Wheelock LSM series
Wheelock LSM
Wheelock WM series
Wheelock VLP series {"label": "Preceded by", "field": "Wheelock WM series
Wheelock VLP series"}
Wheelock RS series
Wheelock RSP series {"label": "Succeeded by", "field": "Wheelock RS series
Wheelock RSP series"}
The Wheelock LSM series is a series of 15/75 candela remote strobes and strobe plates. The strobes were also produced for combination devices.
The LSM series was released around 1994 as an ADA compliant strobe that meets the UL 1971 light distribution requirements. The strobes were only listed for wall-mounting, but many wall-mount devices that were available with LS strobes were also released with LSM strobes.
The LSM remote strobes and strobe plates were phased out after the release of the RS and RSP, which had very similar functionality. Combination strobes such as the MT-24-LSM-VFR remained in production until the early 2000s, with the ET-1080-LSM-24-VFR in production until 2004.
Standalone devices
Model Mounting Color Replaces Replaced by
LS1M-12-VFR[1] Single gang Red None RS-121575-VFR
LSPM-12-VFR Plate Red None RSP-121575-VFR[citation needed]
LSM-24-VFR 4-inch square Red WMT-24 RS-241575-VFR
LS1M-24-VFR Single gang Red WM1T-24 RS-241575-VFR
LS3M-24-VFR Surface Red WM3T-24 RS-241575-VFR
LSPM-24-VFR Plate Red VLPM-24-W-VF-R RSP-241575-VFR[citation needed]
Combination strobes
Model Type Replaces Replaced by
MT-12-LSM-VFR Multitone horn MT4-12-LSM-VFR MT-121575W-FR
MT4-12-LSM-VFR Multitone horn None MT-12-LSM-VFR
MT-24-LSM-VFR Multitone horn MT-24-WM-VFR
MT4-24-LSM-VFR
MT-241575W-FR
MT4-24-LSM-VFR Multitone horn None MT-24-LSM-VFR
AMT-12-LSM-VFR Addressable multitone horn None None
AMT-24-LSM-VFR Addressable multitone horn AES-DL1-LSM-24
AES-EL1-LSM-24
AMT-241575W-FR
AES-DL1-LSM-24 Addressable multitone horn AES-DL1-WM-24 AMT-24-LSM-VFR
AES-EL1-LSM-24 Addressable multitone horn AES-EL1-WM-24 AMT-24-LSM-VFR
MIZ-12-LSM-VFR Mini-horn None NS-121575W-FR
MIZ-24-LSM-VFR Mini-horn MIZ-24-WM-VFR NS-241575W-FR
ET-1070-LSM-24 Speaker ET-1070-WM-24 ET70-241575W-FR
ET-1080-LSM-24 Speaker None ET80-241575W-FR
E-7025-LSM-24 Speaker E-7025-WM-24 E-70-LSM-24-VFR
E-7070-LSM-24 Speaker E-7070-WM-24 E-70-LSM-24-VFR
E-70-LSM-24-VFR Speaker E-7025-LSM-24
E-7070-LSM-24
E70-241575W-FR
SA-70S-LSM-24 Speaker None None
CH-DF1-LSM-24-VFR Chime None CH70-241575W-FR
Honeywell model Wheelock model Replaced Replaced by
SC813A 1021[2] LS1M-24-VFR XLS202-7A-T
S15/75-STD[3] LSM-24-VFR S17-FT
S15/75-SGL LS1M-24-VFR S17-FS
S15/75-SUR LS3M-24-VFR S17-ST
S15/75-RET LSPM-24-VFR S17-6090V
Gamewell Model Wheelock Model Replaces Replaced by
71275 LSPM-24-VFR N/A None
