Wheelock A series
Manufacturer | |
Color(s) |
Rated Voltage |
10.5-15.6VDC & 20-31VDC
Introduced | |
Discontinued | |
Preceded by |
Wheelock MIZ series
Succeeded by |
Wheelock Exceder series
{ "rows": [], "title": "Wheelock A series", "images": [ "WheelockAS-MCWandWheelockAS-2430WandDMP904-81.png" ] }
The Wheelock A series is a series of synchronized horns and two-wire horn strobes and the first horn strobes to support audible silence over two wires, as well as Wheelock's first horn strobes to mount on a universal mounting plate. The A series was produced alongside several other series such as the N series before it was discontinued in March 2010 and replaced with the Exceder series.
The A series was released in 1995 with the same horn as the MT. The original 15, 15/75, 30, and 75 candela strobe models featured a vertical strobe to the right of the horn, resembling the Simplex 4903 series ADA horn strobes. The 110 candela models had a horizontal strobe above the horn. The original models only outputted a continuous tone when receiving a constant input voltage, but they switched to Code 3 when receiving the synchronization protocol.[3]
The AS was updated in 1997 along with the release of the NS to give all models a horizontal strobe above the horn.[4] The A series was updated again in 1998 to gain a free-run Code 3 option.[5]
A multi-candela version of the AS was released in 1999 as part of the SPEC1FIRE series. A ceiling-mount multi-candela model was released in 2003,[6] and high-intensity multi-candela models were released later in 2003.[7]
The A series was discontinued in 2010 and succeeded by the Exceder HS series.
The A series horns can be synchronized when connected to an SM or DSM. There are 3 volume settings, and the horns are capable of outputting either a continuous horn or a Code 3 horn.
Depending on the model of an AS horn strobe, the strobe could output 15, 15/75, 30, 75, 110, 115, 135, 177, or 185 candela.
AH series
Model Number | Nominal Voltage | Color | Replaced by |
AH-12-R | 12VDC | Red | HSR |
AH-12-W | 12VDC | White | HSW |
AH-24-R | 24VDC | Red | HSR |
AH-24-W | 24VDC | White | HSW |
AS series
Model Number | Nominal Voltage | Candela | Color | Strobe Orientation | Mounting | Replaced by |
AS-1215-VFR[8] | 12VDC | 15 | Red | Vertical | Wall | AS-1215W-FR |
AS-1215-VFW | 12VDC | 15 | White | Vertical | Wall | AS-1215W-FW |
AS-121575-VFR | 12VDC | 15/75 | Red | Vertical | Wall | AS-121575W-FR |
AS-121575-VFW | 12VDC | 15/75 | White | Vertical | Wall | AS-121575W-FW |
AS-1230-VFR | 12VDC | 30 | Red | Vertical | Wall | None |
AS-1230-VFW | 12VDC | 30 | White | Vertical | Wall | None |
AS-2415-VFR | 24VDC | 15 | Red | Vertical | Wall | AS-2415W-FR |
AS-2415-VFW | 24VDC | 15 | White | Vertical | Wall | AS-2415W-FW |
AS-241575-VFR | 24VDC | 15/75 | Red | Vertical | Wall | AS-241575W-FR |
AS-241575-VFW | 24VDC | 15/75 | White | Vertical | Wall | AS-241575W-FW |
AS-2430-VFR | 24VDC | 30 | Red | Vertical | Wall | AS-2430W-FR |
AS-2430-VFW | 24VDC | 30 | White | Vertical | Wall | AS-2430W-FW |
AS-2475-VFR | 24VDC | 75 | Red | Vertical | Wall | AS-2475W-FR |
AS-2475-VFW | 24VDC | 75 | White | Vertical | Wall | AS-2475W-FW |
AS-24110-HFR | 24VDC | 110 | Red | Horizontal | Wall | AS-24110W-FR |
AS-24110-HFW | 24VDC | 110 | White | Horizontal | Wall | AS-24110W-FW |
AS-1215W-FR | 12VDC | 15 | Red | Horizontal | Wall | AS-121575W-FR |
AS-1215W-FW | 12VDC | 15 | White | Horizontal | Wall | AS-121575W-FW |
AS-121575W-FR | 12VDC | 15/75 | Red | Horizontal | Wall | HSR |
AS-121575W-FW | 12VDC | 15/75 | White | Horizontal | Wall | HSW |
AS-2415W-FR | 24VDC | 15 | Red | Horizontal | Wall | AS-24MCW-FR |
AS-2415W-FW | 24VDC | 15 | White | Horizontal | Wall | AS-24MCW-FW |
AS-241575W-FR | 24VDC | 15/75 | Red | Horizontal | Wall | HSR |
AS-241575W-FW | 24VDC | 15/75 | White | Horizontal | Wall | HSW |
AS-2430W-FR | 24VDC | 30 | Red | Horizontal | Wall | AS-24MCW-FR |
AS-2430W-FW | 24VDC | 30 | White | Horizontal | Wall | AS-24MCW-FW |
AS-2475W-FR | 24VDC | 75 | Red | Horizontal | Wall | AS-24MCW-FR |
AS-2475W-FW | 24VDC | 75 | White | Horizontal | Wall | AS-24MCW-FW |
AS-24110W-FR | 24VDC | 110 | Red | Horizontal | Wall | AS-24MCW-FR |
AS-24110W-FW | 24VDC | 110 | White | Horizontal | Wall | AS-24MCW-FW |
AS-2415C-FR | 24VDC | 15 | Red | N/A | Ceiling | AS-24MCC-FR |
AS-2415C-FW | 24VDC | 15 | White | N/A | Ceiling | AS-24MCC-FW |
AS-2430C-FR | 24VDC | 30 | Red | N/A | Ceiling | AS-24MCC-FR |
AS-2430C-FW | 24VDC | 30 | White | N/A | Ceiling | AS-24MCC-FW |
AS-2475C-FR | 24VDC | 75 | Red | N/A | Ceiling | AS-24MCC-FR |
AS-2475C-FW | 24VDC | 75 | White | N/A | Ceiling | AS-24MCC-FW |
AS-24100C-FR | 24VDC | 100 | Red | N/A | Ceiling | AS-24MCC-FR |
AS-24100C-FW | 24VDC | 100 | White | N/A | Ceiling | AS-24MCC-FW |
AS-24MCW-FR | 24VDC | 15, 30, 75, 110 | Red | Horizontal | Wall | HSR |
AS-24MCW-FW | 24VDC | 15, 30, 75, 110 | White | Horizontal | Wall | HSW |
AS-24MCWH-FR | 24VDC | 135, 185 | Red | Horizontal | Wall | HSR |
AS-24MCWH-FW | 24VDC | 135, 185 | Red | Horizontal | Wall | HSW |
AS-24MCC-FR | 24VDC | 15, 30, 75, 95 | Red | N/A | Ceiling | HSRC |
AS-24MCC-FW | 24VDC | 15, 30, 75, 95 | White | N/A | Ceiling | HSWC |
AS-24MCCH-FR | 24VDC | 115, 177 | Red | N/A | Ceiling | HSRC |
AS-24MCCH-FW | 24VDC | 115, 177 | White | N/A | Ceiling | HSWC |
There are a few companies that have made rebrands of the Wheelock AS, this includes (but not limited to):
- Bosch/Radionics
- DMP
- Siemens
Gamewell model | Wheelock model | Replaces | Replaced by |
71613[9] | AH-24-R | AH-24-R | |
72032[10] | AS-24MCW-FR | AS-24MCW-FR | |
72033 | AS-24MCW-FW | AS-24MCW-FW | |
71680 | AS-241575W-FR | AS-241575W-FR | |
71727 | AS-2415C-FW | ||
71728 | AS-2430C-FW | ||
71729 | AS-2475C-FW | ||
71684 | AS-24100C-FW |
Siemens started rebranding the A series around 2007, when the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit required the Siemens U series to be discontinued. The series was also sold under the Faraday brand to replace the 6300 series and 2800 series.
Siemens model | Wheelock model | Replaces | Replaced by |
AH-R | AH-24-R | 2831B-14-24 6301B-0-14-24-DC 6311B-0-14-24-DC G1R-P-LG + G1RT(-FIRE)-LG G1RF-P-LG + G1RT(-FIRE)-LG G1R-HD-LG + G1RT(-FIRE)-LG G1RF-HD-LG + G1RT(-FIRE)-LG U-MH U-MHT U-MHU |
SL2HWR-N[11] SL2HCR-N[12] |
AH-W | AH-24-W | 2831B-21-24 6301B-0-21-24-DC 6311B-0-21-24-DC G1-P-LG + G1T(-FIRE)-LG G1F-P-LG + G1T(-FIRE)-LG G1-HD-LG + G1T(-FIRE)-LG G1F-HD-LG + G1T(-FIRE)-LG U-MH-W U-MHT-W U-MHU-W |
SL2HWW-N SL2HCW-N |
AH-R-WP | AH-24WP-R | 2836B-14-24 U-MHU-WP |
Still in production |
AS-MC-R | AS-24MCW-FR | G1R-HDVM-LG G1RF-HDVM-LG |
SL2HSWR-F |
AS-MC-W | AS-24MCW-FW | G1-HDVM-LG G1F-HDVM-LG |
SL2HSWW-F |
AS-HMC-R | AS-24MCWH-FR | None | SL2HSWR-F |
AS-HMC-W | AS-24MCWH-FW | None | SL2HSWW-F |
AS-MC-CR | AS-24MCC-FR | 2834B-14-24 U-MHU-MCS |
SL2HSCR-F |
AS-MC-CW | AS-24MCC-FW | 2834B-21-24 U-MHU-MCS-W |
SL2HSCW-F |
AS-HMC-CR | AS-24MCCH-FR | None | SL2HSCR-F |
AS-HMC-CW | AS-24MCCH-FW | None | SL2HSCW-F |
AS-75-R-WP | ASWP-2475W-FR | 2837B-14-24 U-MHU-MCS-WP |
AS-75-CR-WP | ASWP-2475C-FR | 2837B-14-24 U-MHU-MCS-WP |
Simplex model | Wheelock model | Replaced by |
4903-9246 [13][14][15] | AS-2430W-FR | |
4903-9247[16] | AS-2475W-FR | 4903-9418 |
- ↑ https://www.freepatentsonline.com/5608375.html
- ↑ https://www.wheelock-products.com/media/brochures/FireandSecurity%20Catalog.pdf
- ↑ https://web.archive.org/web/19970214011825fw_/http://www.wheelockinc.com/AS/index.html
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_6caebbed-7fbf-4147-a65b-d9b6fda152c5/
- ↑ https://www.freepatentsonline.com/6194994.html
- ↑ https://web.archive.org/web/20061108090040/http://www.cooperwheelock.com/literature/prod_repl_shed.pdf
- ↑ https://web.archive.org/web/20061108085957/http://www.cooperwheelock.com/literature/sep03_prod_replace.pdf
- ↑ https://web.archive.org/web/19970214013115fw_/http://www.wheelockinc.com/AS/as2.html
- ↑ https://web.archive.org/web/20030405120343/http://gamewell.com/pdf/datasheets/CS-2232.pdf
- ↑ https://web.archive.org/web/20030405024240/http://gamewell.com/pdf/datasheets/CS-2231.pdf
- ↑ https://cache.industry.siemens.com/dl/files/011/109823011/att_1149026/v3/A6V14140218.pdf
- ↑ https://cache.industry.siemens.com/dl/files/010/109823010/att_1149025/v2/A6V14140217.pdf
- ↑ https://i.ebayimg.com/images/g/I0sAAOSwES1n6wvC/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/zs8AAOSw6UBn6wvF/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/RY8AAOSwKPxn6wvI/s-l1200.jpg
- ↑ https://i.ebayimg.com/images/g/vCYAAOSwiYleVsEz/s-l640.jpg
