Faraday 6100 series
6100 series
Gray
24VAC & 24VDC
Faraday 5500 series |
Faraday 6200 series |
"title": "6100 series",
The Faraday 6100 series is a series of electromechanical horns.
First generation
| Model | Voltage | Replaced | Replaced by |
| 6110B-0-0-120-60 | 24 VAC | ||
| 6114L-0-15-120-60[1] | 120 VAC | ||
| 6114B-0-15-240-60[2] | 240 VAC | ||
| 6120 | 21-30 VDC | 6020 | |
| 6140 |
Second generation
| Model | Voltage | Candela | Indoor/outdoor | Mounting | Color | Replaced | Replaced by |
| 6170B-0-14-120-60[3] | 120 VAC | N/A | Indoor/outdoor | Wall | Red | ||
| 6170B-0-21-120-60 | 120 VAC | N/A | Indoor/outdoor | Wall | White | ||
| 6170B-0-14-4-60 | 4 VAC | N/A | Indoor/outdoor | Wall | Red | ||
| 6170B-0-21-4-60 | 4 VAC | N/A | Indoor/outdoor | Wall | White | ||
| 6170B-0-14-7-60 | 7 VAC | N/A | Indoor/outdoor | Wall | Red | ||
| 6170B-0-21-7-60 | 7 VAC | N/A | Indoor/outdoor | Wall | White | ||
| 6180B-0-14-24-60[4] | 24 VAC | N/A | Indoor/outdoor | Wall | Red | ||
| 6180B-0-21-24-60 | 24 VAC | N/A | Indoor/outdoor | Wall | White | ||
| 6180B-0-14-120-60 | 120 VAC | N/A | Indoor/outdoor | Wall | Red | ||
| 6180B-0-21-120-60 | 120 VAC | N/A | Indoor/outdoor | Wall | White | ||
| 6184B-E-14-120-60 | 120 VAC | 15/75 | Indoor | Wall | Red | ||
| 6184B-E-21-120-60 | 120 VAC | 15/75 | Indoor | Wall | White | ||
| 6184B-G-14-120-60 | 120 VAC | 30/75 | Indoor | Wall | Red | ||
| 6184B-G-21-120-60 | 120 VAC | 30/75 | Indoor | Wall | White | ||
| 6184B-J-14-120-60 | 120 VAC | 60/75 | Indoor | Wall | Red | ||
| 6184B-J-21-120-60 | 120 VAC | 60/75 | Indoor | Wall | White | ||
| 6184B-K-14-120-60 | 120 VAC | 75 | Indoor | Wall | Red | ||
| 6184B-K-21-120-60 | 120 VAC | 75 | Indoor | Wall | White | ||
| 6184B-L-14-120-60 | 120 VAC | 110 | Indoor | Wall | Red | ||
| 6184B-L-21-120-60 | 120 VAC | 110 | Indoor | Wall | White | ||
| 6165B-0-4-24-60 | 24 VAC | N/A | Indoor | Ceiling | White | ||
| 6165B-0-4-120-60 | 120 VAC | N/A | Indoor | Ceiling | White | ||
| 6188B-E-4-120-60 | 120 VAC | 15/75 | Indoor | Ceiling | White | ||
| 6188B-G-4-120-60 | 120 VAC | 30/75 | Indoor | Ceiling | White | ||
| 6188B-J-4-120-60 | 120 VAC | 60/75 | Indoor | Ceiling | White | ||
| 6188B-K-4-120-60 | 120 VAC | 75 | Indoor | Ceiling | White | ||
| 6188B-L-4-120-60 | 120 VAC | 110 | Indoor | Ceiling | White | ||
| 6185B-E-14-120-60 | 120 VAC | 68 | Outdoor | Wall | Red | ||
| 6185B-E-21-120-60 | 120 VAC | 68 | Outdoor | Wall | White | ||
| 6185B-L-14-120-60 | 120 VAC | 100 | Outdoor | Wall | Red | ||
| 6185B-L-21-120-60 | 120 VAC | 100 | Outdoor | Wall | White |
Some models in the second generation of 6100 series horns were sold under the Siemens brand as part of the U series.
Simplex rebranded the first generation of 6100 series horns as part of the 2901 series. Simplex continued rebranding these devices for ULC applications through 2000 as part of the 12901 series.[5]
Tork Alert
| Tork model | Faraday model | Replaced | Replaced by |
| TA870-N5[6] | |||
| TA874-G5 | |||
| TA874-N5 | |||
| TA874-N5R | |||
| TA875-G1 | |||
| TA876-G5 | |||
| TA876-N5 | |||
| TA877-G1 | |||
| TA880-N5 | 6184B-E-21-120-60 |
- ↑ https://i.ebayimg.com/images/g/EeAAAOSwVeJbULuY/s-l1600.jpg
- ↑ https://i.ebayimg.com/images/g/C5gAAOSwnDZT1oJj/s-l1600.jpg
- ↑ https://web.archive.org/web/20061015204448/http://www.faradayfirealarms.com/pdf/Installation%20Instructions/archived%20fas/faraday%20archived%20fas%20numbers/FAS-60.pdf
- ↑ https://web.archive.org/web/20010706185831/http://www.faradayllc.com/pdf/FA_S-61.pdf
- ↑ https://docs.johnsoncontrols.com/simplex/api/khub/documents/12LudmKpuYDBk73qmAqCzA/content
- ↑ https://nsi-sales.com/pdf/eTORKAlertCatalog.pdf
