Fire-Lite MS series panels
MS-series.webp: Infobox image for Fire-Lite MS series panels the infobox device.
Communication protocol
CLIP
LiteSpeed {"label": "Communication protocol", "field": "CLIP
LiteSpeed"}
Fire-Lite Miniscan series panels
Fire-Lite Sensiscan series {"label": "Preceded by", "field": "Fire-Lite Miniscan series panels
Fire-Lite Sensiscan series"}
Fire-Lite ES series panels {"label": "Succeeded by", "field": "Fire-Lite ES series panels"}
The Fire-Lite MS series is a series of fire alarm control panels manufactured and produced by Fire-Lite Alarms, a subsidiary of Honeywell. The Fire-Lite MS series comes in conventional and addressable models. "MS" stands for "Micro-Scan", implying the MS series panels are based on micro processors. The MS series panels were some of the first readily available micro processor based panels, as well the MS-9200 was one of the first cost effective and affordable micro processor based addressable fire alarm control panels on the market.
All panels except MS-2/4 and MS-5/10UD have been replaced by the ES series of panels.
The MS-9200 was introduced in 1994 to replace the MS4812 and MS4824, which used the Ademco SLC protocol. The 300 series addressable devices were also introduced at this time.
In 2001, Fire-Lite introduced the MS-9600 together with the 350 series.[1] Although the MS-9600 did not support LiteSpeed, it was capable of polling 318 devices on each SLC.
Later in 2001, the MS-2 and MS-4 were introduced together with the System Sensor i3 series.[2] The MS-2 and MS-4 had integrated i3 protocol support on their 2-wire IDCs, eliminating the need for a separate 2W-MOD.
Between March and April 2010, Fire-Lite introduced the MS-25, which was Fire-Lite's version of the Honeywell HFS panel.[3]
In September 2025, the MS-2-L8 and MS-4 were discontinued. The MS-5UD-3 and MS-10UD-7 were recommended as temporary replacements, with plans announced for longer term replacements in the future.[4]
Model suffix "UD" indicates Upload/Download support (For programming via PS-Tools on a Windows™ computer)
Model suffix "LS" indicates LiteSpeed Protocol support
Addressable models with suffix "UD" and/or "LS" came out later after the initial release of the MS series and have different door designs, firmware, and PCBs.
The MS-5/10/9050UD models all came out later after the initial release of the Fire-Lite MS series.
Conventional Models
Model Number Zones NAC(s) Usable current Output Current Type Released Replaced
MS-2 2 Zones 1 3.0A FWR 2001 MP-12/24
MS-4 4 Zones 2 3.0A or 6.0A FWR 2001 MP-12/24
MS-5012 5 Zones 1 1.0A FWR 1993
MS-5024 5 Zones 2 3.0A FWR 1994
MS-5024UD 5 Zones 2 3.0A or 5.0A FWR 1994
MS-5210UD 10 Zones 2 (up to 4) 3.0A or 6.0A FWR 1996
MS-5UD 5 Zones 4 3.0A or 7.0A FWR (3A) / DC (7A)[5] 2007 MS-5012/24
MS-10UD 10 Zones‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ ‎ 4 3.0A or 7.0A FWR (3A) / DC (7A) 2007 MS-5210UD/2410B
Addressable Models
Model Number Points NAC(s) Usable current Output Current Type Released Replaced Replaced by
MS-25 25 Points 2 2.0A Filtered DC 2010 None MS-9050UD
MS-9050UD 50 Points 2 3.0A Filtered DC 2006 MS-25 ES-50X
MS-9200 198 Points 4 3.0A or 6.0A FWR 1994 MS4812
MS4824
MS-9200UDLS
MS-9200UD 198 Points 4 3.0A or 6.0A FWR 2003 Sensiscan 2000 MS-9200UDLS
MS-9200UDLS 198 Points 4 3.0A or 6.0A FWR 2006 MS-9200
MS-9200UD
ES-200X
MS-9600 318 Points (636 with SLC-2LS) 4 7.0A Filtered DC 2001 MS-9600LS
MS-9600LS 318 Points (636 with SLC-2LS) 4 7.0A Filtered DC 2007 MS-9600 ES-1000XI
MS-9600UDLS 318 Points (636 with SLC-2LS) 4 7.0A Filtered DC 2008 ES-1000X
  • i³™ Technology (Drift Compensation, Maintenance Alerts, Freezing Temperature Supervisory Warning) [Conventional panels only]
  • NAC synchronization (System Sensor, Wheelock, and Gentex Sync) [Amseco and Faraday on the MS-5/10UD]
  • Front Panel Programming
  • Walk Test
  • Form C contact relays (Fully programmable on the MS-5UD and greater)
  • Addressable panels support CLIP and LS models support LiteSpeed protocol for detector and module communication
Peripherals
Annunciator Compatibility Matrix
X RZA-4XF RZA-5F LED-10 LCD-40 LCD-80F ANN-80 ANN-LED
MS-2
MS-4 X
MS-5012/24/24UD X
MS-5UD X X
MS-5210UD X
MS-10UD X X
MS-25 X
MS-9050UD X X
MS-9200 X
MS-9200UD X
MS-9200UDLS X Rev B+ Rev B+
MS-9600 X
MS-9600LS X X X
MS-9600UDLS X X X
ADT & Tyco
ADT model Fire-Lite model Replaced Replaced by
Unimode 5 MS-5024UD
Unimode 10 MS-5210UD
Unimode 5UD MS-5UD
Unimode 10UD MS-10UD
Unimode 9050UD MS-9050UD
Unimode 200 MS-9200
Unimode 200UD MS-9200UD
Unimode 200UDLS MS-9200UDLS
Gamewell-FCI rebranded the conventional panels until 2022, when consumers were instructed to switch to the original Fire-Lite models.[6]
Gamewell-FCI model Fire-Lite model Replaced Replaced by
Flex 402 MS-2 FC-2224 MS-2-L8
Flex 404 MS-4 Flex 4
FC-4224
MS-4
Flex 405 MS-5024UD GF-505
FC-5C MS-5024UD FC-6324 GF-505
FC-10C MS-5210UD FC-6324 GF-510
GF-505 MS-5UD Flex 405
FC-5C
MS-5UD-3
GF-510 MS-10UD FC-10C MS-10UD-7
Notifier model Fire-Lite model Replaced Replaced by
SFP-2402 MS-2 MS-2-L8[7]
SFP-2404 MS-4 MS-4
SFP-1024 MS-5210UD
SFP-5UD MS-5UD MS-5UD-3
SFP-10UD MS-10UD MS-10UD-7
NFW-50 MS-9050UD NSP-25 NFW-50X
AFP-100 MS-9200 NFW2-100
NFW-100 MS-9200UD None NFW2-100
NFW2-100 MS-9200UDLS AFP-100
NFW-100
NFW-100X
Silent Knight rebranded the conventional Micro-scan panels until 2022, when consumers were instructed to switch to the original Fire-Lite versions.[8]
Silent Knight model Fire-Lite model Replaced Replaced by
SK-2 MS-2 SK2224 MS-2-L8
SK-4 MS-4 SK4224 MS-4
Sources
  1. Fire-Lite MS-2 Datasheet https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/literature-and-specs/datasheets/df-52211.pdf
  2. Fire-Lite MS-4 Datasheet https://usalarmdetection.com/products/firelite/MS-4.pdf
  3. Fire-Lite Website (December 2001)https://web.archive.org/web/20011213235633/http://www.firelite.com/ourProducts.htm
  4. Silent Knight Website (September 2006) https://web.archive.org/web/20060924033601/http://silentknight.com/htmfiles/fire/conventionalfacp.htm
