Gentex Commander5 series
Commander5 Series
Gentex Corporation {"label": "Manufacturer", "field": "Gentex Corporation"}
24 VDC {"label": "Rated Voltage", "field": "24 VDC"}
2026 {"label": "Introduced", "field": "2026"}
Gentex Commander series
Gentex SSPK series {"label": "Preceded by", "field": "Gentex Commander series
Gentex SSPK series"}
The Gentex Commander5 series is a series of notification appliances.
Model Color Lettering Replaced
GSR Red FIRE GCS24CR
GSPR Red None GCS24PCR
GSW White FIRE GCS24CW
GSPW White None GCS24PCW
GHSR Red FIRE GCC24CR
GHSPR Red None GCC24PCR
GHSW White FIRE GCC24CW
GHSPW White None GCC24PCW
National Time & Signal
National Time model Gentex model Replaced
SG-C5UF-HSZ[1] SG-C2HS1575Z
SG-C2HS177Z
SG-C3HSZ
SG-C4HSZ
SG-C5UF-NSZ SG-C2NS1575Z
SG-C2NS177Z
SG-C3NSZ
SG-C4NSZ
SG-C5UF-HSZ-WH SG-C2HS1575Z-WH
SG-C2HS177Z-WH
SG-C3HSZ-WH
SG-C4HSZ-WH
SG-C5UF-NSZ-WH SG-C2NS1575Z-WH
SG-C2NS177Z-WH
SG-C3NSZ-WH
SG-C4NSZ-WH
SG-C5UA-HSZ None
SG-C5UA-NSZ None
SG-C5UA-HSZ-WH None
SG-C5UA-NSZ-WH None
SG-C5UP-HSZ None
SG-C5UP-NSZ None
SG-C5UP-HSZ-WH None
SG-C5UP-NSZ-WH None
SG-CXUF-SSZ[2] SG-CXCLP-SSZ
SG-CXLPSSZ
SG-CXLPSS1575Z
SG-CXUF-SN None
SG-CXUF-SSZ-WH SG-CXCLP-SSZ-WH
SG-CXLPSSZ-WH
SG-CXLPSS1575Z-WH
SG-CXUF-SN-WH None
SG-CXUA-SSZ None
SG-CXUA-SN None
SG-CXUA-SSZ-WH None
SG-CXUA-SN-WH None
SG-CXUP-SSZ None
SG-CXUP-SN SG-CXLPSN
SG-CXUP-SSZ-WH None
SG-CXUP-SN-WH SG-CXLPSN-WH
