System Sensor Retro-Plate series
Retro-Plate series
10.5-17 VDC |
1999-2000
System Sensor RK series
"title": "Retro-Plate series",
The System Sensor Retro-Plate series is a series of strobe plates.
The Retro-Plate series was released in 1995 as a successor to the RK series. The strobe plates were designed similar to the UL 1638 strobes in the Simplex 4903 series.
The Retro-Plate series was discontinued between 1999 and 2000.[2][3]
| Model | Voltage | Candela | Color | Replaces |
| RP1215ADA | 12VDC | 15 | Red | None |
| RP1215ADAW | 12VDC | 15 | White | None |
| RP121575ADA | 12VDC | 15/75 | Red | None |
| RP121575ADAW | 12VDC | 15/75 | White | None |
| RP2415ADA | 24VDC | 15 | Red | RK2415ADA |
| RP2415ADAW | 24VDC | 15 | White | None |
| RP241575ADA | 24VDC | 15/75 | Red | RK241575ADA |
| RP241575ADAW | 24VDC | 15/75 | White | None |
| RP2475ADA | 24VDC | 75 | Red | RK2475ADA |
| RP2475ADAW | 24VDC | 75 | White | None |
| RP24110ADA | 24VDC | 110 | Red | RK24110ADA |
| RP24110ADAW | 24VDC | 110 | White | None |
