Gentex HG series
HG Series
GentexSHGHG.gif: Infobox image for HG Series the infobox device.
Gentex {"label": "Manufacturer", "field": "Gentex"}
Red, Beige & White {"label": "Color(s)", "field": "Red, Beige & White"}
Commander series {"label": "Succeeded by", "field": "Commander series"}
The Gentex HG and SHG series of horns and horn strobes was a lineup of electronic horns designed by Gentex and released in 1992. Initially the horns came in continuous and march time tones. The strobes on the original SHG had no reflectors, and instead had a strobe lens that featured magnifiers. These strobes pre-dated ADA requirements. Around 1993, Gentex updated the flash tube circuit to meet ADA requirements, however the strobe was still using the older no-reflector design. In 1994, they were redesigned to have a reflector behind the xenon strobe to be up to ADA requirements. All 15, 30, 60 & 110CD models had fully ridged strobes while 15/75 & 30/75 models had no ridges. Around 1997 the horn was remade to have a more Commander 2, 3 & 4 sound to it while it still had the self coded march time. In 1998, they changed the self coded tone to have a Temporal/Code 3 sound to it. The 1997-2001 SHGs for all 15, 30, 60 & 110CD models still had completely ridged strobes to disperse light while the 15/75 & 30/75CD models only had ridges at the top and bottom of the strobe or left and right if you viewed the strobe horizontally. 1998 was also when Gentex released synchronized strobes and were only available in 15/75 candela. In around 2000–01 Gentex added candela indicators at the bottom of the strobe to give clear indications of what candela the strobe is.
First Generation (1992-1993)
Model Voltage Candela Mounting Lettering Color
HG124R 10-16 VDC & 21-30 VDC N/A Wall/ceiling None Red
HG124B 10-16 VDC & 21-30 VDC N/A Wall/ceiling None Beige
SHG-12-LW 10-16 VDC 17.8 Wall FIRE Red
SHG-12-LWB 10-16 VDC 17.8 Wall FIRE Beige
SHG-12-LC 10-16 VDC 17.8 Ceiling None Red
SHG-12-LCB 10-16 VDC 17.8 Ceiling None Beige
SHG-12-HW 10-16 VDC 100 Wall FIRE Red
SHG-12-HWB 10-16 VDC 100 Wall FIRE Beige
SHG-12-HC 10-16 VDC 100 Ceiling None Red
SHG-12-HCB 10-16 VDC 100 Ceiling None Beige
SHG-24-LW 21-30 VDC 17.8 Wall FIRE Red
SHG-24-LWB 21-30 VDC 17.8 Wall FIRE Beige
SHG-24-LC 21-30 VDC 17.8 Ceiling None Red
SHG-24-LCB 21-30 VDC 17.8 Ceiling None Beige
SHG-24-HW 21-30 VDC 100 Wall FIRE Red
SHG-24-HWB 21-30 VDC 100 Wall FIRE Beige
SHG-24-HC 21-30 VDC 100 Ceiling None Red
SHG-24-HCB 21-30 VDC 100 Ceiling None Beige
Second Generation (1994-1996)
SHG12-15-1WR 10-16 VDC 15 Wall FIRE Red
SHG12-15-1WB 10-16 VDC 15 Wall FIRE Beige
SHG12-15-1PWR 10-16 VDC 15 Wall None Red
SHG12-15-1PWB 10-16 VDC 15 Wall None Beige
SHG12-15/75WR 10-16 VDC 15/75 Wall FIRE Red
SHG12-15/75WB 10-16 VDC 15/75 Wall FIRE Beige
SHG12-15/75PWR 10-16 VDC 15/75 Wall None Red
SHG12-15/75PWB 10-16 VDC 15/75 Wall None Beige
SHG12-15/75CR 10-16 VDC 15/75 Ceiling FIRE Red
SHG12-15/75CB 10-16 VDC 15/75 Ceiling FIRE Beige
SHG12-15/75PCR 10-16 VDC 15/75 Ceiling None Red
SHG12-15/75PCB 10-16 VDC 15/75 Ceiling None Beige
SHG24-15-1WR 21-30 VDC 15 Wall FIRE Red
SHG24-15-1WB 21-30 VDC 15 Wall FIRE Beige
SHG24-15-1PWR 21-30 VDC 15 Wall None Red
SHG24-15-1PWB 21-30 VDC 15 Wall None Beige
SHG24-15/75WR 21-30 VDC 15/75 Wall FIRE Red
SHG24-15/75WB 21-30 VDC 15/75 Wall FIRE Beige
SHG24-15/75PWR 21-30 VDC 15/75 Wall None Red
SHG24-15/75PWB 21-30 VDC 15/75 Wall None Beige
SHG24-15/75CR 21-30 VDC 15/75 Ceiling FIRE Red
SHG24-15/75CB 21-30 VDC 15/75 Ceiling FIRE Beige
SHG24-15/75PCR 21-30 VDC 15/75 Ceiling None Red
SHG24-15/75PCB 21-30 VDC 15/75 Ceiling None Beige
SHG24-30-1WR 21-30 VDC 30 Wall FIRE Red
SHG24-30-1WB 21-30 VDC 30 Wall FIRE Beige
SHG24-30-1PWR 21-30 VDC 30 Wall None Red
SHG24-30-1PWB 21-30 VDC 30 Wall None Beige
SHG24-30/75WR 21-30 VDC 30/75 Wall FIRE Red
SHG24-30/75WB 21-30 VDC 30/75 Wall FIRE Beige
SHG24-30/75PWR 21-30 VDC 30/75 Wall None Red
SHG24-30/75PWB 21-30 VDC 30/75 Wall None Beige
SHG24-30/75CR 21-30 VDC 30/75 Ceiling FIRE Red
SHG24-30/75CB 21-30 VDC 30/75 Ceiling FIRE Beige
SHG24-30/75PCR 21-30 VDC 30/75 Ceiling None Red
SHG24-30/75PCB 21-30 VDC 30/75 Ceiling None Beige
SHG24-60-1WR 21-30 VDC 60 Wall FIRE Red
SHG24-60-1WB 21-30 VDC 60 Wall FIRE Beige
SHG24-60-1PWR 21-30 VDC 60 Wall None Red
SHG24-60-1PWB 21-30 VDC 60 Wall None Beige
SHG24-110-1WR 21-30 VDC 110 Wall FIRE Red
SHG24-110-1WB 21-30 VDC 110 Wall FIRE Beige
SHG24-110-1PWR 21-30 VDC 110 Wall None Red
SHG24-110-1PWB 21-30 VDC 110 Wall None Beige
Third Generation (1997-2001)
Model Voltage Candela Strobe synchronization Mounting Lettering Color
HG124R[1] 10-16 VDC & 21-30 VDC N/A N/A Wall/ceiling None Red
HG124W 10-16 VDC & 21-30 VDC N/A N/A Wall/ceiling None White
SHG12-15WR 10-16 VDC 15 Free-run Wall FIRE Red
SHG12-15WW 10-16 VDC 15 Free-run Wall FIRE White
SHG12-15PWR 10-16 VDC 15 Free-run Wall None Red
SHG12-15PWW 10-16 VDC 15 Free-run Wall None White
SHG12-15/75WR 10-16 VDC 15/75 Free-run Wall FIRE Red
SHG12-15/75WW 10-16 VDC 15/75 Free-run Wall FIRE White
SHG12-15/75PWR 10-16 VDC 15/75 Free-run Wall None Red
SHG12-15/75PWW 10-16 VDC 15/75 Free-run Wall None White
SHG12-15/75CR 10-16 VDC 15/75 Free-run Ceiling FIRE Red
SHG12-15/75CW 10-16 VDC 15/75 Free-run Ceiling FIRE White
SHG12-15/75PCR 10-16 VDC 15/75 Free-run Ceiling None Red
SHG12-15/75PCW 10-16 VDC 15/75 Free-run Ceiling None White
SHG24-15WR 21-30 VDC 15 Free-run Wall FIRE Red
SHG24-15WW 21-30 VDC 15 Free-run Wall FIRE White
SHG24-15PWR 21-30 VDC 15 Free-run Wall None Red
SHG24-15PWW 21-30 VDC 15 Free-run Wall None White
SHG24-15/75WR 21-30 VDC 15/75 Free-run Wall FIRE Red
SHG24-15/75WW 21-30 VDC 15/75 Free-run Wall FIRE White
SHG24-15/75PWR 21-30 VDC 15/75 Free-run Wall None Red
SHG24-15/75PWW 21-30 VDC 15/75 Free-run Wall None White
SHG24-15/75CR 21-30 VDC 15/75 Free-run Ceiling FIRE Red
SHG24-15/75CW 21-30 VDC 15/75 Free-run Ceiling FIRE White
SHG24-15/75PCR 21-30 VDC 15/75 Free-run Ceiling None Red
SHG24-15/75PCW 21-30 VDC 15/75 Free-run Ceiling None White
SHG24-15/75WRZ 21-30 VDC 15/75 Synchronized Wall FIRE Red
SHG24-15/75WWZ 21-30 VDC 15/75 Synchronized Wall FIRE White
SHG24-15/75PWRZ 21-30 VDC 15/75 Synchronized Wall None Red
SHG24-15/75PWWZ 21-30 VDC 15/75 Synchronized Wall None White
SHG24-30WR 21-30 VDC 30 Free-run Wall FIRE Red
SHG24-30WW 21-30 VDC 30 Free-run Wall FIRE White
SHG24-30PWR 21-30 VDC 30 Free-run Wall None Red
SHG24-30PWW 21-30 VDC 30 Free-run Wall None White
SHG24-30/75WR 21-30 VDC 30/75 Free-run Wall FIRE Red
SHG24-30/75WW 21-30 VDC 30/75 Free-run Wall FIRE White
SHG24-30/75PWR 21-30 VDC 30/75 Free-run Wall None Red
SHG24-30/75PWW 21-30 VDC 30/75 Free-run Wall None White
SHG24-30/75CR 21-30 VDC 30/75 Free-run Ceiling FIRE Red
SHG24-30/75CW 21-30 VDC 30/75 Free-run Ceiling FIRE White
SHG24-30/75PCR 21-30 VDC 30/75 Free-run Ceiling None Red
SHG24-30/75PCW 21-30 VDC 30/75 Free-run Ceiling None White
SHG24-60WR 21-30 VDC 60 Free-run Wall FIRE Red
SHG24-60WW 21-30 VDC 60 Free-run Wall FIRE White
SHG24-60PWR 21-30 VDC 60 Free-run Wall None Red
SHG24-60PWW 21-30 VDC 60 Free-run Wall None White
SHG24-110WR 21-30 VDC 110 Free-run Wall FIRE Red
SHG24-110WW 21-30 VDC 110 Free-run Wall FIRE White
SHG24-110PWR 21-30 VDC 110 Free-run Wall None Red
SHG24-110PWW 21-30 VDC 110 Free-run Wall None White
