Bosch FPD-7024
Bosch FPD-7024
BoschFPD7024.png: Infobox image for Bosch FPD-7024 the infobox device.
Bosch {"label": "Manufacturer", "field": "Bosch"}
Series
Fire Series {"label": "Series", "field": "Fire Series"}
24VFWR {"label": "Rated Voltage", "field": "24VFWR"}
2007 {"label": "Introduced", "field": "2007"}
2021 {"label": "Discontinued", "field": "2021"}
Bosch D7024 {"label": "Succeeded by", "field": "Bosch D7024"}
The Bosch FPD-7024 is a hybrid Fire Alarm Control Panel. The panel comes with 4 onboard zones, and can be expanded to 8 with a FPC-7034, or an be used a addressable/intelligent panel with support for Bosch's MUX addressable devices using the FPE-7039. The FPD-7024 replaced the D7024 by adding several enhanced features. The Bosch FPD-7024 was discounted sometime around 2021 due to the lack of parts being available.
Variants
There are 2 variants of the FPD-7024. One has English text on the buttons and next to the LED's, and the other uses icons instead of English text. The ladder variant is mainly used in Latin America.
Specifications[1]
The Bosch FPD-7024 has 4-onboard zones, and can be expanded to 8-zones with the FPC-7034. A FPE-7039 can be used and allows for up to 219 addressable Bosch MUX devices. The panel has 2 on-board NAC's with a shared power of 4 amps and output voltage. The NAC's support Wheelock, Gentex, and System Sensor sync. The panel supports Remote NAC's. The panel has an onboard 2 line LCD and keypad, and can support 8 annunciators. The panels option bus has the same purpose as the SDI bus on Bosch and Radionics panels. The panel has 2-onboard phone lines.
Programing
Programming can be achieved either on board with the , over a modem and the onboard dialer, over IP using the IP module, or over the DX4010V2 USB/serial interface.
Differences from the D7024
The FPD-7024 includes a ground fault and supervisory LED, which the D7024 lacks. The FPD-7024 also has a slightly different firmware. The FPD-7024 has a Acknowledge key which the D7024 lacks. The FPD-7024 has terminal blocks compared to the non-removable terminals on the D7024. The FPD-7024 supports IP communication which the D7024 does not. Other then these differences and a few other minor differences, both panels are the same.
  • IP reporting available when using a Bosch B426 Ethernet Communication Module
  • Remote Programming via RPS
Resources
