| Founded |
1984
| Headquarters |
St. Charles, Illinois, USA
| Parent company | |
| Links |
"title": "System Sensor",
"System-sensor logo.svg"
System Sensor is an American manufacturer of fire protection equipment. Headquartered in St. Charles, Illinois, System Sensor is a subsidiary of Honeywell International. System Sensor develops and distributes fire alarm devices such as notification appliances, fire detectors, manual initiating devices (pull stations and call points), CO detectors, and other fire protection devices for multiple markets across the globe, and for other Honeywell companies.
System Sensor was founded in 1984 as a division of BRK responsible for the 800 series system smoke detectors.[1] In 1987, System Sensor began producing the Multi-Alert sounders, which were multi-tone devices that came in different variants such as a horn/strobe. The PA400 was a mini horn released around this time. System Sensor also released the 400 series detectors around this time.
Between 1990 and 1991, the System Sensor brand was moved to Pittway Corporation.[2][3] System Sensor later updated their notification appliances with ADA-complaint strobes. Starting in 1997, the notification appliances was replaced with the SpectrAlert series. In the 2000’s, System Sensor was acquired from Pittway by Honeywell International. Around this time, System Sensor introduced the i3 line of smoke detectors. In 2006, the original SpectrAlert series were replaced with the SpectrAlert Advance. In 2017, the System Sensor L-Series was released. All SpectrAlert Advance products, expect for the outdoor models and mini horns, were discontinued by February 2020. In October of 2023, System Sensor announced the LED L series. The original L-Series was discontinued in December of 2023. Some L-Series low frequency sounders have been recalled on March 14, 2024.[4]
System Sensor producing devices for other brands
System Sensor produces addressable detectors and modules for many other Honeywell and non-Honeywell brands across the globe. They produce devices for Honeywell brands such as Notifier, Fire-Lite, Gamewell-FCI, Silent Knight, and Honeywell. In Europe they produce devices for Notifier, Morley-IAS, and Honeywell. KAC Alarm Company also produces System Sensor equipment. Some non-Honeywell brands also use System Sensor equipment, such as Mircom and Monaco Enterprises. In Europe, System Sensor also produces devices for non-Honeywell brands like Esmi (Schneider Electric), Chubb and LST (Labour Strauss). Pertronic in Australia/New Zealand use System Sensor equipment as well. Some companies that formerly used System Sensor equipment include Edwards (FAST), Harrington Signal (Now Potter), Spectronics and Johnson Controls.
[5]Products
Notification Appliances
MASS Series (discontinued)
The MASS was multi-tone and came in remote horn and horn strobe models as well as remote strobe models, and speaker strobes and remote speakers. The MASS series was originally sold under BRK Electronics and later under System Sensor. It featured a xenon flash tube housed under a translucent white plastic (Dubbed "Frosted Strobes" by enthusiasts). The original MASS series used break off tabs to change the tone meaning that once the tone is changed, it is permanent. The MASS series was later on updated to use jumpers rather than break off tabs. In 1993, System Sensor filed a patent for a new strobe that was ADA compliant. It featured a clear lens and a reflector to distribute the light as well as higher candela options, the minimum being 15 candela. Soon after, System Sensor implemented the ADA-complaint strobe. In 1997, the MASS was replaced by the SpectrAlert series.
PA400 Series (discontinued)
The System Sensor PA400 was a mini horn, with an optional strobe attachment. In 2007, the PA400 series was discontinued and replaced with the MH series sold under the SpectrAlert Advance name.
SpectrAlert Series (discontinued)
The SpectrAlert series was the successor to the MASS series. The SpectrAlert series included horn strobes, strobes, remote horns, chimes, chime strobes, speakers, and speaker strobes. A main feature of these alarms was the ability to sync them using a System Sensor MDL sync module or the System Sensor sync protocol on a supported fire alarm control panel. Three years after the initial release of the SpectrAlert series, System Sensor released the ceiling mount SpectrAlerts. This included horn strobes, remote strobes, speaker strobes, and remote speakers. There were multiple generations of the SpectrAlert. The first generation had a screw lock. The second generation, released in the early 2000s, replaced the screw lock with a clip lock. Approximately before 2006, the third generation was released with multi-candela strobes, and replaced the jumpers for the horn tone with DIP switches. In 2006, the original SpectrAlert series were replaced with the SpectrAlert Advance. A few years after the discontinuation of the SpectrAlert series, fire alarm enthusiasts dubbed the SpectrAlert series as "SpectrAlert Classic" indicating that it is the original SpectrAlert line of fire alarm products. The term became popular and is now being used by most fire alarm enthusiasts today.
SpectrAlert Advance Series (mostly discontinued)
The SpectrAlert Advance was introduced in 2006 to replace the legacy SpectrAlerts. Its main features were an updated mounting plate wiring design, allowing for easier installation, more candela options, and an updated design. The Advance came in the same models as the original SpectrAlert, with the addition of mini horns, and Low-frequency sounders, which were released in 2014. In 2017, the L-Series was released to replace the SpectrAlert Advance Series. All SpectrAlert Advance products, except for the outdoor models and mini horns, were discontinued by February 2020. The RK series outdoor SpectrAlert Advances were discontinued with the release of the outdoor L-Series LED P2GRKLED in 2024.
L-Series (mostly discontinued)
In 2017, the System Sensor L-Series was released, replacing the SpectrAlert Advance series. New features included a new 3000 hertz tone, more candela options, lower power draw, and an updated design. The low frequency devices were released in 2018. The new low frequency devices had Temporal 4 for Carbon Monoxide (CO) operations. In October of 2023, System Sensor announced the release of a new LED L series that uses lower current draw, which would replace the Xenon L-Series devices. After the announcement of the LED L-Series, the xenon L-Series was offered until December 15th, 2023[6], when it was considered discontinued by Honeywell. However, multiple fire alarm distributor stores carried new xenon L-Series up until around late 2024 when stock started switching over to LED, but even up to now some fire alarm installers still install new buildings with the legacy product as of this editing.
L-Series LED
In October of 2023, System Sensor announced the release of a new LED L series that uses lower current draw to replace the Xenon L-Series devices.
Detection Devices (Conventional)
400 Series (Discontinued)
In the 1990’s System Sensor introduced a line of smoke detectors including the System Sensor 1400 2-wire Ionization detector and the 2400 2-wire Photoelectric detector.
100 Series (Partially discontinued)
In the mid 1990's, System Sensor introduced the 100 series of detectors. Most common models of them are the 2100, 2151 and the 1151. The model numbers with the "51" postfix means it is base wired and uses bases similar to addressable System Sensor detectors. They also have 2 designs, one from the mid 1990's to around 2003 and one from 2003 which looks similar to the Fire-Lite 355 series.
i3 Series
In the 2000’s, System Sensor introduced the i3 line of smoke detectors, which came in 2 and 4 wire models. These devices have a feature which they will poll with the fire alarm panel when the sensor is dirty, causing a trouble condition on the panel. There are also version's with a heat element and a piezoelectric sounder incorporated in the detector.
Detection Devices (Addressable)
500 Series (Discontinued)
Addressable version of the 400 series. The detectors come in optical (2551), heat (5551), ionization (1551) and optical/heat (2551T) variants. Most versions are base wired. That is indicated with the 51 in the end of the model number. This series came out in the late 80's and got discontinued in the mid 1990's.
200 Series (1st generation) (Partially Discontinued)
This series is still produced today after almost 30 years since it was introduced but came in multiple designs. The first version was just the 2251 and came out in the mid 90's but got discontinued in 2003. Variants of this generation include:
- Optical (2251)
- Ionization (1151)
- Heat (5251)
- Photo-heat (2251T)
- Laser (7251)
- Multi-sensor with heat, optical, IR and CO (2251-COPTIR/2251-CTL)
- Spot type aspirating detector (filtrex/harsh) (FTX-P1)
- And supposedly an optical-ion-heat multi sensor (notifier model IPX-751).
Most of these detectors run on CLIP only but all detectors have version's to run on advanced protocol (System Sensor's name for FlashScan like protocol). Most common variant of these which run advance protocol are the 2251CTL and 2251COPTIR which are still produced today.
200 Series (2nd generation/generation b) (Discontinued)
After 2003, the first generation was discontinued and a new design was made (similar to Fire-Lite SD355 series). This series was discontinued somewhere around 2020. This is also the first series to fully have advanced protocol even though clip versions exist. They came with these variants:
- Optical (2251B)
- Ionization (1251B)
- Heat (5251B)
- Optical/heat (2251TB)
- Smart optical/heat Multi-sensor (ADAPT)
200/300 Series (3rd generation/generation c/b)
After 2020 system sensor discontinued the generation b and introduced a new generation. This series is either referred to as 2351B or 2251C. In this part they will be referred as both. They come in
- Optical (2351B/2251C)
- Heat (5351B/5251C)
- Laser (73512B/7251C)
- Optical/Heat (2351TB/2251CT)
variants. They also supposedly should have
- Photo/heat/Ir Multi-sensor (Notifier model FPTI-951)
- Photo/Heat/IR/CO Multi-sensor (Notifier model FCO-951)
- Photo/Co Multi-sensor (Notifier model FPC-951)
- Co detector (Notifier model FSCO-951).
This is the first series which come standard in advanced protocol and needs a special model to work with clip systems. The clip possible models is identified with an IV in the model.
Addressable modules
System Sensor produces addressable modules like contact monitor modules, zone monitor modules, relay modules, control modules, mains switching relay module's and more for fire systems. These are for to integrate a conventional zone or switch like a sprinkler flow switch to work on an addressable system or turn off or on a fan in case of a fire. There were three generations of these modules all under the M500 series. 1st generation was from the late 1980's to mid 1990's, 2nd generation was from the mid 1990's to mid 2000's. This is the first series to have the advanced protocol. The next generation was from the mid 2000's and is still in production today.
[7]European Products (addressable)
System Sensor does produce detectors for the European market along with KAC Alarm Company. European System Sensor products used to be really similar to the American counterparts until the Mid-2000's when Honeywell fully took over Pittway. This section will also include KAC products as they are the same.
Sounders
Yes, System Sensor does make addressable loop powered sounders which are easy to program on the panel. System Sensor had 3 series of sounders. The names of these series aren't listed on the internet so we'll classify them differently than it actually might be.
KAC addressable sounders (mid 1990s - early 2000's)
This series is the first series of addressable sounders that System Sensor/KAC made (Pittway). These run CLIP only and the strobes have xenon tubes instead of LEDs. Variants include: sounders, sounder strobes, strobes, sounder bases.
System Sensor addressable sounders (early 2000's - mid 2010's)
This is the second line of System Sensor addressable sounders. These were from the point when Honeywell took over System Sensor entirely. These can run advanced protocol even though the detectors and module at the time were CLIP only. Variants include: sounders, sounder strobes, strobes, sounder bases, strobe bases, sounder strobe bases. These were mounted with special base.
NFXI (Notifier Term) range (Mid 2010's)
This is the 3rd range of addressable sounders. Came out in the time that advanced/opal (opal is European Notifier FlashScan equivalent) stuff were produced more. Variants include: sounders, sounder strobes, strobes, sounder bases, strobe bases, sounder strobe bases. These were mounted on a standard B501 detector base. These also use Notifier rotary address dials like system sensor/notifier detectors unlike the previous ranges just used small potentiometer.
Detectors
500E Series (Discontinued)
Same as the American counterparts but has an "E" or "EN" in the model number. Example: 5251E
200E Series (Partially Discontinued)
Europe only used the first style of detectors. Same as the American counterparts but has an "E" or "EN" in the model number. Example 2251E. There is no advanced protocol version. Only detectors not in that series here is the "Filtrex" detector. Notifier has a European counter part instead of System Sensor. Model for that is the HPX-751.
2000E Series
This series in not used in the US. Comes with the possibility to have advanced protocol running on it. Variants include:
- Optical (22051E)
- Heat (52051E)
- Photo/Heat (22051TE)
- Photo/Heat/IR Multi-Sensor (22051TLE)
Modules
System Sensor produces addressable modules like contact monitor modules, zone monitor modules, relay modules, control modules, mains switching relay modules and more for fire systems. These are for to integrate a conventional zone or switch like a sprinkler flow switch to work on an addressable system or turn off or on a fan in case of a fire. There were 2 generations with the second having 2 styles.
M500 Series (mid 90s-Mid 2000s)
- European model defined with "E" suffix in model number
- Same design as the Notifier MX series (Example CMX-1)
- Almost completely discontinued except Mini Mods (M501ME/M501MEA) and call points (MCP5A/M5A).
M200 Series
- Different design then the American counter parts.
- Originally came clip only but now has advanced protocol.
- Has multiple ways of mounting like a single module box, 6 module box and din rail mounting.
- Has a new updated design which comes only in advanced protocol unlike the older design which came standard in clip.
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_4aa4d521-f84e-4ef4-8308-588221a0b171/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_d795ea61-7a8c-4316-8447-9f21a585348d/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_94048b31-e022-4bba-9dfd-49dac83371b6/
- ↑ https://www.cpsc.gov/Recalls/2024/Honeywell-Recalls-System-Sensor-L-Series-Low-Frequency-Fire-Alarm-Sounders-and-Strobes-Due-to-Risk-of-Failure-to-Alert-Consumers-to-a-Fire
- ↑ https://buildings.honeywell.com/us/en/brands/our-brands/system-sensor/products
- ↑ https://buildings.honeywell.com/content/dam/hbtbt/en/documents/downloads/System-Sensor-L-Series-LED-Announcement-23.2SS.pdf
- ↑ https://systemsensoreurope.com/products/
