Siemens 3 series
3 series
Pyrotronics |
18-24 VDC (ionization) |
Siemens 4 series |
Siemens 11 series
"title": "3 series",
The Siemens 3 series is a series of conventional detectors originally introduced by Pyrotronics.
| Model | Special feature | Replaced | Replaced by |
| DI-3[1] | None | ||
| DI-3IS | Intrinsically safe | ||
| DI-3H | High altitude | ||
| DI-A3 | High air velocity | ||
| DI-A3H | High altitude High air velocity |
| DI-B3 | Duct use only | ||
| DI-B3H | Duct use only High altitude |
| Model | Heat sensor? | Replaced | Replaced by |
| PE-3[2] | No | ||
| PE-3T | Yes |
| Model | Replaced | Replaced by |
| DT-3P-135[3] |
Mounting bases
| Model | Type | Replaced | Replaced by |
| DB-3S | Low profile | ||
| ADB-3 | Audible | ||
| AD-3I | Duct housing | ||
| AD-3ILP[4] | Duct housing | ||
| SA-3I | Duct housing | ||
| SA-3P | Duct housing |
After Pyrotronics acquired Faraday, Faraday started rebranding 3 series devices as part of the 8900 series.
- ↑ https://web.archive.org/web/19971112113534/http://www.cerbpyro.com/6119.pdf
- ↑ https://web.archive.org/web/19971112113759/http://www.cerbpyro.com/6160.pdf
- ↑ https://web.archive.org/web/19971112113721/http://www.cerbpyro.com/6132.pdf
- ↑ https://web.archive.org/web/19971112113940/http://www.cerbpyro.com/6124.pdf
