Wheelock 30 series
(Redirected from Faraday MH115 series)
Wheelock 30 series
whe_34-t12.jpg: Infobox image for Wheelock 30 series the infobox device.
Gray
Gray
Wheelock MT series {"label": "Succeeded by", "field": "Wheelock MT series"}
The Wheelock 30 series is a series of electromechanical horns.
The 30 series was released in the late 1960s / early 1970s. There were a lot of different versions of these horns, with regards to how much current they took, some AC powered and some DC powered, and non-polarized and polarized models. Additionally, Wheelock offered two options to how the horns were wired up. Many devices had pigtail connectors, but some signals had screw terminals. Models with terminal connections had "T" in their model numbers. The most common model series were the 31/31T AC powered and 34/34T DC powered horns. But there were also these less-common model series: 32/32P, 33, 35, and 37. Between 1977 and 1979, strobe models with WS strobes were released as a 4-wire version of the 7000 series.[1][2]
In 1984, the grille was redesigned to be vandal resistant. About a year later, the 32, 33, and 37 models, along with all models with pigtail wires (including the 31, 34, 35, and 36) were discontinued.
Most products in the 30 series were discontinued in 1994 to shift support to the MT series. The 31T-115 AC horn remains in production for general signaling purposes.[3]
Model Voltage Wiring type Mounting Replaces Replaced by
31-12 12 VAC Pigtail lead Surface 31T-12*
31T-12 12 VAC Screw terminal Surface
31-24 24 VAC Pigtail lead Surface 31T-24*
31T-24 24 VAC Screw terminal Surface
31-115 115 VAC Pigtail lead Surface 31T-115*
31T-115 115 VAC Screw terminal Surface Still in production
31T-115-WS 115 VAC Screw terminal Surface
31T-220 220 VAC Screw terminal Surface
32-24 24 VDC Pigtail lead Surface
32T-24 24 VDC Screw terminal Surface
32P-24 24 VDC polarized Pigtail lead Surface
32PT-24 24 VDC polarized Screw terminal
32PT-24-WS 24 VDC polarized Screw terminal Surface MT4-24-LS-VFR
MT-24-WH-VFR
33-24 24 VDC Pigtail lead Surface
33T-24 24 VDC Screw terminal
34-6 6 VDC polarized Pigtail lead Surface
34-12 12 VDC polarized Pigtail lead Surface 34T-12*
34T-12 12 VDC polarized Screw terminal Surface MT4-12/24
34-24 24 VDC polarized Pigtail lead Surface 34T-24*
34T-24 24 VDC polarized Screw terminal Surface MT4-12/24
34-24-WS-24F 24 VDC polarized Pigtail lead Flush F34T-24-WS*
F34T-24-WS 24 VDC polarized Screw terminal Flush MT-24-LS-VFR
MT-24-WH-VFR
34-24-WS-24 24 VDC polarized Pigtail lead Surface 34T-24-WS*
34T-24-WS 24 VDC polarized Screw terminal Surface MT-24-LS
35T-115 115 VAC polarized Screw terminal Surface
35T-115-WS 115 VAC polarized Screw terminal Surface
36-24 24 VDC polarized Pigtail lead Surface
36T-24 24 VDC polarized Screw terminal Surface MT4-12/24
37-24 24 VDC Pigtail lead Surface
37T-24 24 VDC Screw terminal Surface
*The 3_ and 3_T models came out at the same time. But prior to the grille redesign, pigtail connectors were more common than screw terminals.
Honeywell model Wheelock model Replaces Replaced by
SC806A1004[4] 34-24 SC806A1038
SC806A1038 34T-24 SC806A1004 SC716A-1003
Notifier model Wheelock model Replaces Replaced by
34-24 34-24[5]
34T-24[6]
Siemens started rebranding the 31T around 2007, when the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit required the Siemens U series to be discontinued. The series was also sold under the Faraday brand using the same model names.[7]
Siemens model Wheelock model Replaces
MH115-R[8] 31T-115-R U-HN-AC
