System Sensor SpectrAlert series
SpectrAlert Series
System_Sensor_SpectrAlert_series_lineup.png: Infobox image for SpectrAlert Series the infobox device.
12-24VDC {"label": "Rated Voltage", "field": "12-24VDC"}
1997 {"label": "Introduced", "field": "1997"}
2006 & 2008 {"label": "Discontinued", "field": "2006 & 2008"}
Mini-Alert
Multi-Alert
Signal Strobe
Sound Choice
SP100 series {"label": "Preceded by", "field": "Mini-Alert
Multi-Alert
Signal Strobe
Sound Choice
SP100 series"}
SpectrAlert Advance {"label": "Succeeded by", "field": "SpectrAlert Advance"}
The SpectrAlert series (commonly referred to as “the original SpectrAlerts”, or “SpectrAlert classics”) are a series of notifications appliances from System Sensor. These were the first System Sensor appliances to include synchronization and temporal 3.
The SpectrAlert series was released in 1997 with wall-mount horns, strobes, and horn strobes.[1] The horn strobes were redesigned from the Mini-Alert ADA horn strobes, with the strobe moved to the bottom of the device and enlarged. The horns and strobes were designed consistent with the horn strobes. These first models had fixed candela, and they used a screw on style mounting bracket.
In 1998, ceiling-mount strobes and horn strobes were released.[2] These introduced the notification appliance design where a central strobe is surrounded by the audible grille.
In 1999, the SP200 speakers were released.[3] These featured higher fidelity sound output compared to the SP100 series. The wall-mount speaker strobes consisted of a speaker to the side of a reversible strobe, while the ceiling-mount speaker strobes used a similar design to the ceiling-mount horn strobes.
The second generation SpectrAlerts are also fixed candela, and used "QuickClick" style mounting brackets instead of a screw style mounting bracket. The "QuickClick" mounting brackets snap into place when the device is placed on the bracket and uses a flathead screwdriver or a removal tool to remove the device off the bracket.
In 2003, multi-candela wall-mount strobes were released, those models use the MC suffix and the single-candela wall strobes were discontinued shortly after.[4][5][6]
At the end of 2005, the SP300 speakers were released.[7] These provided a higher SPL output compared to the SP200 speakers, but the fidelity was not as high. The design was the same as the SP200 speakers, except there were no ceiling-mount SP300 speaker strobes.
The horns, chimes, and chime strobes were discontinued in November 2006 when the SpectrAlert Advance was released.[8][9][10] All strobes and horn strobes besides the 120VAC models were discontinued by the beginning of 2007.[11][12] The speakers were discontinued between 2008 and 2009, as the SpectrAlert Advance speakers were not released until then.[13]
K suffix indicates weatherproof models
Model Number Nominal Voltage Candela Mounting Color Replaces Replaced by Current Replacement
S1215[14] 12VDC 15 Wall Red SS1215ADA S1224MC
S1215W 12VDC 15 Wall White SS1215ADAB S1224MCW
S121575 12VDC 15/75 Wall Red SS121575ADA S1224MC
S121575W 12VDC 15/75 Wall White SS121575ADAB S1224MCW
S2415 24VDC 15 Wall Red SS2415ADA
SS2415ADAS
S1224MC SR-LED
S2415W 24VDC 15 Wall White SS2415ADAS S1224MCW SW-LED
S241575 24VDC 15/75 Wall Red SS241575ADA
SS241575ADAS
S1224MC SR-LED
S241575W 24VDC 15/75 Wall White SS241575ADAB S1224MCW SW-LED
S2430[15] 24VDC 30 Wall Red None S1224MC
S2430W 24VDC 30 Wall White None S1224MCW
S2475 24VDC 75 Wall Red SS2475ADA S1224MC
S2475W 24VDC 75 Wall White SS2475ADAB S1224MCW
S24110 24VDC 110 Wall Red SS24110ADA S1224MC
S24110W 24VDC 110 Wall White SS24110ADAB S1224MCW
S1224MC[16] 12VDC & 24VDC 15, 15/75, 30, 75, 110 Wall Red S1215
S121575
S2415
S241575
S2430
S2475
S24110
SR SR-LED
S1224MCW 12VDC & 24VDC 15, 15/75, 30, 75, 110 Wall White S1215W
S121575W
S2415W
S241575W
S2430W
S2475W
S24110W
SW SW-LED
SC2415 24VDC 15 Ceiling Red None SCR SCR-LED
SC2415W 24VDC 15 Ceiling White None SCW SCW-LED
SC241575 24VDC 15/75 Ceiling Red None SCR SCR-LED
SC241575W 24VDC 15/75 Ceiling White None SCW SCW-LED
SC2430 24VDC 30 Ceiling Red None SCR SCR-LED
SC2430W 24VDC 30 Ceiling White None SCW SCW-LED
SC2475 24VDC 75 Ceiling Red None SCR SCR-LED
SC2475W 24VDC 75 Ceiling White None SCW SCW-LED
SC2495 24VDC 95 Ceiling Red None SCR SCR-LED
SC2495W 24VDC 95 Ceiling White None SCW SCW-LED
SC24115 24VDC 115 Ceiling Red None SCR SCR-LED
SC24115W 24VDC 115 Ceiling White None SCW SCW-LED
SC24177 24VDC 177 Ceiling Red None SCRH SCR-LED
SC24177W 24VDC 177 Ceiling White None SCWH SCW-LED
Horns and Horn/Strobes
Model Number Nominal Voltage Horn Control Candela Mounting Color Replaces Replaced by Current Replacement
H12/24 12VDC & 24VDC Synchronized N/A Wall/Ceiling Red None HR
H12/24W 12VDC & 24VDC Synchronized N/A Wall/Ceiling White None HW
HC12/24[17] 12VDC & 24VDC Coded N/A Wall/Ceiling Red MA12/24EH HR
HC12/24W 12VDC & 24VDC Coded N/A Wall/Ceiling White None HW
P1215 12VDC Coded 15 Wall Red MAEH1215ADA
PS1215ADA
P1224MC
P1215W 12VDC Coded 15 Wall White PS1215ADAW P1224MCW
P121575 12VDC Coded 15/75 Wall Red MAEH121575ADA
PS121575ADA
P1224MC
P121575W 12VDC Coded 15/75 Wall White PS121575ADAW P1224MCW
P2415 24VDC Coded 15 Wall Red MAEH2415ADA
MAEH2415ADAS
PS2415ADA
P1224MC
P2415W 24VDC Coded 15 Wall White PS2415ADAW P1224MCW
P241575 24VDC Coded 15/75 Wall Red MAEH241575ADA
MAEH241575ADAS
PS241575ADA
P1224MC
P241575W 24VDC Coded 15/75 Wall White PS241575ADAW P1224MCW
P2430 24VDC Coded 30 Wall Red None P1224MC
P2430W 24VDC Coded 30 Wall White None P1224MCW
P2475 24VDC Coded 75 Wall Red MAEH2475ADA
PS2475ADA
P1224MC
P2475W 24VDC Coded 75 Wall White PS2475ADAW P1224MCW
P24110 24VDC Coded 110 Wall Red MAEH24110ADA
PS24110ADA
P1224MC
P24110W 24VDC Coded 110 Wall White PS24110ADAW P1224MCW
P1224MC 12VDC & 24VDC Coded 15, 15/75, 30, 75, 110 Wall Red P1215
P121575
P2415
P241575
P2430
P2475
P24110
P4R P4RL
P1224MCW 12VDC & 24VDC Coded 15, 15/75, 30, 75, 110 Wall White P1215W
P121575W
P2415W
P241575W
P2430
P2475
P24110
P4W P4WL
PC2415 24VDC Coded 15 Ceiling Red MAEH24MC PC4R
PC2415W 24VDC Coded 15 Ceiling White None PC4W
PC241575 24VDC Coded 15/75 Ceiling Red None PC4R
PC241575W 24VDC Coded 15/75 Ceiling White None PC4W
PC2430 24VDC Coded 30 Ceiling Red None PC4R
PC2430W 24VDC Coded 30 Ceiling White None PC4W
PC2475 24VDC Coded 75 Ceiling Red None PC4R
PC2475W 24VDC Coded 75 Ceiling White None PC4W
PC2495 24VDC Coded 95 Ceiling Red None PC4R
PC2495W 24VDC Coded 95 Ceiling White None PC4W
PC24115 24VDC Coded 115 Ceiling Red None PC4R
PC24115W 24VDC Coded 115 Ceiling White None PC4W
PC24177 24VDC Coded 177 Ceiling Red None PC4RH
PC24177W 24VDC Coded 177 Ceiling White None PC4WH
Model Number Strobe Voltage Candela Mounting Color Replaces Replaced by
SP200W[18] N/A N/A Ceiling White SP100W[19] SPCW
SP201W N/A N/A Wall White SP101W SPW
SP201R N/A N/A Wall Red SP101R SPR
SP2R2415[20] 24VDC 15 Wall Red SP1R2415ADA SP2R1224MC
SP2W2415 24VDC 15 Wall White SP1W2415ADA SP2W1224MC
SP2R241575 24VDC 15/75 Wall Red SP1R241575ADA SP2R1224MC
SP2W241575 24VDC 15/75 Wall White SP1W241575ADA SP2W1224MC
SP2R2430 24VDC 30 Wall Red None SP2R1224MC
SP2W2430 24VDC 30 Wall White None SP2W1224MC
SP2R2475 24VDC 75 Wall Red SP1R2475ADA SP2R1224MC
SP2W2475 24VDC 75 Wall White SP1W2475ADA SP2W1224MC
SP2R24110 24VDC 110 Wall Red SP1R24110ADA SP2R1224MC
SP2W24110 24VDC 110 Wall White SP1W24110ADA SP2W1224MC
SP2R1224MC[21] 12VDC & 24VDC 15, 15/75, 30, 75, 110 Wall Red SP2R2415
SP2R241575
SP2R2430
SP2R2475
SP2R24110
SPSR
SP2W1224MC 12VDC & 24VDC 15, 15/75, 30, 75, 110 Wall White SP2W2415
SP2W241575
SP2W2430
SP2W2475
SP2W24110
SPSW
SP2C2415[22] 24VDC 15 Ceiling White SP100W24MC SPSCW
SP2C241575 24VDC 15/75 Ceiling White None SPSCW
SP2C2430 24VDC 30 Ceiling White None SPSCW
SP2C2475 24VDC 75 Ceiling White None SPSCW
SP2C2495 24VDC 95 Ceiling White None SPSCW
SP2C24177 24VDC 177 Ceiling White None SPSCWH
SP300W[7] N/A N/A Ceiling White None SPCWV
SP301W N/A N/A Wall White None SPWV
SP301R N/A N/A Wall Red None SPRV
SP3R1224MC[23] 12VDC & 24VDC 15, 15/75, 30, 75, 110 Wall Red None SPSRV
SP3W1224MC 12VDC & 24VDC 15, 15/75, 30, 75, 110 Wall White None SPSWV
Chimes
CH12/24[24] 12VDC & 24VDC N/A Wall/Ceiling Red MA12/24D
MA12/24EH
CHR
CH12/24W 12VDC & 24VDC N/A Wall/Ceiling White MA12/24DB CHW
CH2415[25] 24VDC 15 Wall Red MASS2415ADA
MASS2415ADAS
MAEH2415ADA
MAEH2415ADAS
CH24MC
CH2415W 24VDC 15 Wall White MASS2415ADAB CH24MCW
CH241575 24VDC 15/75 Wall Red MASS241575ADA
MASS241575ADAS
MAEH241575ADA
MAEH241575ADAS
CH24MC
CH241575W 24VDC 15/75 Wall White MASS241575ADAB CH24MCW
CH2475 24VDC 75 Wall Red MASS2475ADA
MAEH2475ADA
CH24MC
CH2475W 24VDC 75 Wall White MASS2475ADAB CH24MCW
CH24110 24VDC 110 Wall Red MASS24110ADA
MAEH24110ADA
CH24MC
CH24110W 24VDC 110 Wall White MASS24110ADAB CH24MCW
CH24MC[26] 24VDC 15, 15/75, 30, 75, 110 Wall Red CH2415
CH241575
CH2475
CH24110
CHSR
CH24MCW 24VDC 15, 15/75, 30, 75, 110 Wall White CH2415W
CH241575W
CH2475W
CH24110W
CHSW
FCI model System Sensor model Replaces Replaced by
S2415-FC S2415 S2415
S241575-FC[27] S241575 STW-4F S241575
S2430-FC S2430 None S2430
S2430W-FC S2430W None S2430W
S2430K-FC S2430K None S2430K
S2475-FC S2475 S2475
S2475W-FC S2475W S2475W
S2475K-FC S2475K S2475K
S24110-FC S24110 S24110
S24110W-FC S24110W S24110W
S24110K-FC S24110K S24110K
H12/24-FC H12/24 H12/24
H12/24W-FC H12/24W H12/24W
H12/24K-FC H12/24K H12/24K
HC12/24-FC HC12/24 HEF
HE-8F
HC12/24
HC12/24W-FC HC12/24W HC12/24W
HC12/24K-FC HC12/24K HC12/24K
P2415-FC P2415 P2415
P2415W-FC P2415W P2415W
P2415K-FC P2415K P2415K
P241575-FC P241575 P241575
P241575W-FC P241575W P241575W
P241575K-FC P241575K P241575K
P2430-FC P2430 None P2430
P2430W-FC P2430W None P2430W
P2430K-FC P2430K None P2430K
P2475-FC P2475 P2475
P2475W-FC P2475W P2475W
P2475K-FC P2475K P2475K
P24110-FC[28] P24110 P24110
P24110W-FC P24110W P24110W
P24110K-FC P24110K P24110K
SP200W-FC[29] SP200W SP200W
SP201W-FC SP201W SP201W
SP201R-FC SP201R SP201R
SP2R2415-FC[30] SP2R2415 SP2R2415
SP2R241575-FC SP2R241575 SP2R241575
SP2R2430-FC SP2R2430 SP2R2430
SP2R2475-FC SP2R2475 SP2R2475
SP2R24110-FC SP2R24110 SP2R24110
SP2W2415-FC SP2W2415 SP2W2415
SP2W241575-FC SP2W241575 SP2W241575
SP2W2430-FC SP2W2430 SP2W2430
SP2W2475-FC SP2W2475 SP2W2475
SP2W24110-FC SP2W24110 SP2W24110
  1. https://web.archive.org/web/19970401000729/http://www.systemsensor.com/edocs.htm
  2. "AUDIBLE, VISUAL AND AUDIO/VISUAL NOTIFICATION APPLIANCES" (9020-0495). Fire Control Instruments (1998).
  3. https://www.freepatentsonline.com/6127935.html
  4. https://web.archive.org/web/20030219082631/http://systemsensor.com/html/avn.html?search=horn/strobe
  5. https://web.archive.org/web/20030407140054/http://www.systemsensor.com/html/avn.html?search=Horn/Strobe
  6. https://web.archive.org/web/20031023234400/http://systemsensor.com/html/avn.html?search=Horn/Strobe
  7. 7.0 7.1 "SpectrAlert Dual-Voltage Evacuation Speakers" (A05-0999-006). System Sensor (November 2005).
  8. https://web.archive.org/web/20061109184825/http://www.systemsensor.com/html/avn.html?search=ch12
  9. https://web.archive.org/web/20061109175318/http://www.systemsensor.com/html/avn.html?search=chime/strobe
  10. https://web.archive.org/web/20061109175308/http://www.systemsensor.com/html/avn.html?search=Horn%20only
  11. https://web.archive.org/web/20070101135906/http://www.systemsensor.com/html/avn.html?search=Strobe%20only
  12. https://web.archive.org/web/20061230111816/http://www.systemsensor.com:80/html/avn.html?search=horn/strobe
  13. https://web.archive.org/web/20090125125003/http://www.systemsensor.com/html/avn.html?search=speaker
  14. "SpectrAlert Series Horns, Strobes, and Horn/Strobes" (A05-936-02). System Sensor (April 1997).
  15. "AUDIBLE, VISUAL AND AUDIO/VISUAL NOTIFICATION APPLIANCES" (9020-0495). Fire Control Instruments (1998).
  16. "SpectrAlert Selectable Output Strobe and Horn/Strobes" (A05-0325-006). System Sensor (September 2005).
  17. "SpectrAlert™ Series Horns, Strobes, and Horn/Strobes" (DF-51609). Fire-Lite Alarms (March 30, 2000).
  18. "SpectrAlert™ SP200 Series Dual Voltage Evacuation Speakers" (A05-999-02). System Sensor (January 2000).
  19. "SP100 and V400 Series Speakers and Speaker/Strobes" (A05-191-03). System Sensor (August 1996).
  20. "SpectrAlert™ SP2 Series Wall Speaker/Strobes" (A05-1015-02). System Sensor (August 1999).
  21. "SpectrAlert Selectable Output Wall Speaker/Strobes" (A05-0339-003). System Sensor (May 2004).
  22. "SpectrAlert™ SP2C Series Ceiling Mount Speaker/Strobes" (A05-1024-01). System Sensor (January 2000).
  23. "SpectrAlert Selectable Output Wall Speaker/Strobes" (A05-0339-006). System Sensor (November 2005).
  24. "SpectrAlert™ Electronic Chime/Sounder" (I56-0003-003R). System Sensor (2001).
  25. "SpectrAlert™ Chime and Chime/Strobe" (A05-0282-002). System Sensor (May 2001).
  26. "SpectrAlert Chime and Chime/Strobe" (A05-0282-005). System Sensor (June 2004).
  27. https://firealarms.tv/collection/fci-s241575-fc/
  28. https://firealarms.tv/collection/fci-p24110-fc/
  29. "SP200-FC SERIES" (9020-0469). Fire Control Instruments (1999).
  30. "SP2 Series Speaker and Speaker/Strobe Notification Appliances" (9020-0479). Fire Control Instruments (1999).
