Wheelock MIZ series
(Redirected from Siemens MH series)
Wheelock MIZ
10.5-15.6VDC & 20-31VDC[1] {"label": "Rated Voltage", "field": "10.5-15.6VDC & 20-31VDC[1]"}
1989[2] {"label": "Introduced", "field": "1989[2]"}
Wheelock MIN series {"label": "Preceded by", "field": "Wheelock MIN series"}
Wheelock AS
Wheelock NS {"label": "Succeeded by", "field": "Wheelock AS
Wheelock NS"}
The Wheelock MIZ series is a series of mini-horns and horn strobes.
The MIZ was released in 1989 together with the EH series horn. The series initially consisted of horns and horn strobes using WS strobes.[3] A WM strobe model was later released.[4]
In 1993, models with ADA strobes were released. Specifically, models were produced with the the LS, LSM, MS, IS, and HSW. Because the HSW strobe could only be oriented horizontally, the HSW model had a larger plate to accommodate the strobe above the horn.
After the AS was released, the HSW model was discontinued and replaced with the AS-24110-HFR, which had a smaller footprint.
The MIZ series became part of the NACAlert series after it formed.[5] The strobe models were discontinued around this time due to the high profile that would be needed if the strobe models started using horizontal strobes.[6] The newly released NS provided a lower profile and lower current draw for strobe applications.
Around 2000, the MIZ-TC models were released.[7] These models could be set to output Code 3 without external coding, but they could not be synchronized.
In 2003, the MIZ-24S replaced these models.[8] The MIZ-24S had a synchronizable Code 3 horn, and the tone was changed to a broadband tone, making the series competitive with the Edwards Genesis series horns and Siemens U-MHU-1G.[9]
Model Number Nominal Voltage Candela Strobe Orientation Color Replaces Replaced By
MIZ-12-R 12VDC N/A N/A Red None None
MIZ-12-W 12VDC N/A N/A White MIN-12 None
MIZ-24-R 24VDC N/A N/A Red None MIZ-24S-R
MIZ-24-W 24VDC N/A N/A White MIN-24 MIZ-24S-W
MIZ-12-WS 12VDC 1.3[citation needed] Vertical Red None None
MIZ-24-WS 24VDC 1.3[3] Vertical Red None None
MIZ-24-WM-VFR 24VDC 117[citation needed] Vertical Red MIZ-24-LSM-VFR
MIZ-24-HSW-HFR
None
MIZ-12-LS-VFR 12VDC 15 Vertical Red None NS-1215W-FR
MIZ-12-LSM-VFR 12VDC 15/75 Vertical Red None NS-121575W-FR
MIZ-12-MS-VFR 12VDC 30 Vertical Red None None
MIZ-24-LS-VFR 24VDC 15/75 Vertical Red None NS-2415W-FR
MIZ-24-LSM-VFR 24VDC 15/75 Vertical Red MIZ-24-WM-VFR NS-241575W-FR
MIZ-24-MS-VFR 24VDC 30 Vertical Red None NS-2430W-FR
MIZ-24-IS-VFR 24VDC 75 Vertical Red None NS-2475W-FR
MIZ-24-HSW-HFR 24VDC 110 Horizontal Red MIZ-24-WM-VFR AS-24110-HFR
MIZ-TC12-R 12VDC N/A N/A Red None None
MIZ-TC12-W 12VDC N/A N/A White None None
MIZ-TC24-R 24VDC N/A N/A Red None MIZ-24S-R
MIZ-TC24-W 24VDC N/A N/A White None MIZ-24S-W
MIZ-24S-R 24VDC N/A N/A Red MIZ-24-R
MIZ-TC24-R
None
MIZ-24S-W 24VDC N/A N/A White MIZ-24-W
MIZ-TC24-W
None
72039[10] MIZ-TC24-R
72040 MIZ-TC24-W
FCI model Wheelock model Replaced by
130-3117C[11] MIZ-24-R IHP-24B
IHP-24B[12] MIZ-24-R MIZ-24-R[13]
HM-24[14] MIZ-24-R MH-1G
HM-24W MIZ-24-W MH-1GW
HM-24S MIZ-24-WS HM-15
HM-15 MIZ-24-LS-VFR HM-24S MH-S15-U
HM-15/75 MIZ-24-LSM-VFR MH-S17-U
HM-30 MIZ-24-MS-VFR None
HM-75 MIZ-24-IS-VFR MH-S75-U
HM-110[15] MIZ-24-HSW-HFR MH-S110-U
Siemens rebranded the MIZ series as the MH series starting around 2007 as a result of the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit that required the Siemens U series to be discontinued. The series was also sold under the Faraday brand to replace the 6300 series and 2800 series.
Siemens model Wheelock model Replaces
MH-R[16] MIZ-24S-R 2830B-14-24
6300B-0-14-24-DC
6310B-0-14-24-DC
G1R-P-LG
G1RF-P-LG
U-MH-1G
U-MHT-1G
U-MHU-1G
MH-W MIZ-24S-W 2830B-21-24
6300B-0-21-24-DC
6310B-0-21-24-DC
G1-P-LG
G1F-P-LG
U-MH-1G-W
U-MHT-1G-W
U-MHU-1G-W
Simplex model Wheelock model
4903-9232 MIZ-24-LS-VFR
4903-9233 MIZ-24-LSM-VFR
