Wheelock AMT series
(Redirected from Wheelock AMT)
Wheelock AMT
1995[1] {"label": "Introduced", "field": "1995[1]"}
Wheelock AES series {"label": "Preceded by", "field": "Wheelock AES series"}
The Wheelock AMT is a series of multitone horns and horn strobes.
The AMT was in development as early as 1991, when Wheelock included some details of the AMT in the patent for the AES.[2] This early version could either operate with a single tone selection or under 4 possible tone groups:
Switch 1 (L0) Switch 2 (L1) Priority 1 Priority 2 Priority 3
OFF OFF Siren Hi/Lo Tone
OFF ON Horn Siren Horn
ON OFF Siren Siren Chime
ON ON Slow whoop Bell Chime
Code 3 and march time horns and a Code 3 tone were added after this point, and the single tone selection feature was released separately as the MT in 1993.
The AMT was released in 1995 as a remote horn and horn strobe, following the same design as the MT.[1] Initial strobe models used LS, LSM, and IS strobes.[3]
In 1998, NYC models were released with a specialized tone group.[4]
In 2002, the AMT was updated to use the new 15/75 and 75 candela strobes used by the MT.[5][6][7] The LS/LSM/IS models were discontinued at this time.
In March 2004, the AMT-24MCW-FR and AMT-24MCW-FW were released, and the AMT-2475W models were discontinued at the end of April 2004.[8][9]
At the end of 2015, the AMT-241575W models (including the NYC models) were discontinued, and customers were instructed to switch to the AMT-24MCW.[10]
In 2018, the AMT-12/24-R-NYC was discontinued.[11] Customers were instructed to switch to the AMT-12/24-R.
In 2023, the strobe models of the AMT were discontinued, and customers were recommended to either use a separate strobe or the RSSP when an AMT with a strobe is required.[12] The Eluxa replacement was introduced in March 2025.
In August 2025, it was observed that the AMT horns were marked as "to be discontinued" on Eaton's website.[13]
The AMT horn features 3 pairs of terminals for 3 tones, each of which is assigned a priority. 8 sets of tones are selectable, and there are a total of 9 tones, including a 700 Hz vibrating chime tone that was not present on the MT.[14]
Strobe models feature an additional pair of terminals for the strobe. The strobe can operate in unison with the audible signal, and the horizontal strobe models are synchronizable.
Model Number Nominal Voltage Candela Strobe Orientation Replaces Replaced by
AMT-12/24-R 12VDC/24VDC N/A N/A AES-DL1
AES-EL1
AMT-12-LS-VFR (with RSSP-121575W-FR)
AMT-12-LSM-VFR (with RSSP-121575W-FR)
AMT-24-LS-VFR (with RSSP-24MCW-FR)
AMT-12/24-R-NYC
ELAMTR
AMT-12/24-W 12VDC/24VDC N/A N/A ELAMTW
AMT-12/24-R-NYC 12VDC/24VDC N/A N/A AMT-12/24-R
AMT-12-LS-VFR 12VDC 15 Vertical None AMT-12/24-R + RSSP-121575W-FR
AMT-12-LSM-VFR 12VDC 15/75 Vertical None AMT-12/24-R + RSSP-121575W-FR
AMT-24-LS-VFR 24VDC 15 Vertical None AMT-241575W-FR
AMT-12/24-R + RSSP-24MCW-FR
AMT-24-LSM-VFR[15] 24VDC 15/75 Vertical AES-DL1-LSM-24[16]
AES-EL1-LSM-24
AMT-241575W-FR
AMT-24-IS-VFR[17][18][19][20][21][22][23][24][25][26] 24VDC 75 Vertical None AMT-2475W-FR
AMT-241575W-FR 24VDC 15/75 Horizontal AMT-24-LS-VFR
AMT-24-LSM-VFR
AMT-24MCW-FR
AMT-241575W-FW 24VDC 15/75 Horizontal AMT-24MCW-FW
AMT-241575W-FR-NYC 24VDC 15/75 Horizontal AMT-24MCW-FR
AMT-241575W-FW-NYC 24VDC 15/75 Horizontal AMT-24MCW-FW
AMT-241575W-NW 24VDC 15/75 Horizontal AMT-24MCW-NW
AMT-2475W-FR 24VDC 75 Horizontal AMT-24-IS-VFR AMT-24MCW-FR
AMT-24MCW-FR 24VDC 15, 30, 75, 110 Horizontal AMT-241575W-FR
AMT-241575W-FR-NYC
AMT-2475W-FR
ELAMTSTR
AMT-24MCW-FW 24VDC 15, 30, 75, 110 Horizontal AMT-241575W-FW
AMT-241575W-FW-NYC
ELAMTSTR + ELGSPSTW
AMT-24MCW-NW 24VDC 15, 30, 75, 110 Horizontal AMT-241575W-NW ELAMTSTR + ELGSPSTW-N
The Gamewell rebrands of the AMT series were given a -GAM suffix by Wheelock, but this was not typically visible to the consumer.
71573[27] AMT-12/24-R AMT-12/24-R
72244 AMT-241575W-FR AMT-241575W-FR
72245 AMT-241575W-FW AMT-241575W-FW
72246 AMT-2475W-FR AMT-24MCW-FR
  1. 1.0 1.1 https://nfpa.access.preservica.com/uncategorized/IO_873437a3-fa8d-4d7a-8f60-0f3aac96a700/
  2. https://www.freepatentsonline.com/5293155.html
  3. https://web.archive.org/web/19970214013412/http://www.wheelockinc.com/AMT/amt2.html
  4. https://web.archive.org/web/20030316062543/http://www.wheelockinc.com/Specs/s-series/S4100.pdf
  5. https://web.archive.org/web/20020616010333/http://www.wheelockinc.com/Products/_ae_specs/Fire_Alarm/Audible_Visual/Series_AMT.htm
  6. https://web.archive.org/web/20021022115936/http://www.wheelockinc.com/Products/_ae_specs/Fire_Alarm/Audible_Visual/Series_AMT.htm
  7. https://web.archive.org/web/20040804162250/http://www.wheelockinc.com/Specs/s-series/s4100.pdf
  8. https://web.archive.org/web/20060322120633/http://www.wheelockinc.com/literature/NotifNewsFeb04.pdf
  9. https://web.archive.org/web/20040804164325/http://www.wheelockinc.com/Specs/s-series/s4000.pdf
  10. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-ps-amt-ch-e-et-hs4-mt-rss-product-discontinuation-notice.pdf
  11. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-cvx-csx-amt-nyc-product-discontinuation-notice.pdf
  12. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/Xenon%20Tube%20Cessation.pdf
  13. https://web.archive.org/web/20250817161221/https://www.eaton.com/us/en-us/catalog/alarms-and-signaling-devices/wheelock-amt-multitone-horns.html#tab-2
  14. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/amt/wheelock-amt-horns-strobes-data-sheet-TD450153EN.pdf
  15. https://i.ebayimg.com/images/g/kUoAAeSwRm5oOKkB/s-l1600.webp
  16. https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/manuals-and-guides/device-compatibility-manuals/hbt-fire-15378-CB.pdf
  17. https://i.ebayimg.com/images/g/sSAAAOSwOsxnj~sY/s-l1600.webp
  18. https://i.ebayimg.com/images/g/XaQAAOSw81Znj~ss/s-l1600.webp
  19. https://i.ebayimg.com/images/g/rSsAAOSwX59nj~tR/s-l1600.webp
  20. https://i.ebayimg.com/images/g/x70AAOSwyFdnj0Xd/s-l1600.webp
  21. https://i.ebayimg.com/images/g/fE8AAOSwT8pnj0a1/s-l1600.webp
  22. https://i.ebayimg.com/images/g/r3sAAOSwGkZnj0bn/s-l1600.webp
  23. https://i.ebayimg.com/images/g/JfIAAOSwXa5nj~t5/s-l1600.webp
  24. https://i.ebayimg.com/images/g/ImoAAOSwOUhnj~uZ/s-l1600.webp
  25. https://i.ebayimg.com/images/g/PUAAAOSwLyVnj~uw/s-l1600.webp
  26. https://i.ebayimg.com/images/g/SSkAAOSwoKVnj~wd/s-l1600.webp
  27. https://web.archive.org/web/20030409100412/http://gamewell.com/pdf/datasheets/CS-2248.pdf
