Wheelock HS series (flush mount horns)
Wheelock MT-24-MCW.jpg: Infobox image for Wheelock HS series the infobox device.
16-33VDC {"label": "Rated Voltage", "field": "16-33VDC"}
2003[1] {"label": "Introduced", "field": "2003[1]"}
2023[2] {"label": "Discontinued", "field": "2023[2]"}
Wheelock NS4 {"label": "Preceded by", "field": "Wheelock NS4"}
The Wheelock HS series is a series of horns and 4-wire horn strobes with completely independent horn and strobe control.
The HS4 was released in 2003 as a replacement for the NS4.[1] The device used the same design as the MT and AMT and the same synchronizable horn as the AS. Models were produced with 15/75 candela, 185 candela, and multi-candela strobes. A horn-only HS was also released at this time.
In late 2003, the 185 candela strobe was replaced with a MCWH strobe that could either output 135 or 185 candela.[3]
In the mid 2000s, ceiling mount models of the HS4 were released.[4] The ceiling mount models used either MCC or MCCH strobes.
At the end of 2015, the HS4-241575W models were discontinued, and customers were instructed to switch to the HS4-24MCW models.[5]
The HS series was discontinued in 2023, and consumers were instructed to instead use the Eluxa ELMTS, which has the same 4-wire synchronization capabilities when set to the Code 3 horn.[2]
Like the AS, the HS series horns have 3 volume options. Unlike the NS4, the HS4 horn can still operate without power to the strobe.[6] Both the horn and strobe can be synchronized by the Wheelock sync protocol.
Model Number Candela Mounting Color Replaces Replaced by
HS-24-R N/A Wall/Ceiling Red None ELMTR
HS-24-W N/A Wall/Ceiling White None ELMTW
HS4-121575W-FR[7] 15/75 Wall Red NS4-121575W-FR None
HS4-241575W-FR 15/75 Wall Red NS4-241575W-FR HS4-24MCW-FR
HS4-241575W-FW 15/75 Wall White NS4-241575W-FW HS4-24MCW-FW
HS4-24185W-FR 185 Wall Red None HS4-24MCWH-FR
HS4-24185W-FW 185 Wall White None HS4-24MCWH-FW
HS4-24MCW-FR 15, 30, 75, 110 Wall Red NS4-24MCW-FR
HS4-241575W-FR
ELMTSR
HS4-24MCW-FW 15, 30, 75, 110 Wall White NS4-24MCW-FW
HS4-241575W-FW
ELMTSW
HS4-24MCWH-FR 135, 185 Wall Red HS4-24185W-FR ELMTSR
HS4-24MCWH-FW 135, 185 Wall White HS4-24185W-FW ELMTSW
HS4-24MCC-FR 15, 30, 75, 95 Ceiling Red None ELMTSRC
HS4-24MCC-FW 15, 30, 75, 95 Ceiling White None ELMTSWC
HS4-24MCCH-FR 115, 177 Ceiling Red None ELMTSRC
HS4-24MCCH-FW 115, 177 Ceiling White None ELMTSWC
Siemens started rebranding the HS series around 2007, when the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit required the Siemens U series to be discontinued. The series was also sold under the Faraday brand using the same model names to replace the 2800 series, 6200 series, and 6300 series.[8]
HS-R HS-24-R 6230B-0-14-24-DC
6250B-0-14-24-DC
U-HN
U-HNH
SL2MTWR-F[9]
HS-W HS-24-W 6230B-0-21-24-DC
6250B-0-21-24-DC
U-HN-W
U-HNH-W
SL2MTWW-F
HS-MC-R HS4-24MCW-FR 2834B-14-24
6234B-14-24
6254B-14-24
6304B-14-24
6314B-14-24
U-HN-MCS
U-HNH-MCS
U-MH-MCS
U-MHT-MCS
SL2MTSWR-F
HS-MC-W HS4-24MCW-FW 2834B-21-24
6234B-21-24
6254B-21-24
6304B-21-24
6314B-21-24
U-HN-MCS-W
U-HNH-MCS-W
U-MH-MCS-W
U-MHT-MCS-W
SL2MTSWW-F
HS-HMC-R HS4-24MCWH-FR None SL2MTSWR-F
HS-HMC-W HS4-24MCWH-FW None SL2MTSWR-F
