Potter Select-A series
Select-A series
POTTER-SL24W-1530-Select-A-Strobe-Owners-Manual-7.png: Infobox image for Select-A series the infobox device.
Amseco
Potter Electric Signal Company, LLC {"label": "Manufacturer", "field": "Amseco
Potter Electric Signal Company, LLC"}
1998 {"label": "Introduced", "field": "1998"}
The Potter Select-A series was a series of notification appliances originally introduced by Amseco.
The Select-A-Strobe series was introduced in 1998 with SAD remote strobes and RSD add-on strobes that were mounted similar to the Federal Signal Visalert series.[1] The original strobes were available either with selectable 15/75 or 30/150 candela, or with fixed 110 candela. The RSD strobes were also sold pre-assembled with horns such as the BZ-54.
In 1999, Amseco introduced a new family of strobes, horns, and horn strobes similar to the System Sensor SpectrAlert series.[2] The strobes could be selected for 15/75 or 30/120 candela, and the horns could be selected for an electromechanical or 3000 Hz tone. This new line of devices was mounted to a universal mounting plate.
In 2001, Amseco introduced the SLW24-75110 and SHW24-75110 models as a higher candela version of the SLW24-153075 and SHW24-153075 respectively.[3]
Model Voltage Tones Color Replaced Replaced by
H24WR[4] 24 VDC Electromechanical, 3000 Hz
Low volume, high volume
Non-temporal, temporal 3
Red H-1224R
H24WW White H-1224W
CM24WR[5] 2700 Hz, 2400 Hz
Red H-1224R
CM24WW White H-1224W
H-1224R[6] 12 VDC, 24 VDC 2400 Hz, electromechanical, broadband, chime
Low volume, mid volume, high volume
Non-temporal, temporal 3, march time
Red CM24WR
H24WR
EH-24R
H-1224W White CM24WW
H24WW
EH-24W
Model Voltage Candela Lens color Wall/ceiling Housing color Replaced Replaced by
SAD24-153075R[7] 24 VDC 15/75, 30/120 Clear Wall/ceiling Red SL24W-1530R
SAD24-153075W White SL24W-1530W
SAD24-110R 110 Red SL24R-75110R
SAD24-110W White SL24W-75110W
SL24W-1530R[8] 16-33 VDC 15/75, 30/75 Wall Red SAD24-153075R SL-1224R
SL24W-1530W White SAD24-153075W SL-1224W
SL24W-75110R[9] 75, 110 Red SAD24-110R SL-1224R
SL24W-75110W White SAD24-110W SL-1224W
CSL24W-AR[10] 24 VDC 75, 145 Amber Red CSL-1224W-AR
CSL24W-AW White CSL-1224W-AW
CSL24W-BR 40, 79 Blue Red CSL-1224W-BR
CSL24W-BW White CSL-1224W-BW
CSL24W-GR 79, 154 Green Red CSL-1224W-GR
CSL24W-GW White CSL-1224W-GW
CSL24W-RR 35, 68 Red Red CSL-1224W-RR
CSL24W-RW White CSL-1224W-RW
CSL24W-WR 27, 53 White Red
CSL24W-WW White
SL24C-3075110R[11] 16-33 VDC 30, 75, 110 Clear Wall/ceiling Red CS-24R
SL24C-3075110W White CS-24W
SL24C-177R[12] 177 Red
SL24C-177W White
CSL24C-AR[13] 30, 54, 76 Amber Red CCS-24AR
CSL24C-AW White CCS-24AW
CSL24CH-AR[14] 24 VDC 138 Red CCS-24AR
CSL24CH-AW White CCS-24AW
CSL24C-BR 16-33 VDC 16, 29, 41 Blue Red CCS-24BR
CSL24C-BW White CCS-24BW
CSL24CH-BR 24 VDC 74 Red CCS-24BR
CSL24CH-BW White CCS-24BW
CSL24C-GR 16-33 VDC 32, 57, 80 Green Red CCS-24GR
CSL24C-GW White CCS-24GW
CSL24CH-GR 24 VDC 145 Red CCS-24GR
CSL24CH-GW White CCS-24GW
CSL24C-RR 16-33 VDC 14, 25, 35 Red Red CCS-24RR
CSL24C-RW White CCS-24RW
CSL24CH-RR 24 VDC 65 Red CCS-24RR
CSL24CH-RW White CCS-24RW
CSL24CH-WR 138 White Red
CSL24CH-WW White
SL-1224R[15] 12 VDC, 24 VDC 15, 35, 60/75, 75, 95, 110 Clear Wall Red SL24W-1530R
SL24W-75110R
S-24WR
SL-1224W White SL24W-1530W
SL24W-75110W
S-24WW
SL-1224WP-R[16] Red S-24WR-WP
SLP-24WR-WP
SL-1224WP-W White S-24WW-WP
SLP-24WW-WP
CSL-1224W-AR[17] 14, 37, 49, 69, 83, 99 Amber Red CSL24W-AR CS-24WAR
CSL-1224W-AW White CSL24W-AW CS-24WAW
CSL-1224W-BR 10, 20, 28, 41, 51, 58 Blue Red CSL24W-BR CS-24WBR
CSL-1224W-BW White CSL24W-BW CS-24WBW
CSL-1224W-GR 13, 39, 50, 77, 94, 109 Green Red CSL24W-GR CS-24WGR
CSL-1224W-GW White CSL24W-GW CS-24WGW
CSL-1224W-RR 7, 17, 18, 28, 35, 38 Red Red CSL24W-RR CS-24WRR
CSL-1224W-RW White CSL24W-RW CS-24WRW
Horn strobes
Model Voltage Tones Candela Lens color Wall/ceiling Housing color Replaced Replaced by
SH24W-1530R[18] 24 VDC Electromechanical, 3000 Hz
15, 30 Clear Wall Red SH-1224R
SH24W-1530W White SH-1224W
SH24W-75110R[19] 75, 110 Red SH-1224R
SH24W-75110W White SH-1224W
CSH24W-AR[20] 75, 145 Amber Red CSH-1224W-AR
CSH24W-AW White CSH-1224W-AW
CSH24W-BR 40, 79 Blue Red CSH-1224W-BR
CSH24W-BW White CSH-1224W-BW
CSH24W-GR 79, 154 Green Red CSH-1224W-GR
CSH24W-GW White CSH-1224W-GW
CSH24W-RR 35, 68 Red Red CSH-1224W-RR
CSH24W-RW White CSH-1224W-RW
SH24C-3075110R[21] 30, 75, 110 Clear Wall/ceiling Red CHS-24R
SH24C-3075110W White CHS-24W
SH24C-177R[22] 177 Red
SH24C-177W White
CSH24C-AR[23] 30, 54, 76 Amber Red CCHS-24AR
CSH24C-AW White CCHS-24AW
CSH24CH-AR[24] 138 Red CCHS-24AR
CSH24CH-AW White CCHS-24AW
CSH24C-BR 16, 29, 41 Blue Red CCHS-24BR
CSH24C-BW White CCHS-24BW
CSH24CH-BR 74 Red CCHS-24BR
CSH24CH-BW White CCHS-24BW
CSH24C-GR 32, 57, 80 Green Red CCHS-24GR
CSH24C-GW White CCHS-24GW
CSH24CH-GR 145 Red CCHS-24GR
CSH24CH-GW White CCHS-24GW
CSH24C-RR 14, 25, 35 Red Red CCHS-24RR
CSH24C-RW White CCHS-24RW
CSH24CH-RR 65 Red CCHS-24RR
CSH24CH-RW White CCHS-24RW
CSH24C-WR 30, 54, 76 White Red
CSH24C-WW White
CSH24CH-WR 138 Red
CSH24CH-WW White
SCM24W-153075R[25] 2700 Hz, 2400 Hz
15/75, 30/75 Clear Wall Red SH-1224R
SCM24W-153075W White SH-1224W
SCM24W-75110R[26] 75, 110 Red SH-1224R
SCM24W-75110W White SH-1224W
SH-1224R[27] 12 VDC, 24 VDC 2400 Hz, electromechanical, broadband, chime
15, 35, 60/75, 75, 95, 110 Red SCM24W-153075R
SCM24W-75110R
SH24W-1530R
SH24W-75110R
HS-24WR
SH-1224W White SCM24W-153075W
SCM24W-75110W
SH24W-1530W
SH24W-75110W
HS-24WW
SH-1224WP-R[28] Red HS-24WR-WP
HSLP-24WR
CSH-1224W-AR[29] 14, 37, 49, 69, 83, 99 Amber Red CSH24W-AR CHS-24AR
CSH-1224W-AW White CSH24W-AW CHS-24AW
CSH-1224W-BR 10, 20, 28, 41, 51, 58 Blue Red CSH24W-BR CHS-24BR
CSH-1224W-BW White CSH24W-BW CHS-24BW
CSH-1224W-GR 13, 39, 50, 77, 94, 109 Green Red CSH24W-GR CHS-24GR
CSH-1224W-GW White CSH24W-GW CHS-24GW
CSH-1224W-RR 7, 17, 18, 28, 35, 38 Red Red CSH24W-RR CHS-24RR
CSH-1224W-RW White CSH24W-RW CHS-24RW
SH-120R[30] 108-132 VAC 2400 Hz, electromechanical, broadband
Steady or temporal
90 (UL 1638) Clear Red Still in production
SH-120W White Still in production
Bell strobes
Model Voltage Gong size Candela Housing color Replaced Replaced by
SB624-153075[31] 24 VDC 6" 15, 30 Red
SB824-153075 8"
SB1024-153075 10"
Retrofit strobes
Model Type Voltage Candela Housing color Replaced Replaced by
RSD24-153075R[32] Add-on strobe 24 VDC 15/75, 30/120 Red
RSD24-153075W White
RSD24-110R 110 Red
RSD24-110W White
SB24-1530R[33] Signal cover 15, 30 Red
SB24-75110R 75, 110
Mircom
Mircom model Potter model Replaced Replaced by
FH-340R[34] H-1224R FH-400-RR
FH-400-RR-WP
FH-340W H-1224W FH-400-WW
FS-340R[35] SL-1224R FS-400-RR
FS-340W SL-1224W FS-400-WW
FS-340R-WP[36] SL-1224WP-R FS-400-RR-WP
FHS-340R[37] SH-1224R FHS-400-RR
FHS-340W SH-1224W FHS-400-WW
FHS-340R-WP[38] SH-1224WP-R FHS-400-RR-WP
  1. https://nfpa.access.preservica.com/uncategorized/IO_d18987cf-4b70-455e-a984-a2b260559aa4/
  2. https://nfpa.access.preservica.com/uncategorized/IO_37fd50d2-06eb-4117-bdbc-b525cbb57fb9/
  3. "Fire Signaling Devices Spec Sheets" Amseco. Archive 2001-03-02 vs. 2001-04-01
  4. "H24W SELECT-A-HORN SERIES" (8850050). Amseco (April 2007).
  5. "CM24W SELECT-A-CHIME HORN" (8850024). Amseco (May 2006).
  6. "H-1224 SERIES INDOOR/OUTDOOR SELECT-A-HORN" (8910006). Potter (July 2010).
  7. https://web.archive.org/web/20001029022418fw_/http://amseco-kai.com/specs/sad24.htm
  8. "SL24W-1530 SELECT-A-STROBE" (8850010). Amseco (September 2007).
  9. "SL24W-75110 SELECT-A-STROBE" (8850014). Amseco (September 2007).
  10. "CSL24W Colored Light Strobe Series Select-A-Strobe®" (CSL24W). Amseco (October 2004).
  11. "SL24C-3075110 Ceiling and Wall Mount Select-A-Strobe" (SL24C-3075110). Amseco (February 2003).
  12. "SL24C-177 CEILING AND WALL MOUNT SELECT-A-STROBE®" (8850023). Potter (July 2010).
  13. "CSL24C SERIES COLORED SELECT-A-STROBE" (8850039). Potter (June 2010).
  14. "CSL24CH Colored Light Strobe Series High Candela" (CSL24CH). Amseco (October 2004).
  15. "SL-1224 SERIES WALL MOUNT SELECT-A-STROBE®" (8910002). Potter (July 2010).
  16. "SL-1224WP SERIES WALL MOUNT WEATHER PROOF SELECT-A-STROBE®" (8910007). Potter (July 2010).
  17. "CSL-1224W SERIES WALL MOUNT MASS NOTIFICATION STROBE" (8910011). Potter (June 2010).
  18. "SH24W-1530 SELECT-A-STROBE/HORN COMBINATION" (8850011). Amseco (September 2007).
  19. "SH24W-75110 SELECT-A-STROBE/HORN COMBINATION" (8850015). Amseco (September 2007).
  20. "CSH24W SELECT-A-STROBE/HORN COLORED LIGHT SERIES" (8850036). Amseco (September 2007).
  21. "SH24C-3075110 Ceiling and Wall Mount Select-A-Horn/Strobe Combination" (SH24C-3075110). Amseco (February 2003).
  22. "SH24C-177 SELECT-A-STROBE/HORN®" (8850021). Potter (July 2010).
  23. "CSH24C Colored Light Strobe Series Select-A-Strobe/Horn®" (CSH24C). Amseco (October 2004).
  24. "CSH24CH Colored Light Strobe/Horn Series High Candela" (CSH24CH). Amseco (October 2004).
  25. "SCM24W-153075 SELECT-A-STROBE/ CHIME COMBINATION" (8850025). Amseco (September 2007).
  26. "SCM24W-75110 SELECT-A-STROBE/CHIME COMBINATION" (8850026). Amseco (May 2006).
  27. "SH-1224 SERIES WALL MOUNT SELECT-A-STROBE/HORN®" (8910004). Potter (July 2010).
  28. "SH-1224WP SERIES WALL MOUNT WEATHER PROOF SELECT-A-STROBE/HORN®" (8910008). Potter (December 2017).
  29. "CSH-1224W SERIES WALL MOUNT MASS NOTIFICATION STROBE/HORN" (8910012). Potter (June 2010).
  30. "SH-120 SERIES WALL MOUNT WEATHER PROOF SELECT-A-STROBE/HORN®" (8910015). Potter (November 2021).
  31. "SB24 BELL STROBE SERIES BELL/SELECT-A-STROBE COMBINATION" (8850042). Amseco (May 2006).
  32. https://web.archive.org/web/20001029013920fw_/http://amseco-kai.com/specs/rsd24.htm
  33. "SB24 SERIES SELECT-A-STROBE" (5401400). Amseco (September 2007).
  34. "FH-340 SERIES" (5267). Mircom.
  35. "FS-340 SERIES" (5268). Mircom.
  36. https://web.archive.org/web/20130704015016/http://www.mircom.com/products/details/2064/67/fire/signaling/output-devices/horns-&-strobes/fs-340r-wp-wall-mount-weatherproof-strobe.html
  37. "FHS-340 SERIES" (5269). Mircom.
  38. "FHS-340R-WP" (5271). Mircom.
