System Sensor SpectrAlert series
12-24VDC
1997
2006 & 2008
Mini-Alert |
SpectrAlert Advance
"title": "SpectrAlert Series",
"System_Sensor_SpectrAlert_series_lineup.png"
The SpectrAlert series (commonly referred to as “the original SpectrAlerts”, or “SpectrAlert classics”) are a series of notifications appliances from System Sensor. These were the first System Sensor appliances to include synchronization and temporal 3.
The SpectrAlert series was released in 1997 with wall-mount horns, strobes, and horn strobes.[1] The horn strobes were redesigned from the Mini-Alert ADA horn strobes, with the strobe moved to the bottom of the device and enlarged. The horns and strobes were designed consistent with the horn strobes. These first models had fixed candela, and they used a screw on style mounting bracket.
In 1998, ceiling-mount strobes and horn strobes were released.[2] These introduced the notification appliance design where a central strobe is surrounded by the audible grille.
In 1999, the SP200 speakers were released.[3] These featured higher fidelity sound output compared to the SP100 series. The wall-mount speaker strobes consisted of a speaker to the side of a reversible strobe, while the ceiling-mount speaker strobes used a similar design to the ceiling-mount horn strobes.
The second generation SpectrAlerts are also fixed candela, and used "QuickClick" style mounting brackets instead of a screw style mounting bracket. The "QuickClick" mounting brackets snap into place when the device is placed on the bracket and uses a flathead screwdriver or a removal tool to remove the device off the bracket.
In 2003, multi-candela wall-mount strobes were released, those models use the MC suffix and the single-candela wall strobes were discontinued shortly after.[4][5][6]
At the end of 2005, the SP300 speakers were released.[7] These provided a higher SPL output compared to the SP200 speakers, but the fidelity was not as high. The design was the same as the SP200 speakers, except there were no ceiling-mount SP300 speaker strobes.
The horns, chimes, and chime strobes were discontinued in November 2006 when the SpectrAlert Advance was released.[8][9][10] All strobes and horn strobes besides the 120VAC models were discontinued by the beginning of 2007.[11][12] The speakers were discontinued between 2008 and 2009, as the SpectrAlert Advance speakers were not released until then.[13]
K suffix indicates weatherproof models
| Model Number | Nominal Voltage | Candela | Mounting | Color | Replaces | Replaced by | Current Replacement |
| S1215[14] | 12VDC | 15 | Wall | Red | SS1215ADA | S1224MC | |
| S1215W | 12VDC | 15 | Wall | White | SS1215ADAB | S1224MCW | |
| S121575 | 12VDC | 15/75 | Wall | Red | SS121575ADA | S1224MC | |
| S121575W | 12VDC | 15/75 | Wall | White | SS121575ADAB | S1224MCW | |
| S2415 | 24VDC | 15 | Wall | Red | SS2415ADA SS2415ADAS |
S1224MC | SR-LED |
| S2415W | 24VDC | 15 | Wall | White | SS2415ADAS | S1224MCW | SW-LED |
| S241575 | 24VDC | 15/75 | Wall | Red | SS241575ADA SS241575ADAS |
S1224MC | SR-LED |
| S241575W | 24VDC | 15/75 | Wall | White | SS241575ADAB | S1224MCW | SW-LED |
| S2430[15] | 24VDC | 30 | Wall | Red | None | S1224MC | |
| S2430W | 24VDC | 30 | Wall | White | None | S1224MCW | |
| S2475 | 24VDC | 75 | Wall | Red | SS2475ADA | S1224MC | |
| S2475W | 24VDC | 75 | Wall | White | SS2475ADAB | S1224MCW | |
| S24110 | 24VDC | 110 | Wall | Red | SS24110ADA | S1224MC | |
| S24110W | 24VDC | 110 | Wall | White | SS24110ADAB | S1224MCW | |
| S1224MC[16] | 12VDC & 24VDC | 15, 15/75, 30, 75, 110 | Wall | Red | S1215 S121575 S2415 S241575 S2430 S2475 S24110 |
SR | SR-LED |
| S1224MCW | 12VDC & 24VDC | 15, 15/75, 30, 75, 110 | Wall | White | S1215W S121575W S2415W S241575W S2430W S2475W S24110W |
SW | SW-LED |
| SC2415 | 24VDC | 15 | Ceiling | Red | None | SCR | SCR-LED |
| SC2415W | 24VDC | 15 | Ceiling | White | None | SCW | SCW-LED |
| SC241575 | 24VDC | 15/75 | Ceiling | Red | None | SCR | SCR-LED |
| SC241575W | 24VDC | 15/75 | Ceiling | White | None | SCW | SCW-LED |
| SC2430 | 24VDC | 30 | Ceiling | Red | None | SCR | SCR-LED |
| SC2430W | 24VDC | 30 | Ceiling | White | None | SCW | SCW-LED |
| SC2475 | 24VDC | 75 | Ceiling | Red | None | SCR | SCR-LED |
| SC2475W | 24VDC | 75 | Ceiling | White | None | SCW | SCW-LED |
| SC2495 | 24VDC | 95 | Ceiling | Red | None | SCR | SCR-LED |
| SC2495W | 24VDC | 95 | Ceiling | White | None | SCW | SCW-LED |
| SC24115 | 24VDC | 115 | Ceiling | Red | None | SCR | SCR-LED |
| SC24115W | 24VDC | 115 | Ceiling | White | None | SCW | SCW-LED |
| SC24177 | 24VDC | 177 | Ceiling | Red | None | SCRH | SCR-LED |
| SC24177W | 24VDC | 177 | Ceiling | White | None | SCWH | SCW-LED |
Horns and Horn/Strobes
| Model Number | Nominal Voltage | Horn Control | Candela | Mounting | Color | Replaces | Replaced by | Current Replacement |
| H12/24 | 12VDC & 24VDC | Synchronized | N/A | Wall/Ceiling | Red | None | HR | |
| H12/24W | 12VDC & 24VDC | Synchronized | N/A | Wall/Ceiling | White | None | HW | |
| HC12/24[17] | 12VDC & 24VDC | Coded | N/A | Wall/Ceiling | Red | MA12/24EH | HR | |
| HC12/24W | 12VDC & 24VDC | Coded | N/A | Wall/Ceiling | White | None | HW | |
| P1215 | 12VDC | Coded | 15 | Wall | Red | MAEH1215ADA PS1215ADA |
P1224MC | |
| P1215W | 12VDC | Coded | 15 | Wall | White | PS1215ADAW | P1224MCW | |
| P121575 | 12VDC | Coded | 15/75 | Wall | Red | MAEH121575ADA PS121575ADA |
P1224MC | |
| P121575W | 12VDC | Coded | 15/75 | Wall | White | PS121575ADAW | P1224MCW | |
| P2415 | 24VDC | Coded | 15 | Wall | Red | MAEH2415ADA MAEH2415ADAS PS2415ADA |
P1224MC | |
| P2415W | 24VDC | Coded | 15 | Wall | White | PS2415ADAW | P1224MCW | |
| P241575 | 24VDC | Coded | 15/75 | Wall | Red | MAEH241575ADA MAEH241575ADAS PS241575ADA |
P1224MC | |
| P241575W | 24VDC | Coded | 15/75 | Wall | White | PS241575ADAW | P1224MCW | |
| P2430 | 24VDC | Coded | 30 | Wall | Red | None | P1224MC | |
| P2430W | 24VDC | Coded | 30 | Wall | White | None | P1224MCW | |
| P2475 | 24VDC | Coded | 75 | Wall | Red | MAEH2475ADA PS2475ADA |
P1224MC | |
| P2475W | 24VDC | Coded | 75 | Wall | White | PS2475ADAW | P1224MCW | |
| P24110 | 24VDC | Coded | 110 | Wall | Red | MAEH24110ADA PS24110ADA |
P1224MC | |
| P24110W | 24VDC | Coded | 110 | Wall | White | PS24110ADAW | P1224MCW | |
| P1224MC | 12VDC & 24VDC | Coded | 15, 15/75, 30, 75, 110 | Wall | Red | P1215 P121575 P2415 P241575 P2430 P2475 P24110 |
P4R | P4RL |
| P1224MCW | 12VDC & 24VDC | Coded | 15, 15/75, 30, 75, 110 | Wall | White | P1215W P121575W P2415W P241575W P2430 P2475 P24110 |
P4W | P4WL |
| PC2415 | 24VDC | Coded | 15 | Ceiling | Red | MAEH24MC | PC4R | |
| PC2415W | 24VDC | Coded | 15 | Ceiling | White | None | PC4W | |
| PC241575 | 24VDC | Coded | 15/75 | Ceiling | Red | None | PC4R | |
| PC241575W | 24VDC | Coded | 15/75 | Ceiling | White | None | PC4W | |
| PC2430 | 24VDC | Coded | 30 | Ceiling | Red | None | PC4R | |
| PC2430W | 24VDC | Coded | 30 | Ceiling | White | None | PC4W | |
| PC2475 | 24VDC | Coded | 75 | Ceiling | Red | None | PC4R | |
| PC2475W | 24VDC | Coded | 75 | Ceiling | White | None | PC4W | |
| PC2495 | 24VDC | Coded | 95 | Ceiling | Red | None | PC4R | |
| PC2495W | 24VDC | Coded | 95 | Ceiling | White | None | PC4W | |
| PC24115 | 24VDC | Coded | 115 | Ceiling | Red | None | PC4R | |
| PC24115W | 24VDC | Coded | 115 | Ceiling | White | None | PC4W | |
| PC24177 | 24VDC | Coded | 177 | Ceiling | Red | None | PC4RH | |
| PC24177W | 24VDC | Coded | 177 | Ceiling | White | None | PC4WH |
| Model Number | Strobe Voltage | Candela | Mounting | Color | Replaces | Replaced by |
| SP200W[18] | N/A | N/A | Ceiling | White | SP100W[19] | SPCW |
| SP201W | N/A | N/A | Wall | White | SP101W | SPW |
| SP201R | N/A | N/A | Wall | Red | SP101R | SPR |
| SP2R2415[20] | 24VDC | 15 | Wall | Red | SP1R2415ADA | SP2R1224MC |
| SP2W2415 | 24VDC | 15 | Wall | White | SP1W2415ADA | SP2W1224MC |
| SP2R241575 | 24VDC | 15/75 | Wall | Red | SP1R241575ADA | SP2R1224MC |
| SP2W241575 | 24VDC | 15/75 | Wall | White | SP1W241575ADA | SP2W1224MC |
| SP2R2430 | 24VDC | 30 | Wall | Red | None | SP2R1224MC |
| SP2W2430 | 24VDC | 30 | Wall | White | None | SP2W1224MC |
| SP2R2475 | 24VDC | 75 | Wall | Red | SP1R2475ADA | SP2R1224MC |
| SP2W2475 | 24VDC | 75 | Wall | White | SP1W2475ADA | SP2W1224MC |
| SP2R24110 | 24VDC | 110 | Wall | Red | SP1R24110ADA | SP2R1224MC |
| SP2W24110 | 24VDC | 110 | Wall | White | SP1W24110ADA | SP2W1224MC |
| SP2R1224MC[21] | 12VDC & 24VDC | 15, 15/75, 30, 75, 110 | Wall | Red | SP2R2415 SP2R241575 SP2R2430 SP2R2475 SP2R24110 |
SPSR |
| SP2W1224MC | 12VDC & 24VDC | 15, 15/75, 30, 75, 110 | Wall | White | SP2W2415 SP2W241575 SP2W2430 SP2W2475 SP2W24110 |
SPSW |
| SP2C2415[22] | 24VDC | 15 | Ceiling | White | SP100W24MC | SPSCW |
| SP2C241575 | 24VDC | 15/75 | Ceiling | White | None | SPSCW |
| SP2C2430 | 24VDC | 30 | Ceiling | White | None | SPSCW |
| SP2C2475 | 24VDC | 75 | Ceiling | White | None | SPSCW |
| SP2C2495 | 24VDC | 95 | Ceiling | White | None | SPSCW |
| SP2C24177 | 24VDC | 177 | Ceiling | White | None | SPSCWH |
| SP300W[7] | N/A | N/A | Ceiling | White | None | SPCWV |
| SP301W | N/A | N/A | Wall | White | None | SPWV |
| SP301R | N/A | N/A | Wall | Red | None | SPRV |
| SP3R1224MC[23] | 12VDC & 24VDC | 15, 15/75, 30, 75, 110 | Wall | Red | None | SPSRV |
| SP3W1224MC | 12VDC & 24VDC | 15, 15/75, 30, 75, 110 | Wall | White | None | SPSWV |
Chimes
| CH12/24[24] | 12VDC & 24VDC | N/A | Wall/Ceiling | Red | MA12/24D MA12/24EH |
CHR |
| CH12/24W | 12VDC & 24VDC | N/A | Wall/Ceiling | White | MA12/24DB | CHW |
| CH2415[25] | 24VDC | 15 | Wall | Red | MASS2415ADA MASS2415ADAS MAEH2415ADA MAEH2415ADAS |
CH24MC |
| CH2415W | 24VDC | 15 | Wall | White | MASS2415ADAB | CH24MCW |
| CH241575 | 24VDC | 15/75 | Wall | Red | MASS241575ADA MASS241575ADAS MAEH241575ADA MAEH241575ADAS |
CH24MC |
| CH241575W | 24VDC | 15/75 | Wall | White | MASS241575ADAB | CH24MCW |
| CH2475 | 24VDC | 75 | Wall | Red | MASS2475ADA MAEH2475ADA |
CH24MC |
| CH2475W | 24VDC | 75 | Wall | White | MASS2475ADAB | CH24MCW |
| CH24110 | 24VDC | 110 | Wall | Red | MASS24110ADA MAEH24110ADA |
CH24MC |
| CH24110W | 24VDC | 110 | Wall | White | MASS24110ADAB | CH24MCW |
| CH24MC[26] | 24VDC | 15, 15/75, 30, 75, 110 | Wall | Red | CH2415 CH241575 CH2475 CH24110 |
CHSR |
| CH24MCW | 24VDC | 15, 15/75, 30, 75, 110 | Wall | White | CH2415W CH241575W CH2475W CH24110W |
CHSW |
| FCI model | System Sensor model | Replaces | Replaced by |
| S2415-FC | S2415 | S2415 | |
| S241575-FC[27] | S241575 | STW-4F | S241575 |
| S2430-FC | S2430 | None | S2430 |
| S2430W-FC | S2430W | None | S2430W |
| S2430K-FC | S2430K | None | S2430K |
| S2475-FC | S2475 | S2475 | |
| S2475W-FC | S2475W | S2475W | |
| S2475K-FC | S2475K | S2475K | |
| S24110-FC | S24110 | S24110 | |
| S24110W-FC | S24110W | S24110W | |
| S24110K-FC | S24110K | S24110K | |
| H12/24-FC | H12/24 | H12/24 | |
| H12/24W-FC | H12/24W | H12/24W | |
| H12/24K-FC | H12/24K | H12/24K | |
| HC12/24-FC | HC12/24 | HEF HE-8F |
HC12/24 |
| HC12/24W-FC | HC12/24W | HC12/24W | |
| HC12/24K-FC | HC12/24K | HC12/24K | |
| P2415-FC | P2415 | P2415 | |
| P2415W-FC | P2415W | P2415W | |
| P2415K-FC | P2415K | P2415K | |
| P241575-FC | P241575 | P241575 | |
| P241575W-FC | P241575W | P241575W | |
| P241575K-FC | P241575K | P241575K | |
| P2430-FC | P2430 | None | P2430 |
| P2430W-FC | P2430W | None | P2430W |
| P2430K-FC | P2430K | None | P2430K |
| P2475-FC | P2475 | P2475 | |
| P2475W-FC | P2475W | P2475W | |
| P2475K-FC | P2475K | P2475K | |
| P24110-FC[28] | P24110 | P24110 | |
| P24110W-FC | P24110W | P24110W | |
| P24110K-FC | P24110K | P24110K | |
| SP200W-FC[29] | SP200W | SP200W | |
| SP201W-FC | SP201W | SP201W | |
| SP201R-FC | SP201R | SP201R | |
| SP2R2415-FC[30] | SP2R2415 | SP2R2415 | |
| SP2R241575-FC | SP2R241575 | SP2R241575 | |
| SP2R2430-FC | SP2R2430 | SP2R2430 | |
| SP2R2475-FC | SP2R2475 | SP2R2475 | |
| SP2R24110-FC | SP2R24110 | SP2R24110 | |
| SP2W2415-FC | SP2W2415 | SP2W2415 | |
| SP2W241575-FC | SP2W241575 | SP2W241575 | |
| SP2W2430-FC | SP2W2430 | SP2W2430 | |
| SP2W2475-FC | SP2W2475 | SP2W2475 | |
| SP2W24110-FC | SP2W24110 | SP2W24110 |
- ↑ https://web.archive.org/web/19970401000729/http://www.systemsensor.com/edocs.htm
- ↑ "AUDIBLE, VISUAL AND AUDIO/VISUAL NOTIFICATION APPLIANCES" (9020-0495). Fire Control Instruments (1998).
- ↑ https://www.freepatentsonline.com/6127935.html
- ↑ https://web.archive.org/web/20030219082631/http://systemsensor.com/html/avn.html?search=horn/strobe
- ↑ https://web.archive.org/web/20030407140054/http://www.systemsensor.com/html/avn.html?search=Horn/Strobe
- ↑ https://web.archive.org/web/20031023234400/http://systemsensor.com/html/avn.html?search=Horn/Strobe
- ↑ 7.0 7.1 "SpectrAlert Dual-Voltage Evacuation Speakers" (A05-0999-006). System Sensor (November 2005).
- ↑ https://web.archive.org/web/20061109184825/http://www.systemsensor.com/html/avn.html?search=ch12
- ↑ https://web.archive.org/web/20061109175318/http://www.systemsensor.com/html/avn.html?search=chime/strobe
- ↑ https://web.archive.org/web/20061109175308/http://www.systemsensor.com/html/avn.html?search=Horn%20only
- ↑ https://web.archive.org/web/20070101135906/http://www.systemsensor.com/html/avn.html?search=Strobe%20only
- ↑ https://web.archive.org/web/20061230111816/http://www.systemsensor.com:80/html/avn.html?search=horn/strobe
- ↑ https://web.archive.org/web/20090125125003/http://www.systemsensor.com/html/avn.html?search=speaker
- ↑ "SpectrAlert Series Horns, Strobes, and Horn/Strobes" (A05-936-02). System Sensor (April 1997).
- ↑ "SpectrAlert Selectable Output Strobe and Horn/Strobes" (A05-0325-006). System Sensor (September 2005).
- ↑ "SpectrAlert™ Series Horns, Strobes, and Horn/Strobes" (DF-51609). Fire-Lite Alarms (March 30, 2000).
- ↑ "SpectrAlert™ SP200 Series Dual Voltage Evacuation Speakers" (A05-999-02). System Sensor (January 2000).
- ↑ "SP100 and V400 Series Speakers and Speaker/Strobes" (A05-191-03). System Sensor (August 1996).
- ↑ "SpectrAlert™ SP2 Series Wall Speaker/Strobes" (A05-1015-02). System Sensor (August 1999).
- ↑ "SpectrAlert Selectable Output Wall Speaker/Strobes" (A05-0339-003). System Sensor (May 2004).
- ↑ "SpectrAlert™ SP2C Series Ceiling Mount Speaker/Strobes" (A05-1024-01). System Sensor (January 2000).
- ↑ "SpectrAlert Selectable Output Wall Speaker/Strobes" (A05-0339-006). System Sensor (November 2005).
- ↑ "SpectrAlert™ Electronic Chime/Sounder" (I56-0003-003R). System Sensor (2001).
- ↑ "SpectrAlert™ Chime and Chime/Strobe" (A05-0282-002). System Sensor (May 2001).
- ↑ "SpectrAlert Chime and Chime/Strobe" (A05-0282-005). System Sensor (June 2004).
- ↑ https://firealarms.tv/collection/fci-s241575-fc/
- ↑ https://firealarms.tv/collection/fci-p24110-fc/
- ↑ "SP200-FC SERIES" (9020-0469). Fire Control Instruments (1999).
- ↑ "SP2 Series Speaker and Speaker/Strobe Notification Appliances" (9020-0479). Fire Control Instruments (1999).
