Wheelock 7000 series
Gray
Gray
1976[1] {"label": "Introduced", "field": "1976[1]"}
1994 {"label": "Discontinued", "field": "1994"}
Wheelock MT series {"label": "Succeeded by", "field": "Wheelock MT series"}
The Wheelock 7000 series was the first series of horn strobes.
The 7000 series was released in 1977 as a horn strobe version of the 30 series. These devices featured patented technology so that the 7000 series horn strobes would draw no additional current compared to the 30 series horns.[2]
Wheelock offered two options with regards to how these signals were wired up. Many devices had pigtail connectors, but some had screw terminals. Models with terminals had "T" in their model numbers.
In mid-1984, the paint used was switched from smooth to textured paint. Later, in late 1984, the grille was redesigned to be vandal resistant. A year later in late 1985, models with pigtail wires were discontinued.
The 7000 series was discontinued in 1994 due to the UL 1971 / ADA requirements preventing 7000 series strobes from being used as indoor public mode notification appliances because of their low-intensity.
Model Voltage Wiring type Mounting Strobe orientation Replaced Replaced by
7001-24[3] 24VDC Pigtail lead Flush Horizontal None 7001T-24*
V7001-24[4] 24VDC Pigtail lead Flush Vertical None V7001T-24*
7001T-24[5] 24VDC Screw terminal Flush Horizontal None MT-24-LS-VFR
MT-24-WH-VFR
V7001T-24[6] 24VDC Screw terminal Flush Vertical None MT-24-LS-VFR
MT-24-WH-VFR
7002-24[7] 24VDC Pigtail lead Surface Horizontal None 7002T-24*
7002T-24[8] 24VDC Screw terminal Surface Horizontal None MT4-24-LS-VFR
MT-24-WH-VFR
7003-115[citation needed] 115VAC Pigtail lead Flush Horizontal None None
7004-115[citation needed] 115VAC Pigtail lead Surface Horizontal None 7004T-115*
7004T-115[9] 115VAC Screw terminal Surface Horizontal None None
* The 700_ and 700_T models were introduced at the same time. It was also a common misconception that the non-T models were the predecessors to the T models; however, pigtail connectors were more popular than screw terminals prior to the grille redesign.
ADT
ADT Model Wheelock Model Replaced by
3408-024[10] 7002T-24 N/A
Fire-Lite
Fire-Lite Model Wheelock Model Replaced By
STH-71-24VDC 7001T24
Gamewell Model Wheelock Model Replaced by
70402 7001T-24
V7001T-24
Honeywell Model Wheelock Model Replaced Replaced by
SC807A1003 7002-24 SC807A1029
SC807A1011 7001T-24
SC807A1029[11] 7002T-24 SC807A1003
Pyrotronics Model Wheelock Model Replaced by
HSD-24[12] 7002T-24 MTS4-15
HSD-24F[13] 7001-24
7001T-24
MTS-15
