BRK 800 series
BRK |
1978
BRK 700 series
System Sensor 400 series
"title": "800 series",
The BRK 800 series was a series of smoke alarms and conventional system smoke detectors. The system smoke detectors are also known under the System Sensor brand name.
The 800 series was introduced in 1978 with low-current 4-wire ionization smoke detectors.[1] The 2851 was introduced in 1982 as an alternative to the 2751 without field-adjustable sensitivity, and the 2800 was introduced at the same time.[2]
In 1984, the System Sensor division of BRK formed and became responsible for the 800 series system smoke detectors. Around this time, duct detectors were introduced.[3]
| Model | Wiring | Sensor polarity | Voltage | Replaced | Replaced by |
| 806 | 4-wire | Bipolar | 6 VDC | 1806 | |
| 812 | 4-wire | Bipolar | 12 VDC | 1812 | |
| 824 | 4-wire | Bipolar | 24 VDC | 1824 | |
| 1800[4] | 2-wire | Unipolar | 1400 | ||
| 1806[5] | 4-wire | Unipolar | 6 VDC | 806 | None |
| 1812 | 4-wire | Unipolar | 12 VDC | 812 | 1412 |
| 1824 | 4-wire | Unipolar | 24 VDC | 824 | 1424 |
| 1851B[6] | Plug-in | Unipolar | 1751 | 1451 | |
| 1851DH[7] | Plug-in | Unipolar | 24 VDC & 120 VAC | 1451DH |
| Model | Wiring | Voltage | Heat sensor? | Replaced | Replaced by |
| 2800[8] | 2-wire | No | 2400 | ||
| 2800TH | 2-wire | Yes | 2400TH | ||
| 2806[9] | 4-wire | 6 VDC | No | None | |
| 2806TH | 4-wire | 6 VDC | Yes | None | |
| 2812 | 4-wire | 12 VDC | No | 2412 | |
| 2812TH | 4-wire | 12 VDC | Yes | 2412TH | |
| 2824 | 4-wire | 24 VDC | No | 2424 | |
| 2824TH | 4-wire | 24 VDC | Yes | 2424TH | |
| 2851 | Plug-in | No | 2751 | 2851B | |
| 2851B[10] | Plug-in | No | 2851 | 2451 | |
| 2851BTH | Plug-in | Yes | 3751 | 2451TH | |
| 2851DH | Plug-in | 24 VDC & 120 VAC | No | 2451 |
Duct detectors
| Model | Wiring | Voltage | Type | Replaced | Replaced by |
| DH1851AC | 4-wire | 120 VAC | Ionization | DH400ACDCI | |
| DH1851DC | 2-wire | 24 VDC | Ionization | DH400I DH400ACDCI (with AR-10) | |
| DH2851AC | 4-wire | 120 VAC | Photoelectric | DH400ACDCP | |
| DH2851DC | 2-wire | 24 VDC | Photoelectric | DH400P DH400ACDCP (with AR-10) |
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_9fd5aafc-4b64-4824-ada2-13f7d81dfbcb/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_38b4472f-1936-4fa4-97f0-36768f0803b5/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_4aa4d521-f84e-4ef4-8308-588221a0b171/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_d044a81b-9880-4ca9-b8af-8ae9972ffe82/
- ↑ "1800 Series 4/6 Wire Systems Detectors" (C1806—12—24). BRK Electronics System Sensor Division (June 1985).
- ↑ "1851B 2/4/6-Wire Systems Detectors" (C1851B). BRK Electronics System Sensor Division (December 1985).
- ↑ "DH1851/2851 Series Duct Detectors" (CDH851). BRK Electronics System Sensor Division (July 1985).
- ↑ "2800 Series 2-Wire Systems Detectors" (C2800). BRK Electronics System Sensor Division (September 1985).
- ↑ "2800 Series 4/6 Wire Systems Detectors" (C2806-12-24). BRK Electronics System Sensor Division (March 1985).
- ↑ "2851B Series 2/4/6-Wire Systems Detectors" (C2851B). BRK Electronics System Sensor Division (December 1985).
