System Sensor 100 series
100 series
8.5-35 VDC[1] {"label": "Rated Voltage", "field": "8.5-35 VDC[1]"}
Fire-Lite LP-12 series
System Sensor 2300 series
System Sensor 400 series {"label": "Preceded by", "field": "Fire-Lite LP-12 series
System Sensor 400 series"}
System Sensor i3 series {"label": "Succeeded by", "field": "System Sensor i3 series"}
The System Sensor 100 series is a series of conventional detectors.
The 100 series was released in 1993 with the 1151 and 2151 as a lower profile alternative to the 400 series that had common housing for photoelectric and ionization smoke detectors.[2]
In 1996, System Sensor introduced the 2100, 2100T, 2112/24B, and 2112/24TB as replacements for the 2300 series. The non-thermal models resembled the 2151, and the thermal models had a similar thermistor design to the 3251. The 2112/24TSRB, 1100, and 1112/24B were also introduced at this time.
In 1997,[citation needed] System Sensor introduced Code 3 sounder models of the photoelectric detectors to replace the 400 series sounder models. Unlike the 400 series isolated thermal models, the 2112/24AITR did not provide any contacts for the photoelectric sensor.
The Direct-Wire photoelectric detectors were discontinued in 2003 due to the release of the i3 series.[3]
The 1151 was discontinued between 2004 and 2005.[4] Consumers were instructed to switch to the 1451.
In 2006, the 2151 was redesigned to resemble the 2251B.[5] The 2151T was also introduced at this time as a conventional version of the 2251TB. These new models use the i3 SENS-RDR for sensitivity testing instead of the MOD400R.
The 5151 heat detector was released in 2011 as a replacement for the 5451.[6]
In December 2020, the 2151 was updated to meet the requirements of the 7th edition of UL 268.[citation needed]
Model Wiring Listing Replaced Replaced by
1100[7] 2-wire UL None 1100D
1100D[8] 2-wire UL 1100 B110LP + 1151
2100D
1112/24B 4-wire UL None 1112/24D
1112/24D 4-wire UL 1112/24B B112LP + 1151
1412B
2112/24D
1151[9] Plug-in UL 1100D (with B110LP)
1112/24D (with B112LP)
1451
2151
1151A Plug-in ULC
Model Wiring Heat sensor? Relay Horn? Listing Replaced Replaced by
2100 2-wire No None No UL 2300B 2100D
2100D 2-wire No None No UL 1100D
2100
2100S
2100AT[10] 2-wire Yes None Yes UL 2400AT 2WTA-B[11]
2100S[12] 2-wire No None No 2100D 2W-B
2100T 2-wire Yes None No UL 2300TB 2100TD
2100TD 2-wire Yes None No UL 2100T 2100TS
2100TR 2-wire Yes Alarm No UL 2WTR-B
2100TS 2-wire Yes None No 2100TD 2WT-B
2112/24AT 4-wire Yes None Yes UL None 4WTA-B
2112/24ATR 4-wire Yes Alarm Yes UL 2412AT
2424AT
4WTAR-B
2112/24AITR 4-wire Isolated Alarm Yes UL 2400AIT
2424AIT
4WITAR-B
2112/24B 4-wire No None No UL 2312/24B
BLP-12-4W + LPSD-12
2112/24D
2112/24D 4-wire No None No UL 1112/24D
2112/24B
2112/24S
2112/24R 4-wire No Alarm No UL 4WTR-B
2112/24S 4-wire No None No 2112/24D 4W-B
2112/24TB 4-wire Yes None No UL 2312/24TB 2112/24TD
2112/24TD 4-wire Yes None No UL 2112/24TB 2112/24TS
2112/24TR 4-wire Yes Alarm No UL 4WTR-B
2112/24TS 4-wire Yes None No 2112/24TD 4WT-B
2112/24TSRB 4-wire Yes Supervisory No UL None 2W-MOD + 2WT-B
2151 Plug-in No None No UL 1151
1451
2451
LPSD-12
2151T Plug-in Yes None No UL 2451TH Still in production
2151A Plug-in No None No ULC
Innovair duct detectors
Model Sensor type Wiring Low-flow? Watertight? Replaced Replaced by
DH100ACDCI[13] Ionization 4-wire No No DH400ACDCI D4120
DH100P Photoelectric 2-wire No No DH400I
DH400P
DH100LP
DH100ACDCP Photoelectric 4-wire No No DH400ACDCP DH100ACDCLP
DH100LP Photoelectric 2-wire Yes No DH100P D2
DH100ACDCLP Photoelectric 4-wire Yes No DH100ACDCP D4120
DH100ACDCLWP Photoelectric 4-wire Yes Yes None D4120W
Faraday rebranded 100 series products as part of the 8400 series and 9100 series until 2004.[14][15]
Monaco model System Sensor model Replaced Replaced by
721-122-00[16] 5151 Still in production
723-002-00 2151 Still in production
723-003-00 2151T Still in production
729-097-00 B110RLP Still in production
729-108-00 RTS151 Still in production
729-138-00 RTS151KEY Still in production
729-150-00 B110LP Still in production
729-151-00 B112LP Still in production
Notifier rebranded the 100 series with a modified design similar to the 700 series.[17]
Notifier model System Sensor model Replaced Replaced by
CP-651 1151 1451
SD-651 2151 2151
  1. https://web.archive.org/web/19970401001835/http://www.systemsensor.com/e-docs/manuals/100dw.pdf
  2. https://nfpa.access.preservica.com/uncategorized/IO_e739b0ac-5683-41d8-8725-3d1426de8e70/
  3. "Conventional Detection" System Sensor. Archive 2003-06-08 vs. 2003-12-24
  4. "Conventional Detection" System Sensor. Archive 2004-12-15 vs. 2005-12-03
  5. "100 Series™ Low-Profile Plug-in Smoke Detectors" System Sensor. Archive 2006-03-19 vs. 2006-04-12
  6. "Conventional Detection" System Sensor. Archive 2011-08-06 vs. 2011-10-05
  7. "100 Series™ Low-Profile Direct-Wire Smoke Detector" (A05-227-03). System Sensor (August 1996).
  8. "Device Compatibility Document" (15384). Fire-Lite Alarms (January 25, 2022).
  9. "100 Series™ Low-Profile Plug-in Smoke Detector" (A05-182-03). System Sensor (August 1996).
  10. "100 Series Specialty Direct Wire Smoke Detectors" (A05-0345-000). System Sensor (June 2002).
  11. https://web.archive.org/web/20031224224710/http://systemsensor.com/html/cd.html?search=100
  12. "100 Series Direct Wire Smoke Detectors" (A05-227-09). System Sensor (January 1999).
  13. https://web.archive.org/web/20021008065230/http://systemsensor.com/html/hvac.html?search=conventional
  14. https://web.archive.org/web/20040219084347/http://www.faradayllc.com/products_initiating.html
  15. https://web.archive.org/web/20040401233430/http://faradayfirealarms.com/products_initiating.html
  16. "Monaco Products Catalog". Monaco Enterprises (September 2024).
  17. "SD-651 and CP-651 - Low-Profile Conventional Detectors" (DN-4924). Notifier (March 24, 2005).
