Fire-Lite Sensiscan series
1979
2005
Fire-Lite MRP series |
"title": "Fire-Lite Sensiscan series",
The Fire-Lite Sensiscan series is a series of modular conventional panels.
The Sensiscan 1000 was introduced in 1979.[1]
In 1987, Fire-Lite introduced the Sensiscan 5000 along with the AM 2020.[2] In 1988, the Sensiscan 5000 was renamed to the System 5000 and transferred to Notifier together with the AM 2020.[3]
At some point before 1996, the Sensiscan 1000 was replaced with the Sensiscan 2000.[4] The Sensiscan 200 was also released as a smaller alternative.[5]
In 2005, the Sensiscan 2000 was discontinued.[6] Consumers were instructed to instead use the MRP-4424 for releasing systems or the MS-9200UD with addressable modules for other systems.
Basic Equipment packages
| Model | Contents | Replaced | Replaced by |
| BE-200 | CPU-2000 MPS-24BPCC 4000TA 75171 75169 71071 75170 75168 71072 71070 |
| BE-2000 | CPU-2000 71252 71245 PKB 71085 71086 71087 71093 VP-1F CHS-4 |
Sensiscan 200/2000 modules
| Model | Type | Replaced | Replaced by |
| IZ-8F | 8 Class B zone module | MMF-300 MMF-300-10 MMF-302 MMF-302-6 | |
| IZE-AF | Class A adapter for IZ-8F | N/A | |
| IZ-4F | 4 Class B zone module | MMF-300 MMF-300-10 MMF-302 MMF-302-6 | |
| RS-1459 | Municipal box module | ||
| IC-4F | 4 Class A/B NAC module | CMF-300 CMF-300-6 | |
| ICE-4F | Expansion module for IC-4F with 4 additional Class A/B NACs | CMF-300 CMF-300-6 | |
| CR-4F | 4 Form C relay module | CRF-300 CRF-300-6 | |
| CRE-4F | Expansion module for CR-4F with 4 additional relays | CRF-300 CRF-300-6 | |
| TC-2F | Pre-signal/dual-code/releasing module | ||
| TC-4F | 4 releasing/dual-code circuit module |
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_fa7bd5e3-c6e3-467b-93dc-83b90ccc32d6/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_3bcee565-1b7c-45e7-8527-4101c8428281/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_67bcbc25-06b9-4299-a037-35eed13e4e8d/
- ↑ "The Sensiscan 2000" (15017). Fire-Lite Alarms (October 8, 1996).
- ↑ "The Sensiscan 200" (15032). Fire-Lite Alarms (November 1, 1996).
- ↑ https://web.archive.org/web/20060227111100/http://www.firelite.com/bulletin/sensiscan.pdf
