Wheelock WM series
2001
Wheelock WH series
Wheelock HSW series |
"title": "Wheelock WM",
The Wheelock WM series is a series of strobes rated for 117 candela under UL 1638. The strobes were available as remote strobes and as part of combination strobes.
The WM series was released in 1992 to comply with ADA and to illuminate sleeping areas.[1] Many combination devices with WS series strobes then became available with WM strobes.
In 1994, due to the UL 1971 requirements taking effect, the WM series was no longer usable for indoor public mode signaling.[2] Wheelock continued producing certain WM strobes for outdoor use until the end of 2001.[3][4] At this point, the RSSWP series replaced the WM series.
Standalone devices
| Model | Mounting | Color | Replaces | Replaced by |
| WMT-24 | 4-inch square | Red | None | HSW-24-HFR LSM-24-VFR |
| WM1T-24 | Single gang | Red | None | LS1M-24-VFR |
| WM3T-24 | Surface | Red | WH3T-24 | LS3M-24-VFR RSSWP-2475W-FR |
Combination strobes
| Model | Type | Replaces | Replaced by |
| EH-DL1-WM-24 | Electronic horn | None | MT-24-WM-VFR |
| EH-EL1-WM-24 | Electronic horn | None | None |
| EW-DH1-WM-24 | Slow whoop | None | MT-24-WM-VFR |
| EW-EH1-WM-24 | Slow whoop | None | None |
| MT-24-WM-VFR | Multitone horn | EH-DL1-WM-24 EW-DH1-WM-24 |
MT-24-LSM-VFR MTWP-2475W-FR |
| AES-DL1-WM-24 | Addressable multitone horn | None | AES-DL1-LSM-24 |
| AES-EL1-WM-24 | Addressable multitone horn | None | AES-EL1-LSM-24 |
| MIZ-24-WM-VFR | Mini-horn | None | MIZ-24-HSW-HFR MIZ-24-LSM-VFR |
| ET-1070-WM-24 | Speaker | None | ET-1070-LSM-24-VFR |
| E-7025-WM-24 | Speaker | None | E-7025-LSM-24 |
| E-7070-WM-24 | Speaker | None | E-7070-LSM-24 |
| E-9025-WM-24 | Speaker | None | E-9025-LSM-24 |
Cerberus Pyrotronics
| Cerberus Pyrotronics model | Wheelock model | Replaced | Replaced by |
| SVMT-F[5] | WMT-24 | S15/75-STD S110-STD | |
| SVM1T-F[6] | WM1T-24 | S15/75-SGL | |
| SVM3T-SO | WM3T-24 | S15/75-SUR |
| Honeywell model | Wheelock model | Replaced | Replaced by |
| SC807D1007[7] | WMT-24 |
- ↑ 1.0 1.1 https://nfpa.access.preservica.com/uncategorized/IO_6a9d0d60-3772-4e83-8154-db96b139a8d4/
- ↑ https://web.archive.org/web/19970401001201/http://www.systemsensor.com/e-docs/appguide/a218-02.pdf
- ↑ https://web.archive.org/web/20011103001523/http://www.wheelockinc.com/Products/_ae_specs/Fire_Alarm/Visual/SeriesRSS.htm
- ↑ https://web.archive.org/web/20020206103809/http://www.wheelockinc.com/Products/Product_Index_Pages/Fire_Alarm_Index/nac_alert_visual_appliances.htm
- ↑ "Compatible Notification Appliances" (315-096363-7). Siemens Building Technologies, Inc..
- ↑ https://i.ebayimg.com/00/s/MFgyMTQ3NDgzNjQ3/z/TdIAAOxyDgRQ~us8/$_61.JPG
- ↑ https://i.ebayimg.com/images/g/WT0AAOSwymNkC0O~/s-l1600.png
