Eluxa series
Wheelock Eluxa Series.png: Infobox image for Eluxa series the infobox device.
Black
Black
8-17.5VDC & 16-33VDC (NAC)[1]
25VRMS & 70VRMS (speaker)[2] {"label": "Rated Voltage", "field": "8-17.5VDC & 16-33VDC (NAC)[1]
25VRMS & 70VRMS (speaker)[2]"}
Wheelock: 2020
Siemens: 2023
Potter: 2024 {"label": "Introduced", "field": "Wheelock: 2020
Siemens: 2023
Potter: 2024"}
Wheelock Exceder series
Wheelock RSS series
Wheelock E series
Wheelock ET series
Wheelock EH series
Wheelock CH series
Wheelock WP series {"label": "Preceded by", "field": "Wheelock Exceder series
Wheelock RSS series
Wheelock E series
Wheelock ET series
Wheelock EH series
Wheelock CH series
Wheelock WP series"}
The Wheelock Eluxa series is the latest series of notification appliances from Wheelock.
The Eluxa series was released in 2020 with successors to the products in the Exceder LED3 series. The Eluxa strobes were given a new design with 7 smaller crystals instead of a larger crystal, and higher candela options similar to the RSS series were added.[1] The low-frequency sounders were updated to include ceiling mount models, which do not have the single-gang mounting option, and to use a multi-candela strobe that can either output 110 or 177 candela.[3] Additionally, the anechoic horn output was reduced and the 87 dBA tap on the speaker was changed to 5 watts for 70 VRMS speakers.[4][5]
In 2021, the Exceder LED3 series, RSS series, E50 and E60, and EH series were discontinued.[6] Customers were instructed to switch to equivalent Eluxa devices.
In 2023, new Eluxa chimes and multitone horns were released, with the audible components having the same features as the CH series and MT series respectively. Later in 2023, these two series were discontinued along with the Exceder series, E70 and E90, S 8" speaker strobes, SA speaker strobes, AMT horn strobes, HS4, and ET speaker strobes. Eluxa versions of the ET speaker strobes were announced for Q1 2024, but an 8-watt indoor replacement was not available until May 2025.[7][8]
In April 2024, Wheelock released a new STH speaker strobe with an Eluxa strobe instead of an RSSWP strobe.[9] There was a mention of a weatherproof version being available, but no information was made public.
In July 2024, Wheelock introduced the outdoor Eluxa series strobes, horns, and multitone horns, and in September 2024, speakers were introduced, replacing the entire WP series. All audible devices were given grilles resembling the ASWP grille, regardless of whether they are horns or speakers. These devices also introduced several features previously present in other brands such as System Sensor, including interchangeable lettering bezels, universal wall/ceiling mounting, and a standard set of candela options.
In December 2024, the no-lettering models of outdoor amber strobes were discontinued, and customers were instructed to use the ALERT-lettered models with unmarked lettering plates.[10]
In February 2025, it was observed that Eluxa ELAMT and ELAMTST devices were UL listed as Eluxa replacements for the AMT series. The horns were released at the end of March.[11] These horns use a modified version of the ELMT mounting plate without horn terminals, as the 3 pairs of horn terminals are located on the device itself, similar to the original AMT.[12] The ELAMTSTR featured a revised strobe with a lower current draw.
In April 2025, Wheelock introduced blue-lens indoor speaker strobes.[13] At this time, Wheelock also introduced indoor red/green/blue-lens strobes and horn strobes, which were previously only available on outdoor devices.[14] The wall-mount devices featured the same lower-current strobe as the ELAMTSTR, which was now also available on the ceiling-mount devices. Additionally, the indoor multitone horn strobes were updated to use these newer strobes.[15][16] Together with this change, wall-mount green strobe and ceiling-mount amber strobe variants were released for the multitone line.
In May 2025, the indoor speaker strobes and chime strobes were updated with the new strobe.[17][18] The power taps on the indoor speakers were also updated at this time to match the outdoor speakers.
In June 2025, Wheelock introduced amber lens horn strobes.[19]
In July 2025, Wheelock introduced self-amplified speakers to replace the SA-S series.[20] Like the ELAMT series, the speaker terminals are located on the device itself while the strobe terminals are located on the mounting plate.
In November 2025, Wheelock introduced new trim plates, including a plate with the ESB-KIT footprint, a larger wall plate with similar proportions to the RFP, and a ceiling plate.[21]
Model Number Lens color Mounting Outdoor rating Housing color Lettering Replaces[8]
ELSTR Clear Wall None Red FIRE LSTR3
RSS-24MCW-FR
RSS-24MCWH-FR
STR
ELSTR-A Clear Wall None Red AGENT LSTR3-A
RSS-24MCW-AR
STR-A
ELSTR-AL Clear Wall None Red ALERT LSTR3-AL
RSS-24MCW-ALR
RSS-24MCWH-ALR
STR-AL
ELSTR-ALA[22] Amber Wall None Red ALERT LSTR3-ALA
RSSA-24MCW-ALR
STR-ALA
ELSTR-ALB Blue Wall None Red ALERT LSTR3-ALB
ELSTR-N Clear Wall None Red None LSTR3-N
RSS-24MCW-NR
RSS-24MCWH-NR
STR-N
ELSTR-NA Amber Wall None Red None None
ELSTR-NB Blue Wall None Red None None
ELSTW Clear Wall None White FIRE LSTW3
RSS-24MCW-FW
RSS-24MCWH-FW
STW
ELSTW-A Clear Wall None White AGENT LSTW3-A
STW-A
ELSTW-AL Clear Wall None White ALERT LSTW3-AL
RSS-24MCW-ALW
RSS-24MCWH-ALW
STW-AL
ELSTW-ALA Amber Wall None White ALERT RSSA-24MCW-ALW
ELSTW-ALB Blue Wall None White ALERT None
ELSTW-N Clear Wall None White None None
ELSTW-NA Amber Wall None White None RSSA-24MCW-NW
ELSTW-NB Blue Wall None White None RSSB-24MCW-NW
RSSB-24MCCH-NW
ELSTW-EV Clear Wall None White EVACUATE None
ELSTR-NG Green Wall None Red None None
ELSTR-NR Red Wall None Red None None
ELSTW-NG Green Wall None White None RSSG-24110W-NW
ELSTW-NR Red Wall None White None RSSR-24MCC-NW
ELSTRC Clear Ceiling None Red FIRE LSTRC3
RSS-24MCC-FR
RSS-24MCCH-FR
STRC
ELSTRC-AL Clear Ceiling None Red ALERT LSTRC3-AL
RSS-24MCC-ALR
RSS-24MCCH-ALR
STRC-AL
ELSTRC-ALA Amber Ceiling None Red ALERT LSTRC3-ALA
RSSA-24MCC-ALR
STRC-ALA
ELSTRC-ALB Blue Ceiling None Red ALERT LSTRC3-ALB
ELSTRC-NA Amber Ceiling None Red None None
ELSTRC-NB Blue Ceiling None Red None None
ELSTWC Clear Ceiling None White FIRE LSTWC3
RSS-24MCC-FW
RSS-24MCCH-FW
STWC
ELSTWC-AL Clear Ceiling None White ALERT None
ELSTWC-ALA Amber Ceiling None White ALERT RSSA-24MCC-ALW
ELSTWC-ALB Blue Ceiling None White ALERT None
ELSTWC-NA Amber Ceiling None White None RSSA-24MCC-NW
ELSTWC-NB Blue Ceiling None White None RSSB-24MCC-NW
RSSB-24MCCH-NW
ELSTWC-EV Clear Ceiling None White EVACUATE None
ELSTRC-NG Green Ceiling None Red None None
ELSTRC-NR Red Ceiling None Red None None
ELSTWC-NG Green Ceiling None White None None
ELSTWC-NR Red Ceiling None White None RSSR-24MCC-NW
EL3RST-FR[23] Clear Wall/ceiling NEMA 3R Red FIRE RSSWP-2475C-FR + WFP-R[24]
RSSWP-2475W-FR + WFP-R
RSSWP-24MCCH-FR + WFP-R
RSSWP-24MCWH-FR + WFP-R
EL3RST-FW Clear Wall/ceiling NEMA 3R White FIRE RSSWP-2475C-FW + WFP-W
RSSWP-2475W-FW + WFP-W
RSSWP-24MCCH-FW + WFP-W
RSSWP-24MCWH-FW + WFP-W
EL3RSTA-ALW Amber Wall/ceiling NEMA 3R White ALERT EL3RSTA-NW (with ELLP-NW)
RSSWPA-2475C-ALW + WFP-W
RSSWPA-2475W-ALW + WFP-W
RSSWPA-24MCCH-ALW + WFP-W
RSSWPA-24MCWH-ALW + WFP-W
EL3RSTA-NW Amber Wall/ceiling NEMA 3R White None RSSWPA-2475W-NW + WFP-W
RSSWPA-24MCCH-NW + WFP-W
RSSWPA-2475W-NR + WFP-R
EL4XST-FR Clear Wall/ceiling NEMA 4X Red FIRE RSSWP-2475C-FR + WPSBB
RSSWP-2475W-FR + WPSBB
RSSWP-24MCCH-FR + WPSBB
RSSWP-24MCWH-FR + WPSBB
EL4XST-FW Clear Wall/ceiling NEMA 4X White FIRE RSSWP-2475C-FW + WPSBB
RSSWP-2475W-FW + WPSBB
RSSWP-24MCCH-FW + WPSBB
RSSWP-24MCWH-FW + WPSBB
EL4XSTA-ALW Amber Wall/ceiling NEMA 4X White ALERT EL4XSTA-NW (with ELLP-NW)
RSSWPA-2475C-ALW + WPSBB-W
RSSWPA-2475W-ALW + WPSBB-W
RSSWPA-24MCCH-ALW + WPSBB-W
RSSWPA-24MCWH-ALW + WPSBB-W
EL4XSTA-NW Amber Wall/ceiling NEMA 4X White None RSSWPA-2475W-NW + WPSBB-W
RSSWPA-24MCCH-NW + WPSBB-W
RSSWPA-2475W-NR + WPSBB-R
EL3RSTB-NW[25] Blue Wall/ceiling NEMA 3R White None RSSWPB-2475C-NW + WFP-W
RSSWPB-2475W-NW + WFP-W
RSSWPB-24MCCH-NW + WFP-W
EL4XSTB-NW Blue Wall/ceiling NEMA 4X White None RSSWPB-2475C-NW + WPSBB-W
RSSWPB-2475W-NW + WPSBB-W
RSSWPB-24MCCH-NW + WPSBB-W
EL3RSTG-NW Green Wall/ceiling NEMA 3R White None RSSWPG-24MCCH-NW + WFP-W
EL4XSTG-NW Green Wall/ceiling NEMA 4X White None RSSWPG-24MCCH-NW + WPSBB-W
EL3RSTR-NW Red Wall/ceiling NEMA 3R White None RSSWPR-2475C-NW + WFP-W
RSSWPR-2475W-NR + WFP-R
RSSWPR-24MCCH-NW + WFP-W
RSSWPR-24MCCH-AAW + WFP-W
EL4XSTR-NW White Wall/ceiling NEMA 4X White None RSSWPR-2475C-NW + WPSBB-W
RSSWPR-2475W-NR + WPSBB-R
RSSWPR-24MCCH-NW + WPSBB-W
RSSWPR-24MCCH-AAW + WPSBB-W
Model Number Type Strobe color Mounting Outdoor rating Housing color Lettering Replaces[8]
ELHNR Horn N/A Wall None Red None LHNR3
HNR
ELHNW Horn N/A Wall None White None LHNW3
HNW
ELHNRC Horn N/A Ceiling None Red None LHNRC3
HNRC
ELHNWC Horn N/A Ceiling None White None LHNWC3
HNWC
ELHSR Horn strobe Clear Wall None Red FIRE LHSR3
HSR
ELHSR-A Horn strobe Clear Wall None Red AGENT None
ELHSR-N Horn strobe Clear Wall None Red None None
ELHSW Horn strobe Clear Wall None White FIRE LHSW3
HSW
ELHSW-A Horn strobe Clear Wall None White AGENT None
ELHSW-AL Horn strobe Clear Wall None White ALERT None
ELHSW-N Horn strobe Clear Wall None White None None
ELHSW-EV Horn strobe Clear Wall None White EVACUATE None
ELHSR-NA Horn strobe Amber Wall None Red None None
ELHSW-NA Horn strobe Amber Wall None White None ASA-24MCC-NW
ELHSR-NB Horn strobe Blue Wall None Red None None
ELHSR-NG Horn strobe Green Wall None Red None None
ELHSR-NR Horn strobe Red Wall None Red None None
ELHSW-NB Horn strobe Blue Wall None White None ASB-24MCC-NW
ELHSW-NG Horn strobe Green Wall None White None None
ELHSW-NR Horn strobe Red Wall None White None None
ELHSRC Horn strobe Clear Ceiling None Red FIRE LHSRC3
HSRC
ELHSWC Horn strobe Clear Ceiling None White FIRE LHSWC3
HSWC
ELHSWC-N Horn strobe Clear Ceiling None White None None
ELHSRC-NA Horn strobe Amber Ceiling None Red None None
ELHSWC-NA Horn strobe Amber Ceiling None White None ASA-24MCC-NW
ELHSRC-NB Horn strobe Blue Ceiling None Red None None
ELHSRC-NG Horn strobe Green Ceiling None Red None None
ELHSRC-NR Horn strobe Red Ceiling None Red None None
ELHSWC-NB Horn strobe Blue Ceiling None White None ASB-24MCC-NW
ELHSWC-NG Horn strobe Green Ceiling None White None None
ELHSWC-NR Horn strobe Red Ceiling None White None None
EL3RHN-NR Horn N/A Wall/ceiling NEMA 3R Red None AH-24WP-R + WFP-R
EL3RHN-NW Horn N/A Wall/ceiling NEMA 3R White None None
EL4XHN-NR Horn N/A Wall/ceiling NEMA 4X Red None AH-24WP-R + WBB-R
EL4XHN-NW Horn N/A Wall/ceiling NEMA 4X White None None
EL3RHS-FR Horn strobe Clear Wall/ceiling NEMA 3R Red FIRE ASWP-2475C-FR + WFPA-R
ASWP-2475W-FR + WFPA-R
ASWP-24MCCH-FR + WFPA-R
ASWP-24MCWH-FR + WFPA-R
ASWP-2475W-NR + WFPA-R (with ELLP-NR)
EL3RHS-FW Horn strobe Clear Wall/ceiling NEMA 3R White FIRE ASWP-2475C-FW + WFPA-W
ASWP-24MCCH-FW + WFPA-W
ASWP-24MCWH-FW + WFPA-W
EL4XHS-FR Horn strobe Clear Wall/ceiling NEMA 4X Red FIRE ASWP-2475C-FR + WPBB-R
ASWP-2475W-FR + WPBB-R
ASWP-24MCCH-FR + WPBB-R
ASWP-24MCWH-FR + WPBB-R
ASWP-2475W-NR + WPBB-R (with ELLP-NR)
EL4XHS-FW Horn strobe Clear Wall/ceiling NEMA 4X White FIRE ASWP-2475C-FW + WPBB-W
ASWP-24MCCH-FW + WPBB-W
ASWP-24MCWH-FW + WPBB-W
ELSPKR Speaker N/A Wall None Red FIRE LSPKR
ELSPKR-N Speaker N/A Wall None Red None E50-R
E50-R-ULC
E50H-R
E70-R
E70H-R
ET70-R
LSPKR-N
ELSPKR-AL Speaker N/A Wall None Red ALERT LSPKR-AL
ELSPKW Speaker N/A Wall None White FIRE LSPKW
ELSPKW-N Speaker N/A Wall None White None E50-W
E50-W-ULC
E50H-W
E70-W
E70H-W
ET70-W
LSPKW-N
ELSPKW-AL Speaker N/A Wall None White ALERT E50-ALW
E50H-ALW
LSPKW-AL
ELSPKRC Speaker N/A Ceiling None Red FIRE LSPKRC
ELSPKRC-N Speaker N/A Ceiling None Red None E60-R
E60H-R
E90-R
E90H-R
ET90-R
LSPKRC-N
ELSPKRC-AL Speaker N/A Ceiling None Red ALERT LSPKRC-AL
ELSPKWC Speaker N/A Ceiling None White FIRE LSPKWC
ELSPKWC-N Speaker N/A Ceiling None White None E60-W
E60-W-ULC
E60H-W
E90-W
E90H-W
ET90-W
LSPKWC-N
ELSPKWC-AL Speaker N/A Ceiling None White ALERT E60-ALW
E60H-ALW
LSPKWC-AL
ELSPKBC Speaker N/A Ceiling None Black FIRE None
ELSA-SW-R Self-amplified speaker N/A Wall None Red None
ELSA-SW-W Self-amplified speaker N/A Wall None White None
ELSA-SC-R Self-amplified speaker N/A Ceiling None Red None
ELSA-SC-W Self-amplified speaker N/A Ceiling None White None
ELSPSTR Speaker strobe Clear Wall None Red FIRE E50-24MCW-FR
E50-24MCW-FR-ULC
E50-24MCWH-FR
E50H-24MCW-FR
E50H-24MCWH-FR
E70-24MCW-FR
E70-24MCWH-FR
E70H-24MCW-FR
E70H-24MCWH-FR
ET70-24MCW-FR
ET70-24MCWH-FR
LSPSTR3
ELSPSTR-AL Speaker strobe Clear Wall None Red ALERT E50-24MCW-ALR
E50H-24MCW-ALR
E70-24MCW-ALR
E70H-24MCW-ALR
ET70-24MCW-ALR
LSPSTR3-AL
ELSPSTR-ALA[26] Speaker strobe Amber Wall None Red ALERT LSPSTR3-ALA
ELSPSTR-N Speaker strobe Clear Wall None Red None None
ELSPSTR-NA Speaker strobe Amber Wall None Red None None
ELSPSTR-M Speaker strobe Clear Wall None Red EMERGENCY None
ELSPSTW Speaker strobe Clear Wall None White FIRE E50-24MCW-FW
E50-24MCW-FW-ULC
E50-24MCWH-FW
E50H-24MCW-FW
E50H-24MCWH-FW
E70-24MCW-FW
E70-24MCWH-FW
E70H-24MCW-FW
E70H-24MCWH-FW
ET70-24MCW-FW
ET70-24MCWH-FW
LSPSTW3
ELSPSTW-AL Speaker strobe Clear Wall None White ALERT E50-24MCW-ALW
E50-24MCWH-ALW
E50H-24MCW-ALW
E50H-24MCWH-ALW
E70-24MCW-ALW
E70-24MCWH-ALW
E70H-24MCW-ALW
ET70-24MCW-ALW
LSPSTW3-AL
ELSPSTW-ALA Speaker strobe Amber Wall None White ALERT E50A-24MCW-ALW
E50HA-24MCW-ALW
E70HA-24MCW-ALW
ELSPSTW-N Speaker strobe Clear Wall None White None E50-24MCW-NW
E50H-24MCW-NW
E70-24MCW-NW
E70H-24MCW-NW
ET70-24MCW-NW
ET70H-24MCW-NW
LSPSTW3-N
ELSPSTW-NA Speaker strobe Amber Wall None White None None
ELSPSTW-M Speaker strobe Clear Wall None White EMERGENCY None
ELSPSTR-NB Speaker strobe Blue Wall None Red None None
ELSPSTW-NB Speaker strobe Blue Wall None White None None
ELSPSTRC Speaker strobe Clear Ceiling None Red FIRE E60-24MCC-FR
E60-24MCCH-FR
E60H-24MCC-FR
E60H-24MCCH-FR
E90-24MCC-FR
E90-24MCCH-FR
E90H-24MCC-FR
E90H-24MCCH-FR
LSPSTRC3
ELSPSTRC-AL Speaker strobe Clear Ceiling None Red ALERT None
ELSPSTRC-ALA Speaker strobe Amber Ceiling None Red ALERT None
ELSPSTRC-NA Speaker strobe Amber Ceiling None Red None None
ELSPSTWC Speaker strobe Clear Ceiling None White FIRE E60-24MCC-FW
E60-24MCC-FW-ULC
E60-24MCCH-FW
E60H-24MCC-FW
E60H-24MCCH-FW
E90-24MCC-FW
E90-24MCCH-FW
E90H-24MCC-FW
E90H-24MCCH-FW
ET90-24MCC-FW
ET90-24MCCH-FW
LSPSTWC3
ELSPSTWC-AL Speaker strobe Clear Ceiling None White ALERT E60-24MCC-ALW
E60-24MCCH-ALW
E60H-24MCC-ALW
E60H-24MCCH-ALW
E70-24MCC-ALW
E90-24MCC-ALW
E90-24MCCH-ALW
E90H-24MCC-ALW
E90H-24MCCH-ALW
ET90-24MCC-ALW
LSPSTWC3-AL
ELSPSTWC-ALA Speaker strobe Amber Ceiling None White ALERT E60A-24MCC-ALW
E60HA-24MCC-ALW
E90HA-24MCC-ALW
E90HA-24MCCH-ALW
ET90A-24MCC-ALW
ET90A-24MCCH-ALW
LSPSTWC3-ALA
ELSPSTWC-N Speaker strobe Clear Ceiling None White None E60-24MCC-NW
E60H-24MCC-NW
E70-24MCC-NW
E90-24MCC-NW
E90H-24MCC-NW
ET90-24MCC-NW
LSPSTWC3-N
ELSPSTWC-NA Speaker strobe Amber Ceiling None White None E50A-24MCC-NW
E60A-24MCC-NW
LSPSTWC3-NA
ELSPSTWC-NB Speaker strobe Blue Ceiling None White None E90B-24MCC-NW
ELSA-SSTW-FR Self-amplified speaker strobe Clear Wall None Red FIRE SA-S70-24MCW-FR
ELSA-SSTW-FW Self-amplified speaker strobe Clear Wall None White FIRE SA-S70-24MCW-FW
ELSA-SSTC-FR Self-amplified speaker strobe Clear Ceiling None Red FIRE SA-S90-24MCC-FR
ELSA-SSTC-FW Self-amplified speaker strobe Clear Ceiling None White FIRE SA-S90-24MCC-FW
ELSA-SSTW-ALR Self-amplified speaker strobe Clear Wall None Red ALERT SA-S70-24MCW-ALR
ELSA-SSTW-ALW Self-amplified speaker strobe Clear Wall None White ALERT SA-S70-24MCW-ALW
ELSA-SSTC-ALW Self-amplified speaker strobe Clear Ceiling None White ALERT SA-S90-24MCC-ALW
ELSA-SSTWA-ALW Self-amplified speaker strobe Amber Wall None White ALERT None
ELSA-SSTCA-ALW Self-amplified speaker strobe Amber Ceiling None White ALERT SA-S90A-24MCC-ALW
ELSA-SSTWB-NW Self-amplified speaker strobe Blue Wall None White None None
ELSA-SSTCB-NW Self-amplified speaker strobe Blue Ceiling None White None None
EL3RSPK-NR[27] Speaker N/A Wall/ceiling NEMA 3R Red None
EL3RSPK-NW Speaker N/A Wall/ceiling NEMA 3R White None
EL4XSPK-NR Speaker N/A Wall/ceiling NEMA 4X Red None
EL4XSPK-NW Speaker N/A Wall/ceiling NEMA 4X White None
EL3RSPST-FR Speaker strobe Clear Wall/ceiling NEMA 3R Red FIRE ET70WP-2475C-FR + WFP-R
ET70WP-2475W-FR + WFP-R
ET70WP-24115C-FR + WFP-R
ET70WP-24135W-FR + WFP-R
ET70WP-24177C-FR + WFP-R
ET70WP-24185W-FR + WFP-R
ET70WP-2475W-ALR + WFP-R (with ELLP-ALR)
ET80-24MCW-FR
ET80-24MCWH-FR
EL3RSPST-FW Speaker strobe Clear Wall/ceiling NEMA 3R White FIRE ET70WP-2475C-FW + WFP-W
ET70WP-2475W-FW + WFP-W
ET70WP-24115C-FW + WFP-W
ET70WP-24135W-FW + WFP-W
ET70WP-24177C-FW + WFP-W
ET70WP-24185W-FW + WFP-W
ET70WP-2475W-ALW + WFP-W (with ELLP-ALW)
ET70WP-24135W-ALW + WFP-W (with ELLP-ALW)
ET80-24MCW-FW
ET80-24MCWH-FW
EL4XSPST-FR Speaker strobe Clear Wall/ceiling NEMA 4X Red FIRE ET70WP-2475C-FR + IOB-R
ET70WP-2475W-FR + IOB-R
ET70WP-24115C-FR + IOB-R
ET70WP-24135W-FR + IOB-R
ET70WP-24177C-FR + IOB-R
ET70WP-24185W-FR + IOB-R
ET70WP-2475W-ALR + IOB-R (with ELLP-ALR)
EL4XSPST-FW Speaker strobe Clear Wall/ceiling NEMA 4X White FIRE ET70WP-2475C-FW + IOB-W
ET70WP-2475W-FW + IOB-W
ET70WP-24115C-FW + IOB-W
ET70WP-24135W-FW + IOB-W
ET70WP-24177C-FW + IOB-W
ET70WP-24185W-FW + IOB-W
ET70WP-2475W-ALW + IOB-W (with ELLP-ALW)
ET70WP-24135W-ALW + IOB-W (with ELLP-ALW)
EL3RSPSTA-ALW Speaker strobe Amber Wall/ceiling NEMA 3R White ALERT EL3RSPSTA-NW (with ELLP-NW)
ET70WPA-2475W-ALR + WFP-R
ET70WPA-2475W-ALW + WFP-W
ET70WPA-2475C-ALW + WFP-W
EL3RSPSTA-NW Speaker strobe Amber Wall/ceiling NEMA 3R White None ET70WPA-2475W-NW + WFP-W
EL4XSPSTA-ALW Speaker strobe Amber Wall/ceiling NEMA 4X White ALERT EL4XSPSTA-NW (with ELLP-NW)
ET70WPA-2475W-ALR + IOB-R
ET70WPA-2475W-ALW + IOB-W
ET70WPA-2475C-ALW + IOB-W
EL4XSPSTA-NW Speaker strobe Amber Wall/ceiling NEMA 4X White None ET70WPA-2475W-NW + IOB-W
Low frequency sounders
Model Number Type Strobe color Mounting Housing color Lettering Replaces[8]
ELFHNR Sounder N/A Wall Red FIRE LFHNKR3
ELFHNR-AL Sounder N/A Wall Red ALERT LFHNKR3-AL
ELFHNR-CO Sounder N/A Wall Red CO LFHNKR3-CO
ELFHNR-N Sounder N/A Wall Red None LFHNKR3-N
ELFHNW Sounder N/A Wall White FIRE LFHNKW3
ELFHNW-AL Sounder N/A Wall White ALERT LFHNKW3-AL
ELFHNW-CO Sounder N/A Wall White CO LFHNKW3-CO
ELFHNW-N Sounder N/A Wall White None LFHNKW3-N
ELFHNRC Sounder N/A Ceiling Red FIRE None
ELFHNRC-AL Sounder N/A Ceiling Red ALERT None
ELFHNRC-CO Sounder N/A Ceiling Red CO None
ELFHNRC-N Sounder N/A Ceiling Red None None
ELFHNWC Sounder N/A Ceiling White FIRE None
ELFHNWC-AL Sounder N/A Ceiling White ALERT None
ELFHNWC-CO Sounder N/A Ceiling White CO None
ELFHNWC-N Sounder N/A Ceiling White None None
ELFHSR Sounder strobe White Wall Red FIRE LFHSKR3
LFHSHR3
ELFHSR-AL Sounder strobe White Wall Red ALERT LFHSKR3-AL
LFHSHR3-AL
ELFHSR-CO Sounder strobe White Wall Red CO LFHSKR3-CO
LFHSHR3-CO
ELFHSR-N Sounder strobe White Wall Red None LFHSKR3-N
LFHSHR3-N
ELFHSW Sounder strobe White Wall White FIRE LFHSKW3
LFHSHW3
ELFHSW-AL Sounder strobe White Wall White ALERT LFHSKW3-AL
LFHSHW3-AL
ELFHSW-CO Sounder strobe White Wall White CO LFHSKW3-CO
LFHSHW3-CO
ELFHSW-N Sounder strobe White Wall White None LFHSKW3-N
LFHSHW3-N
ELFHSRC Sounder strobe White Ceiling Red FIRE None
ELFHSRC-AL Sounder strobe White Ceiling Red ALERT None
ELFHSRC-CO Sounder strobe White Ceiling Red CO None
ELFHSRC-N Sounder strobe White Ceiling Red None None
ELFHSWC Sounder strobe White Ceiling White FIRE None
ELFHSWC-AL Sounder strobe White Ceiling White ALERT None
ELFHSWC-CO Sounder strobe White Ceiling White CO None
ELFHSWC-N Sounder strobe White Ceiling White None None
Chimes
ELCHR Chime N/A Wall Red None CH70-24-R
ELCHW Chime N/A Wall White None CH70-24-W
ELCHRC Chime N/A Ceiling Red None CH90-24-R
ELCHWC Chime N/A Ceiling White None CH90-24-W
ELCHSR Chime strobe White Wall Red FIRE CH70-24MCW-FR
CH70-24MCWH-FR
ELCHSW Chime strobe White Wall White FIRE CH70-24MCW-FW
CH70-24MCWH-FW
ELCHSRC Chime strobe White Ceiling Red FIRE CH90-24MCC-FR
ELCHSWC Chime strobe White Ceiling White FIRE CH90-24MCC-FW
CH90-24MCCH-FW
Multitone horns
ELMTR Horn N/A Wall None Red None MT-12/24-R
MT4-12/24-R
HS-24-R
ELMTW Horn N/A Wall None White None MT-12/24-W
MT4-12/24-S
HS-24-W
ELAMTR Prioritized horn N/A Wall None Red AMT-12/24-R
ELAMTW Prioritized horn N/A Wall None White AMT-12/24-W
ELMTSR Horn strobe Clear Wall None Red FIRE MT-121575W-FR
MT-24MCW-FR
HS4-24MCW-FR
HS4-24MCWH-FR
ELMTSR-N Horn strobe Clear Wall None Red None None
ELMTSR-NG Horn strobe Green Wall None Red None None
ELMTSR-NR[28] Horn strobe Red Wall None Red None None
ELMTSR-A Horn strobe Clear Wall None Red AGENT MT-24MCW-AR
ELMTSW Horn strobe Clear Wall None White FIRE MT-24MCW-FW
HS4-24MCW-FW
HS4-24MCWH-FW
ELMTSW-N Horn strobe Clear Wall None White None MT-24MCW-NW
ELMTSW-NA Horn strobe Amber Wall None White None MTA-24MCCH-NW
ELMTSW-NB Horn strobe Blue Wall None White None MTB-24MCW-NW
MTB-24MCCH-NW
ELMTSW-NG Horn strobe Green Wall None White None MTG-24MCCH-NW
ELMTSW-NR Horn strobe Red Wall None White None MTR-24MCCH-NW
ELMTSW-A Horn strobe Clear Wall None White AGENT None
ELMTSRC Horn strobe Clear Ceiling None Red FIRE HS4-24MCC-FR
HS4-24MCCH-FR
ELMTSWC Horn strobe Clear Ceiling None White FIRE HS4-24MCC-FW
HS4-24MCCH-FW
ELMTSWC-NA Horn strobe Amber Ceiling None White None MTA-24MCCH-NW
ELMTSWC-NB Horn strobe Blue Ceiling None White None MTB-24MCCH-NW
ELMTSWC-NG Horn strobe Green Ceiling None White None MTG-24MCCH-NW
ELMTSWC-NR Horn strobe Red Ceiling None White None MTR-24MCCH-NW
ELAMTSTR Prioritized horn strobe N/A Wall None Red AMT-12/24-R + RSSP-24MCW-FR
EL3RMT-NR[29] Horn N/A Wall/ceiling NEMA 3R Red None MT-12/24-R + WFP-R
EL3RMT-NW Horn N/A Wall/ceiling NEMA 3R White None MT-12/24-W + WFP-W
EL4XMT-NR Horn N/A Wall/ceiling NEMA 4X Red None MT-12/24-R + IOB-R
MT4-12/24-R + WBB-R
EL4XMT-NW Horn N/A Wall/ceiling NEMA 4X White None MT-12/24-W + IOB-W
MT4-12/24-S + WBB-S
EL3RMTST-FR Horn strobe Clear Wall/ceiling NEMA 3R Red FIRE MTWP-2475C-FR + WFP-R
MTWP-2475W-FR + WFP-R
MTWP-24MCCH-FR + WFP-R
MTWP-24MCWH-FR + WFP-R
EL3RMTST-FW Horn strobe Clear Wall/ceiling NEMA 3R White FIRE MTWP-2475C-FW + WFP-W
MTWP-2475W-FW + WFP-W
MTWP-24MCCH-FW + WFP-W
MTWP-24MCWH-FW + WFP-W
EL4XMTST-FR Horn strobe Clear Wall/ceiling NEMA 4X Red FIRE MTWP-2475C-FR + IOB-R
MTWP-2475W-FR + IOB-R
MTWP-24MCCH-FR + IOB-R
MTWP-24MCWH-FR + IOB-R
EL4XMTST-FW Horn strobe Clear Wall/ceiling NEMA 4X White FIRE MTWP-2475C-FW + IOB-W
MTWP-2475W-FW + IOB-W
MTWP-24MCCH-FW + IOB-W
MTWP-24MCWH-FW + IOB-W
EL3RMTSTA-ALW Horn strobe Amber Wall/ceiling NEMA 3R White ALERT EL3RMTSTA-NW (with ELLP-NW)
EL3RMTSTA-NW Horn strobe Amber Wall/ceiling NEMA 3R White None MTWPA-2475W-NW + WFP-W
MTWP-24MCCH-NW + WFP-W
MTWPA-2475W-NR + WFP-R
EL4XMTSTA-ALW Horn strobe Amber Wall/ceiling NEMA 4X White ALERT EL4XMTSTA-NW (with ELLP-NW)
EL4XMTSTA-NW Horn strobe Amber Wall/ceiling NEMA 4X White None MTWPA-2475W-NW + IOB-W
MTWP-24MCCH-NW + IOB-W
MTWPA-2475W-NR + IOB-R
EL3RMTSTB-NW[30] Horn strobe Blue Wall/ceiling NEMA 3R White None MTWPB-2475W-NW + WFP-W
MTWPB-24MCCH-NW + WFP-W
EL4XMTSTB-NW Horn strobe Blue Wall/ceiling NEMA 4X White None MTWPB-2475W-NW + IOB-W
MTWPB-24MCCH-NW + IOB-W
EL3RMTSTG-NW Horn strobe Green Wall/ceiling NEMA 3R White None MTWPG-24MCCH-NW + WFP-W
EL4XMTSTG-NW Horn strobe Green Wall/ceiling NEMA 4X White None MTWPG-24MCCH-NW + IOB-W
EL3RMTSTR-NW Horn strobe Red Wall/ceiling NEMA 3R White None MTWPR-2475W-NW + WFP-W
MTWPR-24MCCH-NW + WFP-W
MTWPR-2475W-NR + WFP-R
EL4XMTSTR-NW Horn strobe White Wall/ceiling NEMA 4X White None MTWPR-2475W-NW + IOB-W
MTWPR-24MCCH-NW + IOB-W
MTWPR-2475W-NR + IOB-R
Firecom
Firecom rebrands all clear-lens Eluxa strobes, horns, and speakers except the ELHSWC-N.[31][32] Firecom model codes have an F prefix before the Wheelock model code.
124-099-00[33] ELSPKWC-N Still in production
124-100-00 ELSPKW-AL Still in production
124-101-00 ELSPKWC-AL Still in production
367-106-00 ELSTWC Still in production
367-107-00 ELSTR Still in production
367-108-00 ELSTW-N Still in production
367-109-00 ELSTRC Still in production
367-110-00 ELSTWC-N Still in production
367-111-00 ELSTWC-NA Still in production
367-112-00 ELSTW-ALA Still in production
367-113-00 ELSTWC-AL Still in production
367-114-00 ELSTWC-NA Still in production
580-121-00 ELSPSTWC Still in production
580-122-00 ELSPSTW-AL Still in production
580-123-00 ELSPSTWC-AL Still in production
Potter
In early 2024, Potter Electric Signal Company, LLC released the PE Series of notification appliances, which is a rebrand of the Wheelock Eluxa series.
Potter model Wheelock model Replaced
PE-HSR[34] ELHSR
PE-HSW ELHSW
PE-HSRC ELHSRC CHS-24R
CHS-24PR (with PE-GHSRC-N)[35]
PE-HSWC ELHSWC CHS-24W
CHS-24PW (with PE-GHSWC-N)
PE-STR ELSTR
PE-STW ELSTW
PE-STRC ELSTRC CS-24R
CS-24PR (with PE-GSTRC-N)
PE-STWC ELSTWC CS-24W
CS-24PW (with PE-GSTWC-N)
PE-HNR ELHNR
PE-HNW ELHNW
PE-SPKR[36] ELSPKR FASPKR-R
PE-SPKW ELSPKW FASPKR-W
PE-SPKWC ELSPKWC FASPKR-W
FASPKR-R (with PE-GSPKRC or PE-GSPKRC-N)
PE-SPSTR ELSPSTR SPKSTR-24WLPR
SPKSTR-24WLPPR (with PE-GSPSTR-N)
PE-SPSTW ELSPSTW SPKSTR-24WLPW
SKPSTR-24WLPPW (with PE-GSPSTW-N)
PE-SPSTRC ELSPSTRC SPKSTR-24CLPR
SPKSTR-24CLPPR (with PE-GSPSTRC-N)
PE-SPSTWC ELSPSTWC SPKSTR-24CLPW
SPKSTR-24CLPPW
PE-3RSPK-NR[37] EL3RSPK-NR FASPK-WPR
PE-3RSPK-NW EL3RSPK-NW FASPK-WPW
PE-4XSPK-NR EL4XSPK-NR FASPK-WPR + SPKRBB-R
PE-4XSPK-NW EL4XSPK-NW FASPK-WPW + SPKRBB-W
PE-3RSPST-FR EL3RSPST-FR SPKSTR-24WLPR-WP
SPKSTR-24WLPPR-WP (with PE-LP-NR)
SPKSTR-15/75R-AL-WP (with PE-LP-ALR)
PE-3RSPST-FW EL3RSPST-FW SPKSTR-24WLPW-WP
SPKSTR-24WLPPW-WP (with PE-LP-NW)
SPKSTR-15/75W-AL-WP (with PE-LP-ALW)
PE-4XSPST-FR EL4XSPST-FR SPKSTR-24WLPR-WP + SPKRBB-R
SPKSTR-24WLPPR-WP + SPKRBB-R (with PE-LP-NR)
SPKSTR-15/75R-AL-WP + SPKRBB-R (with PE-LP-ALR)
PE-4XSPST-FW EL4XSPST-FW SPKSTR-24WLPW-WP + SPKRBB-W
SPKSTR-24WLPPW-WP + SPKRBB-W (with PE-LP-NW)
SPKSTR-15/75W-AL-WP + SPKRBB-W (with PE-LP-ALW)
PE-3RSPSTA-NW EL3RSPSTA-ALW + ELLP-NW
PE-4XSPSTA-NW EL4XSPSTA-ALW + ELLP-NW
PE-3RSPSTA-ALW EL3RSPSTA-ALW
PE-4XSPSTA-ALW EL4XSPSTA-ALW
In July 2023, Siemens Building Technologies released the SL2- Series, a rebrand of the Eluxa series.[38] In 2024, the ACEND series was announced, and the SL2 series was marked as a legacy series together with the other rebranded Wheelock equipment.
SL2SWR-ALA[39] ELSTR-ALA ST-AMC-R-MNS-ALERT
SLSWR-ALA
SC-ST-WR-F + SCVR-HS-WR-ALR + STLENS-A
SL2SWW-ALA ELSTW-ALA ST-AMC-W-MNS-ALERT
SLSWW-ALA
SC-ST-WW-F + SCVR-HS-WW-ALR + STLENS-A
SL2SWR-NA ELSTR-NA SLSWR-NA SC-ST-WR-F + SCVR-HS-WR-BNK + STLENS-A
SL2SWW-NA ELSTW-NA SLSWW-NA SC-ST-WW-F + SCVR-HS-WW-BNK + STLENS-A
SL2SWR-ALB ELSTR-ALB None SC-ST-WR-F + SCVR-HS-WR-ALR + STLENS-B
SL2SWW-ALB ELSTW-ALB None SC-ST-WW-F + SCVR-HS-WW-ALR + STLENS-B
SL2SWR-NB ELSTR-NB None SC-ST-WR-F + SCVR-HS-WR-BNK + STLENS-B
SL2SWW-NB ELSTW-NB None SC-ST-WW-F + SCVR-HS-WW-BNK + STLENS-B
SL2SWR-A ELSTR-A ST-MC-R-AR
SLSWR-A
SC-ST-WR-F + SCVR-HS-WR-AGT
SL2SWW-A ELSTW-A None SC-ST-WW-F + SCVR-HS-WW-AGT
SL2SWR-AL ELSTR-AL ST-CMC-R-MNS-ALERT
SLSWR-AL
SL2SWW-AL ELSTW-AL ST-CMC-W-MNS-ALERT
SLSWW-AL
SL2SWR-F ELSTR ST-MC-R
ZR-MC-R
ZR-HMC-R
SLSWR-F
SC-ST-WR-F
SL2SWW-F ELSTW ST-MC-W
ZR-MC-W
ZR-HMC-W
SLSWW-F
SC-ST-WW-F
SL2SWR-N ELSTR-N SLSWR-N SC-ST-WR-F + SCVR-HS-WR-BNK
SL2SWW-N ELSTW-N SLSWW-N SC-ST-WW-F + SCVR-HS-WW-BNK
SL2SWR-FB None SLSWR-FB SC-ST-WR-F + SCVR-HS-WR-HOF
SL2SWW-FB None SLSWW-FB SC-ST-WW-F + SCVR-HS-WW-HOF
SL2SWW-EV ELSTW-EV None None
SL2SCR-ALA ELSTRC-ALA ST-AMC-CR-MNS-ALERT
SLSCR-ALA
SC-ST-CR-F + SCVR-HS-CR-ALR + STLENS-A
SL2SCW-ALA ELSTWC-ALA ST-AMC-CW-MNS-ALERT
SLSCW-ALA
SC-ST-CW-F + SCVR-HS-CW-ALR + STLENS-A
SL2SCR-NA ELSTRC-NA SLSCR-NA SC-ST-CR-F + SCVR-HS-CR-BNK + STLENS-A
SL2SCW-NA ELSTWC-NA SLSCW-NA SC-ST-CW-F + SCVR-HS-CW-BNK + STLENS-A
SL2SCR-ALB ELSTRC-ALB None SC-ST-CR-F + SCVR-HS-CR-ALR + STLENS-B
SL2SCW-ALB ELSTWC-ALB None SC-ST-CW-F + SCVR-HS-CW-ALR + STLENS-B
SL2SCR-NB ELSTRC-NB None SC-ST-CR-F + SCVR-HS-CR-BNK + STLENS-B
SL2SCW-NB ELSTWC-NB None SC-ST-CW-F + SCVR-HS-CW-BNK + STLENS-B
SL2SCR-A None SLSCR-A SC-ST-CR-F + SCVR-HS-CR-AGT
SL2SCW-A None SLSCW-A SC-ST-CW-F + SCVR-HS-CW-AGT
SL2SCR-AL ELSTRC-AL ST-CMC-CR-MNS-ALERT
SLSCR-AL
SL2SCW-AL ELSTWC-AL ST-CMC-CW-MNS-ALERT
SLSCW-AL
SL2SCR-F ELSTR ZR-MC-CR
ZR-HMC-CR
SLSCR-F
SC-ST-CR-F
SL2SCW-F ELSTW ST-MC-CW
ST-HMC-CW
ZR-MC-CW
ZR-HMC-CW
SLSCW-F
SC-ST-CW-F
SL2SCR-N ELSTR-N SLSCR-N SC-ST-CR-F + SCVR-HS-CR-BNK
SL2SCW-N ELSTW-N SLSCW-N SC-ST-CW-F + SCVR-HS-CW-BNK
SL2SCR-FB ELSTR-FB SLSCR-FB SC-ST-CR-F + SCVR-HS-CR-HOF
SL2SCW-FB ELSTW-FB SLSCW-FB SC-ST-CW-F + SCVR-HS-CW-HOF
SL2SCW-EV ELSTW-EV None None
SL23RST-FR[40] EL3RST-FR Still in production
SL23RST-FW EL3RST-FW Still in production
SL24XST-FR EL4XST-FR Still in production
SL24XST-FW EL4XST-FW Still in production
SL23RSTAM-NR EL3RSTA-ALW + ELLP-NR Still in production
SL23RSTAM-NW EL3RSTA-ALW + ELLP-NW Still in production
SL24XSTAM-NR EL4XSTA-ALW + ELLP-NR Still in production
SL24XSTAM-NW EL4XSTA-ALW + ELLP-NW Still in production
SL23RSTB-NW EL3RSTB-NW Still in production
SL23RSTB-NR EL3RSTB-NW + ELLP-NR Still in production
SL23RSTG-NW EL3RSTG-NW Still in production
SL23RSTG-NR EL3RSTG-NW + ELLP-NR Still in production
SL23RSTR-NW EL3RSTR-NW Still in production
SL23RSTR-NR EL3RSTR-NW + ELLP-NR Still in production
SL24XSTB-NW EL4XSTB-NW Still in production
SL24XSTB-NR EL4XSTB-NW + ELLP-NR Still in production
SL24XSTG-NW EL4XSTG-NW Still in production
SL24XSTG-NR EL4XSTG-NW + ELLP-NR Still in production
SL24XSTR-NW EL4XSTR-NW Still in production
SL24XSTR-NR EL4XSTR-NW + ELLP-NR Still in production
SL2HWR-N ELHNR AH-R
ZH-R
SLHWR-N
SC-HN-WR-N
SL2HWW-N ELHNW AH-W
ZH-W
SLHWW-N
SC-HN-WW-N
SL2HSWR-A ELHSR-A SLHSWR-A SC-HS-WR-F + SCVR-HS-WR-AGT
SL2HSWW-A ELHSW-A SLHSWW-A SC-HS-WW-F + SCVR-HS-WW-AGT
SL2HSWR-F ELHSR AS-MC-R
AS-HMC-R
ZH-MC-R
ZH-HMC-R
SLHSWR-F
SC-HS-WR-F
SL2HSWW-F ELHSW AS-MC-W
AS-HMC-W
ZH-MC-W
ZH-HMC-W
SLHSWW-F
SC-HS-WW-F
SL2HSWR-N ELHSR-N SLHSWR-N SC-HS-WR-F + SCVR-HS-WR-BNK
SL2HSWW-N ELHSW-N SLHSWW-N SC-HS-WW-F + SCVR-HS-WW-BNK
SL2HSWR-FB None SLHSWR-FB SC-HS-WR-F + SCVR-HS-WR-HOF
SL2HSWW-FB None SLHSWW-FB SC-HS-WW-F + SCVR-HS-WW-HOF
SL2HSWW-EV ELHSW-EV None None
SL2HCR-N ELHNRC AH-R
NH-CR
ZH-R
SLHCR-N
SC-HN-CR-N
SL2HCW-N ELHNWC AH-W
NH-CW
ZH-W
SLHCW-N
SC-HN-CW-N
SL2HSCR-A None SLHSCR-A SC-HS-CR-F + SCVR-HS-CR-AGT
SL2HSCW-A None SLHSCW-A SC-HS-CW-F + SCVR-HS-CW-AGT
SL2HSCR-AL None SLHSCR-AL SC-HS-CR-F + SCVR-HS-CR-ALR
SL2HSCW-AL None SLHSCW-AL SC-HS-CW-F + SCVR-HS-CW-ALR
SL2HSCR-F ELHSRC AS-MC-CR
AS-HMC-CR
NS-MC-CR
NS-HMC-CR
ZH-MC-CR
ZH-HMC-CR
SLHSCR-F
SC-HS-CR-F
SL2HSCW-F ELHSWC AS-MC-CW
AS-HMC-CW
NS-MC-CW
NS-HMC-CW
ZH-MC-CW
ZH-HMC-CW
SLHSCW-F
SC-HS-CW-F
SL2HSCR-N None SLHSCR-N SC-HS-CR-F + SCVR-HS-CR-BNK
SL2HSCW-N ELHSWC-N SLHSCW-N SC-HS-CW-F + SCVR-HS-CW-BNK
SL2HSCR-FB None SLHSCR-FB SC-HS-CR-F + SCVR-HS-CR-HOF
SL2HSCW-FB None SLHSCW-FB SC-HS-CW-F + SCVR-HS-CW-HOF
SL23RHN-NR EL3RHN-NR Still in production
SL23RHN-NW EL3RHN-NW Still in production
SL24XHN-NR EL4XHN-NR Still in production
SL24XHN-NW EL4XHN-NW Still in production
SL23RHS-FR EL3RHS-FR Still in production
SL23RHS-FW EL3RHS-FW Still in production
SL24XHS-FR EL4XHS-FR Still in production
SL24XHS-FW EL4XHS-FW Still in production
SL2SPWR-AL[41] ELSPKR-AL SLSPWR-AL SC-SP-WR-F + SCVR-SS-WR-ALR
SL2SPWW-AL ELSPKW-AL SEH-W-ALERT
SLSPWW-AL
SC-SP-WW-F + SCVR-SS-WW-ALR
SL2SPWR-F ELSPKR SLSPWR-F SC-SP-WR-F
SL2SPWW-F ELSPKW SLSPWW-F SC-SP-WW-F
SL2SPWR-N ELSPKR-N SE-R
SEF-R
SET-R
SEH-R
SEFH-R
SLSPWR-N
SC-SP-WR-F + SCVR-SS-WR-BNK
SL2SPWW-N ELSPKW-N SE-W
SEF-W
SET-W
SEH-W
SEFH-W
SLSPWW-N
SC-SP-WW-F + SCVR-SS-WW-BNK
SL2SPSWR-ALA ELSPSTR-ALA SET-AMC-R-MNS-ALERT
SLSPSWR-ALA
SC-SS-WR-F + SCVR-SS-WR-ALR + STLENS-A
SL2SPSWW-ALA ELSPSTW-ALA SET-AMC-W-MNS-ALERT
SEH-AMC-W-ALERT
SEFH-AMC-W-ALERT
SLSPSWW-ALA
SC-SS-WW-F + SCVR-SS-WW-ALR + STLENS-A
SL2SPSWR-NA ELSPSTR-NA SLSPSWR-NA SC-SS-WR-F + SCVR-SS-WR-BNK + STLENS-A
SL2SPSWW-NA ELSPSTW-NA SLSPSWW-NA SC-SS-WW-F + SCVR-SS-WW-BNK + STLENS-A
SL2SPSWR-AL ELSPSTR-AL SET-CMC-R-MNS-ALERT
SET-AMC-R-MNS-ALERT
SEH-MC-R-ALERT
SEFH-MC-R-ALERT
SLSPSWR-AL
SL2SPSWW-AL ELSPSTW-AL SET-CMC-W-MNS-ALERT
SEH-MC-W-ALERT
SEH-HMC-W-ALERT
SEFH-MC-W-ALERT
SLSPSWW-AL
SL2SPSWR-M ELSPSTR-M SLSPSWR-M SC-SS-WR-F + SCVR-SS-WR-EMG
SL2SPSWW-M ELSPSTW-M SLSPSWW-M SC-SS-WW-F + SCVR-SS-WW-EMG
SL2SPSWR-F ELSPKR SE-MC-R
SE-HMC-R
SEF-MC-R
SEF-HMC-R
SET-MC-R
SET-HMC-R
SEH-MC-R
SEH-HMC-R
SEFH-MC-R
SEFH-HMC-R
SLSPSWR-F
SC-SS-WR-F
SL2SPSWW-F ELSPKW SE-MC-W
SE-HMC-W
SEF-MC-W
SEF-HMC-W
SET-MC-W
SET-HMC-W
SEH-MC-W
SEH-HMC-W
SEFH-MC-W
SEFH-HMC-W
SLSPSWW-F
SC-SS-WW-F
SL2SPSWR-N ELSPSTR-N SLSPSWR-N SC-SS-WR-F + SCVR-SS-WR-BNK
SL2SPSWW-N ELSPSTW-N SEH-MC-W-BLANK
SEFH-MC-W-BLANK
SLSPSWW-N
SL2SPSWR-FB None SLSPSWR-FB SC-SS-WR-F + SCVR-SS-WR-HOF
SL2SPSWW-FB None SLSPSWW-FB SC-SS-WW-F + SCVR-SS-WW-HOF
SL2SPCB-F ELSPKBC None Special order from ACEND series
SL2SPCR-AL ELSPKRC-AL SLSPCR-AL SC-SP-CR-F + SCVR-SS-CR-ALR
SL2SPCW-AL ELSPKWC-AL SEH-CW-ALERT
SLSPCW-AL
SC-SP-CW-F + SCVR-SS-CW-ALR
SL2SPCR-F ELSPKRC SLSPCR-F SC-SP-CR-F
SL2SPCW-F ELSPKWC SLSPWC-F SC-SP-CW-F
SL2SPCR-N ELSPKRC-N SEC-R
SEF-CR
SECH-R
SEFH-CR
SLSPCR-N
SC-SP-CR-F + SCVR-SS-CR-BNK
SL2SPCW-N ELSPKWC-N SEC-W
SEF-CW
SET-CW
SECH-W
SEFH-CW
SLSPCW-N
SC-SP-CW-F + SCVR-SS-CW-BNK
SL2SPCW-A None SLSPCW-A SC-SP-CW-F + SCVR-SS-CW-AGT
SL2SPSCR-ALA ELSPSTRC-ALA SET-AMC-CR-MNS-ALERT
SLSPSCR-ALA
SC-SS-CR-F + SCVR-SS-CR-ALR + STLENS-A
SL2SPSCW-ALA ELSPSTWC-ALA SET-AMC-CW-MNS-ALERT
SEH-AMC-CW-ALERT
SEFH-AHMC-CW-ALERT
SLSPSCW-ALA
SC-SS-CW-F + SCVR-SS-CW-ALR + STLENS-A
SL2SPSCR-NA ELSPSTRC-NA SLSPSCR-NA SC-SS-CR-F + SCVR-SS-CR-BNK + STLENS-A
SL2SPSCW-NA ELSPSTWC-NA SLSPSCW-NA SC-SS-CW-F + SCVR-SS-CW-BNK + STLENS-A
SL2SPSCR-A None SLSPSCR-A SC-SS-CR-F + SCVR-SS-CR-AGT
SL2SPSCW-A None SLSPSCW-A SC-SS-CW-F + SCVR-SS-CW-AGT
SL2SPSCR-AL ELSPSTRC-AL SET-CMC-CR-MNS-ALERT
SEFH-MC-CR-ALERT
SEFH-HMC-CR-ALERT
SLSPSCR-AL
SL2SPSCW-AL ELSPSTWC-AL SET-CMC-CW-MNS-ALERT
SEH-MC-CW-ALERT
SEFH-MC-CW-ALERT
SEFH-HMC-CW-ALERT
SLSPSCW-AL
SL2SPSCR-F ELSPSTR SE-MC-CR
SE-HMC-CR
SET-MC-CR
SET-HMC-CR
SEH-MC-CR
SEH-HMC-CR
SEFH-MC-CR
SEFH-HMC-CR
SLSPSCR-F
SC-SS-CR-F
SL2SPSCW-F ELSPSTW SE-MC-CW
SE-HMC-CW
SEF-MC-CW
SEF-HMC-CW
SET-MC-CW
SET-HMC-CW
SEH-MC-CW
SEH-HMC-CW
SEFH-MC-CW
SEFH-HMC-CW
SLSPSCW-F
SC-SS-CW-F
SL2SPSCR-N ELSPSTR-N SLSPSCR-N SC-SS-CR-F + SCVR-SS-CR-BNK
SL2SPSCW-N ELSPSTW-N SEH-MC-CW-BLANK
SEFH-MC-CW-BLANK
SLSPSCW-N
SL2SPSCR-FB None SLSPSCR-FB SC-SS-CR-F + SCVR-SS-CR-HOF
SL2SPSCW-FB None SLSPSCW-FB SC-SS-CW-F + SCVR-SS-CW-HOF
SL24XSP-NR[42] EL4XSPK-NR Still in production
SL24XSP-NW EL4XSPK-NW Still in production
SL23RSP-NR EL3RSPK-NR Still in production
SL23RSP-NW EL3RSPK-NW Still in production
SL24XSPS-FR EL4XSPST-FR Still in production
SL24XSPS-FW EL4XSPST-FW Still in production
SL23RSPS-FR EL3RSPST-FR Still in production
SL23RSPS-FW EL3RSPST-FW Still in production
SL24XSPSAM-NR EL4XSPSTA-ALW + ELLP-NR Still in production
SL24XSPSAM-NW EL4XSPSTA-ALW + ELLP-NW Still in production
SL23RSPSAM-NR EL3RSPSTA-ALW + ELLP-NR Still in production
SL23RSPSAM-NW EL3RSPSTA-ALW + ELLP-NW Still in production
SL24XSPSB-NW None Still in production
SL24XSPSB-NR None Still in production
SL24XSPSG-NW None Still in production
SL24XSPSG-NR None Still in production
SL24XSPSR-NW None Still in production
SL24XSPSR-NR None Still in production
SL23RSPSB-NW None Still in production
SL23RSPSB-NR None Still in production
SL23RSPSG-NW None Still in production
SL23RSPSG-NR None Still in production
SL23RSPSR-NW None Still in production
SL23RSPSR-NR None Still in production
Siemens model Wheelock model Replaced Replaced by
SL2FSWR-AL[43] ELFHNR-AL SLFSWR-AL SC-LFS-WR-N + SCVR-SS-WR-ALR
SL2FSWW-AL ELFHNW-AL SLFSWW-AL SC-LFS-WW-N + SCVR-SS-WW-ALR
SL2FSWR-N ELFHNR-N SLFSWR-N SC-LFS-WR-N
SL2FSWW-N ELFHNW-N SLFSWW-N SC-LFS-WW-N
SL2FSWR-CO ELFHNR-CO SLFSWR-CO
SL2FSWW-CO ELFHNW-CO SLFSWW-CO
SL2FSWR-F ELFHNR SLFSWR-F
SL2FSWW-F ELFHNW SLFSWW-F
SL2FSSWR-AL ELFHSR-AL SLFSSWR-AL SC-LFSS-WR-F + SCVR-SS-WR-ALR
SL2FSSWW-AL ELFHSW-AL SLFSSWW-AL SC-LFSS-WW-F + SCVR-SS-WW-ALR
SL2FSSWR-CO ELFHSR-CO SLFSSWR-CO
SL2FSSWW-CO ELFHSW-CO SLFSSWW-CO
SL2FSSWR-F ELFHSR SLFSSWR-F SC-LFSS-WR-F
SL2FSSWW-F ELFHSW SLFSSWW-F SC-LFSS-WW-F
SL2FSSWR-N ELFHSR-N SLFSSWR-N SC-LFSS-WR-F + SCVR-SS-WR-BNK
SL2FSSWW-N ELFHSW-N SLFSSWW-N SC-LFSS-WW-F + SCVR-SS-WW-BNK
SL2FSCR-AL[44] ELFHNRC-AL None SC-LFS-CR-N + SCVR-SS-CR-ALR
SL2FSCW-AL ELFHNWC-AL None SC-LFS-CW-N + SCVR-SS-CW-ALR
SL2FSCR-N ELFHNRC-N None SC-LFS-CR-N
SL2FSCW-N ELFHNWC-N None SC-LFS-CW-N
SL2FSCR-CO ELFHNRC-CO None
SL2FSCW-CO ELFHNWC-CO None
SL2FSCR-F ELFHNRC None
SL2FSCW-F ELFHNWC None
SL2FSSCR-AL ELFHSRC-AL None SC-LFSS-CR-F + SCVR-SS-CR-ALR
SL2FSSCW-AL ELFHSWC-AL None SC-LFSS-CW-F + SCVR-SS-CW-ALR
SL2FSSCR-F ELFHSRC None SC-LFSS-CR-F
SL2FSSCW-F ELFHSWC None SC-LFSS-CW-F
SL2FSSCR-N ELFHSRC-N None SC-LFSS-CR-F + SCVR-SS-CR-BNK
SL2FSSCW-N ELFHSWC-N None SC-LFSS-CW-F + SCVR-SS-CW-BNK
SL2FSSCR-CO ELFHSRC-CO None
SL2FSSCW-CO ELFHSWC-CO None
Chimes
SL2CHWR-F[45] None CH-R
SL2CHWW-F None CH-W
SL2CHSWR-F ELCHSR CH-MC-R
SL2CHSWW-F ELCHSW CH-MC-W
SL2CHCR-F[46] ELCHRC None
SL2CHCW-F ELCHWC CH-CW
SL2CHSCR-F ELCHSRC CH-MC-CR
SL2CHSCW-F ELCHSWC CH-MC-CW
CH-HMC-CW
Multitone horns
SL2MTWR-F[47] None MTH-R
HS-R
SL2MTWW-F None MTH-W
HS-W
SL2MTSWR-F ELMTSR MTH-MC-R
HS-MC-R
HS-HMC-R
SL2MTSWW-F ELMTSW MTH-MC-W
HS-MC-W
HS-HMC-W
SL2MTSWR-FB None None Still in production
SL2MTSWW-FB None None Still in production
SL2MTSWR-A ELMTSR-A MTH-MC-R-AR Still in production
SL2MTSWR-N ELMTSR-N None Still in production
SL2MTSWW-N ELMTSW-N None Still in production
SL2MTSWR-NR ELMTSR-NR None Still in production
SL2MTSWW-NR ELMTSW-NR None Still in production
SL2MTSWW-NA ELMTSW-NA None Still in production
SL2MTSWW-NB ELMTSW-NB None Still in production
SL2MTSWW-NG None None Still in production
SL2MTSCR-F ELMTSRC None Still in production
SL2MTSCW-F ELMTSWC None Still in production
SL2MTSCR-FB None None Still in production
SL2MTSCW-NA ELMTSWC-NA None Still in production
SL2MTSCW-NB ELMTSWC-NB None Still in production
SL2MTSCW-NG ELMTSWC-NG None Still in production
SL2MTSCW-NR ELMTSWC-NR None Still in production
SL24XMT-NW[48] EL4XMT-NW Still in production
SL24XMT-NR EL4XMT-NR Still in production
SL23RMT-NW EL3RMT-NW Still in production
SL23RMT-NR EL3RMT-NR Still in production
SL24XMTS-FW EL4XMTST-FW Still in production
SL24XMTS-FR EL4XMTST-FR Still in production
SL23RMTS-FW EL3RMTST-FW Still in production
SL23RMTS-FR EL3RMTST-FR Still in production
SL24XMTSAM-NW EL4XMTSTA-ALW + ELLP-NW Still in production
SL24XMTSAM-NR EL4XMTSTA-ALW + ELLP-NR Still in production
SL23RMTSAM-NW EL3RMTSTA-ALW + ELLP-NW Still in production
SL23RMTSAM-NR EL3RMTSTA-ALW + ELLP-NR Still in production
SL24XMTSB-NW EL4XMTSTB-NW Still in production
SL24XMTSB-NR EL4XMTSTB-NW + ELLP-NR Still in production
SL24XMTSG-NW EL4XMTSTG-NW Still in production
SL24XMTSG-NR EL4XMTSTG-NW + ELLP-NR Still in production
SL24XMTSR-NW EL4XMTSTR-NW Still in production
SL24XMTSR-NR EL4XMTSTR-NW + ELLP-NR Still in production
SL23RMTSB-NW EL3RMTSTB-NW Still in production
SL23RMTSB-NR EL3RMTSTB-NW + ELLP-NR Still in production
SL23RMTSG-NW EL3RMTSTG-NW Still in production
SL23RMTSG-NR EL3RMTSTG-NW + ELLP-NR Still in production
SL23RMTSR-NW EL3RMTSTR-NW Still in production
SL23RMTSR-NR EL3RMTSTR-NW + ELLP-NR Still in production
Mounting accessories
SL2SBB-R ELSBB-R
SL2SBB-W ELSBB-W
SL2SPBB-R ELSPKBB-R
SL2SPBB-W ELSPKBB-W
SLSPBBCR LSPKBB-CR
SLSPBBCW LSPKBB-CW
  1. 1.0 1.1 https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-horns-strobes-data-sheet-TD450157EN.pdf
  2. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-high-fidelity-speakers-data-sheet-TD450158EN.pdf
  3. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-low-frequency-sounders-TD450159EN.pdf
  4. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-horns-strobes-data-sheet-TD450157EN.pdf
  5. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-high-fidelity-speakers-data-sheet-TD450158EN.pdf
  6. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-led3-e50-e60-e70h-e90h-rss-product-discontinuation-notice.pdf
  7. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/Xenon%20Tube%20Cessation.pdf
  8. 8.0 8.1 8.2 8.3 8.4 8.5 8.6 https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-cross-reference-sell-sheet-PA450011EN.pdf
  9. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/cluster-speakers/eaton-sth-elstc-data-sheet-en%20(1).pdf
  10. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/lsmns-eluxa-outdoor-amber-lens-update-TBASD240005.pdf
  11. "Eluxa AMT Multi-tone Horns and Multi-tone Strobe appliances" (TD450193EN). Eaton (March 2025).
  12. "INSTALLATION INSTRUCTIONS WHEELOCK ELUXA ADDRESSABLE MULTI-TONE, AND MULTI-TONE STROBE APPLIANCES WALL MOUNT (CLEAR LENS)" (P85910B). Cooper Notification (February 2025).
  13. "Eluxa high fidelity speaker strobes blue lens" (TD450192EN). Eaton (April 2025).
  14. "Eluxa horn strobe and strobe colored lens" (TD450191EN). Eaton (April 2025).
  15. "Eluxa multitone horns & horn strobes" (TD450181EN). Eaton (April 2025).
  16. "Eluxa colored lens multitone horns and horn strobes" (TD450182EN). Eaton (April 2025).
  17. "Eluxa high fidelity speaker strobes & speakers clear and amber lens" (TD450158EN). Eaton (May 2025).
  18. "Eluxa chimes and chime strobes" (TD450180EN). Eaton (May 2025).
  19. "Eluxa horns, horn strobes, & strobes clear and amber lens" (TD450157EN). Eaton (June 2025).
  20. "Eluxa supervised self-amplified speakers and speaker strobes" (TD450197EN). Eaton (July 2025).
  21. "Eluxa trim plate series" (TD450199EN). Eaton (November 2025).
  22. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-colored-lens-strobes-data-sheet-TD450160EN.pdf
  23. "Eluxa outdoor 3R/4X horn, horn-strobe and strobe" (TD450188EN). Wheelock (July 2024).
  24. "Wheelock Eluxa outdoor product cross reference" (PA450011EN). Eaton (August 2024).
  25. "Eluxa outdoor colored lens 4X/3R strobes" (TD450185EN). Wheelock (July 2024).
  26. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-amber-speaker-strobes-data-sheet-TD450161EN.pdf
  27. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/nfpa-2024/eaton-eluxa-3R-4X-outdoor-brochure-en-us.pdf
  28. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/eluxa/eluxa-chimes-chime-strobes-data-sheet-TD450180EN.pdf/eluxa-colored-lens-multitone-horns-data-sheet-TD450182EN.pdf
  29. "Eluxa outdoor 3R/4X multi-tone horns and horn strobes" (TD450187EN). Wheelock (July 2024).
  30. "Eluxa outdoor multi-tone colored lens 3R/4X strobes" (TD450186EN). Wheelock (July 2024).
  31. https://www.firecominc.com/wp-content/uploads/sites/10/2023/08/Eluxa-Horn_Strobes_Horn-Strobes-Cat-Cut-Rev-220301.pdf
  32. https://www.firecominc.com/wp-content/uploads/sites/10/2023/08/Eluxa-Speaker_Speaker-Strobes-Cat-Cut-Rev-210901.pdf
  33. "Monaco Products Catalog". Monaco Enterprises (September 2024).
  34. "PE-HN, PE-HS, PE-ST Series Horns, Horn/Strobes, and Strobes" (8830229). Potter Electric Signal Company (February 2024).
  35. https://www.pottersignal.com/forms/pe-ordering-tool
  36. "PE-SPK, PE-SPST Series Speakers and Speaker Strobes" (8830231). Potter Electric Signal Company (July 2024).
  37. "PE-3RSPK/4XSPK, PE-3RSPST/4XSPST Series Speakers and Speaker Strobes" (8830330). Potter Electric Signal Company (April 2025).
  38. https://mall.industry.siemens.com/mall/collaterals/files/150/pdf/ENG_956875.pdf
  39. https://cache.industry.siemens.com/dl/files/011/109823011/att_1149026/v3/A6V14140218.pdf
  40. "SL2 Weatherproof Series Horns" (2625). Siemens (April 2025).
  41. https://cache.industry.siemens.com/dl/files/014/109823014/att_1149029/v2/A6V14140223.pdf
  42. "SL2 Weatherproof Series Speakers" (2626). Siemens (April 2025).
  43. https://mall.industry.siemens.com/mall/collaterals/files/150/pdf/ENG_956926.pdf
  44. https://cache.industry.siemens.com/dl/files/015/109823015/att_1149030/v3/A6V14140225.pdf
  45. https://cache.industry.siemens.com/dl/files/013/109823013/att_1149028/v2/A6V14140221.pdf
  46. https://cache.industry.siemens.com/dl/files/012/109823012/att_1149027/v2/A6V14140220.pdf
  47. https://cache.industry.siemens.com/dl/files/018/109823018/att_1149033/v2/A6V14140230.pdf
  48. "SL2 Weatherproof Series Multi-Tone Horn" (2627). Siemens (April 2025).
