Wheelock RSS series
(Redirected from Siemens ST series)
Wheelock RSS
Wheelock_RSS_series_lineup.png: Infobox image for Wheelock RSS the infobox device.
1997[1] {"label": "Introduced", "field": "1997[1]"}
2021[2] {"label": "Discontinued", "field": "2021[2]"}
Wheelock RS
Wheelock SR {"label": "Preceded by", "field": "Wheelock RS
Wheelock SR"}
Exceder ST
Eluxa ELST {"label": "Succeeded by", "field": "Exceder ST
Eluxa ELST"}
The Wheelock RSS is a series of horizontal remote strobes capable of synchronization.
The RSS was released in 1997 together with the NS and horizontal RS.[3] Initially, models were produced with the same voltage/candela options as the RS.[4]
In 1999, the multi-candela RSS-24MCW was released as part of the SPEC1FIRE series. This model replaced the wall-mount single-candela strobes, except the 15/75 models.
In March 2002, high-candela models were released.[5] These included a 185 candela strobe for wall mounting and 150 and 177 candela strobes for ceiling mounting.
In November 2002, Wheelock introduced round RSS models as an alternative to the square ceiling-mount strobes.[6]
In June 2003, the RSS-24MCC and RSS-24MCCR were released to replace the standard-intensity single-candela ceiling-mount models, which were discontinued in September 2003.[7] The RSS-24MCWH, RSS-24MCCH, and RSS-24MCCHR were also released in September 2003 to replace the high-intensity single-candela models, which were discontinued in December 2003.[8]
In December 2005, the RSS-24MCCR and RSS-24MCCHR were redesigned to resemble the E60, which was released simultaneously.[9] The RSS-24MCCHR was discontinued in March 2010 and replaced with the ceiling-mount Exceder ST.[10]
At the end of 2015, the 15/75 models of the RSS were discontinued.[11] Consumers were instructed to switch to the RSS-24MCW.
In 2021, the RSS series was discontinued, and consumers were instructed to switch to the Eluxa ELST strobes.
RSS strobes support universal mounting, and they can either free-run or run synchronously. Depending on the model, the candela may be 15, 15/75, 30, 75, 95, 100, 110, 115, 135, 150, 177, or 185.
Single-candela wall
Model Number Voltage Color Candela Replaces
RSS-1215W-FR 12VDC Red 15 RS-1215-VFR
RSS-1215W-FW 12VDC White 15 RS-1215-VFW
RSS-121575W-FR 12VDC Red 15/75 RS-121575-VFR
RSS-121575W-FW 12VDC White 15/75 RS-121575-VFW
RSS-2415W-FR 24VDC Red 15 RS-2415W-FR
SR-2415-VFR
RSS-2415W-FW 24VDC White 15 RS-2415W-FW
SR-2415-VFW
RSS-241575W-FR 24VDC Red 15/75 RS-241575W-FR
SR-241575-VFR
RSS-241575W-FW 24VDC White 15/75 RS-241575W-FW
SR-241575-VFW
RSS-2430W-FR 24VDC Red 30 RS-2430-VFR
RSS-2430W-FW 24VDC White 30 RS-2430-VFW
RSS-2475W-FR 24VDC Red 75 RS-2475-VFR
SR-2475-VFR
RSS-2475W-FW 24VDC White 75 RS-2475-VFW
SR-2475-VFW
RSS-24110W-FR 24VDC Red 110 RS-24110-HFR
SR-24110-HFR
RSS-24110W-FW 24VDC White 110 RS-24110-HFW
SR-24110-HFW
RSS-24150W-FR 24VDC Red 150 None
RSS-24150W-FW 24VDC White 150 None
RSS-24177W-FR 24VDC Red 177 None
RSS-24177W-FW 24VDC White 177 None
RSS-24185W-FR 24VDC Red 185 None
RSS-24185W-FW 24VDC White 185 None
Single-candela ceiling
Model Number Voltage Color Candela Shape Replaces
RSS-2415C-FR 24VDC Red 15 Square RS-2415-VFR
SR-2415-VFR
RSS-2415C-FW 24VDC White 15 Square RS-2415-VFW
SR-2415-VFW
RSS-2430C-FR 24VDC Red 30 Square RS-2430-VFR
RSS-2430C-FW 24VDC White 30 Square RS-2430-VFW
RSS-2475C-FR 24VDC Red 75 Square RS-2475-VFR
SR-2475-VFR
RSS-2475C-FW 24VDC White 75 Square RS-2475-VFW
SR-2475-VFW
RSS-24100C-FR 24VDC Red 100 Square RS-24110-CFR
SR-24110-CFR
RSS-24100C-FW 24VDC White 100 Square RS-24110-CFW
SR-24110-CFW
RSS-24150C-FR 24VDC Red 150 Square None
RSS-24150C-FW 24VDC White 150 Square None
RSS-24177C-FR 24VDC Red 177 Square None
RSS-24177C-FW 24VDC White 177 Square None
RSS-2415CR-FR 24VDC Red 15 Round None
RSS-2415CR-FW 24VDC White 15 Round None
RSS-2430CR-FR 24VDC Red 30 Round None
RSS-2430CR-FW 24VDC White 30 Round None
RSS-2475CR-FR 24VDC Red 75 Round None
RSS-2475CR-FW 24VDC White 75 Round None
RSS-24100CR-FR 24VDC Red 100 Round None
RSS-24100CR-FW 24VDC White 100 Round None
RSS-24150CR-FR 24VDC Red 150 Round None
RSS-24150CR-FW 24VDC White 150 Round None
RSS-24177CR-FR 24VDC Red 177 Round None
RSS-24177CR-FW 24VDC White 177 Round None
Multi-candela
Model Number Candela Mounting Shape Replaces
RSS-24MCW 15, 30, 75, 110 Wall Square RSS-2415W
RSS-2430W
RSS-2475W
RSS-24110W
RSS-24MCC 15, 30, 75, 95 Ceiling Square RSS-2415C
RSS-2430C
RSS-2475C
RSS-24100C
RSS-24MCCR 15, 30, 75, 95 Ceiling Round RSS-2415CR
RSS-2430CR
RSS-2475CR
RSS-24100CR
RSS-24MCWH 135, 185 Wall Square RSS-24150W
RSS-24177W
RSS-24185W
RSS-24MCCH 115, 177 Ceiling Square RSS-24150C
RSS-24177C
RSS-24MCCHR 115, 177 Ceiling Round RSS-24150CR
RSS-24177CR
72035[12] RSS-24MCW-FR RSS-24MCW-FR
72036 RSS-24MCW-FW RSS-24MCW-FW
71692 RSS-241575W-FR RSS-241575W-FR
71730 RSS-2415C-FW 72294
71731 RSS-2430C-FW 72294
71732 RSS-2475C-FW 72294
71699 RSS-24100C-FW 72294
72240 RSS-24150C-FW 72296
72239 RSS-24177C-FW 72296
72294[13] RSS-24MCC-FW 71730
71731
71732
71699
RSS-24MCC-FW
72296 RSS-24MCCH-FW 72239
72240
RSS-24MCCH-FW
367-059-00[14] RSSA-24MCC-NW Still in production
367-064-00 RSSB-24MCC-NW Still in production
367-075-00 RSSA-24MCW-ALW Still in production
367-089-00 RSSA-24MCCH-NW Still in production
367-090-00 RSS-24MCC-FR Still in production
367-091-00 RSS-24MCCH-FW Still in production
Siemens started rebranding the RSS series around 2007 as a result of the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit that required the Siemens U series to be discontinued.
ST-MC-R RSS-24MCW-FR G1R-VM-LG
G1RF-VM-LG
U-MCS
SL2SWR-F[15]
ST-MC-R-AR RSS-24MCW-AR SL2SWR-A
ST-MC-W RSS-24MCW-FW G1-VM-LG
G1F-VM-LG
U-MCS-W
SL2SWW-F
ST-MC-CW RSS-24MCCR-FW GC-VM-LG
GCF-VM-LG
U-MCS-W
SL2SCW-F
ST-HMC-CW RSS-24MCCHR-FW GC-VMH-LG
GCF-VMH-LG
SL2SCW-F[16]
ST-MC-RETRO-R RSSP-24MCW-FR U-MCS-6090V[17] Still in production
ST-75-R-WP RSSWP-2475W-FR U-MCS-WP Still in production
ST-75-W-WP RSSWP-2475W-FW U-MCS-W-WP Still in production
ST-75-CR-WP RSSWP-2475C-FR U-MCS-WP Still in production
ST-75-CW-WP RSSWP-2475C-FW U-MCS-W-WP Still in production
ST-HMC-R-WP RSSWP-24MCWH-FR U-MCS-WP Still in production
ST-HMC-W-WP RSSWP-24MCWH-FW U-MCS-W-WP Still in production
ST-HMC-CR-WP RSSWP-24MCCH-FR U-MCS-WP Still in production
ST-HMC-CW-WP RSSWP-24MCCH-FW U-MCS-W-WP Still in production
ST-CMC-R-MNS-ALERT[18] RSS-24MCW-ALR None SL2SWR-AL
ST-CMC-W-MNS-ALERT RSS-24MCW-ALW None SL2SWW-AL
ST-CMC-CR-MNS-ALERT RSS-24MCCR-ALR None SL2SCR-AL
ST-CMC-CW-MNS-ALERT RSS-24MCCR-ALW None SL2SCW-AL
ST-CMC-RETRO-R-MNS-ALERT RSSP-24MCW-ALR None Still in production
ST-CMC-RETRO-W-MNS-ALERT RSSP-24MCW-ALW None Still in production
ST-AMC-R-MNS-ALERT RSSA-24MCW-ALR None SL2SWR-ALA
ST-AMC-W-MNS-ALERT RSSA-24MCW-ALW None SL2SWW-ALA
ST-AMC-CR-MNS-ALERT RSSA-24MCC-ALR None SL2SCR-ALA
ST-AMC-CW-MNS-ALERT RSSA-24MCC-ALW None SL2SCW-ALA
ST-AMC-RETRO-R-MNS-ALERT RSSPA-24MCW-ALR None Still in production
ST-AMC-RETRO-W-MNS-ALERT RSSPA-24MCW-ALW None Still in production
ST-MC-CMNA
ST-MC-RETRO-CMNA
  1. https://nfpa.access.preservica.com/uncategorized/IO_6caebbed-7fbf-4147-a65b-d9b6fda152c5/
  2. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-led3-e50-e60-e70h-e90h-rss-product-discontinuation-notice.pdf
  3. https://nfpa.access.preservica.com/uncategorized/IO_6caebbed-7fbf-4147-a65b-d9b6fda152c5/
  4. https://web.archive.org/web/20010422044354/http://www.wheelockinc.com/Products/_ae_specs/Fire_Alarm/Visual/SeriesRSS.htm
  5. https://web.archive.org/web/20060322120252/http://www.wheelockinc.com/literature/Notification.pdf
  6. https://web.archive.org/web/20060322120450/http://www.wheelockinc.com/literature/November2002.pdf
  7. https://web.archive.org/web/20061108090040/http://www.cooperwheelock.com/literature/prod_repl_shed.pdf
  8. https://web.archive.org/web/20061108085957/http://www.cooperwheelock.com/literature/sep03_prod_replace.pdf
  9. https://web.archive.org/web/20061108090047/http://www.cooperwheelock.com/literature/NN%20Dec%202005.pdf
  10. https://www.wheelock-products.com/media/brochures/FireandSecurity%20Catalog.pdf
  11. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-ps-amt-ch-e-et-hs4-mt-rss-product-discontinuation-notice.pdf
  12. https://web.archive.org/web/20030408081801/http://gamewell.com/pdf/datasheets/CS-2244.pdf
  13. https://web.archive.org/web/20031214070230/http://gamewell.com/datasheets/CS-2244.pdf
  14. "Monaco Products Catalog". Monaco Enterprises (September 2024).
  15. https://cache.industry.siemens.com/dl/files/011/109823011/att_1149026/v3/A6V14140218.pdf
  16. https://cache.industry.siemens.com/dl/files/010/109823010/att_1149025/v2/A6V14140217.pdf
  17. https://web.archive.org/web/20060311133344/http://www.us.sbt.siemens.com/FIS/productdoc/catalogs/2550.pdf
  18. https://cache.industry.siemens.com/dl/files/938/109788938/att_1045697/v2/A6V10333139.pdf
