Siemens I series (detectors)
I series
Pyrotronics |
Cerberus Pyrotronics X series |
"title": "I series",
The Siemens I series is a series of addressable detectors originally introduced by Pyrotronics.
| Model | Voltage | Application | Replaced | Replaced by |
| ID-60I[1] | 16-25 VDC | Maximum 300 ft/min | 30765 + F7 | |
| ID-60IH | 16-25 VDC | Maximum 300 ft/min High altitude |
| ID-60IA | 16-25 VDC | Maximum 1200 ft/min | ||
| ID-60IAH | 16-25 VDC | Maximum 1200 ft/min High altitude |
| ID-60IB | 16-25 VDC | Duct use only | ||
| ID-60IBH | 16-25 VDC | Duct use only High altitude |
| ILI-1[2] | 16-30 VDC | Maximum 300 ft/min | ||
| ILI-1H | 16-30 VDC | Maximum 300 ft/min High altitude |
| ILI-1A | 16-30 VDC | Maximum 1200 ft/min | ||
| ILI-1AH | 16-30 VDC | Maximum 1200 ft/min High altitude |
| ILI-1B | 16-30 VDC | Duct use only | ||
| ILI-1BH | 16-30 VDC | Duct use only High altitude |
| Model | Heat sensor? | Replaced | Replaced by |
| ILP-1[3] | No | 30765 + R7 | |
| ILPT-1 | Yes | 30765 + RT7 | |
| ILP-2[4] | No |
| Model | Replaced | Replaced by |
| ILT-1[5] | 30765 + D9 |
Mounting bases
| Model | Type | Replaced | Replaced by |
| ADBI-60 | Audible |
- ↑ https://web.archive.org/web/19980714165342/http://cerbpyro.com/6155.pdf
- ↑ https://web.archive.org/web/19980714165307/http://cerbpyro.com/6165.pdf
- ↑ https://web.archive.org/web/19980714165248/http://cerbpyro.com/6164.pdf
- ↑ https://web.archive.org/web/19980714165232/http://cerbpyro.com/6172.pdf
- ↑ https://web.archive.org/web/19980714165400/http://cerbpyro.com/6167.pdf
