FST-751 Series Intelligent Thermal (Heat) Detectors with FlashScan®" (DN-6716). Notifier (October 9, 2001).
  80. "FSD-751P and FSD-751RP Intelligent Photoelectric Duct Smoke Detectors with FlashScan®" (DN-6821). Notifier (June 5, 2001).
  81. "FSD-751PL and FSD-751RPL Intelligent Low-Flow Photoelectric Duct Smoke Detectors with Flashscan®" (DN-6955). Notifier (May 24, 2004).
  82. "Data Sheets" Notifier. Archive 2003-02-25 vs. 2003-04-19
  83. "FSP-851, FSP-851T, & FSP-851R Intelligent Plug-In Photoelectric" (dn-6935). Notifier (March 12, 2010).
  84. "FST-851 Series Intelligent Thermal (Heat) Detectors with FlashScan®" (DN-6936). Notifier (April 1, 2003).
  85. "FSC-851(A) IntelliQuad™ Advanced Multi-Criteria Detector with four unique sensing elements" (DN-60412:B). Notifier (August 25, 2010).
  86. "ND-100R Low-Flow Photoelectric Duct Smoke Detector with Relay for FireWarden-100" (DN-7006). Notifier (October 20, 204).
  87. "NH-100 Series Intelligent Addressable Thermal (Heat) Detectors for FireWarden-100" (DN-6997). Notifier (October 20, 2004).
  88. "NI-100(A) Intelligent Addressable Ionization Detectors" (DN-6996). Notifier (September 8, 2004).
  89. "NP-100(A) and NP-100T(A) Addressable Photoelectric Detectors" (DN-6995). Notifier (October 20, 2004).
  90. "NP-100(A), NP-100T(A), NP-100R(A) Addressable Photoelectric Detectors for the FireWarden Series" (dn-6995). Notifier (March 12, 2010).
  91. "Product Guide" Silent Knight. Archive 2009-02-19 vs. 2010-06-01
  92. "SK-PHOTO, SK-PHOTO-T, and SK-PHOTOR Intelligent Photoelectric Smoke Detectors" (350118). Honeywell Silent Knight (November 2017).
