System Sensor 2300 series (Direct-Wire detectors)
8.5-35 VDC
1996
System Sensor 100 series |
"title": "2300 series",
The System Sensor 2300 series is a series of photoelectric smoke detectors.
The 2300 series originally consisted of the 2300T and 2312/24T.[1] The design was a more compact version of the 2400 series with replaceable thermistors to the sides of the photoelectric sensor. These original detectors featured pigtail leads.
In 1993, System Sensor introduced the 2300TB and 2312/24TB.[2] These models used terminal blocks, and the thermistors were no longer replaceable. Unlike the 2312/24T, the 2312/24TB did not have an auxiliary relay.
At the end of 1993, System Sensor introduced the 2300B and 2312/24B as non-thermistor versions of the 2300TB and 2312/24TB respectively.[3]
The 2300 series was discontinued in 1996 due to the release of Direct-Wire models in the 100 series.
| Model | Wiring | Heat sensor? | Auxiliary relay? | Replaced | Replaced by |
| 2300B | 2-wire with terminals | No | No | None | 2100 |
| 2300T | 2-wire with pigtail leads | Yes | No | None | 2300TB |
| 2300TB | 2-wire with terminals | Yes | No | 2300T | 2100T |
| 2312/24B | 4-wire with terminals | No | No | None | 2112/24B |
| 2312/24T | 4-wire with pigtail leads | Yes | Yes | None | 2312/24TB 2412THB 2424TH |
| 2312/24TB | 4-wire with terminals | Yes | No | 2312/24T | 2112/24TB |
- ↑ "2300 Series Photoelectronic Smoke Detector with Electronic Heat Sensing" (C2300). System Sensor (February 1992).
- ↑ "INSTALLATION AND MAINTENANCE INSTRUCTIONS FOR MODEL 2312/24TB" (I56-431-06). System Sensor (1993).
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_74aef308-2293-408d-9df1-9031974c4575/
