Wheelock HS series (flush mount horns)
16-33VDC
| Discontinued | |
Wheelock NS4
"title": "Wheelock HS series",
"Wheelock MT-24-MCW.jpg"
The Wheelock HS series is a series of horns and 4-wire horn strobes with completely independent horn and strobe control.
The HS4 was released in 2003 as a replacement for the NS4.[1] The device used the same design as the MT and AMT and the same synchronizable horn as the AS. Models were produced with 15/75 candela, 185 candela, and multi-candela strobes. A horn-only HS was also released at this time.
In late 2003, the 185 candela strobe was replaced with a MCWH strobe that could either output 135 or 185 candela.[3]
In the mid 2000s, ceiling mount models of the HS4 were released.[4] The ceiling mount models used either MCC or MCCH strobes.
At the end of 2015, the HS4-241575W models were discontinued, and customers were instructed to switch to the HS4-24MCW models.[5]
The HS series was discontinued in 2023, and consumers were instructed to instead use the Eluxa ELMTS, which has the same 4-wire synchronization capabilities when set to the Code 3 horn.[2]
Like the AS, the HS series horns have 3 volume options. Unlike the NS4, the HS4 horn can still operate without power to the strobe.[6] Both the horn and strobe can be synchronized by the Wheelock sync protocol.
| Model Number | Candela | Mounting | Color | Replaces | Replaced by |
| HS-24-R | N/A | Wall/Ceiling | Red | None | ELMTR |
| HS-24-W | N/A | Wall/Ceiling | White | None | ELMTW |
| HS4-121575W-FR[7] | 15/75 | Wall | Red | NS4-121575W-FR | None |
| HS4-241575W-FR | 15/75 | Wall | Red | NS4-241575W-FR | HS4-24MCW-FR |
| HS4-241575W-FW | 15/75 | Wall | White | NS4-241575W-FW | HS4-24MCW-FW |
| HS4-24185W-FR | 185 | Wall | Red | None | HS4-24MCWH-FR |
| HS4-24185W-FW | 185 | Wall | White | None | HS4-24MCWH-FW |
| HS4-24MCW-FR | 15, 30, 75, 110 | Wall | Red | NS4-24MCW-FR HS4-241575W-FR |
ELMTSR |
| HS4-24MCW-FW | 15, 30, 75, 110 | Wall | White | NS4-24MCW-FW HS4-241575W-FW |
ELMTSW |
| HS4-24MCWH-FR | 135, 185 | Wall | Red | HS4-24185W-FR | ELMTSR |
| HS4-24MCWH-FW | 135, 185 | Wall | White | HS4-24185W-FW | ELMTSW |
| HS4-24MCC-FR | 15, 30, 75, 95 | Ceiling | Red | None | ELMTSRC |
| HS4-24MCC-FW | 15, 30, 75, 95 | Ceiling | White | None | ELMTSWC |
| HS4-24MCCH-FR | 115, 177 | Ceiling | Red | None | ELMTSRC |
| HS4-24MCCH-FW | 115, 177 | Ceiling | White | None | ELMTSWC |
Siemens started rebranding the HS series around 2007, when the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit required the Siemens U series to be discontinued. The series was also sold under the Faraday brand using the same model names to replace the 2800 series, 6200 series, and 6300 series.[8]
| Siemens model | Wheelock model | Replaces | Replaced by |
| HS-R | HS-24-R | 6230B-0-14-24-DC 6250B-0-14-24-DC U-HN U-HNH |
SL2MTWR-F[9] |
| HS-W | HS-24-W | 6230B-0-21-24-DC 6250B-0-21-24-DC U-HN-W U-HNH-W |
SL2MTWW-F |
| HS-MC-R | HS4-24MCW-FR | 2834B-14-24 6234B-14-24 6254B-14-24 6304B-14-24 6314B-14-24 U-HN-MCS U-HNH-MCS U-MH-MCS U-MHT-MCS |
SL2MTSWR-F |
| HS-MC-W | HS4-24MCW-FW | 2834B-21-24 6234B-21-24 6254B-21-24 6304B-21-24 6314B-21-24 U-HN-MCS-W U-HNH-MCS-W U-MH-MCS-W U-MHT-MCS-W |
SL2MTSWW-F |
| HS-HMC-R | HS4-24MCWH-FR | None | SL2MTSWR-F |
| HS-HMC-W | HS4-24MCWH-FW | None | SL2MTSWR-F |
- ↑ 1.0 1.1 https://web.archive.org/web/20061108090040/http://www.cooperwheelock.com/literature/prod_repl_shed.pdf
- ↑ 2.0 2.1 https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/Xenon%20Tube%20Cessation.pdf
- ↑ https://web.archive.org/web/20061108085957/http://www.cooperwheelock.com/literature/sep03_prod_replace.pdf
- ↑ https://www.wheelock-products.com/media/brochures/FireandSecurity%20Catalog.pdf
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-ps-amt-ch-e-et-hs4-mt-rss-product-discontinuation-notice.pdf
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/hs/wheelock-hs-horn-strobe-install-sheets-P84391.pdf
- ↑ https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/hs/wheelock-hs4-horns-data-sheet-TD450154EN.pdf
- ↑ https://web.archive.org/web/20110716071442/http://www.us.sbt.siemens.com/faraday/notification.html
- ↑ https://cache.industry.siemens.com/dl/files/018/109823018/att_1149033/v2/A6V14140230.pdf
