Fire-Lite MS series panels
Communication protocol |
CLIP |
Preceded by |
Fire-Lite Miniscan series panels |
Succeeded by |
Fire-Lite ES series panels
{ "rows": [], "title": "Fire-Lite MS series panels", "images": [ "MS-series.webp" ] }
The Fire-Lite MS series is a series of fire alarm control panels manufactured and produced by Fire-Lite Alarms, a subsidiary of Honeywell. The Fire-Lite MS series comes in conventional and addressable models. "MS" stands for "Micro-Scan", implying the MS series panels are based on micro processors. The MS series panels were some of the first readily available micro processor based panels, as well the MS-9200 was one of the first cost effective and affordable micro processor based addressable fire alarm control panels on the market.
All panels except MS-2/4 and MS-5/10UD have been replaced by the ES series of panels.
The MS-9200 was introduced in 1994 to replace the MS4812 and MS4824, which used the Ademco SLC protocol. The 300 series addressable devices were also introduced at this time.
In 2001, Fire-Lite introduced the MS-9600 together with the 350 series.[1] Although the MS-9600 did not support LiteSpeed, it was capable of polling 318 devices on each SLC.
Later in 2001, the MS-2 and MS-4 were introduced together with the System Sensor i3 series.[2] The MS-2 and MS-4 had integrated i3 protocol support on their 2-wire IDCs, eliminating the need for a separate 2W-MOD.
Between March and April 2010, Fire-Lite introduced the MS-25, which was Fire-Lite's version of the Honeywell HFS panel.[3]
Model suffix "UD" indicates Upload/Download support (For programming via PS-Tools on a Windows™ computer)
Model suffix "LS" indicates LiteSpeed Protocol support
Addressable models with suffix "UD" and/or "LS" came out later after the initial release of the MS series and have different door designs, firmware, and PCBs.
The MS-5/10/9050UD models all came out later after the initial release of the Fire-Lite MS series.
Model Number | Zones | NAC(s) | Usable current | Output Current Type | Released | Replaced |
MS-2 | 2 Zones | 1 | 3.0A | FWR | 2001 | MP-12/24 |
MS-4 | 4 Zones | 2 | 3.0A or 6.0A | FWR | 2001 | MP-12/24 |
MS-5012 | 5 Zones | 1 | 1.0A | FWR | 1993 | |
MS-5024 | 5 Zones | 2 | 3.0A | FWR | 1994 | |
MS-5024UD | 5 Zones | 2 | 3.0A or 5.0A | FWR | 1994 | |
MS-5210UD | 10 Zones | 2 (up to 4) | 3.0A or 6.0A | FWR | 1996 | |
MS-5UD | 5 Zones | 4 | 3.0A or 7.0A | FWR (3A) / DC (7A)[4] | 2007 | MS-5012/24 |
MS-10UD | 10 Zones | 4 | 3.0A or 7.0A | FWR (3A) / DC (7A) | 2007 | MS-5210UD/2410B |
Model Number | Points | NAC(s) | Usable current | Output Current Type | Released | Replaced | Replaced by |
MS-25 | 25 Points | 2 | 2.0A | Filtered DC | 2010 | None | MS-9050UD |
MS-9050UD | 50 Points | 2 | 3.0A | Filtered DC | 2006 | MS-25 | ES-50X |
MS-9200 | 198 Points | 4 | 3.0A or 6.0A | FWR | 1994 | MS4812 MS4824 |
MS-9200UDLS |
MS-9200UD | 198 Points | 4 | 3.0A or 6.0A | FWR | 2003 | Sensiscan 2000 | MS-9200UDLS |
MS-9200UDLS | 198 Points | 4 | 3.0A or 6.0A | FWR | 2006 | MS-9200 MS-9200UD |
ES-200X |
MS-9600 | 318 Points (636 with SLC-2LS) | 4 | 7.0A | Filtered DC | 2001 | MS-9600LS | |
MS-9600LS | 318 Points (636 with SLC-2LS) | 4 | 7.0A | Filtered DC | 2007 | MS-9600 | ES-1000XI |
MS-9600UDLS | 318 Points (636 with SLC-2LS) | 4 | 7.0A | Filtered DC | 2008 | ES-1000X |
- i³™ Technology (Drift Compensation, Maintenance Alerts, Freezing Temperature Supervisory Warning) [Conventional panels only]
- NAC synchronization (System Sensor, Wheelock, and Gentex Sync) [Amseco and Faraday on the MS-5/10UD]
- Front Panel Programming
- Walk Test
- Form C contact relays (Fully programmable on the MS-5UD and greater)
- Addressable panels support CLIP and LS models support LiteSpeed protocol for detector and module communication
Peripherals
X | RZA-4XF | RZA-5F | LED-10 | LCD-40 | LCD-80F | ANN-80 | ANN-LED |
MS-2 | |||||||
MS-4 | X | ||||||
MS-5012/24/24UD | X | ||||||
MS-5UD | X | X | |||||
MS-5210UD | X | ||||||
MS-10UD | X | X | |||||
MS-25 | X | ||||||
MS-9050UD | X | X | |||||
MS-9200 | X | ||||||
MS-9200UD | X | ||||||
MS-9200UDLS | X | Rev B+ | Rev B+ | ||||
MS-9600 | X | ||||||
MS-9600LS | X | X | X | ||||
MS-9600UDLS | X | X | X |
ADT & Tyco
ADT model | Fire-Lite model | Replaced | Replaced by |
Unimode 5 | MS-5024UD | ||
Unimode 10 | MS-5210UD | ||
Unimode 5UD | MS-5UD | ||
Unimode 10UD | MS-10UD | ||
Unimode 9050UD | MS-9050UD | ||
Unimode 200 | MS-9200 | ||
Unimode 200UD | MS-9200UD | ||
Unimode 200UDLS | MS-9200UDLS |
Gamewell-FCI rebranded the conventional panels until 2022, when consumers were instructed to switch to the original Fire-Lite models.[5]
Gamewell-FCI model | Fire-Lite model | Replaced | Replaced by |
Flex 402 | MS-2 | FC-2224 | MS-2-L8 |
Flex 404 | MS-4 | Flex 4 FC-4224 |
MS-4 |
Flex 405 | MS-5024UD | GF-505 | |
FC-5C | MS-5024UD | FC-6324 | GF-505 |
FC-10C | MS-5210UD | FC-6324 | GF-510 |
GF-505 | MS-5UD | Flex 405 FC-5C |
MS-5UD-3 |
GF-510 | MS-10UD | FC-10C | MS-10UD-7 |
Notifier model | Fire-Lite model | Replaced | Replaced by |
SFP-2402 | MS-2 | MS-2-L8[6] | |
SFP-2404 | MS-4 | MS-4 | |
SFP-1024 | MS-5210UD | ||
SFP-5UD | MS-5UD | MS-5UD-3 | |
SFP-10UD | MS-10UD | MS-10UD-7 | |
NFW-50 | MS-9050UD | NSP-25 | NFW-50X |
AFP-100 | MS-9200 | NFW2-100 | |
NFW-100 | MS-9200UD | None | NFW2-100 |
NFW2-100 | MS-9200UDLS | AFP-100 NFW-100 |
NFW-100X |
Silent Knight rebranded the conventional Micro-scan panels until 2022, when consumers were instructed to switch to the original Fire-Lite versions.[7]
Silent Knight model | Fire-Lite model | Replaced | Replaced by |
SK-2 | MS-2 | SK2224 | MS-2-L8 |
SK-4 | MS-4 | SK4224 | MS-4 |
Fire-Lite MS-4
Silent Knight SK-4
Sources
- Fire-Lite MS-2 Datasheet https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/literature-and-specs/datasheets/df-52211.pdf
- Fire-Lite MS-4 Datasheet https://usalarmdetection.com/products/firelite/MS-4.pdf
- Fire-Lite Website (December 2001)https://web.archive.org/web/20011213235633/http://www.firelite.com/ourProducts.htm
- Silent Knight Website (September 2006) https://web.archive.org/web/20060924033601/http://silentknight.com/htmfiles/fire/conventionalfacp.htm
- ↑ "Control Panels Page 1" Fire-Lite Alarms. Archive 2001-03-05 vs. 2001-04-12
- ↑ "Control Panels Page 1" Fire-Lite Alarms. Archive 2001-08-15 vs. 2001-12-13
- ↑ "Fire-Lite Alarms - Addressable Fire Alarm Control Panels" Fire-Lite Alarms. Archive 2010-03-09 vs. 2010-04-11
- ↑ UL 464 Directional Sounder, supplemental notification appliance. The directional sounder can be installed in systems using 24 Volt DC regulated power supplies only. It is not approved for use with FWR unregulated power supplies. Therefore, the following panels/power supplies are compatible: • MS-5UD-7(C)(E), MS-10UD-7(C(E)) https://buildings.honeywell.com/content/dam/hbtbt/en/documents/document-lists/firelite/discontinued-products/MS-9600%20-%20Fire-Lite%20Device%20Compatibility%20Document.pdf
- ↑ https://hbtmkto.honeywell.com/rs/127-UCB-316/images/GWFCI%20-%20M22.22%20-%20Discontinuation%20of%20Limited%20Models%20of%20Conventional%20FACPs.pdf
- ↑ https://hbtmkto.honeywell.com/rs/127-UCB-316/images/NOT%20-%20M22.26%20-%20Discontinuation%20of%20Limited%20Models%20of%20Conventional%20FACPs.pdf
- ↑ https://buildings.honeywell.com/content/dam/hbtbt/en/documents/document-lists/silent-knight/announcements/Silent%20Knight%20Conventional%20FACP%20Announcement.pdf
