System Sensor 400 series
2005 (2400 series) |
BRK 800 series |
System Sensor 100 series |
"title": "400 series",
"System_Sensor_1400_smoke_detector.png",
"2400.jpg"
The 400 series is a lineup of conventional detectors produced by System Sensor.
The 1400 series ionization smoke detectors were introduced in 1988 and was phased out after 2007, while the 2400 series was introduced in 1988 and was discontinued in 2005. The 2400 replaced the BRK 2800 series and was replaced by the System Sensor i3.
In 1993, duct smoke detectors were released.[2] The 5451 heat detector was also released in 1993.[3]
In 1997, the sounder models of the photoelectric detectors were discontinued due to the release of new 100 series models that produced a temporal 3 pattern.[4]
In 2005, 2400TH, 2412THB, 2424TH, and 2451TH units manufactured between March and September 2004 were recalled.[5][6] Around this time, the photoelectric detectors were discontinued. Direct-Wire models were replaced with the i3 series, while the plug-in models were replaced with the 2151.
In 2006, the 6424 beam detector was discontinued and replaced with the BEAM1224.[7]
In 2007, the Direct-Wire ionization detectors were discontinued and replaced with the plug-in 1451.[8] The 1451 was discontinued at the end of 2008 with no direct replacement.[9]
In 2011, the 5451 was discontinued and replaced with the 5151.[10]
Some say that the 100 series replaced the 400 series, but that is only partially true because the 100 series was produced alongside the 400 series, as a low-profile version.
| Model | Wiring | Application | Voltage | Relay? | Replaced | Replaced by |
| 1400[11] | 2-wire | Spot | 12 VDC & 24 VDC | No | 1800 | 2W-B B401 + 1451 |
| 1412[12] | 4-wire | Spot | 12 VDC | Yes | 1812 | 1412B |
| 1412B | 4-wire | Spot | 12 VDC | Yes | 1112/24D 1412 |
4W-B 4WTR-B |
| 1424 | 4-wire | Spot | 24 VDC | Yes | 1824 | 4W-B 4WTR-B B402B + 1451 |
| 1451[13] | Plug-in | Spot | 24 VDC | No | 1151 1400 (with B401) 1424 (with B402B) 1851 |
2151 8100 |
| 1451DH[14] | Plug-in | Duct | 12 VDC & 24 VDC | No | 1851DH | |
| 1451DHHT[15] | Plug-in | High-temperature duct | 24 VAC/VDC & 120 VAC & 220 VAC | No | None |
| Model | Wiring | Voltage | Heat sensor | Horn? | Replaced | Replaced by |
| 2400[16] | 2-wire, head wired | 12 VDC & 24 VDC | None | No | 2800 | 2W-B |
| 2400TH | 2-wire, head wired | 12 VDC & 24 VDC | Integral | No | 2800TH | 2WT-B |
| 2400AT | 2-wire | 24 VDC | Integral | Yes | 2100AT | |
| 2400AIT | 2-wire | 24 VDC | Isolated | Yes | 2112/24AITR | |
| 2412 | 4-wire | 12 VDC | None | No | 2812 | 2412B |
| 2412TH | 4-wire | 12 VDC | Integral | No | 2312/24T 2812TH |
2412THB |
| 2412B | 4-wire, head wired, auxiliary contacts | 12 VDC | None | No | 2412 | 4W-B 4WTR-B |
| 2412THB | 4-wire, head wired, auxiliary contacts | 12 VDC | Integral | No | 2412TH | 4WTR-B |
| 2412AT | 4-wire | 12 VDC | Integral | Yes | 2112/24ATR | |
| 2424 | 4-wire, head wired, auxiliary contacts | 24 VDC | None | No | 2824 | 4W-B 4WTR-B |
| 2424TH | 4-wire, head wired, auxiliary contacts | 24 VDC | Integral | No | 2312/24T 2824TH |
4WTR-B |
| 2424AT | 4-wire | 24 VDC | Integral | Yes | 2112/24ATR | |
| 2424AIT | 4-wire | 24 VDC | Isolated | Yes | 2112/24AITR | |
| 2451[17] | Plug-in, base wired | 24 VDC | None | No | 2851B 2851DH |
2151 |
| 2451TH | Plug-in, base wired | 24 VDC | Integral | No | 2851BTH | 2WT-B 4WT-B 2151T |
| Model | Wiring | Voltage | Sensitivity | Listing | Replaced | Replaced by |
| 4451HT[18] | Plug-in | 24 VDC & 120 VAC | 190°F / 88°C | UL | ||
| 4451HTA | Plug-in | 24 VDC & 120 VAC | 190°F / 88°C | ULC | ||
| 5451 | Plug-in | 24 VDC & 120 VAC | 135° F / 57.6°C | UL | 5151 |
Beam detectors
| Model | Wiring | Voltage | Listing | Replaced | Replaced by |
| 6424[19] | 4-wire | 24 VDC | UL | BEAM1224 | |
| 6424A | 4-wire | 24 VDC | ULC |
Duct detectors
| Model | Sensor type | Wiring | Voltage | High temperature? | Listing | Replaced | Replaced by |
| DH400I | Ionization | 2-wire | 12 VDC & 24 VDC | No | UL | DH1851DC | DH100P |
| DH400A | Ionization | 2-wire | 12 VDC & 24 VDC | No | ULC | ||
| DH400P | Photoelectric | 2-wire | 12 VDC & 24 VDC | No | UL | DH2851DC | DH100P |
| DH400ACDCI[20] | Ionization | 4-wire | 24 VAC/VDC & 120 VAC & 220/240 VAC | No | UL | DH1851AC DH1851DC + AR-10 |
DH100ACDCI |
| DH400ACDCA | Ionization | 4-wire | 24 VAC/VDC & 120 VAC & 220/240 VAC | No | ULC | ||
| DH400ACDCP | Photoelectric | 4-wire | 24 VAC/VDC & 120 VAC & 220/240 VAC | No | UL | DH2851AC DH2851DC + AR-10 |
DH100ACDCP |
| DH400ACDCIHT | Ionization | 4-wire | 24 VAC/VDC & 120 VAC & 220 VAC | Yes | UL | D4120 |
Faraday rebranded 400 series products as part of the 8400 series, 9100 series, and 9300 series until 2004.[21][22]
| FCI model | System Sensor model | Replaced | Replaced by |
| SBS-1101[23] | 1400[24] | 1400 | |
| SBS-1201 | 2400 | 2400 | |
| SBS-1201T | 2400TH | 2400TH | |
| 301I[25] | 1451 | 301IL | |
| 301I-DH[26] | 1451DH | ||
| 301P[27] | 2451 | 301PL | |
| 301PT | 2451TH |
Fire-Lite Alarms
| Fire-Lite model | System Sensor model | Replaced | Replaced by |
| CP400[28][29] | 1400 | 1400 | |
| CP451 | 1451 | 1451 | |
| SD400 | 2400 | SD800 | 2400 |
| SD400T | 2400TH | 2400TH | |
| SD451 | 2451 | 2451 | |
| SD451T | 2451TH | 2451TH |
| Honeywell model | System Sensor model | Replaced | Replaced by |
| TC805C1000[30] | 1451 | ||
| TC805C1018[31] | 1451DH |
| Simplex model | System Sensor model | Replaced | Replaced by |
| 2098-9110 | 1400A | ||
| 2098-9577 | 1400 |
System Sensor 1451 (from official datasheet)
System Sensor 2451TH on a B402B 4-wire base. Taken by @Loganetics1
System Sensor 2400, 2412B, and 2424. Credit: https://firealarm.com/wp-content/uploads/2023/09/2400.jpg
System Sensor 2400TH, 2412THB, and 2424TH
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_c4d24131-1892-4c20-ab14-5f9f56e28507/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_f3112296-f0bb-4f42-93e1-9f096c3feb5e/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_f3f1267e-a978-4552-b5d1-0381ba603da8/
- ↑ "400 Series™ Direct-Wire Photoelectronic Smoke Detector" (A05-194-03). System Sensor (February 1997).
- ↑ "Conventional Detection" System Sensor. Archive 2005-02-05 vs. 2005-12-03
- ↑ https://web.archive.org/web/20060604144306/http://systemsensor.com/pdf/400_recall.pdf
- ↑ "Conventional Detection" System Sensor. Archive 2006-07-17 vs. 2006-11-09
- ↑ "Conventional Detection" System Sensor. Archive 2007-02-05 vs. 2007-08-08
- ↑ "Conventional Detection" System Sensor. Archive 2008-12-18 vs. 2009-05-08
- ↑ "Conventional Detection" System Sensor. Archive 2011-08-06 vs. 2011-10-05
- ↑ "400 Series™ Direct-Wire Ionization Smoke Detector" (A05-0219-003). System Sensor (July 2003).
- ↑ "1412 and 1424 Direct Wire Ionization Smoke Detectors" (I56-280-03). System Sensor (1996).
- ↑ "400 Series™ Plug-in Smoke Detector" (A05-205-02). System Sensor (August 1996).
- ↑ "400 Series™ 2-Wire Duct Smoke Detector" (A05-240-01). System Sensor (March 1996).
- ↑ "400 Series™ High-Temperature Duct Smoke Detector" (A05-0953-002). System Sensor (October 2003).
- ↑ "400 Series™ Direct-Wire Photoelectronic Smoke Detector" (A05-194-03). System Sensor (August 1996).
- ↑ "2451 - SYSTEM SENSOR PHOTOELECTRONIC SMOKE DETECTOR" (9020-0585). Fire Control Instruments (2003).
- ↑ "4451HT Plug-in 190°F Thermal Detector" (A05-236-01). System Sensor (August 1996).
- ↑ "Model 6424 Projected Beam Smoke Detector" (A05-217-01). System Sensor (August 1996).
- ↑ "400 Series™ 4-Wire Duct Smoke Detector" (A05-201-02). System Sensor (August 1996).
- ↑ https://web.archive.org/web/20040219084347/http://www.faradayllc.com/products_initiating.html
- ↑ https://web.archive.org/web/20040401233430/http://faradayfirealarms.com/products_initiating.html
- ↑ https://www.youtube.com/watch?v=X5lBcFPzm20
- ↑ https://i.ebayimg.com/images/g/IucAAOSwd2llByaU/s-l1600.jpg
- ↑ "301I Ionization Smoke Detector" (9020-0253). Fire Control Instruments (1997).
- ↑ https://i.ebayimg.com/images/g/5F8AAOSw9xhmAKm5/s-l1600.jpg
- ↑ "301P, 301PT Photoelectronic Smoke Detector" (9020-0254). Fire Control Instruments (1997).
- ↑ https://buildings.honeywell.com/content/dam/hbtbt/en/documents/document-lists/firelie/ul/UROX.S1059.pdf
- ↑ https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/regulatory-documents/fire-listings/UROX.S1059.pdf
- ↑ https://firealarms.tv/collection/honeywell-tc805c1000/
- ↑ https://i.ebayimg.com/images/g/7AQAAOSwuOZduKs5/s-l1600.jpg
