System Sensor 500 series
500 series
System Sensor 200 series {"label": "Succeeded by", "field": "System Sensor 200 series"}
The System Sensor 500 series is a series of addressable detectors and modules.
The 500 series was introduced in 1987 together with the 400 series and Fire-Lite AM 2020 (more commonly known under the Notifier brand).
In 1992, System Sensor introduced the M500X isolator module.[1]
In 1999, the 1551B and 2551HR were designated exclusively for duct use, and the remaining detectors were discontinued and replaced with 200 series equivalents.[2][3] The address selection dials on the modules were also updated at this time to provide space for extended addressing, and the M500CH was replaced with separate M500R and M500S modules depending on whether supervision was required.
The 1551B/2551HR detectors and DH500 duct housings were discontinued around 2000 due to the release of the Innovair duct detectors.
In 2017, the module faceplates were updated to a bright white color, similar to the white L-Series devices. Replacement faceplates in both white and ivory were provided for retrofit applications.[4]
Model Listing Replaced by
1551B[5] UL 1251
1551AB ULC
Model Heat sensor? Listing Replaced by
2551HR No UL 2251
2551AHR No ULC
2551THR Yes UL 2251T
2551TAHR Yes ULC
Model Type Listing Replaced by
5551B Fixed temperature UL 5251P
5551AB Fixed temperature ULC
5551R Rate-of-rise UL 5251RP
5551RA Rate-of-rise ULC
Detector bases
Model Flanges? Auxiliary function Listing Replaced by
B501 No None UL/ULC B501-IV
B501B Yes None UL/ULC B210LP
B524RB Yes Relay UL B224RB
B524RBA Yes Relay ULC
B524BI Yes Isolator UL B224BI
B524BIA Yes Isolator ULC
B501BH No Sounder UL B200SR
B501BHA No Sounder ULC B200SR
B501BHT[6] Temporal sounder UL B200SR
B501BHTA Temporal sounder ULC B200SR
B501BH-2 Sounder UL B200SR
B501BH-2A Sounder ULC B200SR
B501BHT-2 Temporal sounder UL B200SR
B501BHT-2A Temporal sounder ULC B200SR
DH500 N/A Duct housing UL DH200P (with 1551B or 2551HR)
DH500A N/A Duct housing ULC
DH500ACDC N/A Duct housing with relay UL DH200RP (with 1551B or 2551HR)
DH500ACDCA N/A Duct housing with relay ULC
Modules
Model Size Function Listing Replaced Replaced by
M500MB 4-inch Monitor UL
M500MAB 4-inch Monitor ULC
M500M-4-20[7] 4-inch 4-20 mA analog input UL
M500C[8] 4-inch Control UL M500CH
M500CH 4-inch Control UL M500C M500R
M500S
M500CHA 4-inch Control ULC
M500X 4-inch Isolator UL/ULC
M501M Small Monitor UL
M501MA Small Monitor ULC
M502M[9] 4-inch Zone interface UL
M502MA 4-inch Zone interface ULC
M503ME Small Monitor UL
M500R 4-inch Relay UL DH200RPL (with DNR + 2251BR)
M500CH
M500S 4-inch Supervised control UL M500CH
Faraday rebranded 500 series products as part of the 8400 series, 9100 series, and 9200 series until 2004.[10][11][12]
Fire-Lite Alarms
Fire-Lite model System Sensor model Replaced Replaced by
CP300[13] 1551B CPID[14] CP350
CP300A 1551AB None CP350A
SD300[15] 2551HR SDID SD350
SD300A 2551AHR None SD350A
SD300T 2551THR SDID-T SD350T
SD300TA 2551TAHR None SD350TA
C304[16] M500CH None
C304A M500CHA None
I300 M500X DCID
DCID24
I300A M500X None
M300 M500MB IZ412
IZ424
RIZ-1
M300A M500MAB None
M301 M501M None
M301A M501MA None
M302 M502M IZ412
IZ424
M302A M502MA None
FCI CLIP devices
Gamewell-FCI model System Sensor model Replaced Replaced by
ASD-I[17] 1551B ASD-IL
ASD-P[18] 2551HR ASD-PL
ATD[19] 5551B ATD-L
ATD-R 5551R ATD-RL
AMM-2[20] M501M AMM-2F
AMM-2I M500DM AMM-2IF
AMM-4 M500M AMM-4F
AMM-4S M502M AMM-4SF
AOM-2R M500R AOM-2RF
AOM-2S M500S AOM-2SF
SmartScan series
SCE-SS[21] M500S AOM-2SF
RCE-SS M500R AOM-2RF
PIDP-SS[22] M500M AMM-4F
PID-SS M501M AMM-2F
CZI-SS M502M AMM-4SF
DPID-SS M500DM AMM-2IF
SS-LI[23] M500X M500X
Velociti series
AMM-2F[24] M501M AMM-2
PID-SS
AMM-2IF[25] M500DM AMM-2I
DPID-SS
ZDM-D
AMM-4F[26] M500M AMM-4
PIDP-SS
ZDM
VZM
AMM-4SF[27] M502M AMM-4S
CZI-SS
ZDM
ZDM-D
VZM
AOM-2RF[28] M500R ADPRF (with DNR + ASD-PL2FR)
AOM-2R
RCE-SS
SRB-6
TBZ
AOM-2SF[29] M500S AOM-2S
SCE-SS
BCM-6
AOM-TELF[30] M500FP
AOM-MUXF M500DR
TC810S1000[31]
Farenhyt series
Honeywell model System Sensor model Replaced Replaced by
IDP-MONITOR[32] M500MB SD500-AIM Still in production
IDP-MINIMON M501M HFS-MM
SD500-MIM
IDP-MONITOR-2 M500DM None Still in production
IDP-RELAY M500R HFS-MR
IDP-PDUCT-R (with DNR + IDP-PHOTOR)
SD500-ARM
SD505-DUCTR (with DNR + IDP-PHOTO-R-IV)
IDP-RELAYMON-2 M500DMR None Still in production
IDP-CONTROL M500S SD500-ANM Still in production
IDP-ZONE M502M SD500-SDM Still in production
IDP-ISO M500X SD500-LIM Still in production
HFS series
Honeywell rebranded the M501M and M500R modules as part of the HFS series.
XLS series
TC809A1059[33] M500MB Still in production
TC809A1059CDN M500MAB Still in production
TC809B1008 M501M Still in production
TC809B1008CDN M501MA Still in production
TC809D1004 M500DM Still in production
TC809D1004CDN M500DMA Still in production
TC810N1013 M500S Still in production
TC810N1013CDN M500SA Still in production
TC810S1000 Still in production
TC810S1000CDN Still in production
TC810T1000 M500FP Still in production
TC810T1000CDN M500FPA Still in production
TC810R1024 M500R Still in production
TC810R1024CDN M500RA Still in production
TC811A1006[34] M500X Still in production
TC811A1014[35] M500XA Still in production
TC822A1010 M500DMR Still in production
TC822A1010CDN Still in production
TC841A1000 M502M Still in production
TC841A1000CDN M502MA Still in production
Monaco Enterprises rebranded CLIP-only 500 series devices as "Type I" devices and devices capable of the advanced protocol (AP) as "Type II" devices. Monaco also rebranded the M500X as the 729-140-00, and this device was not labeled by either type because it does not directly interact with the SLC communications.[36]
Type I
Monaco model System Sensor model Replaced Replaced by
729-127-00 B501 729-215-00
729-142-00 M500MB 729-217-00
729-143-00 M501M 729-218-00
729-144-00 M502M 729-219-00
729-158-00 M500S 729-225-00
729-159-00 M500R 729-221-00
729-182-00 M500DM 729-220-00
Type II
729-217-00 M500MB 729-142-00 Still in production
729-218-00 M501M 729-143-00 Still in production
729-219-00 M502M 729-144-00 Still in production
729-220-00 M500DM 729-182-00 Still in production
729-221-00 M500R 729-159-00 Still in production
729-225-00 M500S 729-158-00 Still in production
Notifier model System Sensor model Replaced Replaced by
CPX-551[37] 1551B CPX-751
SDX-551 2551HR SDX-751
SDX-551TH 2551THR FSP-751T
FDX-551[38] 5551B FST-751
FDX-551R 5551R FST-751R
CMX-1 M500C CMX-2
CMX-2 M500CH CMX-1
MMX-1[39] M500MB
MMX-2 M502M
MMX-101 M501M
ISO-X M500X
Silent Knight model System Sensor model Replaced Replaced by
SK-MONITOR[40] M500MB SD500-AIM Still in production
SK-MONITOR-2 M500DM None Still in production
SK-MINIMON M501M HFS-MM
SD500-MIM
SK-ZONE M502M SD500-SDM Still in production
SK-CONTROL M500S SD500-ANM Still in production
SK-RELAY M500R HFS-MR
SD500-ARM
SD505-DUCTR (with SK-DUCT-W)
SK-RELAYMON-2 M500DMR None Still in production
SK-ISO M500X SD500-LIM Still in production
  1. https://www.freepatentsonline.com/5400203.html
  2. "1551B Plug-in Intelligent Ionization Sensors with Communications" (I56-1436-00). System Sensor (1999).
  3. "2551HR Plug-in Intelligent Photoelectronic Sensors with Communications" (I56-1437-00). System Sensor (1999).
  4. https://www.securityandfire.honeywell.com/notifier/en-us/news/Articles/bright-white-addressable-faceplate-modules
  5. "500 Series™ Intelligent Sensors with Integral Communications" (A05-228-01). System Sensor (April 1997).
  6. "200 Series Mounting Base Options" (A05-1020-002). System Sensor (April 2006).
  7. "M500M-4-20 4-20mA Analog Input Module" (I56-3070-003). System Sensor (March 11, 2016).
  8. "M500R Relay Control Module" (I56-3852-004). System Sensor (March 11, 2016).
  9. "500 Series™ Intelligent Monitor and Control Modules" (A05-224-01). System Sensor (April 1997).
  10. https://tecumsehtech.com/Detectors-and-Modules
  11. https://web.archive.org/web/20040219083128/http://www.faradayllc.com/products_addressable.html
  12. https://web.archive.org/web/20040401233430/http://faradayfirealarms.com/products_initiating.html
  13. "CP300(A) - Addressable Ionization Detector" (DF-51311). Fire-Lite Alarms (February 15, 2001).
  14. "4812.pdf". Fire-Lite Alarms.
  15. "SD300(A)/SD300T(A) - Addressable Photoelectric Detectors" (DF-51320). Fire-Lite Alarms (February 15, 2001).
  16. "MS-9200 Addressable Modules" (DF-51339). Fire-Lite Alarms (February 15, 2001).
  17. "ASD-I Analog Ionization Sensor" (9020-0277). Fire Control Instruments (1997).
  18. "ASD-P Analog Photoelectronic Sensor" (9020-0275). Fire Control Instruments (1997).
  19. "ATD,ATD-R Analog Thermal Sensor" (9020-0278). Fire Control Instruments (1997).
  20. https://web.archive.org/web/20041205070305/http://firecontrolinstruments.com/prod-id.html
  21. "SCE-SS and RCE-SS Addressable Control and Relay Modules" (CS-2466). Gamewell (October 25, 2004).
  22. "PIDP-SS, PID-SS, CZI-SS, and DPID-SS Monitor Modules with SmartScan™" (CS-2465). Gamewell (October 25, 2004).
  23. "SS-LI Fault Isolator Module" (CS-2464). Gamewell (October 25, 2004).
  24. "Velociti™ Series AMM-2F" (9020-0626). Fire Control Instruments (2005).
  25. "Velociti™ Series AMM-2IF" (9020-0629). Fire Control Instruments (2005).
  26. "Velociti™ Series AMM-4F" (9020-0624). Fire Control Instruments (2005).
  27. "Velociti™ Series AMM-4SF" (9020-0630). Fire Control Instruments (2005).
  28. "Velociti™ Series AOM-2RF" (9020-0625). Fire Control Instruments (2005).
  29. "Velociti™ Series AOM-2SF" (9020-0627). Fire Control Instruments (2005).
  30. "Velociti™ Series AOM-MUXF, AOM-TELF" (9020-0628). Fire Control Instruments (2005).
  31. "TC81021000 Releasing Control Module" (9021-60905). Honeywell Gamewell-FCI (November 2017).
  32. "Addressable Devices with Intelligent Device Protocol (IDP)" (350361). Silent Knight (2015).
  33. "XLS140-2 Intelligent Addressable Fire Alarm Control Panel" (85-3128-13). Honeywell (September 2022).
  34. "TC811A1006 FAULT ISOLATOR MODULE FOR FIRE AND SECURITY SYSTEMS" (I56-3630-002). Honeywell (2012).
  35. "TC811A1014 FAULT ISOLATOR MODULE" (I56-1136-003). Honeywell (2020).
  36. "Monaco Products Catalog". Monaco Enterprises (September 2024).
  37. https://firealarms.tv/collection/notifier-cpx-551/
  38. https://i.ebayimg.com/images/g/2QYAAOSw12Vl4kZk/s-l1600.jpg
  39. "FMM-1(A), FMM-101(A), FZM-1(A) & FDM-1(A) - Monitor Modules with FlashScan®" (DN-6720). Notifier (July 30, 2015).
  40. "Addressable Devices with SK Protocol" (53623). Silent Knight (2013).
