Wheelock A series
Wheelock A series
WheelockAS-MCWandWheelockAS-2430WandDMP904-81.png: Infobox image for Wheelock A series the infobox device.
10.5-15.6VDC & 20-31VDC {"label": "Rated Voltage", "field": "10.5-15.6VDC & 20-31VDC"}
1995[1] {"label": "Introduced", "field": "1995[1]"}
2010[2] {"label": "Discontinued", "field": "2010[2]"}
Wheelock MIZ series {"label": "Preceded by", "field": "Wheelock MIZ series"}
Wheelock Exceder series {"label": "Succeeded by", "field": "Wheelock Exceder series"}
The Wheelock A series is a series of synchronized horns and two-wire horn strobes and the first horn strobes to support audible silence over two wires, as well as Wheelock's first horn strobes to mount on a universal mounting plate. The A series was produced alongside several other series such as the N series before it was discontinued in March 2010 and replaced with the Exceder series.
The A series was released in 1995 with the same horn as the MT. The original 15, 15/75, 30, and 75 candela strobe models featured a vertical strobe to the right of the horn, resembling the Simplex 4903 series ADA horn strobes. The 110 candela models had a horizontal strobe above the horn. The original models only outputted a continuous tone when receiving a constant input voltage, but they switched to Code 3 when receiving the synchronization protocol.[3]
The AS was updated in 1997 along with the release of the NS to give all models a horizontal strobe above the horn.[4] The A series was updated again in 1998 to gain a free-run Code 3 option.[5]
A multi-candela version of the AS was released in 1999 as part of the SPEC1FIRE series. A ceiling-mount multi-candela model was released in 2003,[6] and high-intensity multi-candela models were released later in 2003.[7]
The A series was discontinued in 2010 and succeeded by the Exceder HS series.
The A series horns can be synchronized when connected to an SM or DSM. There are 3 volume settings, and the horns are capable of outputting either a continuous horn or a Code 3 horn.
Depending on the model of an AS horn strobe, the strobe could output 15, 15/75, 30, 75, 110, 115, 135, 177, or 185 candela.
AH series
Model Number Nominal Voltage Color Replaced by
AH-12-R 12VDC Red HSR
AH-12-W 12VDC White HSW
AH-24-R 24VDC Red HSR
AH-24-W 24VDC White HSW
AS series
Model Number Nominal Voltage Candela Color Strobe Orientation Mounting Replaced by
AS-1215-VFR[8] 12VDC 15 Red Vertical Wall AS-1215W-FR
AS-1215-VFW 12VDC 15 White Vertical Wall AS-1215W-FW
AS-121575-VFR 12VDC 15/75 Red Vertical Wall AS-121575W-FR
AS-121575-VFW 12VDC 15/75 White Vertical Wall AS-121575W-FW
AS-1230-VFR 12VDC 30 Red Vertical Wall None
AS-1230-VFW 12VDC 30 White Vertical Wall None
AS-2415-VFR 24VDC 15 Red Vertical Wall AS-2415W-FR
AS-2415-VFW 24VDC 15 White Vertical Wall AS-2415W-FW
AS-241575-VFR 24VDC 15/75 Red Vertical Wall AS-241575W-FR
AS-241575-VFW 24VDC 15/75 White Vertical Wall AS-241575W-FW
AS-2430-VFR 24VDC 30 Red Vertical Wall AS-2430W-FR
AS-2430-VFW 24VDC 30 White Vertical Wall AS-2430W-FW
AS-2475-VFR 24VDC 75 Red Vertical Wall AS-2475W-FR
AS-2475-VFW 24VDC 75 White Vertical Wall AS-2475W-FW
AS-24110-HFR 24VDC 110 Red Horizontal Wall AS-24110W-FR
AS-24110-HFW 24VDC 110 White Horizontal Wall AS-24110W-FW
AS-1215W-FR 12VDC 15 Red Horizontal Wall AS-121575W-FR
AS-1215W-FW 12VDC 15 White Horizontal Wall AS-121575W-FW
AS-121575W-FR 12VDC 15/75 Red Horizontal Wall HSR
AS-121575W-FW 12VDC 15/75 White Horizontal Wall HSW
AS-2415W-FR 24VDC 15 Red Horizontal Wall AS-24MCW-FR
AS-2415W-FW 24VDC 15 White Horizontal Wall AS-24MCW-FW
AS-241575W-FR 24VDC 15/75 Red Horizontal Wall HSR
AS-241575W-FW 24VDC 15/75 White Horizontal Wall HSW
AS-2430W-FR 24VDC 30 Red Horizontal Wall AS-24MCW-FR
AS-2430W-FW 24VDC 30 White Horizontal Wall AS-24MCW-FW
AS-2475W-FR 24VDC 75 Red Horizontal Wall AS-24MCW-FR
AS-2475W-FW 24VDC 75 White Horizontal Wall AS-24MCW-FW
AS-24110W-FR 24VDC 110 Red Horizontal Wall AS-24MCW-FR
AS-24110W-FW 24VDC 110 White Horizontal Wall AS-24MCW-FW
AS-2415C-FR 24VDC 15 Red N/A Ceiling AS-24MCC-FR
AS-2415C-FW 24VDC 15 White N/A Ceiling AS-24MCC-FW
AS-2430C-FR 24VDC 30 Red N/A Ceiling AS-24MCC-FR
AS-2430C-FW 24VDC 30 White N/A Ceiling AS-24MCC-FW
AS-2475C-FR 24VDC 75 Red N/A Ceiling AS-24MCC-FR
AS-2475C-FW 24VDC 75 White N/A Ceiling AS-24MCC-FW
AS-24100C-FR 24VDC 100 Red N/A Ceiling AS-24MCC-FR
AS-24100C-FW 24VDC 100 White N/A Ceiling AS-24MCC-FW
AS-24MCW-FR 24VDC 15, 30, 75, 110 Red Horizontal Wall HSR
AS-24MCW-FW 24VDC 15, 30, 75, 110 White Horizontal Wall HSW
AS-24MCWH-FR 24VDC 135, 185 Red Horizontal Wall HSR
AS-24MCWH-FW 24VDC 135, 185 Red Horizontal Wall HSW
AS-24MCC-FR 24VDC 15, 30, 75, 95 Red N/A Ceiling HSRC
AS-24MCC-FW 24VDC 15, 30, 75, 95 White N/A Ceiling HSWC
AS-24MCCH-FR 24VDC 115, 177 Red N/A Ceiling HSRC
AS-24MCCH-FW 24VDC 115, 177 White N/A Ceiling HSWC
There are a few companies that have made rebrands of the Wheelock AS, this includes (but not limited to):
  • Bosch/Radionics
  • DMP
  • Siemens
71613[9] AH-24-R AH-24-R
72032[10] AS-24MCW-FR AS-24MCW-FR
72033 AS-24MCW-FW AS-24MCW-FW
71680 AS-241575W-FR AS-241575W-FR
71727 AS-2415C-FW
71728 AS-2430C-FW
71729 AS-2475C-FW
71684 AS-24100C-FW
Siemens started rebranding the A series around 2007, when the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit required the Siemens U series to be discontinued. The series was also sold under the Faraday brand to replace the 6300 series and 2800 series.
AH-R AH-24-R 2831B-14-24
6301B-0-14-24-DC
6311B-0-14-24-DC
G1R-P-LG + G1RT(-FIRE)-LG
G1RF-P-LG + G1RT(-FIRE)-LG
G1R-HD-LG + G1RT(-FIRE)-LG
G1RF-HD-LG + G1RT(-FIRE)-LG
U-MH
U-MHT
U-MHU
SL2HWR-N[11]
SL2HCR-N[12]
AH-W AH-24-W 2831B-21-24
6301B-0-21-24-DC
6311B-0-21-24-DC
G1-P-LG + G1T(-FIRE)-LG
G1F-P-LG + G1T(-FIRE)-LG
G1-HD-LG + G1T(-FIRE)-LG
G1F-HD-LG + G1T(-FIRE)-LG
U-MH-W
U-MHT-W
U-MHU-W
SL2HWW-N
AH-R-WP AH-24WP-R 2836B-14-24
U-MHU-WP
AS-MC-R AS-24MCW-FR G1R-HDVM-LG
G1RF-HDVM-LG
SL2HSWR-F
AS-MC-W AS-24MCW-FW G1-HDVM-LG
G1F-HDVM-LG
SL2HSWW-F
AS-HMC-R AS-24MCWH-FR None SL2HSWR-F
AS-HMC-W AS-24MCWH-FW None SL2HSWW-F
AS-MC-CR AS-24MCC-FR 2834B-14-24
U-MHU-MCS
SL2HSCR-F
AS-MC-CW AS-24MCC-FW 2834B-21-24
U-MHU-MCS-W
AS-HMC-CR AS-24MCCH-FR None SL2HSCR-F
AS-HMC-CW AS-24MCCH-FW None SL2HSCW-F
AS-75-R-WP ASWP-2475W-FR 2837B-14-24
U-MHU-MCS-WP
AS-75-CR-WP ASWP-2475C-FR 2837B-14-24
U-MHU-MCS-WP
Simplex model Wheelock model Replaced by
4903-9246 [13][14][15] AS-2430W-FR
4903-9247[16] AS-2475W-FR 4903-9418
