Notifier AFP series
| Communication protocol |
CLIP
1992
2007-2008
Notifier FireWarden series |
"title": "AFP series",
The Notifier AFP series is a series of addressable FACPs.
The AFP-1010 was introduced in early 1992 as a cheaper alternative to the AM-2020.[1] The AFP-1010 used the same LIB-200 SLC interface modules as the AM-2020.
Later in 1992, the AFP-200 was introduced as a smaller alternative to the AFP-1010 with one built-in SLC.[2]
The AFP-400 was introduced in 1996 with 2 built-in SLCs.[3] The AFP-400 could also be used with the conventional System 5000 modules.[4]
The AFP-300 was introduced around 1997 as a single-SLC version of the AFP-400.[5] Like the AFP-400, the AFP-300 could be used with System 5000 modules. The AFP-1010 was also expanded to support 4 SLCs around this time.
In 1999, the AFP-100 was introduced.[6] The AFP-100 was a rebranded Fire-Lite MS-9200.
In November 2006, all AFP panels except the AFP-200 were discontinued.[7] The AFP-200 was discontinued between 2007 and 2008.[8]
| Model | Maximum SLCs | Built-in NACs | Built-in programmable relays | System 5000 modules | Replaced by |
| AFP-100 | 1 | 2 | 0 | 0 | NFW2-100 |
| AFP-200 | 1 | 4 | 99 | 0 | NFS2-640 |
| AFP-300 | 1 | 4 | 0 | 8 | NFS-640 |
| AFP-400 | 2 | 4 | 0 | 8 | NFS-640 |
| AFP-1010 | 2 (first version) 4 (second version) |
0 | 0 | 0 | NFS2-3030 |
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_8e5694bf-26f2-4c75-b9ef-4cf875e79ff1/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_2bc3b977-e857-49b8-9316-374219a0b9e8/
- ↑ https://nfpa.access.preservica.com/uncategorized/IO_4da60699-26e2-4e5a-9353-a5cb0f961f3c/
- ↑ https://web.archive.org/web/20060906153432/http://www.notifier.com/products/datasheets/Dn_5262.pdf
- ↑ https://web.archive.org/web/19980109155207/http://notifier.com/prodint.htm
- ↑ "US Product Line - Intelligent Systems" Notifier Fire Systems. Archive 1999-02-25 vs. 1999-04-30
- ↑ "NOTIFIER - Products - Control Panels" Notifier. Archive 2006-11-03 vs. 2006-11-12
- ↑ "NOTIFIER - Products - Control Panels" Notifier. Archive 2007-10-12 vs. 2008-05-17
