System Sensor Signal Strobe series
BRK (System Sensor)
Beige
12/24VDC
1987
Notifier NWS series
System Sensor RK series |
"title": "Signal Strobe Series",
"System_Sensor_MASS_Sounder_Strobe.png"
Originally released under BRK, the Signal Strobe series was used with the MA Series horns, PA400 mini horns, and as a standalone remote strobe. These strobes used model numbers starting with "SS".
The Signal Strobe series was released in 1987 as part of the Multi-Alert series.[1] The original strobe was 1 candela and it was designed to be attached to a Multi-Alert sounder. There was also a patented filler that allowed it to be used as a standalone strobe.[2] At this time, System Sensor also released the MP-SF to make the device mountable to both 4-inch square and double gang boxes, making the series a replacement for the Notifier NWS series.
In 1993, System Sensor replaced the 1 candela models with LO and M models, which outputted 1.5 and 15 candela respectively.[3] Around 1994, System Sensor released the ADA models, which were UL 1971 compliant. Unlike the UL 1638 strobes, the ADA remote strobes did not have a separate filler device that could be removed to mount the device on a Multi-Alert sounder or V400 speaker. However, strobes that could be used for retrofits on sounders and speakers were released as the RK series.[4]
| Model | Voltage | Candela | Mounting | Color | Replaces | Replaced by |
| SS-12[5] | 12 VDC | 1[citation needed] | Wall | Red | SS12LO | |
| SS-24 | 24 VDC | 1[6] | Wall | Red | NWS-24 | SS24LO |
| SS12LO[7] | 12-17 VDC[8] | 1.5 | Wall | Red | SS-12 | SS1215ADA |
| SS12LOB | 12-17 VDC | 1.5 | Wall | Beige | None | SS1215ADAB |
| SS24LO | 22.5-30 VDC | 1.5 | Wall | Red | SS-24 | RK2415ADA[4] SS2415ADA |
| SS24LOB | 22.5-30 VDC | 1.5 | Wall | Beige | None | SS2415ADAB |
| SS24LOC | 22.5-30 VDC | 1.5 | Ceiling | Beige | None | |
| SS24LOBC | 22.5-30 VDC | 1.5 | Ceiling | Beige | None | |
| SS24M | 22.5-30 VDC | 15 | Wall | Red | None | RK2415ADA SS2415ADA |
| SS24MB | 22.5-30 VDC | 15 | Wall | Beige | None | SS2415ADAB |
| SS24MC | 22.5-30 VDC | 15 | Ceiling | Red | None | |
| SS1215ADA | 10.5-17 VDC | 15 | Wall | Red | SS12LO | S1215 |
| SS1215ADAB | 10.5-17 VDC | 15 | Wall | Beige | SS12LOB | S1215W |
| SS121575ADA | 10.5-17 VDC | 15/75 | Wall | Red | None | S121575 |
| SS121575ADAB | 10.5-17 VDC | 15/75 | Wall | Beige | None | S121575W |
| SS2415ADA | 20-30 VDC | 15 | Wall | Red | SS24LO SS24M |
S2415 |
| SS2415ADAB | 20-30 VDC | 15 | Wall | Beige | SS24LOB SS24MB |
S2415W |
| SS241575ADA | 20-30 VDC | 15/75 | Wall | Red | None | S241575 |
| SS241575ADAB | 20-30 VDC | 15/75 | Wall | Beige | None | S241575W |
| SS2475ADA | 20-30 VDC | 75 | Wall | Red | None | S2475 |
| SS2475ADAB | 20-30 VDC | 75 | Wall | Beige | None | S2475W |
| SS24110ADA | 20-30 VDC | 110 | Wall | Red | None | S24110 |
| SS24110ADAB | 20-30 VDC | 110 | Wall | Beige | None | S24110W |
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_3bcee565-1b7c-45e7-8527-4101c8428281/
- ↑ https://www.freepatentsonline.com/D311705.html
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_e739b0ac-5683-41d8-8725-3d1426de8e70/
- ↑ 4.0 4.1 https://web.archive.org/web/19970401002555/http://www.systemsensor.com/e-docs/manuals/ada.pdf
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_94048b31-e022-4bba-9dfd-49dac83371b6/
- ↑ https://www.schuminweb.com/fire_alarms/system-sensor-mass-24/
- ↑ "Multi-Alert™ Mini-Alert™ Sounder and Strobes" (A05-207-04). System Sensor (August 1996).
- ↑ https://web.archive.org/web/19970709070356/http://www.systemsensor.com/e-docs/manuals/multi.pdf
