Wheelock AMT series
8-17.5VDC & 16-33VDC
Wheelock AES series
"title": "Wheelock AMT",
The Wheelock AMT is a series of multitone horns and horn strobes.
The AMT was in development as early as 1991, when Wheelock included some details of the AMT in the patent for the AES.[2] This early version could either operate with a single tone selection or under 4 possible tone groups:
| Switch 1 (L0) | Switch 2 (L1) | Priority 1 | Priority 2 | Priority 3 |
| OFF | OFF | Siren | Hi/Lo | Tone |
| OFF | ON | Horn | Siren | Horn |
| ON | OFF | Siren | Siren | Chime |
| ON | ON | Slow whoop | Bell | Chime |
Code 3 and march time horns and a Code 3 tone were added after this point, and the single tone selection feature was released separately as the MT in 1993.
The AMT was released in 1995 as a remote horn and horn strobe, following the same design as the MT.[1] Initial strobe models used LS, LSM, and IS strobes.[3]
In 1998, NYC models were released with a specialized tone group.[4]
In 2002, the AMT was updated to use the new 15/75 and 75 candela strobes used by the MT.[5][6][7] The LS/LSM/IS models were discontinued at this time.
In March 2004, the AMT-24MCW-FR and AMT-24MCW-FW were released, and the AMT-2475W models were discontinued at the end of April 2004.[8][9]
At the end of 2015, the AMT-241575W models (including the NYC models) were discontinued, and customers were instructed to switch to the AMT-24MCW.[10]
In 2018, the AMT-12/24-R-NYC was discontinued.[11] Customers were instructed to switch to the AMT-12/24-R.
In 2023, the strobe models of the AMT were discontinued, and customers were recommended to either use a separate strobe or the RSSP when an AMT with a strobe is required.[12] The Eluxa replacement was introduced in March 2025.
In August 2025, it was observed that the AMT horns were marked as "to be discontinued" on Eaton's website.[13]
The AMT horn features 3 pairs of terminals for 3 tones, each of which is assigned a priority. 8 sets of tones are selectable, and there are a total of 9 tones, including a 700 Hz vibrating chime tone that was not present on the MT.[14]
Strobe models feature an additional pair of terminals for the strobe. The strobe can operate in unison with the audible signal, and the horizontal strobe models are synchronizable.
| Model Number | Nominal Voltage | Candela | Strobe Orientation | Replaces | Replaced by |
| AMT-12/24-R | 12VDC/24VDC | N/A | N/A | AES-DL1 AES-EL1 AMT-12-LS-VFR (with RSSP-121575W-FR) AMT-12-LSM-VFR (with RSSP-121575W-FR) AMT-24-LS-VFR (with RSSP-24MCW-FR) AMT-12/24-R-NYC |
ELAMTR |
| AMT-12/24-W | 12VDC/24VDC | N/A | N/A | ELAMTW | |
| AMT-12/24-R-NYC | 12VDC/24VDC | N/A | N/A | AMT-12/24-R | |
| AMT-12-LS-VFR | 12VDC | 15 | Vertical | None | AMT-12/24-R + RSSP-121575W-FR |
| AMT-12-LSM-VFR | 12VDC | 15/75 | Vertical | None | AMT-12/24-R + RSSP-121575W-FR |
| AMT-24-LS-VFR | 24VDC | 15 | Vertical | None | AMT-241575W-FR AMT-12/24-R + RSSP-24MCW-FR |
| AMT-24-LSM-VFR[15] | 24VDC | 15/75 | Vertical | AES-DL1-LSM-24[16] AES-EL1-LSM-24 |
AMT-241575W-FR |
| AMT-24-IS-VFR[17][18][19][20][21][22][23][24][25][26] | 24VDC | 75 | Vertical | None | AMT-2475W-FR |
| AMT-241575W-FR | 24VDC | 15/75 | Horizontal | AMT-24-LS-VFR AMT-24-LSM-VFR |
AMT-24MCW-FR |
| AMT-241575W-FW | 24VDC | 15/75 | Horizontal | AMT-24MCW-FW | |
| AMT-241575W-FR-NYC | 24VDC | 15/75 | Horizontal | AMT-24MCW-FR | |
| AMT-241575W-FW-NYC | 24VDC | 15/75 | Horizontal | AMT-24MCW-FW | |
| AMT-241575W-NW | 24VDC | 15/75 | Horizontal | AMT-24MCW-NW | |
| AMT-2475W-FR | 24VDC | 75 | Horizontal | AMT-24-IS-VFR | AMT-24MCW-FR |
| AMT-24MCW-FR | 24VDC | 15, 30, 75, 110 | Horizontal | AMT-241575W-FR AMT-241575W-FR-NYC AMT-2475W-FR |
ELAMTSTR |
| AMT-24MCW-FW | 24VDC | 15, 30, 75, 110 | Horizontal | AMT-241575W-FW AMT-241575W-FW-NYC |
ELAMTSTR + ELGSPSTW |
| AMT-24MCW-NW | 24VDC | 15, 30, 75, 110 | Horizontal | AMT-241575W-NW | ELAMTSTR + ELGSPSTW-N |
The Gamewell rebrands of the AMT series were given a -GAM suffix by Wheelock, but this was not typically visible to the consumer.
| Gamewell model | Wheelock model | Replaces | Replaced by |
| 71573[27] | AMT-12/24-R | AMT-12/24-R | |
| 72244 | AMT-241575W-FR | AMT-241575W-FR | |
| 72245 | AMT-241575W-FW | AMT-241575W-FW | |
| 72246 | AMT-2475W-FR | AMT-24MCW-FR |
- ↑ 1.0 1.1 https://nfpa.access.preservica.com/uncategorized/IO_873437a3-fa8d-4d7a-8f60-0f3aac96a700/
- ↑ https://www.freepatentsonline.com/5293155.html
- ↑ https://web.archive.org/web/19970214013412/http://www.wheelockinc.com/AMT/amt2.html
- ↑ https://web.archive.org/web/20030316062543/http://www.wheelockinc.com/Specs/s-series/S4100.pdf
- ↑ https://web.archive.org/web/20020616010333/http://www.wheelockinc.com/Products/_ae_specs/Fire_Alarm/Audible_Visual/Series_AMT.htm
- ↑ https://web.archive.org/web/20021022115936/http://www.wheelockinc.com/Products/_ae_specs/Fire_Alarm/Audible_Visual/Series_AMT.htm
- ↑ https://web.archive.org/web/20040804162250/http://www.wheelockinc.com/Specs/s-series/s4100.pdf
- ↑ https://web.archive.org/web/20060322120633/http://www.wheelockinc.com/literature/NotifNewsFeb04.pdf
- ↑ https://web.archive.org/web/20040804164325/http://www.wheelockinc.com/Specs/s-series/s4000.pdf
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-ps-amt-ch-e-et-hs4-mt-rss-product-discontinuation-notice.pdf
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-cvx-csx-amt-nyc-product-discontinuation-notice.pdf
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/Xenon%20Tube%20Cessation.pdf
- ↑ https://web.archive.org/web/20250817161221/https://www.eaton.com/us/en-us/catalog/alarms-and-signaling-devices/wheelock-amt-multitone-horns.html#tab-2
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/amt/wheelock-amt-horns-strobes-data-sheet-TD450153EN.pdf
- ↑ https://i.ebayimg.com/images/g/kUoAAeSwRm5oOKkB/s-l1600.webp
- ↑ https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/manuals-and-guides/device-compatibility-manuals/hbt-fire-15378-CB.pdf
- ↑ https://i.ebayimg.com/images/g/sSAAAOSwOsxnj~sY/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/XaQAAOSw81Znj~ss/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/rSsAAOSwX59nj~tR/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/x70AAOSwyFdnj0Xd/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/fE8AAOSwT8pnj0a1/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/r3sAAOSwGkZnj0bn/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/JfIAAOSwXa5nj~t5/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/ImoAAOSwOUhnj~uZ/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/PUAAAOSwLyVnj~uw/s-l1600.webp
- ↑ https://i.ebayimg.com/images/g/SSkAAOSwoKVnj~wd/s-l1600.webp
- ↑ https://web.archive.org/web/20030409100412/http://gamewell.com/pdf/datasheets/CS-2248.pdf
