Wheelock E series
(Redirected from Siemens SE series)
Wheelock E series
Wheelock-E50-E60.jpg: Infobox image for Wheelock E series the infobox device.
Wheelock E70 and E90.jpg: Infobox image for Wheelock E series the infobox device.
25VRMS & 70VRMS (speaker)
16-33VDC (strobe) {"label": "Rated Voltage", "field": "25VRMS & 70VRMS (speaker)
16-33VDC (strobe)"}
1989[1] {"label": "Introduced", "field": "1989[1]"}
2023[2] {"label": "Discontinued", "field": "2023[2]"}
The Wheelock E series is a series of speakers and speaker strobes. The E50/E70 speakers are square-shaped and mainly intended for wall mounting, while the E60/E90 speakers are round and mainly intended for ceiling mounting.
The E series was released in 1989 as an alternative to the ET series for smaller buildings. The original E series devices had similar designs to the ET-1070 and ET-1090, but there were fewer power taps, and the taps were directly selected by the input terminals instead of a jumper connection.
Around 1995, Wheelock updated the E series speakers to be dual voltage. At this time, the tap selection was also changed to a small movable jumper bridge.
The E70 series was introduced in 1997 as part of the SquareONE brand.[3] The E90 series was also released around this time. These speakers used similar universal mounting plates to the other SquareONE devices, but the grilles required 2 mounting screws. These grilles, known as the ECHG and ECHSG grilles, were also used by the ET70/ET90 series, CH70/CH90 series, and SA-S series.
In 2000, the E70-24MCW was released as part of the SPEC1FIRE series.[4] The E70-24MCC and E90-24MCC were released in June 2003, and the corresponding single-candela strobe models were discontinued in September 2003.[5] The E70-24MCWH and E90-24MCCH were released in September 2003, and the corresponding single-candela strobe models were discontinued in December 2003.[6]
In October 2004, Wheelock released the E50 series as a screw-free alternative to the E70.[7]
In late 2005, Wheelock released the E60 series as a screw-free alternative to the E90.[8] Unlike the E50, the E60 required an extension ring such as the E60EXT.
At the end of 2015, the E50-241575W and E70-241575W were discontinued.[9] Consumers were instructed to switch to the E70-24MCW.
To focus support on the Eluxa series, the E50 and E60 were discontinued in 2021, and the E70 and E90 were discontinued in 2023.[10][2]
The E series speakers have selectable taps for 1/8, 1/4, 1/2, 1, and 2 watts, and either 25 or 70 VRMS, providing between 75 and 87 dB of output.
The strobe is very similar to the RSS, with possible candela outputs of 15, 15/75, 30, 75, 95, 100, 110, 115, 135, 150, 177, or 185 depending on the model.
E50 series
Model Number Candela Mounting Color Lettering Replaces Replaced by
E50-R[11] N/A Wall/Ceiling Red None None ELSPKR-N
E50-W N/A Wall/Ceiling White None None ELSPKW-N
E50-241575W-FR 15/75 Wall Red FIRE None E50-24MCW-FR
E50-241575W-FW 15/75 Wall White FIRE None E50-24MCW-FW
E50-24MCW-FR 15, 30, 75, 110 Wall Red FIRE E50-241575W-FR ELSPSTR
E50-24MCW-FW 15, 30, 75, 110 Wall White FIRE E50-241575W-FW ELSPSTW
E50-24MCWH-FR 135, 185 Wall Red FIRE None ELSPSTR
E50-24MCWH-FW 135, 185 Wall White FIRE None ELSPSTW
E60 series
E60-R N/A Ceiling Red None None ELSPKRC-N
E60-W N/A Ceiling White None None ELSPKWC-N
E60-24MCC-FR 15, 30, 75, 95 Ceiling Red FIRE None ELSPSTRC
E60-24MCC-FW 15, 30, 75, 95 Ceiling White FIRE None ELSPSTWC
E60-24MCCH-FR 115, 177 Ceiling Red FIRE None ELSPSTRC
E60-24MCCH-FW 115, 177 Ceiling White FIRE None ELSPSTWC
E60EXT-R N/A Ceiling Red None None None
E60EXT-W N/A Ceiling White None None None
E70 series
Model Number Candela Mounting Replaces Replaced by
E70-R N/A Wall/Ceiling E-70-R ELSPKR
E70-W N/A Wall/Ceiling ELSPKW
E70-2415W 15 Wall E-70-LS-24-VFR E70-24MCW
E70-241575W 15/75 Wall E-70-LSM-24-VFR E70-24MCW
E70-2430W 30 Wall E-70-MS-24-VFR E70-24MCW
E70-2475W 75 Wall E-70-IS-24-VFR E70-24MCW
E70-24110W 110 Wall None E70-24MCW
E70-2415C-FW 15 Ceiling None E70-24MCC-FW
E70-24100C-FR 100 Ceiling None E70-24MCC-FR
E70-24185W-FR 185 Wall None E70-24MCWH-FR
E70-24185W-FN 185 Wall None E70-24MCWH-FN
E70-24177C-FW 177 Ceiling None None
E70-24MCW-FR 15, 30, 75, 110 Wall E70-2415W-FR
E70-241575W-FR
E70-2430W-FR
E70-2475W-FR
E70-24110W-FR
ELSPSTR
E70-24MCW-FW 15, 30, 75, 110 Wall ELSPSTW
E70-24MCC-FR 15, 30, 75, 95 Ceiling E70-24100C-FR E90-24MCC-FR
E70-24MCC-FW 15, 30, 75, 95 Ceiling E70-2415C-FW E90-24MCC-FW
E70-24MCWH-FR 135, 185 Wall E70-24185W-FR ELSPSTR
E70-24MCWH-FW 135, 185 Wall E70-24MCWH-FN ELSPSTW
E70-24MCWH-FN 135, 185 Wall E70-24185W-FN E70-24MCWH-FW
E-70 series
E-7025 N/A Wall/Ceiling None E-70-R
E-7025-WS-24 1.5 Wall None E-7025-LS-24
E-7025-WM-24 117 Wall None E-7025-LSM-24
E-7025-LS-24 15 Wall None E-70-LS-24-VFR
E-7025-LSM-24 15/75 Wall E-7025-WM-24 E-70-LSM-24-VFR
E-7070 N/A Wall/Ceiling None E-70-R
E-7070-WM-24 117 Wall None E-7070-LSM-24
E-7070-LSM-24 15/75 Wall E-7070-WM-24 E-70-LSM-24-VFR
E-70-R[12] N/A Wall/ceiling E-7025
E-7070
E70-R
E-70-LS-24-VFR 15 Wall E-7025-LS-24 E70-2415W-FR
E-70-LSM-24-VFR 15/75 Wall E-7025-LSM-24
E-7070-LSM-24
E70-241575W-FR
E-70-MS-24-VFR 30 Wall None E70-2430W-FR
E-70-IS-24-VFR 75 Wall None E70-2475W-FR
E-70-SL-24-VFR 15 Wall None E70-2415W-FR
E-70-SLM-24-VFR 15/75 Wall None E70-241575W-FR
E90 series
E90-W N/A Wall/Ceiling White None E-90-W ELSPKWC-N
E90-R[13] N/A Wall/Ceiling Red None None ELSPKRC-N
E90-2415C-FW 15 Ceiling White FIRE E-90-LS-24-CFW E90-24MCC-FW
E90-2415C-FR 15 Ceiling Red FIRE None E90-24MCC-FR
E90-2415C-FN 15 Ceiling Nickel FIRE None E90-24MCC-FN
E90-2415C-NW 15 Ceiling White None None E90-24MCC-NW
E90-2415C-CW 15 Ceiling White EVAC None E90-24MCC-CW
E90-2430C-CW 30 Ceiling White EVAC None E90-24MCC-CW
E90-2430C-FW 30 Ceiling White FIRE E-90-MS-24-CFW E90-24MCC-FW
E90-2430C-FR 30 Ceiling Red FIRE None E90-24MCC-FR
E90-2430C-FN 30 Ceiling Nickel FIRE None E90-24MCC-FN
E90-2430C-NW 30 Ceiling White None None E90-24MCC-NW
E90-2475C-FW 75 Ceiling White FIRE E-90-IS-24-CFW E90-24MCC-FW
E90-2475C-FR 75 Ceiling Red FIRE None E90-24MCC-FR
E90-2475C-FN 75 Ceiling Nickel FIRE None E90-24MCC-FN
E90-2475C-NW 75 Ceiling White None None E90-24MCC-NW
E90-24100C-FW 100 Ceiling White FIRE None E90-24MCC-FW
E90-24100C-FR 100 Ceiling Red FIRE None E90-24MCC-FR
E90-24100C-FN 100 Ceiling Nickel FIRE None E90-24MCC-FN
E90-24100C-NW 100 Ceiling White None None E90-24MCC-NW
E90-24150C-FW 150 Ceiling White FIRE None E90-24MCCH-FW
E90-24150C-FN 150 Ceiling Nickel FIRE None E90-24MCCH-FN
E90-24177C-FW 177 Ceiling White FIRE None E90-24MCCH-FW
E90-24177C-FN 177 Ceiling Nickel FIRE None E90-24MCCH-FN
E90-24MCC-FW 15, 30, 75, 95 Ceiling White FIRE E70-24MCC-FW
E90-2415C-FW
E90-2430C-FW
E90-2475C-FW
E90-24100C-FW
E90-24MCC-FN
ELSPSTWC
E90-24MCC-FR 15, 30, 75, 95 Ceiling Red FIRE E70-24MCC-FR
E90-2415C-FR
E90-2430C-FR
E90-2475C-FR
E90-24100C-FR
ELSPSTRC
E90-24MCC-FN 15, 30, 75, 95 Ceiling Nickel FIRE E90-2415C-FN
E90-2430C-FN
E90-2475C-FN
E90-24100C-FN
E90-24MCC-FW
E90-24MCC-NW 15, 30, 75, 95 Ceiling White None E90-2415C-NW
E90-2430C-NW
E90-2475C-NW
E90-24100C-NW
ELSPSTWC-N
E90-24MCC-CW 15, 30, 75, 95 Ceiling White EVAC E90-2415C-CW
E90-2430C-CW
E90-24MCCH-FW 115, 177 Ceiling White FIRE E90-24150C-FW
E90-24177C-FW
E90-24MCCH-FN
ELSPSTWC
E90-24MCCH-FR 115, 177 Ceiling Red FIRE None ELSPSTRC
E90-24MCCH-FN 115, 177 Ceiling Nickel FIRE E90-24150C-FN
E90-24177C-FN
E90-24MCCH-FW
E-90 series
E-9025 N/A Wall/Ceiling None E-90-W
E-9025-WS-24 1.5 Ceiling None E-9025-LS-24
E-9025-WM-24 117 Ceiling None None
E-9025-LS-24 15 Ceiling None E-90-LS-24-CFW
E-9070 N/A Wall/Ceiling None E-90-W
E-9070-WS-24 1.5 Ceiling None E-9070-LS-24
E-9070-LS-24 15 Ceiling None E-90-LS-24-CFW
E-9070-IS-24-CFW 75 Ceiling None E-90-IS-24-CFW
E-90-W N/A Ceiling E-9025
E-9070
E90-W
E-90-LS-24-CFW 15 Ceiling E-9025-LS-24
E-9070-LS-24
E90-2415C-FW
E-90-MS-24-CFW 30 Ceiling None E90-2430C-FW
E-90-IS-24-CFW 75 Ceiling E-9070-IS-24-CFW E90-2475C-FW
E-90-SL-24-CFW 15 Ceiling None E90-2415C-FW
71595[14] E70-W E70-W
71753 E70-R E70-R
71599 E90-R E90-R
71754 E90-W E90-W
72045[15] E70-24MCW-FR E70-24MCW-FR
72046 E70-24MCW-FW E70-24MCW-FW
71745 E70-241575W-FR E70-241575W-FR
71749 E90-2415C-FW 72285
71750 E90-2430C-FW 72285
71751 E90-2475C-FW 72285
71752 E90-24100C-FW 72285
72241 E90-24150C-FW 72286
72242 E90-24177C-FW 72286
72285[16] E90-24MCC-FW 71749
71750
71751
71752
E90-24MCC-FW
72286 E9-24MCCH-FW 72241
72242
E90-24MCCH-FW
580-064-00[17] E90A-24MCC-NW Still in production
580-077-00 E60A-24MCC-NW Still in production
580-081-00 E70-24MCW-ALW Still in production
580-120-00 E90-24MCC-FW Still in production
SPK-7070[18] E-7070
SPK-9070 E-9070
SS25-15/75 E-7025-LSM-24
SS70-15/75 E-7070-LSM-24
Siemens started rebranding the E series around 2007 as a result of the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit that required the Siemens Clear-Speak series to be discontinued.
SE-R E50-R S-LP25
S-LP70
SL2SPWR-N[19]
SE-W E50-W S-LP25-W
S-LP70-W
SL2SPWW-N
SEC-R E60-R None SL2SPCR-N
SEC-W E60-W GC-S2-LG
GC-S7-LG
GCF-S2-LG
GCF-S7-LG
SL2SPCW-N
SEF-R[20] E70-R S-LP25MG
S-LP70MG
SL2SPWR-N
SEF-W E70-W G4-S2-LG
G4-S7-LG
G4F-S2-LG
G4F-S7-LG
S-LP25MG-W
S-LP70MG-W
SL2SPWW-N
SEF-CR E90-R None SL2SPCR-N
SEF-CW E90-W GC-S2-LG
GC-S7-LG
GCF-S2-LG
GCF-S7-LG
S-LP25-C
S-LP70-C
SL2SPCW-N
SE-MC-R E50-24MCW-FR S-LP25-MCS
S-LP70-MCS
SL2SPSWR-F
SE-MC-W E50-24MCW-FW S-LP25-MCS-W
S-LP70-MCS-W
SL2SPSWW-F
SE-HMC-R E50-24MCWH-FR None SL2SPSWR-F
SE-HMC-W E50-24MCWH-FW GC-S2VMH-LG
GC-S7VMH-LG
GCF-S2VMH-LG
GCF-S7VMH-LG
SL2SPSWW-F
SE-MC-CR E60-24MCC-FR None SL2SPSCR-F
SE-MC-CW E60-24MCC-FW GC-S2VM-LG
GC-S7VM-LG
GCF-S2VM-LG
GCF-S7VM-LG
SL2SPSCW-F
SE-HMC-CR E60-24MCCH-FR None SL2SPSCR-F
SE-HMC-CW E60-24MCCH-FW None SL2SPSCW-F
SEF-MC-R E70-24MCW-FR G4R-S2VM-LG
G4R-S7VM-LG
G4RF-S2VM-LG
G4RF-S7VM-LG
S-LP25MG-MCS
S-LP70MG-MCS
SL2SPSWR-F
SEF-MC-W E70-24MCW-FW G4-S2VM-LG
G4-S7VM-LG
G4F-S2VM-LG
G4F-S7VM-LG
S-LP25MG-MCS-W
S-LP70MG-MCS-W
SL2SPWW-F
SEF-HMC-R E70-24MCWH-FR None SL2SPSWR-F
SEF-HMC-W E70-24MCWH-FW None SL2SPSWW-F
SEF-MC-CW E90-24MCC-FW GC-S2VM-LG
GC-S7VM-LG
GCF-S2VM-LG
GCF-S7VM-LG
S-LP25-MCS-C
S-LP70-MCS-C
SL2SPSCW-F
SEF-HMC-CW E90-24MCCH-FW GC-S2VMH-LG
GC-S7VMH-LG
GCF-S2VMH-LG
GCF-S7VMH-LG
SL2SPSCW-F
  1. https://nfpa.access.preservica.com/uncategorized/IO_92075e14-eea0-4484-a5d7-f020cbaf9db4/
  2. 2.0 2.1 https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/Xenon%20Tube%20Cessation.pdf
  3. https://trademarks.justia.com/752/33/square-one-75233001.html
  4. https://nfpa.access.preservica.com/uncategorized/IO_fc6eeb17-a4c8-46a3-a2e7-c0f9b50a4d89/
  5. https://web.archive.org/web/20061108090040/http://www.cooperwheelock.com/literature/prod_repl_shed.pdf
  6. https://web.archive.org/web/20061108085957/http://www.cooperwheelock.com/literature/sep03_prod_replace.pdf
  7. https://web.archive.org/web/20060322120332/http://www.wheelockinc.com/literature/Sept_2004.pdf
  8. https://web.archive.org/web/20061108090047/http://www.cooperwheelock.com/literature/NN%20Dec%202005.pdf
  9. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-ps-amt-ch-e-et-hs4-mt-rss-product-discontinuation-notice.pdf
  10. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-led3-e50-e60-e70h-e90h-rss-product-discontinuation-notice.pdf
  11. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/e50-e60-e70-e90/wheelock-e50e60-speakers-strobes-data-sheet-TD450023EN.pdf
  12. https://web.archive.org/web/19970214013223fw_/http://www.wheelockinc.com/E/seriesE2.html
  13. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/e50-e60-e70-e90/wheelock-e70e90-speakers-strobes-data-sheet-TD450024EN.pdf
  14. https://web.archive.org/web/20030407230719/http://gamewell.com/pdf/datasheets/CS-2242.pdf
  15. https://web.archive.org/web/20030408060625/http://gamewell.com/pdf/datasheets/CS-2243.pdf
  16. https://web.archive.org/web/20031214015425/http://gamewell.com/datasheets/CS-2243.pdf
  17. "Monaco Products Catalog". Monaco Enterprises (September 2024).
  18. Page 90 of https://web.archive.org/web/20060515093442/http://wtc.nist.gov/pubs/NISTNCSTAR1-4CDraft.pdf
  19. https://cache.industry.siemens.com/dl/files/014/109823014/att_1149029/v2/A6V14140223.pdf
  20. https://cache.industry.siemens.com/dl/files/531/109787531/att_1044285/v3/A6V10238718.pdf
