Wheelock RS series
(Redirected from Wheelock RS)
Wheelock RS
10-15.6VDC & 20-31VDC {"label": "Rated Voltage", "field": "10-15.6VDC & 20-31VDC"}
1995[1] {"label": "Introduced", "field": "1995[1]"}
2001 {"label": "Discontinued", "field": "2001"}
Wheelock LS series
Wheelock LSM series
Wheelock MS series
Wheelock IS series
Wheelock HSW series {"label": "Preceded by", "field": "Wheelock LS series
Wheelock LSM series
Wheelock MS series
Wheelock IS series
Wheelock HSW series"}
Wheelock RSS {"label": "Succeeded by", "field": "Wheelock RSS"}
The Wheelock RS series is a series of non-synchronizable remote strobes with universal mounting plates.
The RS series was released in 1995 together with the RSP series as updated versions of Wheelock's ADA strobes. Like the ADA strobes, the original RS strobes were mostly vertically oriented with a horizontal 110 cd strobe. Unlike the HSW, the RS-24110-HFR had the same thickness as the other models, so the FIRE lettering was printed above and below the lens instead of on the sides.
The RS-2415 and RS-241575 were updated in 1997 to have a horizontal strobe with a similar design to the RS-24110-HFR.[2] The other models were discontinued at this time due to the RSS having the same functionality, and these two models were discontinued in the U.S. between 1999 and 2000.[3][4][5] The devices remained in production for ULC applications until the end of 2001.[6]
The original RS was a typical strobe that flashed once per second when given a continuous voltage. Depending on the model, the candela could be 15, 15/75, 30, 75, or 110, and all models except the 15/75 models could be ceiling mounted.
The second version of the RS was designed to be used as a wall-mount horizontal strobe, and it was only produced in 15 and 15/75 candela models for 24 volts.
Version 1
Model Number Nominal Voltage Candela Color Strobe Orientation Replaces Replaced By
RS-1215-VFR 12VDC 15 Red Vertical LS1-12-VFR RS-1215W-FR
RS-1215-VFW 12VDC 15 White Vertical LS1-12-VFR RS-1215W-FW
RS-121575-VFR 12VDC 15 Red Vertical LS1M-12-VFR RS-121575W-FR
RS-1215-VFW 12VDC 15 White Vertical LS1M-12-VFR RS-121575W-FW
RS-1230-VFR 12VDC 30 Red Vertical MS1-12-VFR RSS-1230W-FR
RS-1230-VFW 12VDC 30 White Vertical MS1-12-VFW RSS-1230W-FW
RS-2415-VFR 24VDC 15 Red Vertical LS-24-VFR
LS1-24-VFR
LS3-24-VFR
RS-2415W-FR
RSS-2415C-FR
RS-2415-VFW 24VDC 15 White Vertical LS-24-VFW
LS1-24-VFW
LS3-24-VFW
RS-2415W-FW
RSS-2415C-FW
RS-241575-VFR 24VDC 15/75 Red Vertical LSM-24-VFR
LS1M-24-VFR
LS3M-24-VFR
RS-241575W-FR
RS-241575-VFW 24VDC 15/75 White Vertical LSM-24-VFW
LS1M-24-VFW
LS3M-24-VFW
RS-241575W-FW
RS-2430-VFR 24VDC 30 Red Vertical MS-24-VFR
MS1-24-VFR
MS3-24-VFR
RSS-2430W-FR
RSS-2430C-FR
RS-2430-VFW 24VDC 30 White Vertical MS-24-VFW
MS1-24-VFW
MS3-24-VFW
RSS-2430W-FW
RSS-2430C-FW
RS-2475-VFR 24VDC 75 Red Vertical IS-24-VFR
IS1-24-VFR
IS3-24-VFR
RSS-2475W-FR
RSS-2475C-FR
RS-2475-VFW 24VDC 75 White Vertical IS-24-VFW
IS1-24-VFW
IS3-24-VFW
RSS-2475W-FW
RSS-2475C-FW
RS-24110-HFR 24VDC 110 Red Horizontal HSW-24-HFR
HS2W-24-HFR
RSS-24110W-FR
RS-24110-HFW 24VDC 110 White Horizontal HSW-24-HFW
HS2W-24-HFW
RSS-24110W-FW
RS-24110-CFR 24VDC 110 Red Ceiling HSW-24-HFR
HS2W-24-HFR
RSS-24100C-FR
RS-24110-CFW 24VDC 110 White Ceiling HSW-24-HFW
HS2W-24-HFW
RSS-24100C-FW
Version 2
Model Number Nominal Voltage Color Candela Replaces Replaced By
RS-1215W-FR 12VDC Red 15 RS-1215-VFR RSS-1215W-FR
RS-1215W-FW 12VDC White 15 RS-1215-VFW RSS-1215W-FW
RS-121575W-FR 12VDC Red 15/75 RS-121575-VFR RSS-121575W-FR
RS-121575W-FW 12VDC White 15/75 RS-121575-VFW RSS-121575W-FW
RS-2415W-FR 24VDC Red 15 RS-2415-VFR RSS-2415W-FR
RS-2415W-FW 24VDC White 15 RS-2415-VFW RSS-2415W-FW
RS-241575W-FR 24VDC Red 15/75 RS-241575-VFR RSS-241575W-FR
RS-241575W-FW 24VDC White 15/75 RS-241575-VFW RSS-241575W-FW
