System Sensor SpectrAlert Advance series
8-17.5VDC & 16-33VDC
2017 & 2020
[2]
Mini-Alert |
"title": "SpectrAlert Advance Series",
"System Sensor SpectrAlert Advance devices.png"
The SpectrAlert Advance Series is a series of fire alarm notification appliances that were manufactured by the American fire alarm company System Sensor. It is the successor to the original SpectrAlert series. In 2017, the SpectrAlert Advance series were replaced by the L series and most of the SpectrAlert Advance devices were discontinued, although outdoor models and mini horns are still in production.
System Sensor introduced the SpectrAlert Advance series in 2006, replacing the original SpectrAlert line. The series initially consisted of horn/strobes, remote strobes, remote horns, chimes, and chime/strobes.[1] A pre-wiring feature was introduced to compete with the Gentex Commander2 Series, and the strobes were redesigned to work on both walls and ceilings, allowing the devices to compete with the Siemens "The Adapter" strobes.[3] A new patented multi-frequency horn was also introduced in this series.[4] Finally, the chimes were redesigned to use a small sounder similar to the horns, with only one frequency supported, and a slow whoop tone was added.[5]
The SpectrAlert Advance Series was expanded in 2008 with the introduction of speakers and speaker/strobe models models[6][7], and then again in 2011 with the addition of dual strobe expander plates.[8][9] The SpectrAlert Advance series got expanded once again in 2013 with low frequency sounders and sounder/strobes.[10] The series continued production with little change until 2017 when System Sensor introduced the L-Series, replacing most of the Advance line with their L-Series counterparts. Most of the devices in the SpectrAlert Advance line were discontinued in 2017, with the exception of low frequency sounders and sounder/strobes, 4-wire horn/strobes, and dual strobe expander plates, which were kept in production until 2020.[2] In 2020 System Sensor brought back the low-frequency devices from the SpectrAlert Advance line for a short time in response to a parts shortage restricting production of L-Series low-frequency devices[11]. Outdoor models and mini horns are currently the only products of the SpectrAlert Advance series that are still in production.
The SpectrAlert Advance series has selectable candela ranging from 15, 15/75, 30, 75, 95, 110 and 115 candela for standard devices and 135,150,177, and 185 for high candela devices.[12]
Horns and horn/strobe models have Temporal High, Temporal Medium, Temporal Low, Non-Temporal High, Non-Temporal Medium, Non Temporal Low, Coded High, Coded Medium and Coded Low as tone selections (Coded options are only available on 4 wire and Horn only devices).[12]
Chimes and chime/strobe models have 1 Second Chime High, 1 Second Chime Low, 1/4 Second Chime High, 1/4 Second Chime Low, Temporal Chime High, Temporal Chime Low, 5 Second Whoop High, 5 Second Whoop Low, and One Test Chime as tone selections.
Low frequency sounder and sounder/strobe models have Temporal 3, Continuous, and Coded for tone selections (Coded only available for the HR-LF and HW-LF)[13].
Speaker and speaker/strobe models have a selectable watt range from 2W, 1W, 1/2W, and 1/4W[14].
The SpectrAlert Advance series features a plug in design where the mounting bracket is first installed on the wall and the wires connected, then the device is fitted to the bracket and held in place with a screw. [15] All devices in the SpectrAlert Advance series can be synchronized together by a panel with System Sensor Sync capability or with a System Sensor MDL/MDL3 sync module[12].
UL Horn Strobes
| Model Number | Type of Device | Marking | Candela Range | Color | Mounting | Location | Replaces | Replaced By | Current Replacement |
| P2R | 2 Wire Horn Strobe | FIRE | Standard | Red | Wall | Indoor | P1224MC,
P2415, P241575 P2430, P2475, P24110, P1215 P121575 |
P2RL | P2RLED |
| P2R-P | 2 Wire Horn Strobe | Plain | Standard | Red | Wall | Indoor | P1224MCP,
P241575P |
P2RL-P | P2RLED-P |
| P2R-SP | 2 Wire Horn Strobe | FUEGO | Standard | Red | Wall | Indoor | P1224MCSP,
P241575F, P2RH-SP |
P2RL-SP | P2RLED-SP |
| P2RH | 2 Wire Horn Strobe | FIRE | High Candela | Red | Wall | Indoor | P2RH-P | P2RL | P2RLED |
| P2RH-P | 2 Wire Horn Strobe | Plain | High Candela | Red | Wall | Indoor | None | P2RH | P2RLED |
| P2RH-SP | 2 Wire Horn Strobe | FUEGO | High Candela | Red | Wall | Indoor | P2R-SP | P2RLED-SP | |
| P4R | 4 Wire Horn Strobe | FIRE | Standard | Red | Wall | Indoor | P1224MC,
P4RL | |
| P4R-P | 4 Wire Horn Strobe | FIRE | Standard | Red | Wall | Indoor | P1224MCP | ||
| P2W | 2 Wire Horn Strobe | FIRE | Standard | White | Wall | Indoor | P1224MCW,
P2415W, P2430W, P2475W, P24110W |
P2WL | P2WLED |
| P2W-P | 2 Wire Horn Strobe | Plain | Standard | White | Wall | Indoor | P1224MCWP,
P241575PW |
P2WL-P | P2WLED-P |
| P2WH | 2 Wire Horn Strobe | FIRE | High Candela | White | Wall | Indoor | None | P2WL | P2WLED |
| P2WH-P | 2 Wire Horn Strobe | Plain | High Candela | White | Wall | Indoor | P2WL-P | P2WLED-P | |
| P4W | 4 Wire Horn Strobe | FIRE | Standard | White | Wall | Indoor | P1224MC,
P4WL | |
| P4W-P | 4 Wire Horn Strobe | Plain | Standard | White | Wall | Indoor | P1224MCWP,
P241575PW | ||
| P4WH | 4 Wire Horn Strobe | FIRE | High Candela | White | Wall | Indoor | None | P4W | P4WL |
| P4WH-P | 4 Wire Horn Strobe | Plain | High Candela | White | Wall | Indoor | P4WH | ||
| PC2R | 2 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Indoor | PC2415,
PC241575 PC2430, PC2475, PC2495, PC24115 |
PC2RL | PC2RLED |
| PC2R-P | 2 Wire Horn Strobe | Plain | Standard | Red | Ceiling | Indoor | PC241575P | PC2RL-P | |
| PC2RH | 2 Wire Horn Strobe | FIRE | High Candela | Red | Ceiling | Indoor | PC24177 | PC2RL | PC2RLED |
| PC2RH-P | 2 Wire Horn Strobe | Plain | High Candela | Red | Ceiling | Indoor | None | PC2RH | PC2RLED |
| PC4R | 4 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Indoor | PC2415,
PC241575 PC2430, PC2475, PC2495, PC24115 PC4RK PC4RK-R PC4RHK PC4RHK-R |
PC4RL | |
| PC4RH | 4 Wire Horn Strobe | FIRE | High Candela | Red | Ceiling | Indoor | PC24177 | ||
| PC2W | 2 Wire Horn Strobe | FIRE | Standard | White | Ceiling | Indoor | PC2415W,
PC241575W, PC2430W, PC2475W, PC2495W, PC24115W |
PC2WL | PC2WLED |
| PC2W-P | 2 Wire Horn Strobe | Plain | Standard | White | Ceiling | Indoor | PC241575PW | None | None |
| PC2W-SP | 2 Wire Horn Strobe | FUEGO | Standard | White | Ceiling | Indoor | None | PC2WL | PC2WLED |
| PC2WH | 2 Wire Horn Strobe | FIRE | High Candela | White | Ceiling | Indoor | PC24177W | PC2WL | PC2WLED |
| PC2WH-P | 2 Wire Horn Strobe | Plain | High Candela | White | Ceiling | Indoor | None | None | None |
| PC2WH-SP | 2 Wire Horn Strobe | FUEGO | High Candela | White | Ceiling | Indoor | PC2W | PC2WLED | |
| PC4W | 4 Wire Horn Strobe | FIRE | Standard | White | Ceiling | Indoor | PC2415W,
PC4WL | |
| PC4WH | 4 Wire Horn Strobes | FIRE | High Candela | White | Ceiling | Indoor | PC24177W | PC4W | PC4WL |
| P2RK | 2 Wire Horn Strobe | FIRE | Standard | Red | Wall | Outdoor | P1224MCK,
P121575K, P241575K, P2475K, P24110K |
P2GRKLED | |
| P2RK-R | 2 Wire Horn Strobe | FIRE | Standard | Red | Wall | Outdoor
No Backbox |
None | ||
| P2RK-P | 2 Wire Horn Strobe | Plain | Standard | Red | Wall | Outdoor | P2GRKLED-P | ||
| P2RK-SP | 2 Wire Horn Strobe | FUEGO | Standard | Red | Wall | Outdoor | P2R-SP | P2RLED-SP | |
| P2RHK | 2 Wire Horn Strobe | FIRE | High Candela | Red | Wall | Oudoor | P2GRKLED | ||
| P2RHK-R | 2 Wire Horn Strobe | FIRE | High Candela | Red | Wall | Outdoor
No Backbox |
P2RHK | ||
| P2RHK-P | 2 Wire Horn Strobe | Plain | High Candela | Red | Wall | Outdoor | P2GRKLED-P | ||
| P2RHK-120 | 120v AC Horn Strobe | FIRE | High Candela | Red | Wall | Outdoor | P12015K | Still in production | |
| P4RK | 4 Wire Horn strobe | FIRE | Standard | Red | Wall | Outdoor | P1224MCK,
P121575K, P241575K, P2475K, P24110K P4RHK P4RHK-R | ||
| P4RK-R | 4 Wire Horn strobe | FIRE | Standard | Red | Wall | Outdoor
No Backbox |
None | ||
| P4RHK | 4 Wire Horn strobe | FIRE | High Candela | Red | Wall | Outdoor | P4RK | ||
| P4RHK-R | 4 Wire Horn strobe | FIRE | High Candela | Red | Wall | Outdoor
No Backbox | |||
| P2WK | 2 Wire Horn Strobe | FIRE | Standard | White | Wall | Outdoor | P2WK-R | P2GWKLED | |
| P2WK-R | 2 Wire Horn Strobe | Fire | Standard | White | wall | Outdoor
No Backbox |
None | P2WK | |
| P2WK-P | 2 Wire Horn Strobe | Plain | Standard | White | Wall | Outdoor
No Backbox |
P2GWKLED-P | ||
| P2WHK | 2 Wire Horn Strobe | FIRE | High Candela | White | Wall | Outdoor | P2WHK-R | P2GWKLED | |
| P2WHK-R | 2 Wire Horn Strobe | FIRE | High Candela | White | Wall | Outdoor | None | P2WHK | |
| P2WHK-SP | 2 Wire Horn Strobe | FUEGO | High Candela | White | Wall | Outdoor | None | ||
| P4WK | 4 Wire Horn Strobe | FIRE | Stnadard | White | Wall | Outdoor | PC4WK | ||
| PC2RK | 2 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Outdoor | PC2RK-R | PC2RKLED | |
| PC2RK-R | 2 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Outdoor
No Backbox |
None | PC2RK | |
| PC2RHK | 2 Wire Horn Strobe | FIRE | High Candela | Red | Ceiling | Outdoor | PC2RHK-R | PC2RKLED | |
| PC2RHK-R | 2 Wire Horn Strobe | FIRE | High Candela | Red | Ceiling | Outdoor
No Backbox |
None | PC2RHK | |
| PC4RK | 2 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Outdoor | PC4R | PC4RL | |
| PC4RK-R | 2 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Outdoor | |||
| PC4RHK | 2 Wire Horn Strobe | FIRE | High Candela | Red | Ceiling | Outdoor | |||
| PC4RHK-R | 2 Wire Horn Strobe | FIRE | Standard | Red | Ceiling | Outdoor
No Backbox | |||
| PC2WK | 2 Wire Horn Strobe | FIRE | Standard | White | Ceiling | Outdoor | PC2WKLED | ||
| PC2WHK | 2 Wire Horn Strobe | FIRE | High | White | Ceiling | Outdoor | |||
| PC4WK | 4 Wire Horn Strobe | FIRE | Standard | White | Ceiling | Outdoor | PC4WHK | P4WK | |
| PC4WHK | 4 Wire Horn Strobe | FIRE | Standard | White | Ceiling | Outdoor | None | PC4WK | P4WK |
UL Horns:
| Model Number | Color | Location | Replaces | Replaced By | Current Replacement |
| HR | Red | Indoor | H12/24 | HRL | |
| HW | White | Indoor | H12/24W | HWL | |
| HRK | Red | Outdoor | H12/24K | HGRKL | |
| HRK-R | Red | Outdoor No Backbox | None | ||
UL Strobes:
| Model Number | Strobe Color | Marking | Candela Range | Color | Mounting | Location | Replaces | Replaced By | Current Replacement |
| SR | Clear | FIRE | Standard | Red | Wall | Indoor | S1224MC, S1215,
S121575, S2415, S241575, S2430,S2475, S24110 |
SRL | SRLED |
| SR-P | Plain | S1224MCP,
S241575P |
SRL-P | SRLED-P | |||||
| SR-SP | FUEGO | S1224MCSP,
S241575F |
SRL-SP | SRLED-SP | |||||
| SRH | FIRE | High Candela | SRH-SP | SRL | SRLED | ||||
| SRH-P | Plain | None | SRH | ||||||
| SRH-SP | FUEGO | ||||||||
| SW | FIRE | Standard | White | S1224MCW, S1215W,
S121575W, S2415W, S241575W, S2430W,S2475W, S24110W |
SWL | SWLED | |||
| SW-P | Plain | Standard | S1224MCPW
S241575PW |
SWL-P | SWLED-P | ||||
| SW-ALERT | Amber | ALERT | None | SWL-ALERT | SWLED-ALERT | ||||
| SW-CLR-ALERT | Clear | SWL-CLR-ALERT | SWLED-CLR-ALERT | ||||||
| SWH | FIRE | High Candela | SWL | SWLED | |||||
| SWH-P | Plain | SWL-P | SWLED-P | ||||||
| SWH-ALERT | Amber | ALERT | SWL-ALERT | SWLED-ALERT | |||||
| SWH-CLR-ALERT | Clear | SWL-CLR-ALERT | SWLED-CLR-ALERT | ||||||
| SCR | FIRE | Standerd | Red | Ceiling | SC2415,SC241575,
SC2430, SC2475, SC2495, SC24115 SCR-P |
SCRL | SCRLED | ||
| SCR-P | Plain | SC-241575P | SCR | ||||||
| SCRH | FIRE | High Candela | SC24177, SCRH-P | SCRL | |||||
| SCRH-P | Plain | None | SCRH | ||||||
| SCW | FIRE | Standard | White | SC2415W,SC241575,
SC2430W, SC2495W, SC24115, SCW-SP |
SCWL | SCWLED | |||
| SCW-P | Plain | SC241575PW | Still being Produced | ||||||
| SCW-SP | FUEGO | None | SCW | SCWLED | |||||
| SCW-CLR-ALERT | ALERT | None | SCWL-CLR-ALERT | SCWLED-CLR-ALERT | |||||
| SCWH | FIRE | High Candela | SC24177W,SCWH-P,
SCWH-SP |
SCWL | SCWLED | ||||
| SCWH-P | Plain | None | SCWH | SCWLED | |||||
| SCWH-SP | FUEGO | None | SCWH | SCWLED | |||||
| SRK | FIRE | Standard | Red | Wall | Outdoor | S1224MCK,
S121575K, S241575K, S2475K,S24110K |
SGRKLED | ||
| SRK | FIRE | Outdoor
No Backbox |
None | ||||||
| SRK-P | Plain | Outdoor | None | ||||||
| SRHK | FIRE | High Candela | SRHK-R | SGRKLED | |||||
| SRHK-R | Outdoor
No Backbox |
None | SRHK | ||||||
| SRHK-P | Plain | Outdoor | SGRKLED-P | ||||||
| SWK | FIRE | Standard | White | SGWKLED | |||||
| SWK-R | Outdoor
No Backbox |
SGWKLED | |||||||
| SWK-P | Plain | Outdoor | SGWKLED-P | ||||||
| SCRK | FIRE | Red | Ceiling | SCRKLED | |||||
| SCRK-R | Outdoor
No Backbox |
None | |||||||
| SCRHK | High Candela | Outdoor | SCRKLED | ||||||
| SCRHK-R | Outdoor
No Backbox |
None | |||||||
| SCWK | Standard | White | Outdoor | SCWKLED | |||||
| SCWHK | High Candela | ||||||||
UL Low Frequency Sounders:
| Model Number | Type of Device | Marking | Color | Mounting | Replaced By | Current Replacement |
| HR-LF | Horn | Plain | Red | Wall | HRL-LF | |
| HW-LF | Horn | Plain | White | Wall | HWL-LF | |
| P2RH-LF | Horn Strobe | FIRE | Red | Wall | P2RL-LF | |
| P2WH-LF | Horn Strobe | FIRE | White | Wall | P2WL-LF | |
UL Chimes and Chime Strobes:
| Model Number | Type of Device | Marking | Candela Range | Color | Replaces | Replaced By | Current Replacement |
| CHR | Chime | Plain | None | Red | CH1224 | CHRL | |
| CHW | Plain | White | CH1224W | CHWL | |||
| CHSR | Chime Strobe | Plain | Standard | Red | CH2415,CH241575,CH2475,
CH24110, CH24MC |
CHSRL | |
| CHSW | Plain | White | CH2415W, CH241575W,
CH2475W, CH24110W, CH24MCW |
CHSWL | |||
UL Speakers:
| Model Number | Speaker | Color | Mounting | Location | Replaces | Replaced By | Current Replacement |
| SPR | Standard | Red | Wall | Indoor | SP201R | SPRL | |
| SPRV | High dB | Red | Wall | Indoor | SP301R | SPRL | |
| SPW | Standard | White | Wall | Indoor | SP201W | SPWL | |
| SPWV | High dB | White | Wall | Indoor | SP301W | SPWL | |
| SPCR | Standard | Red | Ceiling | Indoor | None | SPCRL | |
| SPCRV | High dB | Red | Ceiling | Indoor | None | SPCRL | |
| SPCW | Standard | White | Ceiling | Indoor | SP200W | SPCWL | |
| SPCWV | High dB | White | Ceiling | Indoor | SP300W | SPCWL | |
| SPRK | Standard | Red | Wall | Outdoor | SP201K | Still in Production | |
| SPRK-R | Standard | Red | Wall | Outdoor No backbox | None | Still in Production | |
| SPWK | Standard | White | Wall | Outdoor | SPWK-R | Still in Production | |
| SPWK-R | Standard | White | Wall | Outdoor No Backbox | None | SPWK | |
| SPCWK | Standard | White | Ceiling | Outdoor | None | Still in Production | |
| SPCWK-R | Standard | White | Ceiling | Outdoor No Backbox | None | Still in Production | |
UL Speaker Strobes:
| Model Number | Marking | Strobe Color | Speaker | Candela Range | Color | Mounting | Location | Replaces | Replaced By | Current Replacement |
| SPSR | FIRE | Clear | Standard | Standard | Red | Wall | Indoor | SP2R1224MC,
SP2R2415 SP2R241575 SP2R2430 SP2R2475 SP2R24110 |
SPSRL | |
| SPSR-P | Plain | Clear | Standard | Standard | Red | Wall | Indoor | SPSRH-P, SPSRV-P | SPSRL-P | |
| SPSRV | FIRE | Clear | High dB | Standard | Red | Wall | Indoor | SP3R1224MC | SPSRL | |
| SPSRV-P | Plain | Clear | High db | Standard | Red | Wall | Indoor | None | SPSR-P | SPSRL |
| SPSRH | FIRE | Clear | Standard | High Candela | Red | Wall | Indoor | None | SPSRL | |
| SPSRH-P | Plain | Clear | Standard | High Candela | Red | Wall | Indoor | None | SPSR-P | SPSRL |
| SPSW | FIRE | Clear | Standard | Standard | White | Wall | Indoor | SP2W1224MC,
SP2W2415 SP2W241575 SP2W2430 SP2W2475 SP2W24110 |
SPSWL | |
| SPSW-P | Plain | Clear | Standard | Standard | White | Wall | Indoor | None | SPSWL-P | |
| SPSW-ALERT | ALERT | Amber | Standard | Standard | White | Wall | Indoor | None | SPSCW-ALERT | |
| SPSW-CLR-ALERT | ALERT | Clear | Standard | Standard | White | Wall | Indoor | None | SPSCW-CLR-ALERT | |
| SPSWV | FIRE | Clear | High dB | Standard | White | Wall | Indoor | SP3W1224MC
SPSWV-P |
SPSWL | |
| SPSWV-P | Plain | Clear | High dB | Standard | White | Wall | Indoor | None | SPSWV | SPSWL |
| SPSWH | FIRE | Clear | Standard | High Candela | White | Wall | Indoor | None | SPSWL | |
| SPSWH-P | Plain | Clear | Standard | High Candela | White | Wall | Indoor | None | None | |
| SPSCR | FIRE | Clear | Standard | Standard | Red | Ceiling | Indoor | None | SPSCRL | |
| SPSCRV | FIRE | Clear | High dB | Standard | Red | Ceiling | Indoor | None | SPSCRL | |
| SPSCRH | FIRE | Clear | Standard | High Candela | Red | Ceiling | Indoor | None | SPSCRL | |
| SPSCRVH | FIRE | Clear | High dB | High Candela | Red | Ceiling | Indoor | None | SPSCRL | |
| SPSCW | FIRE | Clear | Standard | Standard | White | Ceiling | Indoor | SP2C2415
SP2C241575 SP2C2430 SP2C2475 SP2C2495 SP2C24115 |
SPSCWL | |
| SPSCW-P | Plain | Clear | Standard | White | Wall | Indoor | None | None | SPSCWL-P | |
| SPSCW-CLR-ALERT | ALERT | Clear | Standard | White | Wall | Indoor | None | None | SPSCWL-CLR-ALERT | |
| SPSCWV | FIRE | Clear | High dB | Standard | White | Ceiling | Indoor | None | SPSCWL | |
| SPSCWV-P | Plain | Clear | High dB | Standard | White | Ceiling | Indoor | SPSCWVH-P | SPSCWL-P | |
| SPSCWH | FIRE | Clear | Standard | High Candela | White | Ceiling | Indoor | SP2C24177 | SPSCWL | |
| SPSCWH-P | Plain | Clear | Standard | High Candela | White | Ceiling | Indoor | None | SPSCWL-P | |
| SPSCWVH | FIRE | Clear | High dB | High Candela | White | Ceiling | Indoor | None | SPSCWL | |
| SPSCWVH-P | Plain | Clear | High dB | High Candela | White | Ceiling | Indoor | None | SPSCWVH-P | SPSCWL-P |
| SPSRK | FIRE | Clear | Standard | Standard | Red | Wall | Outdoor | SP2R1224MCK | Still in Production | |
| SPSRK-R | FIRE | Clear | Standard | Standard | Red | Wall | Outdoor No Backbox | None | Still in Production | |
| SPSRK-P | Plain | Clear | Standard | Standard | Red | Wall | Outdoor | None | Still in Production | |
| SPSRHK | FIRE | Clear | Standard | High Candela | Red | Wall | Outdoor | None | Still in Production | |
| SPSWK | FIRE | Clear | Standard | Standard | White | Wall | Outdoor | None | Still in Production | |
| SPSWK-P | Plain | Clear | Standard | Standard | White | Wall | Outdoor | None | Still in Production | |
| SPSWK-CLR-ALERT | ALERT | Clear | Standard | Standard | White | Wall | Outdoor | None | Still in Production | |
| SPSCWK | FIRE | Clear | Standard | Standard | White | Wall | Outdoor | None | Still in Production | |
| SPSCWK-CLR-ALERT | ALERT | Clear | Standard | Standard | White | Wall | Outdoor | None | Still in Production | |
UL Mini-Horns:
| MHR | Red | Indoor | PA400R |
| MHW | White | Indoor | PA400W |
UL Dual Strobe Expander plates:
| Model Number | Marking | Strobe Color | Design for | Color | Mounting | Replaced By | Current Replacement |
| SEP-SW | ALERT | Amber | SW, SWH, SW-P, SWH-P | White | Wall | SEP-SPSWL | |
| SEP-SW-P | Plain | None | SW, SWH, SW-P, SWH-P | White | Wall | SEP-SPSWL-P | |
| SEP-SPSW | ALERT | Amber | SPSW, SPSWH, SPSW-P, SPSWV, SPSWV-P, SPSWH-P | White | Wall | SEP-SPSWL | |
| SEP-SPSW-P | Plain | None | SPSW, SPSWH, SPSW-P, SPSWV, SPSWV-P, SPSWH-P | White | Wall | SEP-SPSWL-P | |
Resources
Data Sheets:
Wall Horns, Strobes, and Horn/Strobes
Ceiling Horn/Strobes and Strobes
Wall Speakers and Speaker Strobes
Ceiling Speakers and Speaker Strobes
Outdoor Wall Horn, Strobes and Horn/Strobes
Outdoor Ceiling Horn Strobes and Strobes
Outdoor Wall Speakers and Speaker Strobes
Outdoor Ceiling Speakers and Speaker Strobes
Field Selectable Emergency Communications devices
Manuals:
Horns, Strobes and Horn/Strobes
- ↑ 1.0 1.1 https://web.archive.org/web/20061214163820/http://www.systemsensor.com/av
- ↑ 2.0 2.1 https://buildings.honeywell.com/content/dam/hbtbt/en/documents/document-lists/system-sensor/announcement/SS-Web-SpectrAlert-Advance-Indoor-EOL-2020-02.pdf
- ↑ "Selectable Output Strobes, Horns, and Horn/Strobes" (I56-2769-003R). System Sensor (2006).
- ↑ https://www.freepatentsonline.com/7501935.html
- ↑ "Selectable Output Chimes and Chime/Strobes" (I56-2783-001R). System Sensor (2006).
- ↑ https://web.archive.org/web/20080430144350/http://www.systemsensor.com/av/
- ↑ https://web.archive.org/web/20080512023210/http://www.systemsensor.com/
- ↑ https://web.archive.org/web/20120130062906/http://www.systemsensor.com:80/press/
- ↑ https://web.archive.org/web/20120525010448/http://www.systemsensor.com/press/r126_av-mass-notification.html
- ↑ https://web.archive.org/web/20130827010707/http://www.systemsensor.com/press/
- ↑ https://buildings.honeywell.com/content/dam/hbtbt/en/documents/downloads/System%20Sensor%20SpectrAlert%20Advance%20LF%20Announcement.pdf
- ↑ 12.0 12.1 12.2 "Indoor Selectable-Output Horns, Strobes, and Horn Strobes for Wall Applications" (AVDS10201). System Sensor (January 2014).
- ↑ "Selectable-Output Low Frequency Sounder and Low Frequency Sounder Strobes for Wall Applications" (AVDS16404). System Sensor (January 2015).
- ↑ "Indoor Selectable-Output Speaker Strobes and Dual Voltage Evacuation Speakers for Wall Applications" (AVDS00801). System Sensor (March 2012).
- ↑ "Selectable Output Strobes, Horns, and Horn/Strobes" (I56-2769-022). System Sensor (May 22, 2019).
