List of Silent Knight Addersable Devices
This is a list of all Silent Knight addressable devices between all 3 protocols. Because each protocol is not cross compatible, this chart may also be helpful if swapping out devices between panels or protocols.
| Device Type | SD (Hochiki)
For use on any Silent Knight or Farenhyt addressable panel, mainly on older systems. (Series Discontinued) |
SK (System Sensor)
For use on newer Silent Knight Panels (made after circa 2010) that support SK Protocol and most IFP/Fryahient Panels that support SK Protocol, mainly on newer systems. |
IDP (System Sensor, IFP/Farenhyt Panels Only)
For use with Silent Knight/Farenhyt IFP Panels only when using IDP Protocol. |
| Single Action Pull Station | SD-500PS | SK-PULL-SA | IDP-PULL-SA |
| Dual Action Pull Station | SD-505PSDA | SK-PULL-DA | IDP-PULL-DA |
| Dry Contact Single Input Module | SD500-AIM | SK-MONITOR | IDP-MONITOR |
| Dry Contact Dual Input Module | N/A | SK-MONITOR-2 | IDP-MONITOR-2 |
| Dry Contact 10 Input Module | N/A | SK-MON-10 | IDP-MON-10 |
| Mini Single Contact Input Module | SD500-MIM | SK-MINIMON | IDP-MINIMON |
| Dry Contact Single Relay Module | SD500-ARM | SK-RELAY | IDP-RELAY |
| Form C 6 Relay Module | N/A | SK-RELAY-6 | IDP-RELAY-6 |
| Single Notification Appliance Control | SD500-ANM | SK-CONTROL | IDP-CONTROL |
| 6 Notification Appliance Control | N/A | SK-CONTROL-6 | IDP-CONTROL-6 |
| 2-wire zone interface module | SD500-SDM | SK-ZONE | IDP-ZONE |
| SLC Isolator | SD500-LIM | SK-ISO | IDP-ISO |
| LED Annunciator Driver | SD-500LED | No Addressable Equivalent (Use Silent Knight 5880) | No Addressable Equivalent (Use Silent Knight 5880) |
| Duct Detector Test Switch | SD505-DTS-2 | No Addressable Equivalent (Use System Sensor Key-switch connected directly to duct board) | No Addressable Equivalent (Use System Sensor Key-switch connected directly to duct board) |
| Photoelectric Smoke Detector (White) | SD505-PHOTO | SK-PHOTO-W | IDP-PHOTO-W |
| Photoelectric Smoke Detector (Ivory) | SD505-APS | SK-PHOTO-IV | IDP-PHOTO-IV |
| Ionization Smoke Detector (White) | N/A | SK-ION | IDP-ION |
| Fixed-temp Heat Detector (White) | SD505-HEAT | SK-HEAT | IDP-HEAT |
| Fixed-temp Heat Detector (Ivory) | SD-505-AHS | SK-HEAT-IV | IDP-HEAT-IV |
| High temp Heat Detector | N/A | SK-HEAT-HT | IDP-HEAT-HT |
| Fixed-temp/Rate of rise Heat Detector | N/A | SK-HEAT-ROR | IDP-HEAT-ROR |
| Duct Detector Housing | SD505-DUCT | SK-DUCT | IDP-DUCT |
| Duct Detector Housing with FORM C contact relay | SD505-DUCTR | N/A (Use SK-DUCT with SK-RELAY) | N/A (Use IDP-DUCT with IDP-RELAY) |
| Smoke/CO Detector | N/A | SK-FIRE-CO | IDP-FIRE-CO |
| 4" Detector Base | SD505-4AB | B501 | B501 |
| 6" Detector Base | SD505-6AB | B210LP | B210LP |
| 6" Detector Base with Isolator | SD505-6IB | B224BI | B224BI |
| 6" Detector Base with Form C contact | SD505-6RB | B224RB | B224RB |
| 6" Sounder Base | SD505-6SB | B200S | B200S |
| Beam Detector | N/A | SK-BEAM | IDP-BEAM |
| Beam Detector with built-in sensitivity testing | N/A | SK-BEAM-T | IDP-BEAM-T |
| Combo Smoke/Heat Detector with false alarm prevention features | N/A | SK-ACCLIMATE | IDP-ACCLIMATE |
