Wheelock Exceder LED3 series
(Redirected from Siemens SL series)
Exceder LED3 series
Wheelock_Exceder_LED3_series.png: Infobox image for Exceder LED3 series the infobox device.
8-17.5VDC & 16-33VDC (NAC)[1]
25VRMS & 70VRMS (speaker)[2] {"label": "Rated Voltage", "field": "8-17.5VDC & 16-33VDC (NAC)[1]
25VRMS & 70VRMS (speaker)[2]"}
2017 {"label": "Introduced", "field": "2017"}
Wheelock: 2021[3]
Siemens: 2024 {"label": "Discontinued", "field": "Wheelock: 2021[3]
Siemens: 2024"}
Exceder LED series {"label": "Preceded by", "field": "Exceder LED series"}
Eluxa series {"label": "Succeeded by", "field": "Eluxa series"}
The Wheelock Exceder LED3 series is a series of notification appliances.
The Exceder LED3 series was released in 2017 to address NFPA's 20 millisecond strobe flash duration requirement introduced in 2016, and as a result of this change, the new strobes were capable of being placed in the same field of view as Wheelock's xenon strobes. Both of these features were previously seen in the Simplex TrueAlert ES 5900 Series.[4] Additionally, the LED3 strobes draw slightly less current than the LED2 strobes.[5][6] At this time, Wheelock also updated the horns and low frequency sounders to draw slightly less current.[7] However, the speaker-only devices remained unchanged aside from their housing.
In 2018, Wheelock released the LFHSH3 devices, which are 177 cd low frequency sounder strobes. At this time, the low frequency sounders were updated to have a reverberant sound output of 80 dBA regardless of tone selection, and the housing of the sounder strobes was updated to have the candela printed above the tone selection window.[8]
In 2021, the Exceder LED3 series was discontinued, as all devices had equivalents in the Eluxa series.[3] The Siemens rebrand (SLS series) continued to be made.
In late 2023, Siemens released the SL2 series which is their rebrand of the Wheelock Eluxa series. The SLS series was discontinued in April 2024.
The horns in the Exceder LED3 series can output 95 or 90 anechoic dBA, the speakers output 300-8000 Hz at 1/8, 1/4, 1/2, 1, or 2 watts, and the low frequency sounders output 80 dBA. Depending on the model, the strobe candela output may be 15, 30, 75, 95, 110, or 177 candela.
Like the Exceder LED series, the low frequency sounders in the Exceder LED3 series produce a high-static noise.[9] The low frequency sounders have tone options for continuous, Code 3, Code 4, and Code 3/Code 4.
All devices are capable of being surface mounted or mounted to 4-inch square backboxes. Ceiling-mount devices are also capable of mounting to 4-inch octagonal backboxes, and all wall-mount devices besides the speakers and speaker strobes can mount to single-gang backboxes.
Model Number Lens color Candela Mounting Color Lettering Replaces Replaced By
LSTR3 White 15, 30, 75, 110 Wall Red FIRE LSTR ELSTR
LSTR3-A White 15, 30, 75, 110 Wall Red AGENT LSTR-A ELSTR-A
LSTR3-AL White 15, 30, 75, 110 Wall Red ALERT LSTR-AL ELSTR-AL
LSTR3-ALA[10] Amber 15, 30, 75, 110 Wall Red ALERT LSTR-ALA ELSTR-ALA
LSTR3-ALB[11] Blue 3, 6, 15, 22 Wall Red ALERT None ELSTR-ALB
LSTR3-N White 15, 30, 75, 110 Wall Red None LSTR-N ELSTR-N
LSTR3-NA Amber 15, 30, 75, 110 Wall Red None LSTR-NA ELSTR-NA
LSTR3-NB Blue 3, 6, 15, 22 Wall Red None None ELSTR-NB
LSTW3 White 15, 30, 75, 110 Wall White FIRE LSTW ELSTW
LSTW3-A White 15, 30, 75, 110 Wall White AGENT LSTW-A ELSTW-A
LSTW3-AL White 15, 30, 75, 110 Wall White ALERT LSTW-AL ELSTW-AL
LSTW3-ALA Amber 15, 30, 75, 110 Wall White ALERT LSTW-ALA ELSTW-ALA
LSTW3-ALB Blue 3, 6, 15, 22 Wall White ALERT None ELSTW-ALB
LSTW3-N White 15, 30, 75, 110 Wall White None LSTW-N ELSTW-N
LSTW3-NA Amber 15, 30, 75, 110 Wall White None LSTW-NA ELSTW-NA
LSTW3-NB Blue 3, 6, 15, 22 Wall White None None ELSTW-NB
LSTRC3[12] White 15, 30, 75, 95 Ceiling Red FIRE LSTRC ELSTRC
LSTRC3-AL White 15, 30, 75, 95 Ceiling Red ALERT LSTRC-AL ELSTRC-AL
LSTRC3-ALA[13] Amber 15, 30, 75, 95 Ceiling Red ALERT LSTRC-ALA ELSTRC-ALA
LSTRC3-ALB Blue 3, 6, 15, 19 Ceiling Red ALERT None ELSTRC-ALB
LSTRC3-NB Blue 3, 6, 15, 19 Ceiling Red None None ELSTRC-NB
LSTWC3 White 15, 30, 75, 95 Ceiling White FIRE LSTWC ELSTWC
LSTWC3-AL White 15, 30, 75, 95 Ceiling White ALERT LSTWC-AL ELSTWC-AL
LSTWC3-ALA Amber 15, 30, 75, 95 Ceiling White ALERT LSTWC-ALA ELSTWC-ALA
LSTWC3-ALB Blue 3, 6, 15, 19 Ceiling White ALERT None ELSTWC-ALB
LSTWC3-NB Blue 3, 6, 15, 19 Ceiling White None None ELSTWC-NB
Model Number Type Strobe color Candela Mounting Color Lettering Replaces Replaced By
LHNR3 Horn N/A N/A Wall Red None LHNR ELHNR
LHNW3 Horn N/A N/A Wall White None LHNW ELHNW
LHNRC3 Horn N/A N/A Ceiling Red None LHNRC ELHNRC
LHNWC3 Horn N/A N/A Ceiling White None LHNWC ELHNWC
LHSR3 Horn strobe White 15, 30, 75, 110 Wall Red FIRE LHSR ELHSR
LHSR3-A Horn strobe White 15, 30, 75, 110 Wall Red AGENT LHSR-A ELHSR-A
LHSR3-N Horn strobe White 15, 30, 75, 110 Wall Red None LHSR-N ELHSR-N
LHSW3 Horn strobe White 15, 30, 75, 110 Wall White FIRE LHSW ELHSW
LHSW3-A Horn strobe White 15, 30, 75, 110 Wall White AGENT LHSW-A ELHSW-A
LHSW3-AL Horn strobe White 15, 30, 75, 110 Wall White ALERT LHSW-AL ELHSW-AL
LHSW3-N Horn strobe White 15, 30, 75, 110 Wall White None LHSW-N ELHSW-N
LHSRC3 Horn strobe White 15, 30, 75, 95 Ceiling Red FIRE LHSRC ELHSRC
LHSWC3 Horn strobe White 15, 30, 75, 95 Ceiling White FIRE LHSWC ELHSWC
LSPKR[14] Speaker N/A N/A Wall Red FIRE None ELSPKR
LSPKR-N Speaker N/A N/A Wall Red None None ELSPKR-N
LSPKR-AL Speaker N/A N/A Wall Red ALERT None ELSPKR-AL
LSPKW Speaker N/A N/A Wall White FIRE None ELSPKW
LSPKW-N Speaker N/A N/A Wall White None None ELSPKW-N
LSPKW-AL Speaker N/A N/A Wall White ALERT None ELSPKW-AL
LSPKRC Speaker N/A N/A Ceiling Red FIRE None ELSPKRC
LSPKRC-AL Speaker N/A N/A Ceiling Red ALERT None ELSPKRC-AL
LSPKRC-N Speaker N/A N/A Ceiling Red None None ELSPKRC-N
LSPKWC Speaker N/A N/A Ceiling White FIRE None ELSPKWC
LSPKWC-AL Speaker N/A N/A Ceiling White ALERT None ELSPKWC-AL
LSPKWC-N Speaker N/A N/A Ceiling White None None ELSPKWC-N
LSPSTR3 Speaker strobe White 15, 30, 75, 110 Wall Red FIRE LSPSTR ELSPSTR
LSPSTR3-AL Speaker strobe White 15, 30, 75, 110 Wall Red ALERT LSPSTR-AL ELSPSTR-AL
LSPSTR3-ALA[15] Speaker strobe Amber 15, 30, 75, 110 Wall Red ALERT LSPSTR-ALA ELSPSTR-ALA
LSPSTR3-N Speaker strobe White 15, 30, 75, 110 Wall Red None LSPSTR-N ELSPSTR-AL
LSPSTR3-NA Speaker strobe Amber 15, 30, 75, 110 Wall Red None LSPSTR-NA ELSPSTR-NA
LSPSTW3 Speaker strobe White 15, 30, 75, 110 Wall White FIRE LSPSTW ELSPSTW
LSPSTW3-AL Speaker strobe White 15, 30, 75, 110 Wall White ALERT LSPSTW-AL ELSPSTW-AL
LSPSTW3-ALA Speaker strobe Amber 15, 30, 75, 110 Wall White ALERT LSPSTW-ALA ELSPSTW-ALA
LSPSTW3-N Speaker strobe White 15, 30, 75, 110 Wall White None LSPSTW-N ELSPSTW-N
LSPSTW3-NA Speaker strobe Amber 15, 30, 75, 110 Wall White None LSPSTW-NA ELSPSTW-NA
LSPSTRC3 Speaker strobe White 15, 30, 75, 95 Ceiling Red FIRE LSPSTRC ELSPSTRC
LSPSTRC3-AL Speaker strobe White 15, 30, 75, 95 Ceiling Red ALERT LSPSTRC-AL ELSPSTRC-AL
LSPSTRC3-ALA[16] Speaker strobe Amber 15, 30, 75, 95 Ceiling Red ALERT LSPSTRC-ALA ELSPSTRC-ALA
LSPSTWC3 Speaker strobe White 15, 30, 75, 95 Ceiling White FIRE LSPSTWC ELSPSTWC
LSPSTWC3-AL Speaker strobe White 15, 30, 75, 95 Ceiling White ALERT LSPSTWC-AL ELSPSTWC-AL
LSPSTWC3-ALA Speaker strobe Amber 15, 30, 75, 95 Ceiling White ALERT LSPSTWC-ALA ELSPSTWC-ALA
Low frequency sounders
LFHNKR3 Sounder N/A N/A Wall Red FIRE LFHNKR ELFHNR
LFHNKR3-AL Sounder N/A N/A Wall Red ALERT LFHNKR-AL ELFHNR-AL
LFHNKR3-CO Sounder N/A N/A Wall Red CO LFHNKR-CO ELFHNR-CO
LFHNKR3-N Sounder N/A N/A Wall Red None LFHNKR-N ELFHNR-N
LFHNKW3 Sounder N/A N/A Wall White FIRE LFHNKW ELFHNW
LFHNKW3-AL Sounder N/A N/A Wall White ALERT LFHNKW-AL ELFHNW-AL
LFHNKW-CO Sounder N/A N/A Wall White CO LFHNKW-CO ELFHNW-CO
LFHSKR3 Sounder strobe White 110 Wall Red FIRE LFHSKR ELFHSR
LFHSKR3-AL Sounder strobe White 110 Wall Red ALERT LFHSKR-AL ELFHSR-AL
LFHSKR3-CO Sounder strobe White 110 Wall Red CO LFHSKR-CO ELFHSR-CO
LFHSKR3-N Sounder strobe White 110 Wall Red None LFHSKR-N ELFHSR-N
LFHSKW3 Sounder strobe White 110 Wall White FIRE LFHSKW ELFHSW
LFHSKW3-AL Sounder strobe White 110 Wall White ALERT LFHSKW-AL ELFHSW-AL
LFHSKW3-CO Sounder strobe White 110 Wall White CO LFHSKW-CO ELFHSW-CO
LFHSKW3-N Sounder strobe White 110 Wall White None LFHSKW-N ELFHSW-N
LFHSHR3 Sounder strobe White 177 Wall Red FIRE None ELFHSR
LFHSHR3-AL Sounder strobe White 177 Wall Red ALERT None ELFHSR-AL
LFHSHR3-CO Sounder strobe White 177 Wall Red CO None ELFHSR-CO
LFHSHR3-N Sounder strobe White 177 Wall Red None None ELFHSR-N
LFHSHW3 Sounder strobe White 177 Wall White FIRE None ELFHSW
LFHSHW3-AL Sounder strobe White 177 Wall White ALERT None ELFHSW-AL
LFHSHW3-CO Sounder strobe White 177 Wall White CO None ELFHSW-CO
LFHSHW3-N Sounder strobe White 177 Wall White None None ELFHSW-N
Mounting accessories
Model Number Type Mounting Color
LSBB-R Backbox Wall Red
LSBB-W Backbox Wall White
ESB-KIT-R Trimplate Wall Red
ESB-KIT-W Trimplate Wall White
LSPKBB-R Backbox Wall Red
LSPKBB-W Backbox Wall White
LSPKBB-CR Backbox Ceiling Red
LSPKBB-CW Backbox Ceiling White
LFTP-R Trimplate Wall Red
LFTP-W Trimplate Wall White
In addition to the standard lettering from Wheelock, Siemens produced -FB models that had fire evacuation pictograms.
In late 2023, Siemens announced that they will discontinue their rebrands at the end of April 2024 because they have started to rebrand the Eluxa series.
Siemens model Wheelock model Replaced by
SLSWR-F LSTR3 SL2SWR-F
SLSWW-F LSTW3 SL2SWW-F
SLSWR-FB None SL2SWR-FB
SLSWW-FB None SL2SWW-FB
SLSWR-A LSTR3-A SL2SWR-A
SLSWR-AL LSTR3-AL SL2SWR-AL
SLSWW-AL LSTW3-AL SL2SWW-AL
SLSWR-ALA LSTR3-ALA SL2SWR-ALA
SLSWW-ALA LSTW3-ALA SL2SWW-ALA
SLSWR-NA LSTR3-NA SL2SWR-NA
SLSWW-NA LSTW3-NA SL2SWW-NA
SLSWR-N LSTR3-N SL2SWR-N
SLSWW-N LSTW3-N SL2SWW-N
SLSCR-F[17] LSTRC3 SL2SCR-F[18]
SLSCW-F LSTWC3 SL2SCW-F
SLSCR-FB None SL2SCR-FB
SLSCW-FB None SL2SCW-FB
SLSCR-AL LSTRC3-AL SL2SCR-AL
SLSCW-AL LSTWC3-AL SL2SCW-AL
SLSCR-ALA LSTRC3-ALA SL2SCR-ALA
SLSCW-ALA LSTWC3-ALA SL2SCW-ALA
SLSCR-NA None SL2SCR-NA
SLSCW-NA None SL2SCW-NA
SLSCR-N None SL2SCR-N
SLSCW-N None SL2SCW-N
SLSCR-A None SL2SCR-A
SLSCW-A None SL2SCW-A
SLHWR-N[19] LHNR3 SL2HWR-N[20]
SLHWW-N LHNW3 SL2HWW-N
SLHSWR-F LHSR3 SL2HSWR-F
SLHSWW-F LHSW3 SL2HSWW-F
SLHSWR-FB None SL2HSWR-FB
SLHSWW-FB None SL2HSWW-FB
SLHSWR-A LHSR3-A SL2HSWR-A
SLHSWW-A LHSW3-A SL2HSWW-A
SLHSWR-N LHSR3-N SL2HSWR-N
SLHSWW-N LHSW3-N SL2HSWW-N
SLHSWR-AL None SL2HSWR-AL
SLHSWW-AL LHSW3-AL SL2HSWW-AL
SLHCR-N LHNRC3 SL2HCR-N[21]
SLHCW-N LHNWC3 SL2HCW-N
SLHSCR-F LHSRC3 SL2HSCR-F
SLHSCW-F LHSWC3 SL2HSCW-F
SLHSCR-FB None SL2HSCR-FB
SLHSCW-FB None SL2HSCW-FB
SLHSCR-A None SL2HSCR-A
SLHSCW-A None SL2HSCW-A
SLHSCR-AL None SL2HSCR-AL
SLHSCW-AL None SL2HSCW-AL
SLHSCR-N None SL2HSCR-N
SLHSCW-N None SL2HSCW-N
SLSPWR-F[22] LSPKR SL2SPWR-F[23]
SLSPWW-F LSPKW SL2SPWW-F
SLSPWR-AL LSPKR-AL SL2SPWR-AL
SLSPWW-AL LSPKW-AL SL2SPWW-AL
SLSPWR-N LSPKR-N SL2SPWR-N
SLSPWW-N LSPKW-N SL2SPWW-N
SLSPSWR-F LSPSTR3 SL2SPSWR-F
SLSPSWW-F LSPSTW3 SL2SPSWW-F
SLSPSWR-NA LSPSTR3-NA SL2SPSWR-NA
SLSPSWW-NA LSPSTW3-NA SL2SPSWW-NA
SLSPSWR-ALA LSPSTR3-ALA SL2SPSWR-ALA
SLSPSWW-ALA LSPSTW3-ALA SL2SPSWW-ALA
SLSPSWR-AL LSPSTR3-AL SL2SPSWR-AL
SLSPSWW-AL LSPSTW3-AL SL2SPSWW-AL
SLSPSWR-N LSPSTR3-N SL2SPSWR-N
SLSPSWW-N LSPSTW3-N SL2SPSWW-N
SLSPSWR-M None SL2SPSWR-M
SLSPSWW-M None SL2SPSWW-M
SLSPSWR-FB None SL2SPSWR-FB
SLSPSWW-FB None SL2SPSWW-FB
SLSPCR-F[24] LSPKRC SL2SPCR-F
SLSPCW-F LSPKWC SL2SPCW-F
SLSPCR-AL LSPKRC-AL SL2SPCR-AL
SLSPCW-AL LSPKWC-AL SL2SPCW-AL
SLSPCR-N LSPKRC-N SL2SPCR-N
SLSPCW-N LSPKWC-N SL2SPCW-N
SLSPCW-A None SL2SPCW-A
SLSPSCR-F LSPSTRC3 SL2SPSCR-F
SLSPSCW-F LSPSTWC3 SL2SPSCW-F
SLSPSCR-AL LSPSTRC3-AL SL2SPSCR-AL
SLSPSCW-AL LSPSTWC3-AL SL2SPSCW-AL
SLSPSCR-ALA LSPSTRC3-ALA SL2SPSCR-ALA
SLSPSCW-ALA LSPSTWC3-ALA SL2SPSCW-ALA
SLSPSCR-NA None SL2SPSCR-NA
SLSPSCW-NA None SL2SPSCW-NA
SLSPSCR-A None SL2SPSCR-A
SLSPSCW-A None SL2SPSCW-A
SLSPSCR-N None SL2SPSCR-N
SLSPSCW-N None SL2SPSCW-N
SLSPSCR-FB None SL2SPSCR-FB
SLSPSCW-FB None SL2SPSCW-FB
SLFSWR-F[25] LFHNKR3 SL2FSWR-F[26]
SLFSWW-F LFHNKW3 SL2FSWW-F
SLFSWR-CO LFHNKR3-CO SL2FSWR-CO
SLFSWW-CO LFHNKW3-CO SL2FSWW-CO
SLFSWR-AL LFHNKR3-AL SL2FSWR-AL
SLFSWW-AL LFHNKW3-AL SL2FSWW-AL
SLFSWR-N LFHNKR3-N SL2FSWR-N
SLFSWW-N None SL2FSWW-N
SLFSSWR-F LFHSKR3 SL2FSSWR-F
SLFSSWW-F LFHSKW3 SL2FSSWW-F
SLFSSWR-CO LFHSKR3-CO SL2FSSWR-CO
SLFSSWW-CO LFHSKW3-CO SL2FSSWW-CO
SLFSSWR-AL LFHSKR3-AL SL2FSSWR-AL
SLFSSWW-AL LFHSKW3-AL SL2FSSWW-AL
SLFSSWR-N LFHSKW3-N SL2FSSWR-N
SLFSSWW-N LFHSKW3-N SL2FSSWW-N
SLSBBR LSBB-R
SLSBBW LSBB-W
SLSGP-R ESB-KIT-R
SLSGP-W ESB-KIT-W
SLSSBBCR LSPKBB-CR
SLSSBBCW LSPKBB-CW
SLSPBBCR LSPKBB-CR
SLSPBBCW LSPKBB-CW
LFSBB-R LSPKBB-R
LFSBB-W LSPKBB-W
  1. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-wall-data-sheet-TD450117EN.pdf
  2. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-speakers-ceiling-data-sheet-TD450119EN.pdf
  3. 3.0 3.1 https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-led3-e50-e60-e70h-e90h-rss-product-discontinuation-notice.pdf
  4. https://web.archive.org/web/20170325012208/https://simplex-fire.com/en/us/Pages/ProductDetail.aspx?productdetail=%E2%80%8BTrueAlert+ES+5900+Series+LED+Addressable+Notification+Appliances
  5. https://www.wheelock-products.com/lanotattachments/download/file/id/1542/store/2/wheelockexceder_led_wall.pdf
  6. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-wall-data-sheet-TD450117EN.pdf
  7. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-wall-horn-strobe-install-sheet-P85580.pdf
  8. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-low-frequency-sounder-data-sheet-TD450121EN.pdf
  9. https://www.youtube.com/watch?v=n6uyG_F37bk
  10. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-mns-strobes-wall-data-sheet-TD450122EN.pdf
  11. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-blue-strobes-data-sheet-TD450144EN.pdf
  12. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-ceiling-data-sheet-TD450118EN.pdf
  13. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-mns-strobes-ceiling-data-sheet-TD450125EN.pdf
  14. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-speakers-wall-data-sheet-TD450120EN.pdf
  15. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-mns-speaker-strobes-wall-data-sheet-TD450123EN.pdf
  16. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/exceder-led3/exceder-led3-mns-speaker-strobes-ceiling-data-sheet-TD450128EN.pdf
  17. https://sid.siemens.com/pdf-viewer?file=https%3A%2F%2Fsid.siemens.com%2Fapi%2Fkhub%2Fdocuments%2F~R5Wf8IiJo1DFp_JLGpbMg%2Fcontent%3FFt-Calling-App%3Dft%252Fturnkey-portal%26Ft-Calling-App-Version%3D4.3.26%26filename%3DA6V11396487_en.pdf
  18. https://cache.industry.siemens.com/dl/files/010/109823010/att_1149025/v2/A6V14140217.pdf
  19. https://sid.siemens.com/pdf-viewer?file=https%3A%2F%2Fsid.siemens.com%2Fapi%2Fkhub%2Fdocuments%2F2Q9AsJ1Y2LmGKeMFUCxR~A%2Fcontent%3FFt-Calling-App%3Dft%252Fturnkey-portal%26Ft-Calling-App-Version%3D4.3.26%26filename%3DA6V11396486_en.pdf
  20. https://cache.industry.siemens.com/dl/files/011/109823011/att_1149026/v3/A6V14140218.pdf
  21. https://cache.industry.siemens.com/dl/files/010/109823010/att_1149025/v2/A6V14140217.pdf
  22. https://sid.siemens.com/pdf-viewer?file=https%3A%2F%2Fsid.siemens.com%2Fapi%2Fkhub%2Fdocuments%2FVMirU1CYTDixE3pY5ttmoA%2Fcontent%3FFt-Calling-App%3Dft%252Fturnkey-portal%26Ft-Calling-App-Version%3D4.3.26%26filename%3DA6V11401076_en.pdf
  23. https://cache.industry.siemens.com/dl/files/014/109823014/att_1149029/v2/A6V14140223.pdf
  24. https://sid.siemens.com/pdf-viewer?file=https%3A%2F%2Fsid.siemens.com%2Fapi%2Fkhub%2Fdocuments%2FbM3bVtoJ9YO~97Q4aGx9PQ%2Fcontent%3FFt-Calling-App%3Dft%252Fturnkey-portal%26Ft-Calling-App-Version%3D4.3.26%26filename%3DA6V11401077_en.pdf
  25. https://sid.siemens.com/pdf-viewer?file=https%3A%2F%2Fsid.siemens.com%2Fapi%2Fkhub%2Fdocuments%2FZIZ~zHCJr_dMm6QVgwQNrw%2Fcontent%3FFt-Calling-App%3Dft%252Fturnkey-portal%26Ft-Calling-App-Version%3D4.3.26%26filename%3DA6V11396485_en.pdf
  26. https://mall.industry.siemens.com/mall/collaterals/files/150/pdf/ENG_956926.pdf
