Simplex 2098 series
The Simplex 2098 series is a series of conventional smoke detectors with 2 or 4 conventional/addressable bases, beam detectors, heat detectors, and remote test stations/LEDs manufactured by Simplex.
Simplex 2098 series
Simplex {"label": "Manufacturer", "field": "Simplex"}
24VDC / 28VDC
120VAC {"label": "Rated Voltage", "field": "24VDC / 28VDC
120VAC"}
Communication protocol
MAPNET I (addressable bases only)
MAPNET II (addressable bases only) {"label": "Communication protocol", "field": "MAPNET I (addressable bases only)
MAPNET II (addressable bases only)"}
Simplex 4250/60 series {"label": "Preceded by", "field": "Simplex 4250/60 series"}
Simplex 4098 series {"label": "Succeeded by", "field": "Simplex 4098 series"}
Ionization Smoke Detectors
Model Voltage OEM OEM Model Modication Replaced Replaced By
2098-9110[1] 24VDC System Sensor 1400 Simplex logo
2098-9130[2] 24VDC Hochiki N/A
2098-9508[3] 24VDC Hochiki PID-C2 Simplex logo 4262-20 2098-9544
2098-9544[3] 24VDC Hochiki SIF-24 Simplex logo 2098-9508 2098-9576
2098-9560[4] 24VDC Fenwal N/A
2098-9575 24VDC BRK Simplex logo
2098-9576 24VDC Hochiki SIH-24F N/A 2098-9544
2098-9577 24VDC System Sensor 1400 Simplex logo
Photoelectric Smoke Detectors
Model Voltage OEM OEM Model Modification Replaced Replaced By
2098-9201 24VDC Hochiki N/A 2098-9636
2098-9202 24VDC Hochiki SLK-24FH N/A 2098-9642
2098-9203 24VDC Hochiki N/A 2098-9636
2098-9208[5] 24VDC Matsushita[4] N/A
2098-9209 24VDC Matsushita[4] N/A
2098-9602 24VDC Fenwal N/A
2098-9603 24VDC Hochiki PED-C Simplex logo 2098-9635
2098-9604[6] 24VDC Fenwal N/A
2098-9635[3] 24VDC Hochiki SLG-24 Simplex logo 2098-9603 2098-9636
2098-9636[3] 24VDC Hochiki SLG-24F Simplex logo 2098-9635 2098-9201 / 2098-9203
2098-9642[3] 24VDC Hochiki SLG-24FH N/A 2098-9202
2098-9647[3] 24VDC Hochiki SLG-24F Simplex logo 2098-9201 / 2098-9203
2098-9648 24VDC Hochiki AL-HADH + SLG-24FDH[7] Simplex logo
2098-9669[4] 120VAC Gentex
2098-9673[4] 120VAC Gentex
2098-9674[4] 120VAC Gentex
2098-9675[4] 120VAC Gentex
Beam Detectors
2098-9207[8] 24VDC Detection Systems[4] Simplex logo
Heat Detectors
Model Voltage Rating OEM OEM Model Modification Replaced Replaced By
2098-9400[4] 24VDC / 120VAC 136°F Fixed and Rate of Rise Chemetron[4] N/A 4255-1
2098-9401[4] 24VDC / 120VAC 190°F Fixed and Rate of Rise Chemetron N/A 4255-2
2098-9402[4] 24VDC / 120VAC 136°F Fixed Only Chemetron N/A 4255-3
2098-9403[4] 24VDC / 120VAC 190°F Fixed Only Chemetron N/A 4255-4
2098-9430[4] 24VDC / 120VAC 136°F Fixed and Rate of Rise Chemetron N/A 4256-1
2098-9431[4] 24VDC / 120VAC 136°F Fixed and Rate of Rise Chemetron N/A 4256-2
2098-9432[4] 24VDC / 120VAC 190°F Fixed and Rate of Rise Chemetron N/A 4256-3
2098-9433[4] 24VDC / 120VAC 190°F Fixed and Rate of Rise Chemetron N/A 4256-4
2098-9434[4] 24VDC / 120VAC 135°F Fixed Only Chemetron N/A 4256-5
2098-9435[4] 24VDC / 120VAC 135°F Fixed Only Chemetron N/A 4256-6
2098-9436[4] 24VDC / 120VAC 190°F Fixed Only Chemetron N/A 4256-7
2098-9437[4] 24VDC / 120VAC 190°F Fixed Only Chemetron N/A 4256-8
2098-9438[4] 24VDC 135°F Fixed and Rate of Rise Hochiki N/A
2098-9439[4] 24VDC / 120VAC 135°F Fixed and Rate of Rise Chemetron N/A
2098-9440[4] 24VDC / 120VAC 200°F Fixed and Rate of Rise Chemetron N/A
2098-9441[4] 24VDC / 120VAC 135°F Fixed Only Chemetron N/A
2098-9442[4] 24VDC / 120VAC 200°F Fixed Only Chemetron N/A
2098-9443[4] 24VDC / 120VAC 135°F Fixed and Rate of Rise Chemetron N/A
2098-9444[4] 24VDC / 120VAC 200°F Fixed and Rate of Rise Chemetron N/A
2098-9445[4] 24VDC / 120VAC 135°F Fixed Only Chemetron N/A
2098-9446[4] 24VDC / 120VAC 200°F Fixed Only Chemetron N/A
2098-9460[4] 24VDC / 120VAC 135°F Fixed Only Chemetron N/A 4265-135
2098-9461[4] 24VDC / 120VAC 200°F Fixed Only Chemetron N/A 4265-200
2098-9462[4] 24VDC / 120VAC 135°F Fixed Only Chemetron N/A 4266-135
2098-9463[4] 24VDC / 120VAC 200°F Fixed Only Chemetron N/A 4266-200
2098-9464[4] 24VDC / 120VAC 135°F Fixed and Rate of Rise Edwards N/A 4255-5
2098-9478[4] 24VDC 135°F Fixed Only Hochiki N/A
Remote Test Stations/Indicators
Model Number Voltage Type Replaced Replaced By
2098-9784[4] 28VDC Remote LED indicator
2098-9786 24VDC Remote test station with LED indicator
2098-9805[4] 28VDC Remote test station with LED indicator
2098-9806 28VDC Remote test station with LED indicator
2098-9808 24VDC Remote LED indicator
2098-9816[4] 24VDC Remote test station with LED indicator
