System Sensor L-Series
L-Series
System Sensor_L-Series_Product_LED_Overview.png: Infobox image for L-Series the infobox device.
NOTIFIER-Low-Frequency-Sounders-Strobes-L-Series.jpg: Infobox image for L-Series the infobox device.
2017 Xenon[1] 2023 LED[2] {"label": "Introduced", "field": "2017 Xenon[1] 2023 LED[2]"}
2023 Xenon[2] {"label": "Discontinued", "field": "2023 Xenon[2]"}
Honeywell XLS Genesis series
System Sensor SpectrAlert Advance series {"label": "Preceded by", "field": "Honeywell XLS Genesis series
System Sensor SpectrAlert Advance series"}
The L-Series is a series of fire alarm notification appliances that were manufactured by the American fire alarm company System Sensor. The L-Series received a LED upgrade with the new devices sharing the same series name as their xenon strobe counterparts, the original strobes have been discontinued since December 15, 2023[2]
In 2017, the L-Series was released as a successor to the System Sensor SpectrAlert Advance series. Chime and low frequency models were not available yet. Models made before chime and low frequency models released came with a light gray mounting bracket. L-Series that came with the newer (dark gray) mounting bracket can not be mounted on these but the L-series that came with the older (light gray) mounting brackets can be mounted on the newer (dark gray) mounting brackets.
Speaker and speaker strobe models got recalled in August 2017 due to issues with mounting brackets.
In late 2018, chime models were released.[citation needed]
In July 2019, the mounting plates were strengthened, and in October 2019, low frequency sounders were introduced.[3]
In late 2020, most ULC devices with English-only lettering and all devices with French-only lettering were discontinued.[4] Consumers were instructed to use the respective bezel kits when such lettering was required.
In 2022, talked started about System Sensor releasing a new series of devices.
In late 2022 or early 2023, Notifier made a PDF about upcoming LED appliances[5]. The PDF seems to be for some kind of webinar. While it's unknown whether this PDF was public before the official system sensor release or it was made public after, images of the LED L-Series started to circulate in the fire alarm community from this PDF. Criticism spread surrounding the design.
In May 2023, the SpectrAlert Advance series and L-Series were discontinued in Australia and replaced with the KAC ENscape series.[6]
In September 2023, the L-Series with LED was released[7]. Only indoor horns and horn strobes were released. A source of criticism was the lack of being listed to work on FWR.
In early 2024, the LED L-Series received a listing for FWR, it has been discovered that there is a possibility that the first models produced in 2023 do not work on FWR, and models made after December 2023 can run on FWR, nothing has been officially confirmed yet.
On March 11, 2024, L-Series low frequency sounders with date codes of 3034 and 3035 were recalled due to a "risk of low or no sound output".
In June 2024, outdoor strobes, horns, and horn strobes were released together with indoor LED speaker strobes.[8]
On November 15, 2024, the LED L-Series’ T4 capability was accidentally discovered by an enthusiast attempting to power their alarm with a 9V battery, causing it to produce the Temporal 4 pattern and switch to a yellow strobe.[9]Unfortunately this behavior has yet to be reproduced, likely meaning that a currently unavailable synchronization module will be required to reliably activate the T4 mode, similar to the Gentex GHLF low frequency sounder and Mircom 400 series lines of signals.
In December 2025, System Sensor introduced LED low frequency sounder strobes and second generation low frequency sounders. These have a new physical appearance, and the LED ceiling sounder strobes have a centered strobe, unlike the xenon version.
UL xenon horn strobes
Model Number Type of Device Marking Color Mounting Replaces Replaced By Current Replacement
P2RL 2 Wire Horn Strobe FIRE Red Wall P2R
P2RH
XLSG1R-HDVM + XLSG1RT(-FIRE)
XLSG1RF-HDVM + XLSG1RT(-FIRE)
CWSS-RW-S5
P2RLED
CWSS-RW-S5
P2RLED
P2RL-P 2 Wire Horn Strobe Plain Red Wall P2R-P CWSS-RW-S5
P2RLED-P
CWSS-RW-S5
P2RLED-P
P2RL-SP 2 Wire Horn Strobe FEGUO Red Wall P2R-SP P2RLED-SP P2RLED-SP
P2GRL 2 Wire Horn Strobe FIRE Red Wall, Compact XLSG1R-HDVM
XLSG1RF-HDVM
P2GRLED P2RGLED
P4RL 4 Wire Horn Strobe FIRE Red Wall P4R
P4RH
Still being produced
P2WL 2 Wire Horn Strobe FIRE White Wall P2W
P2WH
XLSG1-HDVM + XLSG1T(-FIRE)
XLSG1F-HDVM + XLSG1T(-FIRE)
P2WLED P2WLED
P2WL-P 2 Wire Horn Strobe Plain White Wall P2W-P
P2WH-P
CWSS-WW-S5
P2WLED-P
CWSS-WW-S5
P2WLED-P
P2WL-SP 2 Wire Horn Strobe FEGUO White Wall P2W-SP
P2WH-SP
P2WLED-SP P2WLED-SP
P2GWL 2 Wire Horn Strobe FIRE White Wall,
Compact
XLSG1-HDVM
XLSG1F-HDVM
P2GWLED P2GWLED
P4WL 4 Wire Horn Strobe FIRE White Wall P4W Still being produced
PC2RL 2 Wire Horn Strobe FIRE Red Ceiling PC2R,
PC2RH
PC2RLED PC2RLED
PC4RL 4 Wire Horn Strobe FIRE Red Ceiling PC4R
PC4RH
PC2WL 2 Wire Horn Strobe FIRE White Ceiling PC2W
PC2WH
XLSGC-HDVM
XLSGCF-HDVM
XLSGC-HDVMH
XLSGCF-HDVMH
PC2WLED PC2WLED
PC4WL 4 Wire Horn Strobe FIRE White Ceiling PC4W Still being produced
ULC xenon horn strobes
Model Wiring Marking Color Mounting Replaced Replaced by
P2RLA[10] 2-wire FIRE-FEU Red Wall P2RLED-B
P2RLA-E 2-wire FIRE Red Wall P2RLED
P2RLA-F 2-wire FEU Red Wall P2RLA + BZR-FR
P2WLA 2-wire FIRE-FEU White Wall P2WLED-B
P2WLA-E 2-wire FIRE White Wall P2WLED
P2WLA-F 2-wire FEU White Wall P2WLA + BZW-FR
P2GRLA 2-wire FIRE-FEU Red Wall P2GRLED-B
P2GRLED (with BZGR-F)
P2GRLA-E 2-wire FIRE Red Wall P2GRLA + BZGR-F
P2GRLA-F 2-wire FIRE-FEU Red Wall P2GRLA + BZGR-FR
P2GWLA 2-wire FIRE-FEU White Wall P2GWLED-B
P2GWLED (with BZGW-F)
P2GWLA-E 2-wire FIRE White Wall P2GWLA + BZGW-F
P2GWLA-F 2-wire FEU White Wall P2GWLA + BZGW-FR
P2RLA-P 2-wire None Red Wall P2RLED-P
P2WLA-P 2-wire None White Wall P2WLED-P
P4RLA 4-wire FIRE-FEU Red Wall Still in production
P4RLA-E 4-wire FIRE Red Wall P4RLA + BZR-F
P4RLA-F 4-wire FEU Red Wall P4RLA + BZR-FR
P4WLA 4-wire FIRE-FEU White Wall Still in production
P4WLA-E 4-wire FIRE White Wall P4WLA + BZW-F
P4WLA-F 4-wire FEU White Wall P4WLA + BZW-FR
PC2RLA[11] 2-wire FIRE-FEU Red Ceiling PC2RLED-B
PC2RLA-E 2-wire FIRE Red Ceiling PC2RLED
PC2RLA-F 2-wire FEU Red Ceiling PC2RLA + BZRC-FR
PC2WLA 2-wire FIRE-FEU White Ceiling PC2WLED-B
PC2WLA-E 2-wire FIRE White Ceiling PC2WLED
PC2WLA-F 2-wire FEU White Ceiling PC2WLA + BZWC-FR
PC4RLA 4-wire FIRE-FEU Red Ceiling Still in production
PC4RLA-E 4-wire FIRE Red Ceiling PC4RLA + BZRC-F
PC4RLA-F 4-wire FEU Red Ceiling PC4RLA + BZRC-FR
PC4WLA 4-wire FIRE-FEU White Ceiling Still in production
PC4WLA-E 4-wire FIRE White Ceiling Still in production
PC4WLA-F 4-wire FEU White Ceiling PC4WLA + BZWC-FR
UL xenon strobes
Model Number Strobe Color Marking Color Mounting Replaces Replaced By Current Replacement
SRL Clear FIRE Red Wall SR
SRH
XLSG1R-VM + XLSG1RT(-FIRE)
XLSG1RF-VM + XLSG1RT(-FIRE)
CWST-RW-S5
SRLED
CWST-RW-S5
SRLED
SRL-P Clear Plain Red Wall SR-P CWST-RW-S5
SRLED-P
CWST-RW-S5
SRLED-P
SRL-SP Clear FEGUO Red Wall SR-SP SRLED-SP SRLED-P
SGRL Clear FIRE Red Wall
Compact
XLSG1R-VM
XLSG1RF-VM
SGRLED SGRLED
SWL Clear FIRE White Wall SW
SWH
XLSG1-VM + XLSG1T(-FIRE)
XLSG1F-VM + XLSG1T(-FIRE)
CWST-WW-S5
SWLED
CWST-WW-S5
SWLED
SGWL Clear FIRE White Wall XLSG1-VM
XLSG1F-VM
SGWLED SGWLED
SWL-P Clear Plain White Wall SW-P
SWH-P
CWST-WW-S5
SWLED-P
CWST-WW-S5
SWLED-P
SWL-ALERT Amber ALERT White Wall SW-ALERT
SWH-ALERT
SWLED-ALERT SWLED-ALERT
SWL-CLR-ALERT Clear ALERT White Wall SW-CLR-ALERT SWLED-CLR-ALERT SWLED-CLR-ALERT
SCRL Clear FIRE Red Ceiling SCR
SCRH
SCRLED SCRLED
SCWL Clear FIRE White Ceiling SCW
SCWH
XLSGC-VM
XLSGCF-VM
XLSGC-VMH
XLSGCF-VMH
SCWLED SCWLED
SCWL-CLR-ALERT Clear ALERT White Ceiling SCW-CLR ALERT SCWLED-CLR-ALERT SCWLED-CLR-ALERT
ULC xenon strobes
Model Lens color Marking Color Mounting Replaced Replaced by
SRLA Clear FIRE-FEU Red Wall SRLED-B
SRLA-E Clear FIRE Red Wall SRLED
SRLA-F Clear FEU Red Wall SRLA + BZR-FR
SWLA Clear FIRE-FEU White Wall SWLED-B
SWLA-E Clear FIRE White Wall SWLED
SWLA-F Clear FEU White Wall SWLA + BZW-FR
SGRLA Clear FIRE-FEU Red Wall SGRLED-B
SGRLA-E Clear FIRE Red Wall SGRLED
SGRLA-F Clear FEU Red Wall SGRLA + BZGR-FR
SGWLA Clear FIRE-FEU White Wall SGWLED-B
SGWLA-E Clear FIRE White Wall SGWLED
SGWLA-F Clear FEU White Wall SGWLA + BZGW-FR
SRLA-P Clear None Red Wall SRLED-P
SWLA-P Clear None White Wall SWLED-P
SCRLA Clear FIRE-FEU Red Ceiling SCRLED-B
SCRLA-E Clear FIRE Red Ceiling SCRLED
SCRLA-F Clear FEU Red Ceiling SCRLA + BZRC-FR
SCWLA Clear FIRE-FEU White Ceiling SCWLED-B
SCWLA-E Clear FIRE White Ceiling SCWLED
SCWLA-F Clear FEU White Ceiling SCWLA + BZWC-FR
Model Number Color Size Location Listing Replaces
HRL Red Standard Indoor UL HR
XLSG1R-P + XLSG1RT(-FIRE)
XLSG1RF-P + XLSG1RT(-FIRE)
XLSG1R-HD + XLSG1RT(-FIRE)
XLSG1RF-HD + XLSG1RT(-FIRE)
HRLA Red Standard Indoor ULC
HWL White Standard Indoor UL HW
XLSG1-P + XLSG1T(-FIRE)
XLSG1F-P + XLSG1T(-FIRE)
XLSG1-HD + XLSG1T(-FIRE)
XLSG1F-HD + XLSG1T(-FIRE)
HWLA White Standard Indoor ULC
HGRL Red Compact Indoor UL XLSG1R-P
XLSG1RF-P
XLSG1R-HD
XLSG1RF-HD
HGRLA Red Compact Indoor ULC
HGWL White Compact Indoor UL XLSG1-P
XLSG1F-P
XLSG1-HD
XLSG1F-HD
HGWLA White Compact Indoor ULC
HGRKL Red Compact Outdoor UL/ULC HRK
HGRKL-B Red Compact Outdoor UL/ULC
UL xenon chime strobes
Model Number Color Mounting Replaces
CHSRL Red Wall CHSR
XLSG1R-CVM
XLSG1RF-CVM
CHSWL White Wall CHSW
XLSG1-CVM
XLSG1F-CVM
CHSCRL Red Ceiling N/A
CHSCWL White Ceiling N/A
ULC xenon chime strobes
Model Lettering Color Mounting Replaces Replaced by
CHSRLA[12] FIRE-FEU Red Wall
CHSRLA-E FIRE Red Wall CHSRLA + BZR-F
CHSRLA-F FEU Red Wall CHSRLA + BZR-FR
CHSWLA FIRE-FEU White Wall
CHSWLA-E FIRE White Wall CHSWLA + BZW-F
CHSWLA-F FEU White Wall CHSWLA + BZW-FR
CHSCRLA FIRE-FEU Red Ceiling
CHSCRLA-E FIRE Red Ceiling CHSCRLA + BZCR-F
CHSCRLA-F FEU Red Ceiling CHSCRLA + BZCR-FR
CHSCWLA FIRE-FEU White Ceiling
CHSCWLA-E FIRE White Ceiling CHSCWLA + BZCW-F
CHSCWLA-F FEU White Ceiling CHSCWLA + BZCW-FR
Chimes
Model Color Listing Replaces
CHRL Red UL CHR
XLSG1R-C
XLSG1RF-C
CHWL White UL CHW
XLSG1-C
XLSG1F-C
CHRLA Red ULC
CHWLA White ULC
UL xenon speaker strobes
Model Number Strobe Color Marking Color Mounting Replaces Replaced by
SPSRL Clear FIRE Red Wall SPSR
SPSRH
SPSRV
XLSG4R-S2VM
XLSG4R-S7VM
XLSG4RF-S2VM
XLSG4RF-S7VM
SPSRLED
SPSRL-P Clear Plain Red Wall SPSR-P SPSRLED-P
SPSRL-SP Clear FEGUO Red Wall SPSR-SP SPSRLED-SP
SPSWL Clear FIRE White Wall SPSW
SPSWH
SPSWV
XLSG4-S2VM
XLSG4-S7VM
XLSG4F-S2VM
XLSG4F-S7VM
SPSWLED
SPSWL-P Clear Plain White Wall SPSW-P
SPSWH-P
SPSWLED-P
SPSWL-ALERT Amber ALERT White Wall SPSW-ALERT SPSWLED-ALERT
SPSWL-CLR-ALERT Clear ALERT White Wall SPSW-CLR-ALERT SPSWLED-CLR-ALERT
SPSCRL Clear FIRE Red Ceiling SPSCR,
SPSCRH, SPSCRV, SPSCRVH
SPSCRLED
SPSCWL Clear FIRE White Ceiling SPSCW
SPSCWH
SPSCWV
SPSCWVH
XLSGC-S2VM
XLSGC-S7VM
XLSGCF-S2VM
XLSGCF-S7VM
XLSGC-S2VMH
XLSGC-S7VMH
XLSGCF-S2VMH
XLSGCF-S7VMH
SPSCWLED
SPSCWL-P Clear Plain White Ceiling SPSCW-P
SPSCWH-P SPSCWV-P
SPSCWLED-P
SPSCWL-SP Clear FEUGO White Ceiling N/A SPSCWLED-SP
SPSCWL-CLR-ALERT Clear ALERT White Ceiling SPSCW-CLR-ALERT SPSCWLED-CLR-ALERT
ULC xenon speaker strobes
Model Strobe color Marking Color Mounting Replaced Replaced by
SPSCWLA[13] Clear FIRE-FEU White Ceiling SPSCWLED-B
SPSCWLED-BT (with TRCWLA-10)
SPSCWLED-P (with BZSPWC-P)
SPSCWLED-TP (with BZSPWC-P + TRCWLA-10)
SPSCWLA-E Clear FIRE White Ceiling SPSCWLED
SPSCWLED-T (with TRCWLA-10)
SPSCWLA-F Clear FEU White Ceiling SPSCWLA + BZSPWC-FR
SPSCRLA Clear FIRE-FEU Red Ceiling SPSCRLED-B
SPSCRLED (with BZSPRC-F)
SPSCRLED-BT (with TRCRLA-10)
SPSCRLA-E Clear FIRE Red Ceiling SPSCRLA + BZSPRC-F
SPSCRLA-F Clear FEU Red Ceiling SPSCRLA + BZSPRC-FR
SPSCWLA-T Clear FIRE-FEU White Ceiling SPSCWLA + TRCWLA-10
SPSCRLA-T Clear FIRE-FEU Red Ceiling SPSCRLA + TRCRLA-10
SPSCWLA-TE Clear FIRE White Ceiling SPSCWLA-E + TRCWLA-10
SPSCRLA-TE Clear FIRE Red Ceiling SPSCRLA + BZSPRC-F + TRCRLA-10
SPSCWLA-TF Clear FEU White Ceiling SPSCWLA + BZSPWC-FR + TRCWLA-10
SPSCRLA-TF Clear FEU Red Ceiling SPSCRLA + BZSPRC-FR + TRCRLA-10
SPSCWLA-P Clear None White Ceiling SPSCWLA + BZSPWC-P
SPSCWLA-TP Clear None White Ceiling SPSCWLA + BZSPWC-P + TRCWLA-10
SPSWLA[14] Clear FIRE-FEU White Wall SPSWLED-B
SPSWLA-E Clear FIRE White Wall SPSWLED
SPSWLA-F Clear FEU White Wall SPSWLA + BZSPW-FR
SPSRLA Clear FIRE-FEU Red Wall SPSRLED-B
SPSRLED (with BZSPR-F)
SPSRLA-E Clear FIRE Red Wall SPSRLA + BZSPR-F
SPSRLA-F Clear FEU Red Wall SPSRLA + BZSPR-FR
SPSWLA-P Clear None White Wall SPSWLED-P
SPSRLA-P Clear None Red Wall SPSRLED-P
Model Number Color Mounting Listing Replaces
SPRL Red Wall UL SPR
SPRV
XLSG4R-S2
XLSG4R-S7
XLSG4RF-S2
XLSG4RF-S7
SPWL White Wall UL SPW
SPWV
XLSG4-S2
XLSG4-S7
XLSG4F-S2
XLSG4F-S7
SPCRL Red Wall UL SPCR
SPCRV
SPCWL White Wall UL SPCW
SPCWV
XLSGC-S2
XLSGC-S7
XLSGCF-S2
XLSGCF-S7
SPCWLA White Ceiling ULC
SPCRLA Red Ceiling ULC
SPCWLA-T White Ceiling ULC
SPCRLA-T Red Ceiling ULC
SPWLA White Wall ULC
SPRLA Red Wall ULC
UL low frequency sounders
HRL-LF Sounder Plain Red Wall HR-LF
HWL-LF Sounder Plain White Wall HW-LF
HGRL-LF Sounder Plain Red Wall
Compact
N/A
HGWL-LF Sounder Plain White Wall
Compact
N/A
HCRL-LF Sounder Plain Red Ceiling N/A
HCWL-LF Sounder Plain White Ceiling N/A
P2RL-LF Sounder Strobe FIRE Red Wall P2RH-LF
P2WL-LF Sounder Strobe FIRE White Wall P2WH-LF
PC2RL-LF Sounder Strobe FIRE White Ceiling N/A
PC2WL-LF Sounder Strobe FIRE White Ceiling N/A
ULC low frequency sounders
Model Type Marking Color Mounting Hush function? Replaced
HRLA-LF[15] Sounder None Red Wall No
HWLA-LF Sounder None White Wall No
HGRLZA-LF Sounder None Red Wall
Compact
Yes
HGWLZA-LF Sounder None White Wall
Compact
Yes
HCRLA-LF Sounder None Red Ceiling No
HCWLA-LF Sounder None White Ceiling No
P2RLA-LF Sounder strobe Red Wall No
P2WLA-LF Sounder strobe White Wall No
PC2RLA-LF Sounder strobe Red Ceiling No
PC2WLA-LF Sounder strobe White Ceiling No
UL strobe expander plates
Model Number Comes with Replaces
SEP-SPSWL SWL-ALERT (2018-2023)
SWLED-ALERT (2023-Present)
SEP-SW
SEP-SPSW
SEP-SPSWL-P SWL-P (2018-2023)
SWLED-P (2023-Present)
SEP-SPSW-P
SEP-SW-P
UL ceiling tile devices
SCWL-TILE Strobe
SPSWL-TILE Speaker Strobes
SPWL-TILE Speaker
PC2WLED (Ceiling Mount, White)
LED horn strobes
Model Number Type of Device Marking Color Mounting Location Replaces
P2RLED 2 Wire Horn Strobe FIRE Red Wall Indoor P2RL
P2RLA-E
P2RLED-B 2 Wire Horn Strobe FIRE-FEU Red Wall Indoor P2RLA
P2RLED-P 2 Wire Horn Strobe Plain Red Wall Indoor P2RL-P
P2RLA-P
P2RLED-SP 2 Wire Horn Strobe FEGUO Red Wall Indoor P2RL-SP
P2GRLED 2 Wire Horn Strobe FIRE Red Wall
Compact
Indoor P2GRL
P2GRLA + BZGR-F
P2GRLED-B 2 Wire Horn Strobe FIRE-FEU Red Wall
Compact
Indoor P2GRLA
P2WLED 2 Wire Horn Strobe FIRE White Wall Indoor P2WL
P2WLA-E
P2WLED-B 2 Wire Horn Strobe FIRE-FEU White Wall Indoor P2WLA
P2WLED-P 2 Wire Horn Strobe Plain White Wall Indoor P2WL-P
P2WLA-P
P2WLED-SP 2 Wire Horn Strobe FEGUO White Wall Indoor P2WL-SP
P2GWLED 2 Wire Horn Strobe FIRE White Wall
Compact
Indoor P2GWL
P2GWLA + BZGW-F
P2GWLED-B 2 Wire Horn Strobe FIRE-FEU White Wall
Compact
Indoor P2GWLA
PC2RLED 2 Wire Horn Strobe FIRE Red Ceiling Indoor PC2RL
PC2RLA-E
PC2RLED-B 2 Wire Horn Strobe FIRE-FEU Red Ceiling Indoor PC2RLA
PC2WLED 2 Wire Horn Strobe FIRE White Ceiling Indoor PC2WL
PC2WLA-E
PC2WLED-B 2 Wire Horn Strobe FIRE-FEU White Ceiling Indoor PC2WLA
P2GRKLED 2 Wire Horn Strobe FIRE Red Wall Outdoor P2RK
P2RHK
P2GRKLED-P 2 Wire Horn Strobe Plain Red Wall Outdoor P2RK-P
P2RHK-P
P2GWKLED 2 Wire Horn Strobe FIRE White Wall Outdoor P2WK
P2WHK
P2GWKLED-P 2 Wire Horn Strobe Plain White Wall Outdoor P2WK-P
P2WHK-P
PC2RKLED 2 Wire Horn Strobe FIRE Red Ceiling Outdoor PC2RK
PC2RHK
PC2RKLED-P 2 Wire Horn Strobe Plain Red Ceiling Outdoor None
PC2WKLED 2 Wire Horn Strobe FIRE White Ceiling Outdoor PC2WK
PC2WHK
PC2WKLED-P 2 Wire Horn Strobe Plain White Ceiling Outdoor None
LED strobes
SRLED (Strobe Only, Red)
Model Number Strobe Color Marking Color Mounting Location Replaces
SRLED Clear FIRE Red Wall Indoor SRL
SRLA-E
SRLED-B Clear FIRE-FEU Red Wall Indoor SRLA
SRLED-P Clear Plain Red Wall Indoor SRL-P
SRLA-P
SRLED-SP Clear FEGUO Red Wall Indoor SRL-SP
SGRLED Clear FIRE Red Wall
Compact
Indoor SGRL
SGRLA-E
SGRLED-B Clear FIRE-FEU Red Wall
Compact
Indoor SGRLA
SWLED Clear FIRE White Wall Indoor SWL
SWLA-E
SWLED-B Clear FIRE-FEU White Wall Indoor SWLA
SGWLED Clear FIRE White Wall Indoor SGWL
SGWLA-E
SGWLED-B Clear FIRE-FEU White Wall Indoor SGWLA
SWLED-P Clear Plain White Wall Indoor SWL-P
SWLA-P
SWLED-ALERT Amber ALERT White Wall Indoor SWL-ALERT
SWLED-CLR-ALERT Clear ALERT White Wall Indoor SWL-CLR-ALERT
SCRLED Clear FIRE Red Ceiling Indoor SCRL
SCRLA-E
SCRLED-B Clear FIRE-FEU Red Ceiling Indoor SCRLA
SCWLED Clear FIRE White Ceiling Indoor SCWL
SCWLA-E
SCWLED-B Clear FIRE-FEU White Ceiling Indoor SCWLA
SCWLED-CLR-ALERT Clear ALERT White Ceiling Indoor SCWL-CLR-ALERT
SGRKLED Clear FIRE Red Wall Outdoor SRK
SRHK
SGRKLED-P Clear Plain Red Wall Outdoor SRK-P
SRHK-P
SGWKLED Clear FIRE White Wall Outdoor SWK
SWHK
SGWKLED-P Clear Plain White Wall Outdoor SWK-P
SWHK-P
SCRKLED Clear FIRE Red Ceiling Outdoor SCRK
SCRHK
SCRKLED-P Clear Plain Red Ceiling Outdoor None
SCWKLED Clear FIRE White Ceiling Outdoor SCWK
SCWHK
SCWKLED-P Clear Plain White Ceiling Outdoor None
LED speaker strobes
SPSCRLED Clear FIRE Red Ceiling SPSCRL
SPSCRLA + BZSPRC-F
SPSCRLED-B Clear FIRE-FEU Red Ceiling SPSCRLA
SPSCRLED-BT Clear FIRE-FEU Red Ceiling SPSCRLA + TRCRLA-10
SPSCWLED-CLR-ALERT Clear ALERT White Ceiling SPSCWL-CLR-ALERT
SPSCWLED Clear FIRE White Ceiling SPSCWL
SPSCWLA-E
SPSCWLED-T Clear FIRE White Ceiling SPSCWLA-E + TRCWLA-10
SPSCWLED-B Clear FIRE-FEU White Ceiling SPSCWLA
SPSCWLED-BT Clear FIRE-FEU White Ceiling SPSCWLA + TRCWLA-10
SPSCWLED-SP Clear FUEGO White Ceiling SPSCWL-SP
SPSCWLED-P Clear Plain White Ceiling SPSCWL-P
SPSCWLA + BZSPWC-P
SPSCWLED-TP Clear Plain White Ceiling SPSCWLA + BZSPWC-P + TRCWLA-10
SPSRLED Clear FIRE Red Wall SPSRL
SPSRLA + BZSPR-F
SPSRLED-B Clear FIRE-FEU Red Wall SPSRLA
SPSRLED-SP Clear FUEGO Red Wall SPSRL-SP
SPSRLED-P Clear Plain Red Wall SPSRL-P
SPSRLA-P
SPSWLED-CLR-ALERT Clear ALERT White Wall SPSWL-CLR-ALERT
SPSWLED-ALERT Amber ALERT White Wall SPSWL-ALERT
SPSWLED Clear FIRE White Wall SPSWL
SPSWLA-E
SPSWLED-B Clear FIRE-FEU White Wall SPSWLA
SPSWLED-P Clear Plain White Wall SPSWL-P
SPSWLA-P
Second generation low frequency sounders
HRL2-LF[16] Sounder None Red Wall
HWL2-LF Sounder None White Wall
HGRL2-LF Sounder None Red Compact wall
HGWL2-LF Sounder None White Compact wall
HCRL2-LF Sounder None Red Ceiling
HCWL2-LF Sounder None White Ceiling
P2RLED-LF Sounder strobe FIRE Red Wall
P2WLED-LF Sounder strobe FIRE White Wall
PC2RLED-LF Sounder strobe FIRE Red Ceiling
PC2WLED-LF Sounder strobe FIRE White Ceiling
Recalls
When System Sensor first launched their Xenon strobe L-Series with the Speaker and Speaker Strobe models SPRL through SPSCWLA-TP which goes from it's first launch date until August 8 of that year. It was discovered on September of that year that System Sensor noticed there had a problem with their bases not maintaining a proper electrical connection and being too flexible and warped. The Consumer Product Safety Commission was not involved in this one since it was only issued out by the company themselves and was quickly resolved by changing the bases that needed to be mounted on the Speakers and Speaker Strobes. [17]
On March 11 of 2024 Honeywell has put out a recall this time with the Consumer Product Safety Commission because the low frequency sounders including the strobe variants has been found to not be able to put out the sound that is required by the NFPA either being too quiet or not being able to make any noise at all. This seems to only affect the date codes of 3034 and 3035 although it is unsure if this will affect the new LED L-Series models as well since it doesn't affect the Xenon strobes to have any problems. This recall was announced by the Consumer Product Safety Commission 3 days later. [18]
  1. https://www.securityandfire.honeywell.com/notifier/en-us/news/Articles/new-system-sensor-l-series-indoor-notification-devices-now-available
  2. 2.0 2.1 2.2 https://buildings.honeywell.com/content/dam/hbtbt/en/documents/downloads/System-Sensor-L-Series-LED-Announcement-23.2SS.pdf
  3. https://web.archive.org/web/20190227175320/https://www.systemsensor.com/en-us/Pages/welcome.aspx
  4. https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/notices-and-notifications/product-bulletins/System%2520Sensor%2520Canadian%2520AV%2520Markings%2520Discontinuation.pdf
  5. Future of Building Communications: AV with LED Strobes https://www.securityandfire.honeywell.com/en/-/media//Files/Confernce/Future%20of%20Building%20Communications%20AV%20with%20LED%20Strobes
  6. https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/notices-and-notifications/product-bulletins/notifier-aus/ba-fire-PB23-014-SpectrAlert-Range-Discontinuance-Notice.pdf?download=false
  7. Product Announcement:  L-Series with LED Notification Appliances - October 2023 - Bulletin M23.2SS https://buildings.honeywell.com/content/dam/hbtbt/en/documents/downloads/System-Sensor-L-Series-LED-Announcement-23.2SS.pdf
  8. https://cdn.adiglobaldistribution.us/pim/Original/10181/BK-SPSWLED_Product-Data-Sheet.pdf
  9. https://forums.thefirepanel.com/t/new-led-system-sensor-l-series/10219/203
  10. "Indoor Selectable-Output Horns, Strobes, and Horn Strobes for Wall Applications" (AVDS884-02). System Sensor (12/01/2017).
  11. "Indoor Selectable-Output Strobes and Horn Strobes for Ceiling Applications" (AVSD88501). System Sensor (March 2017).
  12. "Selectable Output Chimes and Chime/Strobes" (AVDS88301). System Sensor (March 2017).
  13. "Indoor Selectable-Output Speaker Strobes and Dual Voltage Evacuation Speakers for Ceiling Applications" (AVDS89301). System Sensor (June 28, 2017).
  14. "Indoor Selectable-Output Speaker Strobes and Dual Voltage Evacuation Speakers for Wall Applications" (AVDS894-02). System Sensor (March 23, 2018).
  15. "L-Series Low Frequency Sounders and Sounder Strobes" (DN-62011:E). Notifier (March 10, 2021).
  16. "L-Series Low Frequency Sounders and L-Series with LED Low Frequency Sounder Strobes" (AVDS-62202). System Sensor (10/23/2025).
  17. https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/notices-and-notifications/safety-bulletins/FINAL-NOTICE-COC_SS-Safety-Bulletin_L-Series-Speakers-Speaker-Strobes.pdf
  18. https://www.cpsc.gov/Recalls/2024/Honeywell-Recalls-System-Sensor-L-Series-Low-Frequency-Fire-Alarm-Sounders-and-Strobes-Due-to-Risk-of-Failure-to-Alert-Consumers-to-a-Fire
