Siemens 11 series
11 series
Pyrotronics |
16-26.6 VDC (photoelectric) |
Siemens 3 series
"title": "11 series",
The Siemens 11 series is a series of detectors originally introduced by Pyrotronics.
| Model | Heat sensor? | Listing | Replaced | Replaced by |
| PE-11[1] | No | UL | ||
| PE-11C | No | ULC | ||
| PE-11T | Yes | UL | ||
| PE-11TC | Yes | ULC |
| Model | Conventional/addressable | Listing | Replaced | Replaced by |
| DT-11[2] | Conventional | UL | ||
| DT-11C | Conventional | ULC | ||
| FPT-11[3] | Addressable | UL | ||
| FPT-11C | Addressable | ULC |
FirePrint detectors
| Model | Listing | Replaced | Replaced by |
| FP-11[4] | UL | ||
| FP-11C | ULC |
Mounting bases
| Model | Type | Listing | Replaced | Replaced by |
| DB-11 | Low profile | UL | ||
| DB-11C | Low profile | ULC | ||
| DB-X11RS | Addressable relay | UL | ||
| DB-X11RSC | Addressable relay | ULC | ||
| ADBX-11 | Addressable sounder | UL | ||
| ADBX-11C | Addressable sounder | ULC | ||
| DB-ADPT | Adapter for DB-3 | UL | ||
| AD-11P | Duct housing | UL | ||
| AD-11PC | Duct housing | ULC | ||
| AD-11PR | PE-11 duct housing with relay | UL | ||
| AD-11XPR[5] | FP-11 duct housing with relay | UL | ||
| AD-11UK | Upgrade kit for AD-3 housing | UL |
After Pyrotronics acquired Faraday, Faraday started rebranding 11 series devices as part of the 8700 series and 8800 series.
- ↑ https://web.archive.org/web/19980714170734/http://cerbpyro.com/6173.pdf
- ↑ https://web.archive.org/web/19980714170742/http://cerbpyro.com/6174.pdf
- ↑ https://web.archive.org/web/19980714170620/http://cerbpyro.com/6176.pdf
- ↑ https://web.archive.org/web/19980714170158/http://cerbpyro.com/6175.pdf
- ↑ https://web.archive.org/web/19980714171034/http://cerbpyro.com/6178.pdf
