Cerberus Pyrotronics IXL
1990-1993
1996
Gamewell Identifire Network System 2
Cerberus Pyrotronics MXL series
"title": "Cerberus Pyrotronics IXL",
The Cerberus Pyrotronics IXL was an enhanced version of the Gamewell Identifire Network System 2.
In 1990, Gamewell split from Cerberus Pyrotronics, leading to the INS-2 being supported under both brands. The IXL was later released as a panel compatible with both INS-2 devices and I series detectors through the use of a new ICon module, which could facilitate the transition from Gamewell equipment to Cerberus Pyrotronics equipment. Upgrade kits were also introduced to provide limited IXL functionality on INS-2 systems.[1]
The IXL was discontinued in 1996 due to the release of the MXL-IQ, which had a similar device capacity while using the same equipment as the other MXL systems.
Components
Main packages
| Model | Color | AC voltage | Additional components | Replaced | Replaced by |
| IXL | Black | 120 VAC | None | INS 2 INS 2AP (with LAN) INS 2P (with LPI) INS 2E (with IXL-EXP) INS 2EAP (with IXL-EXP + LAN) INS 2EP (with IXL-EXP + LPI) INS-2F INS-2APF (with LAN) INS-2PF (with LPI) INS-2EF (with IXL-EXP) INS-2EAPF (with IXL-EXP + LAN) INS-2EPF (with IXL-EXP + LPI) |
MSE-3L + SMB-1 + MPS-6 |
| IXL-RED | Red | 120 VAC | None | None | MSE-3L + SMB-1 + MPS-6 |
| IXL-DEMO | Black | 120 VAC | LAN ICon LED CE-S ID-60I |
None | |
| IXL-INT | Black | 220/240 VAC | None | None |
INS-2 upgrade kits
| Model | Upgraded components |
| CON CHIP KIT | Main IXL panel |
| A/P CHIP KIT | LAN, RAN, LPI, RPI |
| CON A/P UPGRADE | Entire system |
SLC devices
| Model | Description | Replaced | Replaced by |
| CZI-L2S | Class B contact monitor module | 30771-12 | |
| CZI-L4S | Class A contact monitor module | 30771-10 | |
| CZI-H2S | Class B high current monitor module | 30774-12 | |
| CZI-H4S | Class A higher current monitor module | 30774-10 | |
| CE-S | Relay control module | 30770-10 | CRM-4 |
| LAN | Local alphanumeric display | 30773-01 INS 2AP (with IXL) INS 2EAP (with IXL + IXL-EXP) INS-2APF (with IXL) INS-2EAPF (with IXL + IXL-EXP) |
MKB-4 |
| RAN | Remote alphanumeric display | 30773-02 | RCC-1 |
| LPI | Local printer inteface | 30773 INS 2P (with IXL) INS 2EP (with IXL + IXL-EXP) INS-2PF (with IXL) INS-2EPF (with IXL + IXL-EXP) |
| RPI | Remote printer interface | 30773-03 | |
| LED-1 | White LED annunciator | 30766 | |
| LED-2 | Black LED annunciator | 30766-01 | |
| GAD | Graphic annunciator driver | 30788 | |
| RRD | Relay driver | ||
| INS-EVI | Voice interface module | 30843 | |
| ICon | I series SLC interface module | None | ALD-2I |
| GenCon | |||
| RemCon | Remote control module | 30852 |
- ↑ "IXL - The Intermediate XL Member of the InteLINK Family" (9350). Cerberus Pyrotronics (March 1994).
