Wheelock SR series
24VDC
| Discontinued | |
Wheelock SL series |
Wheelock RSS
"title": "Wheelock SR",
The Wheelock SR is a series of synchronizable remote strobes with universal mounting plates.
The SR series was released in 1995 together with the SRP series as updated versions of Wheelock's synchronizable strobes. Like the old strobes, the 15 and 15/75 candela SR strobes are vertically oriented, while the 110 candela SR strobes are horizontally oriented, following the same design as the RS.
The SR was discontinued in 1997 and replaced with the RSS.
Like the RS, the SR has a universal mounting plate. The SR can also be synchronized using an SM or DSM. However, models only existed for 15, 15/75, and 110 candela.[3][4]
| Model Number | Nominal Voltage | Candela | Strobe Orientation | Replaces |
| SR-2415 | 24VDC | 15 | Vertical | SL-24-VFR SL1-24-VFR SL3-24-VFR |
| SR-241575 | 24VDC | 15/75 | Vertical | SLM-24-VFR SL1M-24-VFR SL3M-24-VFR |
| SR-2475 | 24VDC | 75 | Vertical | None |
| SR-24110 | 24VDC | 110 | Horizontal | SHW-24-HFR SH2W-24-HFR |
- ↑ https://www.freepatentsonline.com/5684467.html
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_6caebbed-7fbf-4147-a65b-d9b6fda152c5/
- ↑ https://prod-edam.honeywell.com/content/dam/honeywell-edam/hbt/en-us/documents/manuals-and-guides/device-compatibility-manuals/hbt-fire-15378-CB.pdf
- ↑ https://firealarms.tv/collection/wheelock-sr-24110/
