Wheelock CH series
(Redirected from Faraday CH series)
Wheelock CH series
Wheelock E70 and E90.jpg: Infobox image for Wheelock CH series the infobox device.
20-31VDC {"label": "Rated Voltage", "field": "20-31VDC"}
1984 {"label": "Introduced", "field": "1984"}
2023[1] {"label": "Discontinued", "field": "2023[1]"}
Wheelock 700 series {"label": "Preceded by", "field": "Wheelock 700 series"}
The Wheelock CH series is a series of electronic chimes and chime strobes.
The CH series was released in 1984 as an electronic successor to the 700 series.[2][3] Initial mounting options included a surface mounting option that most closely resembled the 712 series, as well as a wall flush mounting option and a ceiling flush mounting option.
The CH70 was released in 1997 as part of the SquareONE series, and the CH90 was released around this time. Both support universal mounting, and they use the same grille covers as the E70/E90, ET70/ET90, and SA-S.
In 2000, the CH70-24MCW was released as part of the SPEC1FIRE series of multi-candela appliances.[4][5] The CH90-24MCC was released in June 2003, and the corresponding single-candela models were discontinued in September 2003.[6] The CH70-MCWH and CH90-MCCH were released in September 2003 to provide high-candela options for the chime strobes.[7]
At the end of 2015, the CH70-241575W was discontinued, and consumers were instructed to instead use the CH70-24MCW.[8]
In 2019, the CH70 and CH90 chimes were updated to add a 2 Hz vibrating mode and a synchronizable Code 3 tone. The frequency was also locked to 890 Hz in this update.[9]
In 2023, the CH70 and CH90 were discontinued due to the release of the Eluxa ELCH and ELCHS, which contain the same chime functionality.
The first version of the CH70/CH90 could be set to single stroke or 1 Hz vibrating operation, with an adjustable frequency between 800 Hz and 1200 Hz and a maximum anechoic sound output of 83 dBA. Depending on the model, the strobe could be 15, 15/75, 30, 75, 95, 100, 110, 115, 135, 177, or 185 candela.
The 2019 version of the CH70/CH90 could be set to single stroke, synchronized Code 3, 1 Hz vibrating, or 2 Hz vibrating operation. The frequency was fixed at 890 Hz, but the volume was still adjustable.[9] Depending on the model, the strobe could be 15, 30, 75, 95, 110, 115, 135, 177, or 185 candela.
CH-BF series
Model Number Candela Mounting Replaces Replaced by
CH-BF2-R N/A Wall/Ceiling None None
CH-BF1-R N/A Wall/Ceiling 712P-24 None
CH-BF1-WS-24 1.5 Wall 712P-24+WS-24VDC None
CH-CF series
CH-CF2-W N/A Wall/Ceiling None None
CH-CF1-W N/A Wall/Ceiling None CH90-24-W
CH-CF1-LS-24-CFW[10] 15 Ceiling None None
CH-CF1-MS-24-CFW 30 Ceiling None None
CH-CF1-IS-24-CFW 75 Ceiling None CH90-2475C-FW
CH-DF series
CH-DF2-R N/A Wall/Ceiling None None
CH-DF2-WS-12 1.5 Wall None None
CH-DF1-R N/A Wall/Ceiling None CH70-24-R
CH-DF1-WS-24 1.5 Wall None CH-DF1-LS-24-VFR
CH-DF1-LS-24-VFR 15 Wall CH-DF1-WS-24 CH70-2415W-FR
CH-DF1-LSM-24-VFR 15/75 Wall None CH70-241575W-FR
CH-DF1-MS-24-VFR 30 Wall None CH70-2430W-FR
CH-DF1-IS-24-VFR 75 Wall None CH70-2475W-FR
CH70 series
Model Number Candela Mounting Color Lettering Replaces Replaced by
CH70-24-R N/A Wall/Ceiling Red None CH-DF1-R ELCHR
CH70-24-W N/A Wall/Ceiling White None None ELCHW
CH70-2415W-FR 15 Wall Red FIRE CH-DF1-LS-24-VFR CH70-24MCW-FR
CH70-2415W-FW 15 Wall White FIRE None CH70-24MCW-FW
CH70-241575W-FR 15/75 Wall Red FIRE CH-DF1-LSM-24-VFR CH70-24MCW-FR
CH70-241575W-FW 15/75 Wall White FIRE None CH70-24MCW-FW
CH70-2430W-FR 30 Wall Red FIRE CH-DF1-MS-24-VFR CH70-24MCW-FR
CH70-2475W-FR 75 Wall Red FIRE CH-DF1-IS-24-VFR CH70-24MCW-FR
CH70-24110W-FW 110 Wall White FIRE None CH70-24MCW-FW
CH70-24MCW-FR 15, 30, 75, 110 Wall Red FIRE CH70-2415W-FR
CH70-241575W-FR
CH70-2430W-FR
CH70-2475W-FR
ELCHSR
CH70-24MCW-FW 15, 30, 75, 110 Wall White FIRE CH70-2415W-FW
CH70-241575W-FW
CH70-24110W-FW
ELCHSW
CH70-24MCWH-FR 135, 185 Wall Red FIRE None ELCHSR
CH70-24MCWH-FW 135, 185 Wall White FIRE None ELCHSW
CH90 series
CH90-24-W N/A Wall/Ceiling White None CH-CF1-W ELCHWC
CH90-24-R N/A Wall/Ceiling Red None None ELCHRC
CH90-2475C-FW 75 Ceiling White FIRE CH-CF1-IS-24-CFW CH90-24MCC
CH90-24100C-FW 100 Ceiling White FIRE None CH90-24MCC
CH90-24MCC-FW 15, 30, 75, 95 Ceiling White FIRE CH90-2475C-FW
CH90-24100C-FW
ELCHSWC
CH90-24MCC-FR 15, 30, 75, 95 Ceiling Red FIRE None ELCHSRC
CH90-24MCCH-FW 115, 177 Ceiling White FIRE None ELCHSWC
71758[11] CH90-24-W CH90-24-W
71759 CH70-24-R CH70-24-R
72041[12] CH70-24MCW-FR CH70-24MCW-FR
72042 CH70-24MCW-FW CH70-24MCW-FW
71761 CH70-241575W-FR CH70-241575W-FR
Honeywell model Wheelock model Replaces Replaced by
SC715D1032[13] CH-BF1-WS-24
CS-15-R[14] CH-DF1-LS-24-VFR EC-S15-F
CS-15-W CH-DF1-LS-24-VFW
CS-15/75-R[15] CH-DF1-LSM-24-VFR EC-S17-F
CS-15/75-W CH-DF1-LSM-24-VFW
CS-30R CH-DF1-MS-24-VFR
CS-30W CH-DF1-MS-24-VFW
CS-75R CH-DF1-IS-24-VFR EC-S75-F
CS-75W CH-DF1-IS-24-VFW
Siemens started rebranding the CH series around 2007 as a result of the Wheelock, Inc., v. Siemens Building Technologies, Inc. lawsuit that required the Siemens U series to be discontinued.
CH-R[16] CH70-24-R 5390-0-14-24-DC
G1R-C-LG
G1RF-C-LG
U-EC
SL2CHWR-F[17]
CH-W CH70-24-W 5390-0-21-24-DC
G1-C-LG
G1F-C-LG
U-EC-W
SL2CHWW-F
CH-CW CH90-24-W 5395-0-21-24-DC
U-EC-C
SL2CHCW-F[18]
CH-MC-R CH70-24MCW-FR 5394-14-24
G1R-CVM-LG
G1RF-CVM-LG
U-EC-MCS
SL2CHSWR-F
CH-MC-W CH70-24MCW-FW 5394-21-24
G1-CVM-LG
G1F-CVM-LG
U-EC-MCS-W
SL2CHSWW-F
CH-MC-CR CH90-24MCC-FR None SL2CHSCR-F
CH-MC-CW CH90-24MCC-FW 5398-21-24
U-EC-MCS-C
SL2CHSCW-F
CH-HMC-CW CH90-24MCCH-FW None SL2CHSCW-F
  1. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/Xenon%20Tube%20Cessation.pdf
  2. https://nfpa.access.preservica.com/uncategorized/IO_3307fa47-0017-46f2-b0a2-04079626809b/
  3. https://nfpa.access.preservica.com/uncategorized/IO_4aa4d521-f84e-4ef4-8308-588221a0b171/
  4. https://nfpa.access.preservica.com/uncategorized/IO_fc6eeb17-a4c8-46a3-a2e7-c0f9b50a4d89/
  5. https://web.archive.org/web/20000817060745/http://www.wheelockinc.com/Selection_Frames/frames/MultiCandela.htm
  6. https://web.archive.org/web/20061108090040/http://www.cooperwheelock.com/literature/prod_repl_shed.pdf
  7. https://web.archive.org/web/20061108085957/http://www.cooperwheelock.com/literature/sep03_prod_replace.pdf
  8. https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/product-discontinuation/wheelock-ps-amt-ch-e-et-hs4-mt-rss-product-discontinuation-notice.pdf
  9. 9.0 9.1 https://www.eaton.com/content/dam/eaton/products/safety-security-emergency-communications/lsmns/wheelock/ch/wheelock-ch-chimes-data-sheet-TD450151EN.pdf
  10. https://web.archive.org/web/19970214013441fw_/http://www.wheelockinc.com/CH/ch2.html
  11. https://web.archive.org/web/20030407055354/http://gamewell.com/pdf/datasheets/CS-2239.pdf
  12. https://web.archive.org/web/20030408174516/http://gamewell.com/pdf/datasheets/CS-2245.pdf
  13. https://firealarms.tv/collection/honeywell-sc71501302/
  14. "Compatible Notification Appliances" (315-096363-7). Siemens Building Technologies, Inc..
  15. https://www.youtube.com/watch?v=jGyYZM8Vn1s
  16. https://cache.industry.siemens.com/dl/files/521/109787521/att_1044275/v1/A6V10238708.pdf
  17. https://cache.industry.siemens.com/dl/files/013/109823013/att_1149028/v2/A6V14140221.pdf
  18. https://cache.industry.siemens.com/dl/files/012/109823012/att_1149027/v2/A6V14140220.pdf
