Simplex 4903 series
Simplex |
Simplex 2903 series
"title": "4903 series",
The Simplex 4903 series is a series of strobe plates and combination strobes. The 4903 series was first introduced around 1989–90 as the light plates and 4.75CD Strobe plates. In around 1992, Simplex replaced those with the 4903–9105 100CD strobe plates with a magnified strobe from Gentex. They replaced the strobe design in 1994 with a clear lensed 15/75CD strobe with a reflector. In around 1993–94 was when they introduced the 15, 30 & 110CD units that we use today. The original 1993–94 units only flashed at 24 times a minute while in late 1994 they changed the flash rate to 60 times a minute and introduced separate 4903–93XX Speaker/Strobes & 4903–94XX Horn/Strobes that had synchronized strobes. These separate Free Run only 4903–91XX Series Speaker/Strobes & 4903–92XX Series Horn strobes and their synchronized 4903-93XX & 4903–94XX counterparts were discontinued in 2000. The electromechanical horn/strobes were discontinued however in 1998 being replaced with the Electronic Horns that were introduced that same year and were discontinued in 2000. Simplex also made separate Speaker/Strobe models for 25VRMS & 70VRMS lines. Nowadays Simplex uses selectable 4903s to replace all legacy 4903 units that preceded them. These 4903s have the same exact counterparts as the TrueAlerts and the speaker/strobes were dual voltage. In 1997 Simplex added a colored shape indicator on the strobe reflector to indicate the candela. This included a Green Asterisk to indicate 15CD (or 15/75CD), a Blue Circle to indicate 30CD (or 30/110CD) and an Orange Triangle to indicate 110CD. In around late 1999 Simplex used clear candela stickers using black numbers and letters inside of a round white circle to indicate the candela.
Light/strobe plates
| Model number | Voltage | Type | Candela | Strobe orientation | Color |
| 4903-9001 | 24 VDC | Light plate | 0.5 | Red | |
| 4903-9051 | 120 VAC | Light plate | 0.32 | ||
| 4903-9101[1] | 24 VDC | Strobe plate | 4.75 | Vertical/Horizontal | Red |
| 4903-9102[2] | 24 VDC | Light plate | 0.5 | Horizontal | Red |
| 4903-9104[3] | 24 VDC | Strobe plate | 4.75 | Ceiling | Red |
| 4903-9105[4] | 24 VDC | Strobe plate | 100 (Sometimes 15/75) | Vertical/Horizontal | Red |
| 4903-9151 | 120 VAC | Strobe plate | 8.4 | ||
| 4903-9152 | 120 VAC | Light plate | 0.32 | ||
| 4903-9154 | 120 VAC | Strobe plate | 8.4 | ||
| 4903-9501 | N/A | Plate | N/A | N/A | Red |
Speaker strobes
| Model number | Candela | Synchronization | Volts RMS | Strobe/Fire Lettering orientation | Color | Mounting orientation | Replaces | Replaced By | Current Replacement |
| 4903-9106[5][6][7][8] | 15 | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | 25 | Vertical | Red | Horizontal | 4903-9146 | 4903-9150 | |
| 4903-9107[9] | 110 | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | 25 | Vertical | Red | Horizontal | 4903-9144 | 4903-9149 | |
| 4903-9109 [10] | 110 | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | 70 | Vertical | Red | Horizontal | 4903-9174 | ||
| 4903-9136[11][12] | 15 | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | 25 | Horizontal | Red | Vertical | 4903-9147 | 4903-9153 | |
| 4903-9142[13] | 30 | Free-run | 25 | Vertical | Red | Horizontal | 4903-9148 | ||
| 4903-9143 | 30 | Free-run | 25 | Horizontal | Red | Vertical | 4903-9199 | ||
| 4903-9144[14][15] | 110 | Free-run | 25 | Vertical | Red | Horizontal | 4903-9107 | 4903-9149 | |
| 4903-9145[16][17][18] | 110 | Free-run | 25 | Horizontal | Red | Vertical | 4903-9343 | ||
| 4903-9146[19] | 15 | Free-run | 25 | Vertical | Red | Horizontal | 4903-9150 | ||
| 4903-9147[20] | 15 | Free-run | 25 | Horizontal | Red | Vertical | 4903-9136 | 4903-9153 | |
| 4903-9148[21][22] | 30 | Free-run/Synchronized | 25/70 | Vertical | Red | Horizontal | 4903-9142, 4903-9171, 4903-9303, 4903-9329 | ||
| 4903-9149[23] | 110 | Free-run/Synchronized | 25/70 | Vertical | Red | Horizontal | 4903-9107, 4903-9109, 4903-9144, 4903-9174, 4903-9305, 4903-9332 | ||
| 4903-9150[24] | 15 | Free-run/Synchronized | 25/70 | Vertical | Red | Horizontal | 4903-9146, 4903-9168, 4903-9301, 4903-9326 | ||
| 4903-9153[25] | 15 | Free-run/Synchronized | 25/70 | Horizontal | Red | Vertical | 4903-9136, 4903-9147, 4903-9176, 4903-9302, 4903-9334 | ||
| 4903-9155[26] | 15 | Free-run | 25 | Ceiling | White (Round) | Round | 4903-9196
4903-9371 | ||
| 4903-9156 | 15 | Free-run | 25 | Vertical | White (Round) | Round | |||
| 4903-9157 | 15 | Free-run | 70 | Ceiling | White (Round) | Round | 4903-9196
4903-9371 | ||
| 4903-9158 | 15 | Free-run | 70 | Wall | White (Round) | Round | |||
| 4903-9159 | 30 | Free-run | 25 | Ceiling | White (Round) | Round | 4903-9197
4903-9372 (75CD) | ||
| 4903-9160 | 30 | Free-run | 25 | Vertical | White (Round) | Round | |||
| 4903-9161 | 30 | Free-run | 70 | Ceiling | White (Round) | Round | 4903-9197
| 4903-9162 | 30 | Free-run | 70 | Wall | White (Round) | Round | |||
| 4903-9163 | 110 | Free-run | 25 | Ceiling | White (Round) | Round | 4903-9198
4903-9373 | ||
| 4903-9164 | 110 | Free-run | 25 | Vertical | White (Round) | Round | |||
| 4903-9165 | 110 | Free-run | 70 | Ceiling | White (Round) | Round | 4903-9198
4903-9373 | ||
| 4903-9166 | 110 | Free-run | 70 | Vertical | White (Round) | Round | |||
| 4903-9167[27] | 15 | Free-run | 25 | Vertical | White | Horizontal | 4903-9193 | ||
| 4903-9168[28] | 15 | Free-run | 70 | Vertical | Red | Horizontal | 4903-9150 | ||
| 4903-9169 | 15 | Free-run | 70 | Vertical | White | Horizontal | 4903-9193 | ||
| 4903-9170[29] | 30 | Free-run | 25 | Vertical | White | Horizontal | 4903-9194 | ||
| 4903-9171 | 30 | Free-run | 70 | Vertical | Red | Horizontal | 4903-9148 | ||
| 4903-9172 | 30 | Free-run | 70 | Vertical | White | Horizontal | 4903-9194 | ||
| 4903-9173[30] | 110 | Free-run | 25 | Vertical | White | Horizontal | 4903-9195 | ||
| 4903-9174[31] | 110 | Free-run | 70 | Vertical | Red | Horizontal | 4903-9109 | 4903-9149 | |
| 4903-9175 | 110 | Free-run | 70 | Vertical | White | Horizontal | 4903-9195 | ||
| 4903-9176 | 15 | Free-run | 70 | Horizontal | Red | Vertical | 4903-9153 | ||
| 4903-9177 | 30 | Free-run | 70 | Horizontal | Red | Vertical | 4903-9199 | ||
| 4903-9178 | 110 | Free-run | 70 | Horizontal | Red | Vertical | 4903-9343 | ||
| 4903-9193[32] | 15 | Free-run/Synchronized | 25/70 | Vertical | White | Horizontal | 4903-9167, 4903-9169, 4903-9325, 4903-9327 | ||
| 4903-9194 | 30 | Free-run/Synchronized | 25/70 | Vertical | White | Horizontal | 4903-9170, 4903-9172, 4903-9328, 4903-9330 | ||
| 4903-9195[33] | 110 | Free-run/Synchronized | 25/70 | Vertical | White | Horizontal | 4903-9173, 4903-9175, 4903-9331, 4903-9333 | ||
| 4903-9196[34] | 15 | Free-run/Synchronized | 25/70 | Ceiling | White | Round | 4903-9155, 4903-9157, 4903-9313, 4903-9315 | ||
| 4903-9197[35] | 30 | Free-run/Synchronized | 25/70 | Ceiling | White | Round | 4903-9159, 4903-9161, 4903-9317, 4903-9321 | ||
| 4903-9198[36] | 110 | Free-run/Synchronized | 25/70 | Ceiling | White | Round | 4903-9163, 4903-9165, 4903-9321, 4903-9323 | ||
| 4903-9199 | 30 | Free-run/Synchronized | 25/70 | Horizontal | Red | Vertical | 4903-9143, 4903-9177, 4903-9304, 4903-9335 | ||
| 4903-9301 [37][38][39] | 15 | Synchronized | 25 | Vertical | Red | Horizontal | 4903-9150 | ||
| 4903-9302 | 15 | Synchronized | 25 | Horizontal | Red | Vertical | 4903-9153 | ||
| 4903-9303[40] | 30 | Synchronized | 25 | Vertical | Red | Horizontal | 4903-9148 | ||
| 4903-9304 | 30 | Synchronized | 25 | Horizontal | Red | Vertical | 4903-9199 | ||
| 4903-9305[41][42][43][44][45][46][47] | 110 | Synchronized | 25 | Vertical | Red | Horizontal | 4903-9149 | ||
| 4903-9306 | 110 | Synchronized | 25 | Horizontal | Red | Vertical | 4903-9343 | ||
| 4903-9307 | 15 | Synchronized | 25 | Ceiling | Red | Round | 4903-9347 | 4906-9160 (15CD) | |
| 4903-9308 | 30 | Synchronized | 25 | Ceiling | Red | Round | 4903-9348
4903-9369 (75CD) |
4906-9160 (30CD) | |
| 4903-9309 | 110 | Synchronized | 25 | Ceiling | Red | Round | 4903-9349
4903-9370 |
4906-9160 (110CD) | |
| 4903-9310 | 15 | Synchronized | 70 | Ceiling | Red | Round | 4903-9347 | 4906-9160 (15CD) | |
| 4903-9311 | 30 | Synchronized | 70 | Ceiling | Red | Round | 4903-9348
4903-9369 (75CD) |
| 4903-9312 | 110 | Synchronized | 70 | Ceiling | Red | Round | 4903-9349
4903-9370 |
| 4903-9313 | 15 | Synchronized | 25 | Ceiling | White (Round) | Round | 4903-9196
4903-9371 |
4906-9154 (15CD) | |
| 4903-9314 | 15 | Synchronized | 25 | Wall | White (Round) | Round | |||
| 4903-9315 | 15 | Synchronized | 70 | Ceiling | White (Round) | Round | 4903-9196
4903-9371 |
| 4903-9316 | 15 | Synchronized | 70 | Vertical | White (Round) | Round | |||
| 4903-9317 | 30 | Synchronized | 25 | Ceiling | White (Round) | Round | 4903-9197
4903-9372 (75CD) |
4906-9154 (30CD) | |
| 4903-9318 | 30 | Synchronized | 25 | Vertical | White (Round) | Round | |||
| 4903-9319 | 30 | Synchronized | 70 | Ceiling | White (Round) | Round | 4903-9197
4903-9372 (75CD) |
| 4903-9320 | 30 | Synchronized | 70 | Wall | White (Round) | Round | |||
| 4903-9321 | 110 | Synchronized | 25 | Ceiling | White (Round) | Round | 4903-9198
4903-9373 |
4906-9154 (110CD) | |
| 4903-9322 | 110 | Synchronized | 25 | Vertical | White (Round) | Round | |||
| 4903-9323 | 110 | Synchronized | 70 | Ceiling | White (Round) | Round | 4903-9198
4903-9373 |
| 4903-9324 | 110 | Synchronized | 70 | Vertical | White (Round) | Round | |||
| 4903-9325 | 15 | Synchronized | 25 | Vertical | White | Horizontal | 4903-9193 | ||
| 4903-9326[48] | 15 | Synchronized | 70 | Vertical | Red | Horizontal | 4903-9150 | ||
| 4903-9327 | 15 | Synchronized | 70 | Vertical | White | Horizontal | 4903-9193 | ||
| 4903-9328 | 30 | Synchronized | 25 | Vertical | White | Horizontal | 4903-9194 | ||
| 4903-9329[49][50][51] | 30 | Synchronized | 70 | Vertical | Red | Horizontal | 4903-9148 | ||
| 4903-9330 | 30 | Synchronized | 70 | Vertical | White | Horizontal | 4903-9194 | ||
| 4903-9331 | 110 | Synchronized | 25 | Vertical | White | Horizontal | 4903-9195 | ||
| 4903-9332[52][53][54] | 110 | Synchronized | 70 | Vertical | Red | Horizontal | 4903-9149 | ||
| 4903-9333 | 110 | Synchronized | 70 | Vertical | White | Horizontal | 4903-9195 | ||
| 4903-9334 | 15 | Synchronized | 70 | Horizontal | Red | Vertical | 4903-9153 | ||
| 4903-9335 | 30 | Synchronized | 70 | Horizontal | Red | Vertical | 4903-9199 | ||
| 4903-9336 | 110 | Synchronized | 70 | Horizontal | Red | Vertical | 4903-9343 | ||
| 4903-9337 | 15 | Synchronized | 25 | Horizontal | White | Vertical | 4903-9344 | ||
| 4903-9338 | 30 | Synchronized | 25 | Horizontal | White | Vertical | 4903-9345 | ||
| 4903-9339 | 110 | Synchronized | 25 | Horizontal | White | Vertical | 4903-9346 | ||
| 4903-9340 | 15 | Synchronized | 70 | Horizontal | White | Vertical | 4903-9344 | ||
| 4903-9341 | 30 | Synchronized | 70 | Horizontal | White | Vertical | 4903-9345 | ||
| 4903-9342 | 110 | Synchronized | 70 | Horizontal | White | Vertical | 4903-9346 | ||
| 4903-9343 | 110 | Free-run/Synchronized | 25/70 | Horizontal | Red | Vertical | 4903-9145, 4903-9178, 4903-9306, 4903-9336 | ||
| 4903-9344 | 15 | Free-run/Synchronized | 25/70 | Horizontal | White | Vertical | 4903-9179, 4903-9182, 4903-9337, 4903-9340 | ||
| 4903-9345 | 30 | Free-run/Synchronized | 25/70 | Horizontal | White | Vertical | 4903-9180, 4903-9183, 4903-9338, 4903-9341 | ||
| 4903-9346 | 110 | Free-run/Synchronized | 25/70 | Horizontal | White | Vertical | 4903-9181, 4903-9184, 4903-9339, 4903-9342 | ||
| 4903-9347 | 15 | Free-run/Synchronized | 25/70 | Ceiling | Red | Round | 4903-9307, 4903-9310 | ||
| 4903-9348 | 30 | Free-run/Synchronized | 25/70 | Ceiling | Red | Round | 4903-9308, 4903-9311 | ||
| 4903-9349 | 110 | Free-run/Synchronized | 25/70 | Ceiling | Red | Round | 4903-9309, 4903-9312 | ||
Rectangular horn strobes
| Model number | Horn model | Candela | Strobe orientation | Strobe sync | Mounting orientation | Color | Replaces | Replaced By | Current Replacement |
| 4903-9200[55] | 4901-9805 | 15 | Vertical | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Horizontal | Red | 4903-9219 | 4903-9252
4903-9425 | |
| 4903-9201 | 4901-9805 | 30 | Vertical | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Horizontal | Red | 4903-9215 | 4903-9253
4903-9426 (75CD) | |
| 4903-9202[56] | 4901-9805 | 110 | Vertical | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Horizontal | Red | 4903-9217 | 4903-9254
4903-9427 | |
| 4903-9203 | 4901-9805 | 15 | Horizontal | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Vertical | Red | 4903-9220 | 4903-9255
4903-9425 | |
| 4903-9204 | 4901-9805 | 30 | Horizontal | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Vertical | Red | 4903-9216 | 4903-9426 (75CD) | |
| 4903-9205 | 4901-9805 | 110 | Horizontal | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Vertical | Red | 4903-9218 | 4903-9256
4903-9427 | |
| 4903-9206 | 4901-9805 | 15 | Vertical | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Horizontal | White | 4903-9221 | 4903-9431 | |
| 4903-9207 | 4901-9805 | 30 | Vertical | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Horizontal | White | 4903-9222 | 4903-9432 (75CD) | |
| 4903-9208 | 4901-9805 | 110 | Vertical | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Horizontal | White | 4903-9223 | 4903-9433 | |
| 4903-9209 | 4901-9805 | 15 | Ceiling | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Ceiling | Red | 4903-9262 | 4903-9274
4903-9434 | |
| 4903-9210 | 4901-9805 | 30 | Ceiling | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Ceiling | Red | 4903-9263 | 4903-9275
4903-9436 (75CD) | |
| 4903-9211 | 4901-9805 | 110 | Ceiling | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Ceiling | Red | 4903-9264 | 4903-9276
4903-9436 | |
| 4903-9212 | 4901-9805 | 15 | Ceiling | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Ceiling | White | 4903-9265 | 4903-9277
4903-9437 | |
| 4903-9213 | 4901-9805 | 30 | Ceiling | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Ceiling | White | 4903-9266 | 4903-9278
4903-9438 (75CD) | |
| 4903-9214 | 4901-9805 | 110 | Ceiling | 24 FPM (Note; this is NOT SmartSync, this just takes a long time for the strobe to charge up) | Ceiling | White | 4903-9267 | 4903-9279
4903-9439 | |
| 4903-9215[57] | 4901-9805 | 30 | Vertical | Free-run | Horizontal | Red | 4903-9201 | 4903-9237 | 4903-9253
4903-9426 (75CD) |
| 4903-9216 | 4901-9805 | 30 | Horizontal | Free-run | Vertical | Red | 4903-9204 | 4903-9426 (75CD) | |
| 4903-9217[58] | 4901-9805 | 110 | Vertical | Free-run | Horizontal | Red | 4903-9202 | 4903-9238 | 4903-9254
4903-9427 |
| 4903-9218[59] | 4901-9805 | 110 | Horizontal | Free-run | Vertical | Red | 4903-9205 | 4903-9240 | 4903-9256
4903-9427 |
| 4903-9219[60] | 4901-9805 | 15 | Vertical | Free-run | Horizontal | Red | 4903-9200 | 4903-9236 | 4903-9252
4903-9425 |
| 4903-9220[61] | 4901-9805 | 15 | Horizontal | Free-run | Vertical | Red | 4903-9203 | 4903-9239 | 4903-9255
4903-9425 |
| 4903-9221[62] | 4901-9806 | 15 | Vertical | Free-run | Horizontal | White | 4903-9206 | 4903-9241 | 4903-9431 |
| 4903-9222[63] | 4901-9806 | 30 | Vertical | Free-run | Horizontal | White | 4903-9207 | 4903-9242 | 4903-9432 (75CD) |
| 4903-9223 | 4901-9806 | 110 | Vertical | Free-run | Horizontal | White | 4903-9208 | 4903-9243 | 4903-9433 |
| 4903-9225 | 4901-9806 | 15 | Horizontal | Free-run | Vertical | White | 4903-9244 | 4903-9431 | |
| 4903-9226 | 4901-9806 | 30 | Horizontal | Free-run | Vertical | White | 4903-9432 (75CD) | ||
| 4903-9227 | 4901-9806 | 110 | Horizontal | Free-run | Vertical | White | 4903-9245 | 4903-9433 | |
| 4903-9236[64] | 4901-9822 | 15 | Vertical | Free-run | Horizontal | Red | 4903-9200, 4903-9219 | 4903-9252, 4903-9425 | |
| 4903-9237[65] | 4901-9822 | 30 | Vertical | Free-run | Horizontal | Red | 4903-9201, 4903-9215 | 4903-9253, 4903-9426 (75CD) | |
| 4903-9238[66] | 4901-9822 | 110 | Vertical | Free-run | Horizontal | Red | 4903-9202, 4903-9217 | 4903-9254, 4903-9427 | |
| 4903-9239[67] | 4901-9822 | 15 | Horizontal | Free-run | Vertical | Red | 4903-9203, 4903-9220 | 4903-9255, 4903-9425 | |
| 4903-9240 | 4901-9822 | 110 | Horizontal | Free-run | Vertical | Red | 4903-9205, 4903-9218 | 4903-9256, 4903-9427 | |
| 4903-9241[68] | 4901-9822 (in white) | 15 | Vertical | Free-run | Horizontal | White | 4903-9206, 4903-9221 | 4903-9257, 4903-9431 | 4903-9431 |
| 4903-9242[69] | 4901-9822 (in white) | 30 | Vertical | Free-run | Horizontal | White | 4903-9207, 4903-9222 | 4903-9258, 4903-9432 (75CD) | 4903-9432 (75CD) |
| 4903-9244 | 4901-9822 (in white) | 15 | Horizontal | Free-run | Vertical | White | 4903-9225 | 4903-9260
4903-9431 | |
| 4903-9245 | 4901-9822 (in white) | 110 | Horizontal | Free-run | Vertical | White | 4903-9227 | 4903-9261
4903-9433 | |
| 4903-9252[70][71] | 4901-9822 | 15 | Vertical | Free-run | Horizontal | Red | 4903-9200, 4903-9219, 4903-9236, 4903-9401, 4903-9422 | ||
| 4903-9253[72] | 4901-9822 | 30 | Vertical | Free-run | Horizontal | Red | 4903-9201, 4903-9215, 4903-9237, 4903-9403, 4903-9423 | ||
| 4903-9254[73] | 4901-9822 | 110 | Vertical | Free-run | Horizontal | Red | 4903-9202, 4903-9217, 4903-9238, 4903-9405, 4903-9424 | ||
| 4903-9255[74] | 4901-9822 | 15 | Horizontal | Free-run | Vertical | Red | 4903-9203, 4903-9220, 4903-9239, 4903-9402, 4903-9420 | ||
| 4903-9256 | 4901-9822 | 110 | Horizontal | Free-run | Vertical | Red | 4903-9205, 4903-9218, 4903-9240, 4903-9406, 4903-9421 | ||
| 4903-9257[75] | 4901-9822 (in white) | 15 | Vertical | Free-run | Horizontal | White | 4903-9221, 4903-9241, 4903-9413 | ||
| 4903-9258[76][77][78][79][80][81][82] | 4901-9822 (in white) | 30 | Vertical | Free-run | Horizontal | White | 4903-9222, 4903-9242, 4903-9414 | ||
| 4903-9259 | 4901-9822 (in white) | 110 | Vertical | Free-run | Horizontal | White | 4903-9223, 4903-9243, 4903-9415 | ||
| 4903-9260 | 4901-9822 (in white) | 15 | Horizontal | Free-run | Vertical | White | 4903-9225, 4903-9244 | ||
| 4903-9261 | 4901-9822 (in white) | 110 | Horizontal | Free-run | Vertical | White | 4903-9227, 4903-9245 | ||
| 4903-9262 | 4901-9805 | 15 | Ceiling | Free-run | Ceiling | Red | 4903-9209 | 4903-9268 | 4903-9274
4903-9434 |
| 4903-9263 | 4901-9805 | 30 | Ceiling | Free-run | Ceiling | Red | 4903-9210 | 4903-9269 | 4903-9275
4903-9436 (75CD) |
| 4903-9264 | 4901-9805 | 110 | Ceiling | Free-run | Ceiling | Red | 4903-9211 | 4903-9270 | 4903-9276
4903-9436 |
| 4903-9265 | 4901-9806 | 15 | Ceiling | Free-run | Ceiling | White | 4903-9212 | 4903-9271 | 4903-9277
4903-9437 |
| 4903-9266 | 4901-9806 | 30 | Ceiling | Free-run | Ceiling | White | 4903-9213 | 4903-9272 | 4903-9278
4903-9438 (75CD) |
| 4903-9267 | 4901-9806 | 110 | Ceiling | Free-run | Ceiling | White | 4903-9214 | 4903-9273 | 4903-9279
4903-9439 |
| 4903-9268 | 4901-9822 | 15 | Ceiling | Free-run | Ceiling | Red | 4903-9262 | 4903-9274, 4903-9434 | |
| 4903-9269 | 4901-9822 | 30 | Ceiling | Free-run | Ceiling | Red | 4903-9263 | 4903-9275, 4903-9435 (75CD) | |
| 4903-9270 | 4901-9822 | 110 | Ceiling | Free-run | Ceiling | Red | 4903-9264 | 4903-9276, 4903-9436 | |
| 4903-9271 | 4901-9822 (in white) | 15 | Ceiling | Free-run | Ceiling | White | 4903-9265 | 4903-9277, 4903-9437 | |
| 4903-9272 | 4901-9822 (in white) | 30 | Ceiling | Free-run | Ceiling | White | 4903-9266 | 4903-9278, 4903-9438 (75CD) | |
| 4903-9273 | 4901-9822 (in white) | 110 | Ceiling | Free-run | Ceiling | White | 4903-9267 | 4903-9279, 4903-9439 | |
| 4903-9274 | 4901-9822 | 15 | Ceiling | Free-run/Synchronized | Ceiling | Red | 4903-9209, 4903-9262, 4903-9268, 4903-9407 | ||
| 4903-9275 | 4901-9822 | 30 | Ceiling | Free-run/Synchronized | Ceiling | Red | 4903-9210, 4903-9263, 4903-9269, 4903-9408 | ||
| 4903-9276 | 4901-9822 | 110 | Ceiling | Free-run/Synchronized | Ceiling | Red | 4903-9211, 4903-9264, 4903-9270, 4903-9409 | ||
| 4903-9277 | 4901-9822 (in white) | 15 | Ceiling | Free-run/Synchronized | Ceiling | White | 4903-9212, 4903-9265, 4903-9271, 4903-9410 | ||
| 4903-9278 | 4901-9822 (in white) | 30 | Ceiling | Free-run/Synchronized | Ceiling | White | 4903-9213, 4903-9266, 4903-9272, 4903-9411 | ||
| 4903-9279 | 4901-9822 (in white) | 110 | Ceiling | Free-run/Synchronized | Ceiling | White | 4903-9214, 4903-9267, 4903-9273, 4903-9412 | ||
| 4903-9401[83] | 4901-9805 | 15 | Vertical | Synchronized[citation needed] | Horizontal | Red | 4903-9422 | 4903-9252
4903-9425 | |
| 4903-9402 | 4901-9805 | 15 | Horizontal | Synchronized | Vertical | Red | 4903-9420 | 4903-9255
4903-9425 | |
| 4903-9403[84] | 4901-9805 | 30 | Vertical | Synchronized | Horizontal | Red | 4903-9423 | 4903-9253
| 4903-9404 | 4901-9805 | 30 | Horizontal | Synchronized | Vertical | Red | 4903-9426 (75CD) | ||
| 4903-9405[85] | 4901-9805 | 110 | Vertical | Synchronized | Horizontal | Red | 4903-9424 | 4903-9254
4903-9427 | |
| 4903-9406 | 4901-9805 | 110 | Horizontal | Synchronized | Vertical | Red | 4903-9421 | 4903-9256
4903-9427 | |
| 4903-9407 | 4901-9805 | 15 | Ceiling | Synchronized | Ceiling | Red | 4903-9274, 4903-9434 | ||
| 4903-9408 | 4901-9805 | 30 | Ceiling | Synchronized | Ceiling | Red | 4903-9275, 4903-9435 (75CD) | ||
| 4903-9409 | 4901-9805 | 110 | Ceiling | Synchronized | Ceiling | Red | 4903-9276, 4903-9436 | ||
| 4903-9410 | 4901-9806 | 15 | Ceiling | Synchronized | Ceiling | White | 4903-9277, 4903-9437 | ||
| 4903-9411 | 4901-9806 | 30 | Ceiling | Synchronized | Ceiling | White | 4903-9278, 4903-9438 (75CD) | ||
| 4903-9412 | 4901-9806 | 110 | Ceiling | Synchronized | Ceiling | White | 4903-9279, 4903-9439 | ||
| 4903-9413 | 4901-9806 | 15 | Vertical | Synchronized | Horizontal | White | 4903-9257
4903-9431 |
4903-9431 | |
| 4903-9414 | 4901-9806 | 30 | Vertical | Synchronized | Horizontal | White | 4903-9258
4903-9432 |
4903-9432 | |
| 4903-9415 | 4901-9806 | 110 | Vertical | Synchronized | Horizontal | White | 4903-9259
4903-9433 |
4903-9433 | |
| 4903-9420 | 4901-9822 | 15 | Horizontal | Synchronized | Vertical | Red | 4903-9402 | 4903-9255
4903-9425 | |
| 4903-9421 | 4901-9822 | 110 | Horizontal | Synchronized | Vertical | Red | 4903-9406 | 4903-9256
4903-9427 | |
| 4903-9422[86] | 4901-9822 | 15 | Vertical | Synchronized | Horizontal | Red | 4903-9401 | 4903-9252, 4903-9425 | |
| 4903-9423[87] | 4901-9822 | 30 | Vertical | Synchronized | Horizontal | Red | 4903-9403 | 4903-9253, 4903-9426 (75CD) | |
| 4903-9424[88] | 4901-9822 | 110 | Vertical | Synchronized | Horizontal | Red | 4903-9405 | 4903-9254, 4903-9427 | |
Rebranded horn strobes
| Simplex model | OEM | OEM model | Replaced | Replaced by |
| 4903-9103 | Gentex | GX90S-4 | ||
| 4903-9224 | Gentex | GX90S-4-15/75WR | ||
| 4903-9230 | Wheelock | MT-24-SL-VFR | 4903-9425 | |
| 4903-9231 | Wheelock | MT-24-SLM-VFR | ||
| 4903-9232 | Wheelock | MIZ-24-LS-VFR | ||
| 4903-9233 | Wheelock | MIZ-24-LSM-VFR | ||
| 4903-9234[89][90][91][92][93][94][95][96][97][98][99][100][101] | Wheelock | MT-24-LSM-VFR | ||
| 4903-9235[102] | Wheelock | MT-24-WM-VFR | 4903-9427 | |
| 4903-9243[103][104][105][106][107] | Wheelock | AS-24110W-FR | 4903-9419 | |
| 4903-9246[108][109][110] | Wheelock | AS-2430W-FR | ||
| 4903-9247[111] | Wheelock | AS-2475W-FR | 4903-9418 | |
| 4903-9248 | Wheelock | NS4-2415W-FR | ||
| 4903-9249 | Wheelock | NS4-241575W-FR |
Rebranded speaker strobes
| 4903-9179 | Wheelock | E-70-SL-24-VFR | ||
| 4903-9180 | Wheelock | E-70-SLM-24-VFR | ||
| 4903-9181 | Wheelock | ET-1070-SL-24-VFR | ||
| 4903-9182 | Wheelock | ET-1070-SLM-24-VFR | ||
| 4903-9183 | Wheelock | ET-1080-SL-24-VFR | ||
| 4903-9184 | Wheelock | ET-1080-SLM-24-VFR | ||
| 4903-9185 | Wheelock | E-70-SL-24-CFR | ||
| 4903-9186 | Wheelock | E70-2415W-FR | ||
| 4903-9187[112][113][114][115][116][117][118] | Wheelock | E70-241575W-FR | ||
| 4903-9188[119][120][121][122][123][124][125][126][127] | Wheelock | E90-2415C-FW | ||
| 4903-9189 | Wheelock | ET70-2415W-FR | ||
| 4903-9190 | Wheelock | ET70-241575W-FR | ||
| 4903-9191 | Wheelock | E90-2430C-FW | ||
| 4903-9192 | Wheelock | E90-2475C-FW |
Rebranded chime strobes
| Simplex Model | OEM | OEM model | Replaced | Replaced By |
| 4903-9293[128][129] | Wheelock | CH70-241575W-FR |
Notes
- ↑ https://www.schuminweb.com/fire_alarms/simplex-4903-9101/
- ↑ https://firealarms.tv/collection/simplex-4903-9102/
- ↑ https://www.ebay.com/itm/115884333480
- ↑ http://www.fazone.net/html/simplex_4903-9105.html
- ↑ https://i.ebayimg.com/images/g/cRIAAOSwJkJWlbn~/s-l1600.jpg
- ↑ https://i.ebayimg.com/images/g/zeYAAOSwX~dWlboF/s-l1600.jpg
- ↑ https://i.ebayimg.com/images/g/tVEAAOSwwPhWlbn5/s-l1600.jpg
- ↑ https://i.ebayimg.com/images/g/cAoAAOSwJkJWlbnz/s-l1600.jpg
- ↑ https://i.ebayimg.com/images/g/OvsAAOSwpK1kwxmu/s-l1600.webp
- ↑ https://cdn.thefirepanel.com/original/2X/4/4264c21bc0179fad81c01e18495d67686d765318.jpeg
- ↑ https://cdn.thefirepanel.com/original/3X/0/6/06a676035e8d8283bf777c6f8c1ad4696c438eb6.jpeg
- ↑ https://cdn.thefirepanel.com/original/3X/c/0/c02fdd2dcd36ccaef5b00ee91cb04bd72944088d.jpeg
- ↑ https://www.ebay.com/itm/280885619273
- ↑ https://www.ebay.com/itm/364216814892
- ↑ https://cdn.thefirepanel.com/original/3X/3/7/377c69f927629133584dbbaed1782ae844a8071e.jpeg
- ↑ https://i.ebayimg.com/images/g/SxQAAOSw0AtoWV0c/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/sdoAAOSwlbpoWV0d/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/Uq4AAOSwHkVoWV0e/s-l1600.webp
- ↑ https://www.youtube.com/watch?v=5EJuKh94kjo
- ↑ https://www.youtube.com/watch?v=PHzZWzRRb7I
- ↑ "Speaker/Visible Appliances; Speaker with Strobe Selectable as Free-Run or Synchronized" (S4903-0016-5). Simplex (May 2014).
- ↑ https://www.buyfirealarmparts.com/shop/simplex-4903-9148-speaker-strobe.html
- ↑ https://cdn.thefirepanel.com/original/3X/b/f/bfc9c9518405fdc828caae3a6705cee4425469c4.jpeg
- ↑ https://www.buyfirealarmparts.com/shop/simplex-4903-9150-strobe-with-speakers.html
- ↑ https://thefirealarmsupplier.com/cdn/shop/products/simplex-4903-9153-812933.jpg?v=1719577463&width=2048
- ↑ https://cdn.thefirepanel.com/docs/simplex/Simplex%20-%204903%20Speaker%20Visible%20And%204904%20Visible%20Only%20Units%20Installation%20Instructions.pdf
- ↑ https://www.buyfirealarmparts.com/shop/simplex-4903-9167.html
- ↑ https://firealarms.tv/wp-content/uploads/2016/04/4903-9168_2751_1.jpg
- ↑ https://www.picclickimg.com/images/g/yskAAOSwU0VdwXlc/s-l1600.jpg
- ↑ https://th.bing.com/th/id/R.ac234a1bd1ba468393924615b326c8f3?rik=2oMAJSRwnemcNw&riu=http%3a%2f%2fs3.amazonaws.com%2fidealm_img%2f15000%2f15423%2f15423.jpg&ehk=iaU9FHxig5W4j0a4wfVO%2f0L%2bqTXf2U06aI0qThClDC8%3d&risl=&pid=ImgRaw&r=0
- ↑ https://sbindustrialsupply.com/wp-content/uploads/imported/1/91/NEW-SIMPLEX-4903-9174-FIRE-ALARM-HORNSTROBE-49039174-193773879891.JPG
- ↑ https://www.buyfirealarmparts.com/shop/pub/media/catalog/product/cache/86a3c1e3f0f8a151f5dc54c5673def02/d/s/dscn1796.png
- ↑ https://th.bing.com/th/id/R.c8941a1bf5b3bc29f5d6b2853d162a03?rik=Gr3mjZ%2b%2fPGYDIg&riu=http%3a%2f%2flistings.toomanyamps.com%2fimage%2fSIM49039195USED-B.jpg&ehk=mcwsfpL6Nufj%2bTXHrbxmZGT%2fUyd%2bkWIwa9JxKmKGDpQ%3d&risl=1&pid=ImgRaw&r=0
- ↑ https://www.buyfirealarmparts.com/shop/pub/media/catalog/product/cache/6de89ad008d52a1c1754ac54640b396e/d/s/dscn2357.png
- ↑ https://www.buyfirealarmparts.com/shop/pub/media/catalog/product/cache/6de89ad008d52a1c1754ac54640b396e/2/0/20200820_122206_edited.jpg
- ↑ https://www.buyfirealarmparts.com/shop/pub/media/catalog/product/cache/86a3c1e3f0f8a151f5dc54c5673def02/s/i/simplex_4903-9198_4_edited.jpg
- ↑ https://i.ebayimg.com/images/g/3GAAAeSwaqVoLmIs/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/9b0AAeSwl3loLmIu/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/c6cAAeSwNV1oLmIu/s-l1200.jpg
- ↑ https://www.youtube.com/watch?v=RAkmfAXi37g
- ↑ https://i.ebayimg.com/images/g/EvIAAOSwqtljA-SK/s-l1600.jpg
- ↑ https://i.ebayimg.com/images/g/OigAAOSwud9jA-SN/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/0sMAAOSw9cljA-SO/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/ZZgAAOSw031jA-SP/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/W6EAAOSwN39jA-SQ/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/easAAOSwRU5jA-SS/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/psgAAOSws5NjA-ST/s-l1600.webp
- ↑ https://www.youtube.com/watch?v=DV7IscnjMQA
- ↑ https://i.ebayimg.com/images/g/FLMAAeSwf-hpC4Oh/s-l1200.png
- ↑ https://i.ebayimg.com/images/g/9pAAAeSwd0tpC4Oh/s-l1200.png
- ↑ https://i.ebayimg.com/images/g/VXMAAeSwK0RpC4Oj/s-l1200.png
- ↑ https://i.ebayimg.com/images/g/fj0AAeSwBzFpC4Kr/s-l1200.png
- ↑ https://i.ebayimg.com/images/g/rXEAAeSwtwVpC4Ks/s-l1200.png
- ↑ https://i.ebayimg.com/images/g/ZocAAeSwkvBpC4Ks/s-l1200.png
- ↑ https://cdn.thefirepanel.com/original/2X/5/5f58b8b378f0c992138de9f05ce059ef97794858.jpeg
- ↑ https://www.youtube.com/watch?v=5pjilhUNvqE
- ↑ https://www.imssupply.com/productImages/4/6/2/D/9/9/1/462D9918-4BB7-4DCA-9B47-6933CB2FB6B8_01.JPG?timestamp=1738181184828
- ↑ https://firealarms.tv/collection/simplex-4903-9217/
- ↑ https://i.ebayimg.com/images/g/ZhkAAOSw7oNnN3M6/s-l1200.jpg
- ↑ https://firealarms.tv/collection/simplex-4903-9219/
- ↑ https://firealarms.tv/collection/simplex-4903-9220/
- ↑ https://www.youtube.com/watch?v=xquTiNlfoSs
- ↑ https://cdn.thefirepanel.com/original/2X/c/c9a8e4f80b8f895f975c00b0f63fd6a7f7744f36.jpeg
- ↑ https://firealarms.tv/collection/simplex-4903-9236/
- ↑ https://www.youtube.com/watch?v=25aKQxN2-k8
- ↑ https://firealarms.tv/collection/simplex-4903-9238/
- ↑ https://firealarms.tv/collection/simplex-4903-9239/
- ↑ https://firealarms.tv/wp-content/uploads/2016/05/4903-9241_6071_1.jpg
- ↑ https://www.youtube.com/watch?v=N8jsp8gEFqM
- ↑ https://docs.johnsoncontrols.com/simplex/api/khub/documents/_YIm58KQE~0K3eWQeIW0Gw/content
- ↑ https://www.fazone.net/Simplex_4903-9252_1.JPG
- ↑ https://www.buyfirealarmparts.com/shop/pub/media/catalog/product/cache/6de89ad008d52a1c1754ac54640b396e/4/9/4903-9253_edited.jpg
- ↑ https://i.ebayimg.com/images/g/S7EAAOSwhLFnX1T0/s-l1600.webp
- ↑ https://www.hvacusa.com/simplex_4903-9255
- ↑ https://www.youtube.com/watch?v=y2ovJhe75IU
- ↑ https://i.ebayimg.com/images/g/YBQAAOSw5wxoN0EK/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/gekAAOSwzdJoN0EL/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/6KUAAOSwYNxoN0EL/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/u6oAAOSwLMNoN0EK/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/Ia4AAOSwg85oN0EM/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/9zAAAOSwkOdoN0EN/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/MrwAAOSwakZoN0EN/s-l1200.jpg
- ↑ https://www.youtube.com/watch?v=RXFFDaqaaGI
- ↑ https://www.youtube.com/watch?v=-hggxK87Ts8
- ↑ http://www.fazone.net/html/simplex_4903-9405.html
- ↑ https://th.bing.com/th/id/R.ade977406190a6d7de0dfec9e37bf1b9?rik=exDEIx%2bV4gFgcQ&riu=http%3a%2f%2ffiles.schuminweb.com%2fodds-and-ends%2falarm-collection%2ffull-size%2fsimplex-4903-9422-01.jpg&ehk=4meAV6lKVk7hT1jqOJLCLPTHSJcMdDaUpJFsKMF0xfA%3d&risl=&pid=ImgRaw&r=0
- ↑ https://www.youtube.com/watch?v=1BOCV9ego6Q
- ↑ https://www.fazone.net/html/simplex_4903-9424.html
- ↑ https://i.ebayimg.com/images/g/AKAAAOSw-m1oJ5KZ/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/9ekAAOSwDSVoJ5Kb/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/JEsAAOSwHuNoJ5Kc/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/VW0AAOSwxfxoJ5Ke/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/7~oAAOSwB9BoJ5Kg/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/S6sAAOSwCaJoJ5Kh/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/0SwAAOSwAWZoJ5Ki/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/Y9MAAOSwPgJoJ5Kk/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/NbAAAOSwJRVoJ5Kl/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/H3QAAOSwqQxoJ5Km/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/~XIAAOSwxr9oJ5Ko/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/LpEAAOSwr79oJ5Kp/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/5PQAAOSwWAhoJ5Kq/s-l1200.jpg
- ↑ http://www.fazone.net/html/wheelock_mt-24-wm.html
- ↑ https://www.ebay.com/itm/177898636470?itmmeta=01KJTGF6X80BCMQ7MQ23N89NNA&hash=item296b95c4b6:g:kEEAAeSwrClpoG2J
- ↑ https://i.ebayimg.com/images/g/I0sAAOSwES1n6wvC/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/zs8AAOSw6UBn6wvF/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/RY8AAOSwKPxn6wvI/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/vCYAAOSwiYleVsEz/s-l640.jpg
- ↑ https://i.ebayimg.com/images/g/kWoAAOSwMrJnhE38/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/6z0AAOSwqPlnhE4j/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/cmoAAOSwEChnhE8n/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/StgAAOSwrBVnhE41/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/m70AAOSw9E1nhE8U/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/7mwAAOSwtGBnhE4I/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/4-sAAOSw7NNnhE4T/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/qW0AAOSw3vVnS3AO/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/NogAAOSwnQVnS3AP/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/0N0AAOSwacBnS3AQ/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/4CwAAOSwrllnS3AQ/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/hSEAAOSwz8xnS3AR/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/nIcAAOSwqj1nS3AW/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/U9IAAOSwA4RnS3AX/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/BjsAAOSw7iNnS3AX/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/LA0AAOSwCJdnS3AY/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/2zYAAOSwA7hn9nou/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/RVsAAOSwSeRn9npS/s-l1600.webp
