Wheelock SR series
(Redirected from Wheelock SR)
Wheelock SR
24VDC {"label": "Rated Voltage", "field": "24VDC"}
1995[1] {"label": "Introduced", "field": "1995[1]"}
1997[2] {"label": "Discontinued", "field": "1997[2]"}
Wheelock SL series
Wheelock SLM series
Wheelock SHW series {"label": "Preceded by", "field": "Wheelock SL series
Wheelock SLM series
Wheelock SHW series"}
Wheelock RSS {"label": "Succeeded by", "field": "Wheelock RSS"}
The Wheelock SR is a series of synchronizable remote strobes with universal mounting plates.
The SR series was released in 1995 together with the SRP series as updated versions of Wheelock's synchronizable strobes. Like the old strobes, the 15 and 15/75 candela SR strobes are vertically oriented, while the 110 candela SR strobes are horizontally oriented, following the same design as the RS.
The SR was discontinued in 1997 and replaced with the RSS.
Like the RS, the SR has a universal mounting plate. The SR can also be synchronized using an SM or DSM. However, models only existed for 15, 15/75, and 110 candela.[3][4]
Model Number Nominal Voltage Candela Strobe Orientation Replaces
SR-2415 24VDC 15 Vertical SL-24-VFR
SL1-24-VFR
SL3-24-VFR
SR-241575 24VDC 15/75 Vertical SLM-24-VFR
SL1M-24-VFR
SL3M-24-VFR
SR-2475 24VDC 75 Vertical None
SR-24110 24VDC 110 Horizontal SHW-24-HFR
SH2W-24-HFR
