Wheelock Exceder LED series
(Redirected from Edwards Genesis GL series)
Exceder LED series
Wheelock_Exceder_LED_series.png: Infobox image for Exceder LED series the infobox device.
8-17.5VDC & 16-33VDC (NAC)[1][2]
25VRMS & 70VRMS (speaker)[3] {"label": "Rated Voltage", "field": "8-17.5VDC & 16-33VDC (NAC)[1][2]
25VRMS & 70VRMS (speaker)[3]"}
2012[4] {"label": "Introduced", "field": "2012[4]"}
2018[5] {"label": "Discontinued", "field": "2018[5]"}
Exceder LED3 series {"label": "Succeeded by", "field": "Exceder LED3 series"}
The Wheelock Exceder LED series is a series of notification appliances. The strobes in this series use LED2 bulbs.
The Exceder LED series was released in 2012 with wall-mount horns, strobes, and horn strobes to complement the xenon devices in the Exceder series. These devices resembled the Edwards Genesis G1 devices.[4][6] By 2014, Edwards was rebranding these devices with their own housing as the Edwards GL1 series.[7][8]
In 2013, the Exceder LED wall-mount speakers and speaker strobes were released. These were redesigned E50H speakers in housing that resembled the Edwards Genesis G4 devices.
In 2014, ceiling-mount notification appliances were released. The horns and strobes were redesigned from the xenon Exceder devices, with smaller strobe lenses and larger grilles. The ceiling speakers had a new design with the speaker fully surrounding the central strobe.
The LLFHN and LLFHS low frequency sounders and sounder strobes were also released in 2014, with similar housing to the wall speakers, to meet the NFPA 72 low frequency requirements that took effect in 2014. These introduced a new Code 4 signal to prepare for the NFPA 720 requirements in 2015, and they had a new mode that allowed Code 3 and Code 4 to be provided on the same NAC.
In 2016, the LLFHN and LLFHS were replaced with the LFHNK and LFHSK respectively.[9] The new devices were functionally similar to the old devices, but they were more compact than the original devices, allowing them to fit in a single-gang backbox.
In 2018, the Exceder LED series was discontinued due to the release of the Exceder LED3 series.[5]
The horns in the Exceder LED series can output 95 or 90 anechoic dBA, the speakers output 300-8000 Hz at 1/8, 1/4, 1/2, 1, or 2 watts, and the low frequency sounders output 80 anechoic dBA. The strobes on the low frequency sounders only output 110 candela, while all other strobes can be set to 15, 30, 75, 95 (ceiling models), or 110 candela (wall models).
Compared to low frequency sounders from other companies, the Exceder 520 Hz tone less closely resembles a pure square wave, instead producing a tone with ample static noise.[10]
The low frequency sounders include a Code 3/Code 4 tone that causes the device to output a Code 3 tone when the synchronization module places the horn in audible silence mode and Code 4 at other times. Audible silence is not supported in this mode.[11]
The horns and strobes are designed to mount on a single-gang box, but they can also mount on 4-inch square boxes using an ESB-KIT. The speakers and low frequency sounders are designed to mount on 4-inch square boxes, but the LFHNK and LFHSK can be mounted on single-gang boxes using an LFTP.
Model Number Mounting Color Xenon Alternative Replaced By
LSTR Wall Red STR LSTR3
LSTW Wall White STW LSTW3
LSTRC Ceiling Red STRC LSTRC3
LSTWC Ceiling White STWC LSTWC3
Model Number Type Mounting Color Xenon Alternative Replaced By
LHNR Horn Wall Red HNR LHNR3
LHNW Horn Wall White HNW LHNW3
LHNRC Horn Ceiling Red HNRC LHNRC3
LHNWC Horn Ceiling White HNWC LHNWC3
LHSR Horn strobe Wall Red HSR LHSR3
LHSW Horn strobe Wall White HSW LHSW3
LHSRC Horn strobe Ceiling Red HSRC LHSRC3
LHSWC Horn strobe Ceiling White HSWC LHSWC3
LSPKR Speaker Wall Red E50H-R
E70H-R
ELSPKR
LSPKW Speaker Wall White E50H-W
E70H-W
ELSPKW
LSPKRC Speaker Ceiling Red E60H-R
E90H-R
ELSPKRC
LSPKWC Speaker Ceiling White E60H-W
E90H-W
ELSPKWC
LSPSTR Speaker strobe Wall Red E50H-24MCW-FR
E70H-24MCW-FR
LSPSTR3
LSPSTW Speaker strobe Wall White E50H-24MCW-FW
E70H-24MCW-FW
LSPSTW3
LSPSTRC Speaker strobe Ceiling Red E60H-24MCC-FR
E90H-24MCC-FR
LSPSTRC3
LSPSTWC Speaker strobe Ceiling White E60H-24MCC-FW
E90H-24MCC-FW
LSPSTWC3
Low frequency sounders
Model Number Type Mounting Color Replaced By
LLFHNR Sounder Wall Red LFHNKR
LLFHNW Sounder Wall White LFHNKW
LLFHSR Sounder strobe Wall Red LFHSKR
LLFHSW Sounder strobe Wall White LFHSKW
LFHNKR Compact sounder Wall Red LFHNKR3
LFHNKW Compact sounder Wall White LFHNKW3
LFHSKR Compact sounder strobe Wall Red LFHSKR3
LFHSKW Compact sounder strobe Wall Red LFHSKW3
Mounting accessories
LSBB-R Backbox Wall Red
LSBB-W Backbox Wall White
ESB-KIT-R Trimplate Wall Red
ESB-KIT-W Trimplate Wall White
LSPKBB-R Backbox Wall Red
LSPKBB-W Backbox Wall White
LSPKBB-CR Backbox Ceiling Red
LSPKBB-CW Backbox Ceiling White
LFTP-R Trimplate Wall Red
LFTP-W Trimplate Wall White
Edwards
Edwards rebranded the Exceder LED horns and strobes with their own covers as the Genesis GL series. Shortly after the Exceder LED series was discounted, Edwards released their own lineup of LED devices in the Genesis series (Genesis LED G4S series) to replace the GL1 series.
Model Color Lettering Replaced by[12]
GL1RF-VMC Red FIRE G1VRF
G4VRF
GL1RN-VMC Red None G1VRN
G4VRN
GL1WF-VMC White FIRE G1VWF
G4VWF
GL1WN-VMC White None G1VWN
G4VWN
Model Type Color Lettering Replaced by
GL1RF-HD Horn Red FIRE G1ARF
GL1RN-HD Horn Red None G1ARN
GL1WF-HD Horn White FIRE G1AWF
GL1WN-HD Horn White None G1AWN
GL1RF-HDVMC Horn strobe Red FIRE G1AVRF
G4AVRF
GL1RN-HDVMC Horn strobe Red None G1AVRN
G4AVRN
GL1WF-HDVMC Horn strobe White FIRE G1AVWF
G4AVWF
GL1WN-HDVMC Horn strobe White None G1AVWN
G4AVWN
